johnnyde94 Posted September 12, 2020 Share Posted September 12, 2020 Armbianmonitor: http://ix.io/2xkq Hello I can not seem to get my USB Ethernet dongle with a r8152b chip to work on the latest armbian focal release. I tied both kernels 4.14.y. and 5.4.y with no luck. It works on "clean" ubuntu focal when i first plug it it without drivers and when i add the drivers. I am also posting in the odroid fourms here: https://forum.odroid.com/viewtopic.php?f=172&t=38713&p=306027#p306027 I am following these directions: tar -xf r8152.53.56-2.13.0.tar.bz2 cd r8152-2.13.0 make sudo make install lsmod | grep r8 If this works, and if the module does not load at reboot, add "r8152" in modules.conf: sudo vi /etc/modules-load.d/modules.conf or sudo vi /etc/modules.conf. Not sure which one it is on the Ubuntu running on your XU4. At the lsmod step nothing is showing up. Here is my lsusb -t lsusb -t /: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M |__ Port 1: Dev 2, If 0, Class=Vendor Specific Class, Driver=r8152, 5000M /: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M /: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/2p, 5000M |__ Port 1: Dev 3, If 0, Class=Hub, Driver=hub/4p, 5000M |__ Port 4: Dev 7, If 0, Class=Vendor Specific Class, Driver=, 5000M /: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/2p, 480M |__ Port 1: Dev 3, If 0, Class=Hub, Driver=hub/4p, 480M |__ Port 3: Dev 9, If 1, Class=Human Interface Device, Driver=usbhid, 12M |__ Port 3: Dev 9, If 2, Class=Human Interface Device, Driver=usbhid, 12M |__ Port 3: Dev 9, If 0, Class=Human Interface Device, Driver=usbhid, 12M |__ Port 1: Dev 5, If 2, Class=Vendor Specific Class, Driver=btusb, 12M |__ Port 1: Dev 5, If 0, Class=Vendor Specific Class, Driver=btusb, 12M |__ Port 1: Dev 5, If 3, Class=Application Specific Interface, Driver=, 12M |__ Port 1: Dev 5, If 1, Class=Vendor Specific Class, Driver=btusb, 12M |__ Port 2: Dev 8, If 2, Class=Human Interface Device, Driver=usbhid, 12M |__ Port 2: Dev 8, If 0, Class=Human Interface Device, Driver=usbhid, 12M |__ Port 2: Dev 8, If 1, Class=Human Interface Device, Driver=usbhid, 12M |__ Port 2: Dev 4, If 0, Class=Hub, Driver=hub/4p, 480M /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=exynos-ohci/3p, 12M /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=exynos-ehci/3p, 480M 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted September 12, 2020 Share Posted September 12, 2020 4 minutes ago, johnnyde94 said: It works on "clean" ubuntu focal What image or system do you mean with "clean ubuntu focal"? 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted September 12, 2020 Share Posted September 12, 2020 55 minutes ago, johnnyde94 said: If this works, and if the module does not load at reboot, add "r8152" Odroid XU4 uses very similar chip which uses the same driver. If driver is build into the kernel as a module - you can try to blacklist it, then load your new module. But as we provide this improved driver that enables some 2.5GBps USB dongles, we had to disable improvements specifically on XU4. Since they are not compatible: https://github.com/armbian/build/commit/ce9cb071bf6618060903fd4edfbe75ab2d4cf188#diff-f7fcda652c17fc7ee4e59123984acf5d Adding driver: https://github.com/armbian/build/commit/f6abcc7c852f564991b65ea534f41e6675844312#diff-f7fcda652c17fc7ee4e59123984acf5d 0 Quote Link to comment Share on other sites More sharing options...
johnnyde94 Posted September 13, 2020 Author Share Posted September 13, 2020 (edited) 5 hours ago, Igor said: Odroid XU4 uses very similar chip which uses the same driver. If driver is build into the kernel as a module - you can try to blacklist it, then load your new module. But as we provide this improved driver that enables some 2.5GBps USB dongles, we had to disable improvements specifically on XU4. Since they are not compatible: https://github.com/armbian/build/commit/ce9cb071bf6618060903fd4edfbe75ab2d4cf188#diff-f7fcda652c17fc7ee4e59123984acf5d Adding driver: https://github.com/armbian/build/commit/f6abcc7c852f564991b65ea534f41e6675844312#diff-f7fcda652c17fc7ee4e59123984acf5d let me see if that works Edited September 13, 2020 by johnnyde94 0 Quote Link to comment Share on other sites More sharing options...
johnnyde94 Posted September 15, 2020 Author Share Posted September 15, 2020 nope no luck 0 Quote Link to comment Share on other sites More sharing options...
johnnyde94 Posted November 9, 2020 Author Share Posted November 9, 2020 Any new ideas? when you said you added the driver, was there something more i had to do or was that on the ambian end? Most up to date pastebin note the dongle is plugged into my USB 3 hub but the Ethernet is not plugged into it. https://pastebin.com/KiWfTQY9 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted November 9, 2020 Share Posted November 9, 2020 17 minutes ago, johnnyde94 said: when you said you added the driver, was there something more i had to do or was that on the ambian end? We added it but we also remove it later since it caused problems with onboard NIC. Its on your to move on - we will certainly not. Also kernel 4.14.y will be dropped soon. Hard kernel moved to 5.4.y and 5.9.y is also progressing nicely. Perhaps you should try there, but you are again alone doing that. Anyway we don't support things you plug into USB. 0 Quote Link to comment Share on other sites More sharing options...
