I am using Cubietruck with Armbian 5:04 Debian Jessie 3.4.110 with Asterisk 13 and Dahdi 2:10 with Amfeltec Piranha USB - FXO. Kernel Panic occurs constantly.
We can't help much when 3rd party hardware is used. Sorry.
I would suggest to try recent Vanilla kernels.
I had this kind of issue with 3.x kernel and USB-Ethernet hardware (kernel panic), the only hope is having a proper mainline kernel
Hello Igor!
It worked and stopped giving the kernel panic in the version of Armbian 5.14 Cubietruck jessie Debian 4.6.2.
However when trying to run nand-sata-intall script to copy the sd-card to nand, displays the following message:
"There are no targets. Please check your drives."
Hello Igor!
