phpmyadmin 404 not found on Debian Buster and ispconfig 3.1.15p3
Hi all,
I've installed ISPConfig by the "armbian-config" menu
I created several sites on my web server installed in debian Buster and ISPConfig 3.1.15p3.
I would like to use phpmyadmin to create an independent database at ISPConfig.
When I try to start phpMyadmin (http: // myipadresse / phpmyadmin), I get a 404 error message.
I found this post: https://www.howtoforge.com/community/threads/phpmyadmin-404-not-found-debian-9-3-ispconfig-3.78145/
I applied the first line without difficulty (ln -s /etc/phpmyadmin/apache.conf /etc/apache2/conf-available/phpmyadmin.conf). The second line (a2enconf phpmyadmin) gives me an error again: "ERROR: Conf phpmyadmin does not exist!"
How to access phpmyadmin by setting it correctly ?
Thanks
Odd. You could utilize steamroller tactics and place the symlink into conf-enabled directly and see what happens when you restart apache. Maybe there is something wrong with the config file itselt and therefore it is not detected properly.
