Espressobin, Focal: Crashes with 1TB 2.5 inch WD Blue drives
I just experienced this old problem with Focal:
WD drives inaccessible starting with kernel 4.13
-As the topic is now closed, I'd like to add some information.
My drive is a 2.5" 1TB WD10SPZX (WD BLUE).
It was connected via a Startech.com port-multiplier.
Normally I use only WD RED, but I had to move some large files, so I attached it temporarily.
Here's stack-trace #1...
[94740.634921] ata2.00: failed to read SCR 1 (Emask=0x40)
[94740.634938] ata2.01: failed to read SCR 1 (Emask=0x40)
[94740.634945] ata2.02: failed to read SCR 1 (Emask=0x40)
[94740.634951] ata2.03: failed to read SCR 1 (Emask=0x40)
[94740.634973] ata2.04: failed to read SCR 1 (Emask=0x40)
[94740.694172] Internal error: synchronous external abort: 96000210 [#1] PREEMPT SMP
[94740.699046] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_multiport iptable_filter zram zsmalloc bridge stp llc sch_fq_codel ip_tables x_tables mv88e6xxx dsa_core
[94740.714197] Process scsi_eh_1 (pid: 124, stack limit = 0x00000000d275a4fb)
[94740.721262] CPU: 1 PID: 124 Comm: scsi_eh_1 Not tainted 4.19.56-mvebu64 #5.89
[94740.728601] Hardware name: Globalscale Marvell ESPRESSOBin Board (DT)
[94740.735251] pstate: 80000005 (Nzcv daif -PAN -UAO)
[94740.740173] pc : ahci_scr_read+0x40/0x78
[94740.744199] lr : sata_scr_read+0x64/0x78
[94740.748223] sp : ffffff8009b0bb10
[94740.751630] x29: ffffff8009b0bb10 x28: ffffffc07f2423e0
[94740.757093] x27: 0000000000000000 x26: ffffffc07f240000
[94740.762560] x25: ffffffc07ee65828 x24: ffffffc07f2439b8
[94740.768025] x23: 0000000000000000 x22: ffffff8008f89000
[94740.773490] x21: 0000000000003008 x20: ffffffc07f242040
[94740.778957] x19: 0000000000000000 x18: ffffffffffffffff
[94740.784421] x17: 0000000000000000 x16: 0000000000000000
[94740.789888] x15: ffffff8008fa2000 x14: 00000000fffffff0
[94740.795355] x13: ffffff8009044cd2 x12: ffffff8008fa2000
[94740.800820] x11: 0000000000000000 x10: ffffff8009044000
[94740.806284] x9 : 0000000000000000 x8 : 0000000000000003
[94740.811750] x7 : ffffff8009b0bbb4 x6 : 0000000000000001
[94740.817216] x5 : ffffffc07f242040 x4 : ffffff8008c505d0
[94740.822680] x3 : 0000000000000180 x2 : ffffff8009b0bbb4
[94740.828148] x1 : ffffff80090c21b0 x0 : ffffff80090c2000
[94740.833612] Call trace:
[94740.836126]  ahci_scr_read+0x40/0x78
[94740.839801]  ata_eh_link_autopsy+0x84/0xa20
[94740.844100]  ata_eh_autopsy+0xd4/0xe0
[94740.847867]  sata_pmp_error_handler+0x48/0x920
[94740.852434]  ahci_error_handler+0x3c/0x78
[94740.856555]  ata_scsi_port_error_handler+0x198/0x680
[94740.861661]  ata_scsi_error+0x94/0xd0
[94740.865429]  scsi_error_handler+0x98/0x370
[94740.869639]  kthread+0x128/0x130
[94740.872953]  ret_from_fork+0x10/0x1c
[94740.876629] Code: b8615881 34000161 8b21c061 8b010001 (b9400021)
[94740.882899] ---[ end trace a517129638be4c55 ]---
Stack-trace #2:
[14633.530216] ata2.00: failed to read SCR 1 (Emask=0x40)
[14633.530232] ata2.01: failed to read SCR 1 (Emask=0x40)
[14633.530239] ata2.02: failed to read SCR 1 (Emask=0x40)
[14633.530246] ata2.03: failed to read SCR 1 (Emask=0x40)
[14633.530267] ata2.04: failed to read SCR 1 (Emask=0x40)
[14633.582564] Internal error: synchronous external abort: 96000210 [#1] PREEMPT SMP
[14633.587434] Modules linked in: zram zsmalloc bridge stp llc sch_fq_codel ip_tables x_tables mv88e6xxx dsa_core
[14633.597740] Process scsi_eh_1 (pid: 124, stack limit = 0x00000000fb61dcc8)
[14633.604819] CPU: 1 PID: 124 Comm: scsi_eh_1 Not tainted 4.19.56-mvebu64 #5.89
[14633.612156] Hardware name: Globalscale Marvell ESPRESSOBin Board (DT)
[14633.618807] pstate: 80000005 (Nzcv daif -PAN -UAO)
[14633.623730] pc : ahci_scr_read+0x40/0x78
[14633.627752] lr : sata_scr_read+0x64/0x78
[14633.631780] sp : ffffff8009aebb10
[14633.635185] x29: ffffff8009aebb10 x28: ffffffc07f2463e0
[14633.640649] x27: 0000000000000000 x26: ffffffc07f244000
[14633.646115] x25: ffffffc07ee65828 x24: ffffffc07f2479b8
[14633.651581] x23: 0000000000000000 x22: ffffff8008f89000
[14633.657047] x21: 0000000000003008 x20: ffffffc07f246040
[14633.662512] x19: 0000000000000000 x18: ffffffffffffffff
[14633.667977] x17: 0000000000000000 x16: 0000000000000000
[14633.673442] x15: ffffff8008fa2000 x14: 00000000fffffff0
[14633.678910] x13: ffffff8009044cd2 x12: ffffff8008fa2000
[14633.684376] x11: 0000000000000000 x10: ffffff8009044000
[14633.689840] x9 : 0000000000000000 x8 : 0000000000000003
[14633.695306] x7 : ffffff8009aebbb4 x6 : 0000000000000001
[14633.700771] x5 : ffffffc07f246040 x4 : ffffff8008c505d0
[14633.706236] x3 : 0000000000000180 x2 : ffffff8009aebbb4
[14633.711702] x1 : ffffff80090c21b0 x0 : ffffff80090c2000
[14633.717168] Call trace:
[14633.719682]  ahci_scr_read+0x40/0x78
[14633.723357]  ata_eh_link_autopsy+0x84/0xa20
[14633.727655]  ata_eh_autopsy+0xd4/0xe0
[14633.731422]  sata_pmp_error_handler+0x48/0x920
[14633.735990]  ahci_error_handler+0x3c/0x78
[14633.740110]  ata_scsi_port_error_handler+0x198/0x680
[14633.745218]  ata_scsi_error+0x94/0xd0
[14633.748981]  scsi_error_handler+0x98/0x370
[14633.753194]  kthread+0x128/0x130
[14633.756509]  ret_from_fork+0x10/0x1c
[14633.760182] Code: b8615881 34000161 8b21c061 8b010001 (b9400021)
[14633.766455] ---[ end trace 5867ea8f72bf6a7f ]---
I tried reading a large tar-file several times from the drive, but Focal kept crashing.
After that, I tried switching to a WD BLUE (Slim) I had some data on already, and the copy from the tar archive completed without crashing.
Here's a list of 3 different types of drives (connected via the same port multiplier):
$ lsscsi
[1:3:0:0]    disk    ATA      WDC WD10SPCX-08S 1A01  /dev/sdd
[1:4:0:0]    disk    ATA      WDC WD10JFCX-68N 0A82  /dev/sde
$ lsscsi
[1:3:0:0]    disk    ATA      WDC WD10SPZX-00Z 1A01  /dev/sdg
WD10JFCX-68N is a WD RED (these work very well)
WD10SPCX-08S is a WD BLUE, (known as 'Slim', this works)
WD10SPZX-00Z is a WD BLUE, this is the drive that causes the crash.
The tar-archive I was reading from, is very large (around 300 GB) and the file I was reading was around 2.3GB.
2.3GB would be a negative number as a 32-bit integer, but I don't think there would be any problem regarding this.
All the partitions I work with are BTRFS partitions, but this shouldn't matter, since the problem seems to be in the driver.
Oh, I used dist-upgrade from Bionic to get to Focal.
Please let me know if there's any further useful information I could supply.
That could be an issue. This kind of upgrade is neither tested nor supported. If you have a chance try with a fresh image.
And always handy to have: armbianmonitor -u
Thank you for your advice, I'll take it with lots of appreciation! :)
I'm currently in the process of restoring my server, so I'll have to wait a few days, but I will try with a fresh installation of the most recent image from the download page.
Unfortunately I only have one ZXSP drive, so I can't test with several drives of this type - it could have been very useful to know if it really depends on this drive type.
Just in case someone reading this should be tempted: I think it's a bad idea to use BLUE (desktop drives) for a server - RED are much more stable.
