niccodemi Posted September 11, 2020 Posted September 11, 2020 Hi, I installed Armbian image 20.8.1-focal-5.8.5 to Orange Pi PC. I am experiencing issues with playing sounds (tested with playing .wav files). Upon starting playback first 1-2 seconds are omitted and then sound plays as it should. I didn't notice this issue on Xenial (3.4.113). Issue is identical to the ones reported in following threads: https://forum.armbian.com/topic/12059-orange-pi-lite-missing-first-second-of-the-audio-output/ https://forum.armbian.com/topic/12059-orange-pi-lite-missing-first-second-of-the-audio-output/ Has anyone managed to solve it? Thanks
guidol Posted September 11, 2020 Posted September 11, 2020 isnt a new problem, but I didnt found also a actual solution I did use the little trick to play short "empty" .wav file, wait 2 seconds then play the .wav that should be played. with that the amplifier is enabled (and in 2 secondes it doesnt go in sleep-mode again) so you will hear also the start of your .wav-file aplay -D plughw:0,0 /tmp/empty.wav 2>/dev/null sleep 2 aplay -D plughw:0,0 /tmp/espeak.wav 2>/dev/null
niccodemi Posted September 15, 2020 Author Posted September 15, 2020 Thanks for reply. Do you know if all H2 boards are affected with this issue? Sent from my Redmi 4A using Tapatalk
