kimwida Posted September 5, 2020 Posted September 5, 2020 Armbianmonitor: http://ix.io/2wcz Hi. I was testing pwm with a motor, then my rock pis stopped. After boot, I couldn't see wlan0 in nmtui-connect. So I reinstall fresh armbian, I can see wlan0 again. I do wifi setting with nmtui-connect but after rebooting I can't connect wifi. I have to redo wifi setting with nmtui-connect, put password again and it adds another wifi. It seems like it can't connect to previous wifi. When I do "nmcli con show", I can see the previous wifi but it is deactive. I searched about it and found wifi mac address randomization issue. So I checked "10-override-random-mac-disable.conf". [connection] wifi.mac-address-randomization=1 [device] wifi.scan-rand-mac-address=no Whenever I redo nmtui-connect, it add file count in "/etc/NetworkManager/system-connections" Is there any way to solve it? Or pwm thing break wifi chips??
kimwida Posted September 6, 2020 Author Posted September 6, 2020 I found a workaround. After boot, p2p0 connection is alive. But each booting make its ip address grow. So I changed it fixed ip like it. #ifconfig p2p0 down #ifconfig p2p0 2.1.1.38 netmask 255.255.255.0 up #route add default gw 2.1.1.1 then, I can use wifi with p2p0. So I add these commands into "rc.local". ifconfig p2p0 down ifconfig p2p0 2.1.1.38 netmask 255.255.255.0 up route add default gw 2.1.1.1 sleep 10 dhclient p2p0
Werner Posted September 6, 2020 Posted September 6, 2020 You could try to set a fixed mac in your /boot/armbianEnv.txt like ethaddr=02:38:a0:82:2d:c0
kimwida Posted September 6, 2020 Author Posted September 6, 2020 I don't know why but my rock pis can't fix mac even adding the line. Booting with new debian and armbian with new SD card have same result. I think my rock pis went wrong with my pwm things...
kimwida Posted September 6, 2020 Author Posted September 6, 2020 I searched and found solution. After install fresh armbian, I added this to "/etc/network/interfaces" auto wlan0 allow-hotplug wlan0 iface wlan0 inet manual wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf iface default inet static address 2.1.1.38 netmask 255.255.255.0 gateway 2.1.1.1 dns-nameservers 168.126.63.1 168.126.63.2 wireless-mode Managed wireless-power off 1
