Hi i have a orangepi 4 , i try install armbian mainline based kernel 5.4.y having issue with hdmi, no display, the os cant sense any hdmi connection. But when i try kernel 4.4 the hdmi work with? anyone having the sane issue?
The OPi4 is built around the RK3399 SoC which is known to perform best on kernel 4.4.x in desktop applications. So if you plan to build a desktop around that board you should stick with the legacy branch.
