qweryt Posted June 25, 2016 Posted June 25, 2016 Hi, I'm trying to make my opi one act as a keyboard. I've found that I need to activate g_hid module, but when I trying to execute: modprobe g_hid it says: modprobe: FATAL: Module g_hid not found. Also, g_ether, g_mass_storage, g_multi, g_ptinter and g_serial modules are available. So, what should I do and maybe anyone can provide me an example how to send a keystroke to my pc? Thanks. 1
zador.blood.stained Posted June 26, 2016 Posted June 26, 2016 G_HID was not enabled in kernel config for this board before, it will be available in new kernel release.
lanefu Posted June 26, 2016 Posted June 26, 2016 G_HID was not enabled in kernel config for this board before, it will be available in new kernel release.for mainline or legacy? ill finally be able to use my Opi One for the reason i got into the opi wormhole in the first... to press f1 to boot my frankendell server Tapatalk thinks its important to tell you im using tapatalk from a phone.
zador.blood.stained Posted June 26, 2016 Posted June 26, 2016 for mainline or legacy? ill finally be able to use my Opi One for the reason i got into the opi wormhole in the first... to press f1 to boot my frankendell server Legacy of course. Mainline doesn't have even "normal" (host-only) USB support for H3 yet.
lanefu Posted June 26, 2016 Posted June 26, 2016 Legacy of course. Mainline doesn't have even "normal" (host-only) USB support for H3 yet. thanks... i shoulda known...
qweryt Posted July 5, 2016 Author Posted July 5, 2016 I've managed to compile and install kernel with G_HID enabled. Also I've patched hid.c as gadget_hid.txt says and created ghid0 device. But when I try to run an example I get this /dev/hidg0: Invalid argument You can find custom kernel and hid.c here.
qweryt Posted July 11, 2016 Author Posted July 11, 2016 I've made it work finally. Just executed these two lines. echo 1 > /sys/bus/platform/devices/sunxi_usb_udc/otg_role echo 2 > /sys/bus/platform/devices/sunxi_usb_udc/otg_role
renard Posted November 16, 2017 Posted November 16, 2017 Guys. Probably that will be really stupid question. Googled a lot, looked through documentation but had not found the answer. How exactly may I crosscompile custom g_hid.ko for orangepiwin (sunxi64). I successfully build default kernel with compile.sh. But when I try to substitute cache/sources/linux-mainline/linux-4.13.y/drivers/usb/gadget/legacy/hid.c with the one provided by qweryt and run compile.sh once again it became overwritten with original and compiled the same as it was. Obviously I am missing some configuration flag e.g. OVERWRITE_LOCAL_CHANGES_IN_SOURCES=n Or should I create diff patch and put it somewhere in ./patch? Compiling on 4.4.0-97-generic Linux Mint 18 Sarah with hacked ./lib/general.sh os version check. Or should I invoke direct make modules with 100500 parameters from cache/sources/linux-mainline/linux-4.13.y/? Thanks in advance.
renard Posted November 17, 2017 Posted November 17, 2017 Ok. Now It works. Created git diff from qweryt's git.c and putted it into /userpatches/kernel/sunxi.next (as told in https://docs.armbian.com/Developer-Guide_User-Configurations/#user-provided-sources-config-overrides, by bad for missing it). Now it is applied but fail to compile with multiple errors. Probably his git.c was based on too old kernel sources. Will study gadget_hid.txt and try to patch myself. Maybe someone has more recent version for 4.13.13? Noticed that this one is from 3.4.112. Does anyone have any hid.c example for mainline?
MitchD Posted November 17, 2017 Posted November 17, 2017 If you are using the mainline kernel, you can use configfs for setting up USB HID. Try this example: modprobe libcomposite mount -t configfs none /sys/kernel/config cd /sys/kernel/config/usb_gadget mkdir g1 cd g1 mkdir configs/c.1 mkdir functions/hid.usb0 echo 1 > functions/hid.usb0/protocol echo 1 > functions/hid.usb0/subclass echo 8 > functions/hid.usb0/report_length cat my_report_desc > functions/hid.usb0/report_desc mkdir strings/0x409 mkdir configs/c.1/strings/0x409 echo 0xa4ac > idProduct echo 0x0525 > idVendor echo serial > strings/0x409/serialnumber echo manufacturer > strings/0x409/manufacturer echo HID Gadget > strings/0x409/product echo "Conf 1" > configs/c.1/strings/0x409/configuration echo 120 > configs/c.1/MaxPower ln -s functions/hid.usb0 configs/c.1 ls /sys/class/udc > UDC Which I got from my own working USB OTG ethernet + midi + file storage script and this example here. Note that they create a file called "my_report_desc" for HID specific stuff. 1
renard Posted November 17, 2017 Posted November 17, 2017 Thanks! Also found this thread now and it also says about libcomposite. Will try it out. 1
