Armbianmonitor:
Hi. I am getting a kernel Oops in the Pine64+   . . . .see below.  Kernel is 5.8.13-sunxi64. It was installed after a recent update.
I would like to drop back to the previous kernel if possible.
Does this seem like a reasonable search term for a suitable kernel?
Any ideas on searching and installing a previous kernel appreciated.
sudo apt-cache search kernel 5.8* | grep sunxi64
linux-dtb-current-sunxi64 - Linux DTB, version 5.8.13-sunxi64
linux-dtb-dev-sunxi64 - Linux DTB, version 5.9.0-rc7-sunxi64
linux-dtb-legacy-sunxi64 - Linux DTB, version 5.4.62-sunxi64
linux-headers-current-sunxi64 - Linux kernel headers for 5.8.13-sunxi64 on arm64
linux-headers-dev-sunxi64 - Linux kernel headers for 5.9.0-rc7-sunxi64 on arm64
linux-headers-legacy-sunxi64 - Linux kernel headers for 5.4.62-sunxi64 on arm64
linux-image-current-sunxi64 - Linux kernel, version 5.8.13-sunxi64
linux-image-dev-sunxi64 - Linux kernel, version 5.9.0-rc7-sunxi64
linux-image-legacy-sunxi64 - Linux kernel, version 5.4.62-sunxi64
linux-source-5.4.58-legacy-sunxi64 - This package provides the source code for the Linux kernel 5.4.58
linux-source-5.4.61-legacy-sunxi64 - This package provides the source code for the Linux kernel 5.4.61
[   23.475944] ------------[ cut here ]------------
[   23.478571] WARNING: CPU: 3 PID: 171 at drivers/clocksource/arm_arch_timer.c:364 sun50i_a64_read_cntpct_el0+0x30/0x38
[   23.480502] Modules linked in: cpufreq_dt realtek dwmac_sun8i pinctrl_axp209 mdio_mux i2c_mv64xxx
[   23.483003] CPU: 3 PID: 171 Comm: kworker/3:3 Not tainted 5.8.13-sunxi64 #20.08.7
[   23.484968] Hardware name: Pine64+ (DT)
[   23.487226] Workqueue: events dbs_work_handler
[   23.489416] pstate: 80000005 (Nzcv daif -PAN -UAO BTYPE=--)
[   23.491571] pc : sun50i_a64_read_cntpct_el0+0x30/0x38
[   23.493700] lr : arch_counter_get_cntpct_stable+0x3c/0x80
[   23.495784] sp : ffff800011afb9c0
[   23.497758] x29: ffff800011afb9c0 x28: ffff0000743a9a00
[   23.499861] x27: ffff0000713ed600 x26: ffff0000743a9c68
[   23.501992] x25: ffff000072e38228 x24: 0000000000000000
[   23.504054] x23: 0000000000000001 x22: ffff800011afbb10
[   23.506137] x21: 0000000000000000 x20: 0000000000000018
[   23.508260] x19: ffff8000113dd000
[   23.510328] hrtimer: interrupt took 27046125 ns
[   23.512242] x18: ffff800011afb9b8
[   23.514290] x17: 0000000000000004 x16: 0000000000000001
[   23.516399] x15: 0000000000000018 x14: 0000000000000002
[   23.518455] x13: 0000000000000001 x12: 0000000000000001
[   23.520483] x11: 0000000000000005 x10: 0000000000000021
[   23.522575] x9 : 0000000044aa2000 x8 : ffff8000113aaf98
[   23.524628] x7 : 0000000000000000 x6 : 00000000112a8800
[   23.526731] x5 : 0000000000000010 x4 : 0000000000000012
[   23.528810] x3 : 0000000000000050 x2 : 000000002ec5d477
[   23.530879] x1 : 0000000000000000 x0 : 000000002ec5d47d
[   23.532925] Call trace:
[   23.535068]  sun50i_a64_read_cntpct_el0+0x30/0x38
[   23.537130]  __delay+0x24/0xa8
[   23.539201]  __udelay+0x2c/0x38
[   23.541332]  ccu_mux_notifier_cb+0x64/0xa0
[   23.543415]  notifier_call_chain+0x54/0x98
[   23.545482]  __srcu_notifier_call_chain+0x58/0x98
[   23.547538]  srcu_notifier_call_chain+0x18/0x28
[   23.549615]  __clk_notify+0x88/0xd0
[   23.551707]  clk_propagate_rate_change+0xc4/0xd8
[   23.553808]  clk_core_set_rate_nolock+0x114/0x1f8
[   23.555895]  clk_set_rate+0x38/0xa8
[   23.558113]  dev_pm_opp_set_rate+0x264/0x618
[   23.560250]  set_target+0x40/0x88 [cpufreq_dt]
[   23.562349]  __cpufreq_driver_target+0x2c4/0x668
[   23.564464]  od_dbs_update+0x140/0x1a0
[   23.566542]  dbs_work_handler+0x40/0x80
[   23.568628]  process_one_work+0x1c8/0x378
[   23.570711]  worker_thread+0x14c/0x4c8
[   23.572806]  kthread+0xf8/0x128
[   23.574887]  ret_from_fork+0x10/0x30
[   23.576963] ---[ end trace 32a37354cad394e6 ]---
[   23.735669] sun8i-ce 1c15000.crypto: Set mod clock to 300000000 (300 Mhz) from 24000000 (24 Mhz)
[   23.735961] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
Expand
armbian-config -> system -> alternative kernels
Thanks for the suggestion. Kernel 5.8.10-sunxi64 is exhibiting the same problem. Not sure how this will impact things. No locking up so should I just go with it - ignore and carry on? It is used as a Tinker board more than anything. It is running docker and a few containers.
Allwinner A64 board are all experiencing some issues lately. Try kernel 5.4.y
