Since I had a power supply problem with my XU4 I decided to download the image and start from scratch. First time I recall everything went smooth until my PS failed.
Now, starting from a fresh image, when the first boot gets to SSH key regeneration, it hangs forever. Tried several times, tested the sd card, used a different one for test. Still hangs at SSH key regeneration.
I had never tried moving the OS to the HD. All the contents there are good and it has passed all the long smart tests.
If I reboot after a while hanging at SSH key regeneration it boots and does all the password stuff as expected, and everything else seems fine.
Should I worry about it?
@Technicavolous
ok, I have the reply from the other thread :) so your hdd is ok
btw, you are using the legacy version (kernel 3.x) because vanilla (kernel 4.x) is highly experimental.
- can you move your SDcard and do a
sudo fsck -s /dev/something1 and something2
can you unplug the HDD for a moment?
- try to boot from another "fresh" SDcard.
the SSH key generation stalled can come from a broken SD card (broken with the other power supply) or more simply by a lack of random data from /dev/random (if empty it can stall the generation, so try to move the mouse, press some keys from keyboard)
also the Wifi plug (as host) can draw random data
Tried two different brand new 8GB cards (I bought a bunch of 'em ) one that I used as is and one that I did SDFormatter with size readjust. Same issue. Disconnected hard drive, same issue.
I did notice that I've been trying this with 5.14 and the first run I used 5.10. I have a very slow connection so I'm redownloading 5.14 and pulling out the 1TB drive that I have the 5.10 image archived on. I'll see if I have a bad download or track down whatever I'm doing wrong.
In the meantime I burned a couple of other images and they've worked fine.Usually when something doesn't work I format and start over with good results. This is persistent.  When 5.14 completes download (hours ...) I'll report back.
BTW I'm using Rufus on win7 to burn the images to SD, IIR this is the preferred way, no?
Thanks again.
@Technicavolous
yes rufus is recommanded by the Armbian team
(I only use dd / dc3dd on linux based systems)
7zip would have detected an error during decompression
ok, tell us when you have pieces of news please
Sorry for the delay, that work stuff ;]
I am unable to get past this issue. Redownloaded, tried just the board and no cloudshell, tried different SD cards, tried with no wifi dongle, put an OScope on the power lol it's clean ... But it always hangs at SSH ke regeneration. Everything else works fine after I force a reboot, I cannot find any malfunction or error.
Since it hangs stating it's making SSH keys, I imagine I should go learn a little SSH linux and find out if it is indeed making the key and hanging on the next step? I am able to ssh into the odroid after reboot so I'm not so sure what's actually happening, or if it even matters.
You know how it is, something that isn't 'right' just bugs ya.
Regardless, I'm moving forward as if it were not a problem.
This forum is awesome - I've learned more reading posts here than just about anywhere else. I'll definitely be a regular.
@Technicavolous
I was thinking of "haveged" package which provides some entropy from CPU internal registers a bit like recent linux kernels with jitter_entropy
it seems haveged package is included in Armbian images for a while. What I don't know: is haveged started before ssh key generation?
So, yes, if you can access using SSH during key generation (or a UART console) to check how the entropy pool is low or not
cat /proc/sys/kernel/random/entropy_avail
so we have a clue if it is the low entropy pool that is the source of the problem OR something different in the booting process.
Actually several tasks are executed at this point:
  • Creating SSH keys
  • Creating swap file
  • Adjusting swap related parameters
  • Tweaking ramlog if it is installed
There should be some messages in /var/log/armhwinfo.log regarding some steps.
Are you sure that it completely hangs? Can you switch to other TTYs (i.e. to tty2 by pressing Ctrl-Alt-F2) and login from there if a prompt is available?
So it gives [OK] resizing filesystem, [OK]  creating 128 mb swap, [OK] starting ssh keys regeneration and then "hangs" but
@wildcat - no I can't ssh in
@zador - yes indeed can ctrl-alt-f2 and log in on another tty! I should have thought of that thanks!
It does what is expected and has me change the root password and add the user, then it starts the desktop.
After the desktop starts if I ctrl-alt-f1 it still shows the 'hung' start screen on tty1.
@wildcat I switched to tty3 and the output of the cat you asked for is simply
 1814
When I went back to tty2 where the desktop was, it had the root prompt. So I typed reboot and the desktop appeared for a brief flash and the unit rebooted nicely back to the desktop. I think that flash of the desktop was video memory.
When it rebooted I did the entropy cat command again and it returned 4089.
I've redone this thing so many times it's funny and every time exactly the same. My gut says everything is fine but if you guys want any other data just let me know I'll be happy to post it. I've been using this last install long enough I'm going to go ahead and move it to the hard drive and see how that goes.
This one is going to become a regular tool on the desk. I'm going to have a little fun with Armbian on my Orange Pi next, :]
A million thanks, there will most likely be more questions!
Tracy
Please try this:
  • Flash a new image
  • Boot it and wait until it hangs
  • Log in from tty2
  • When it asks to create a new user, press Ctrl-C
  • Execute "top -n 1 >> /root/log.txt" and "pstree >> /root/log.txt"
  • Provide here contents of created log.txt
This should help in understanding what doesn't work
OK here is the contents of log.txt
#[?25l#[?1c#[H#[J#[0;10mtop - 19:24:59 up 6 min,  1 user,  load average: 0.01, 0.08, 0.05#[0;10m#[39;49m#[0;10m#[39;49m#[K
Tasks:#[0;10m#[39;49m#[1m 128 #[0;10m#[39;49mtotal,#[0;10m#[39;49m#[1m   1 #[0;10m#[39;49mrunning,#[0;10m#[39;49m#[1m 127 #[0;10m#[39;49msleeping,#[0;10m#[39;49m#[1m   0 #[0;10m#[39;49mstopped,#[0;10m#[39;49m#[1m   0 #[0;10m#[39;49mzombie#[0;10m#[39;49m#[0;10m#[39;49m#[K
%Cpu(s):#[0;10m#[39;49m#[1m  0.6 #[0;10m#[39;49mus,#[0;10m#[39;49m#[1m  0.9 #[0;10m#[39;49msy,#[0;10m#[39;49m#[1m  0.0 #[0;10m#[39;49mni,#[0;10m#[39;49m#[1m 97.8 #[0;10m#[39;49mid,#[0;10m#[39;49m#[1m  0.7 #[0;10m#[39;49mwa,#[0;10m#[39;49m#[1m  0.0 #[0;10m#[39;49mhi,#[0;10m#[39;49m#[1m  0.0 #[0;10m#[39;49msi,#[0;10m#[39;49m#[1m  0.0 #[0;10m#[39;49mst#[0;10m#[39;49m#[0;10m#[39;49m#[K
KiB Mem: #[0;10m#[39;49m#[1m  2042792 #[0;10m#[39;49mtotal,#[0;10m#[39;49m#[1m   363056 #[0;10m#[39;49mused,#[0;10m#[39;49m#[1m  1679736 #[0;10m#[39;49mfree,#[0;10m#[39;49m#[1m     7616 #[0;10m#[39;49mbuffers#[0;10m#[39;49m#[0;10m#[39;49m#[K
KiB Swap:#[0;10m#[39;49m#[1m   131068 #[0;10m#[39;49mtotal,#[0;10m#[39;49m#[1m        0 #[0;10m#[39;49mused,#[0;10m#[39;49m#[1m   131068 #[0;10m#[39;49mfree.#[0;10m#[39;49m#[1m   108312 #[0;10m#[39;49mcached Mem#[0;10m#[39;49m#[0;10m#[39;49m#[K
#[K
#[7m  PID USER      PR  NI    VIRT    RES    SHR S  %CPU %MEM     TIME+ COMMAND        #[0;10m#[39;49m#[K
#[0;10m#[1m 1337 root      20   0    4684   1240    800 R  15.2  0.1   0:00.09 top        #[0;10m#[39;49m#[K
#[0;10m    1 root      20   0    5188   3112   1480 S   0.0  0.2   0:07.28 systemd        #[0;10m#[39;49m#[K
#[0;10m    2 root      20   0       0      0      0 S   0.0  0.0   0:00.01 kthreadd        #[0;10m#[39;49m#[K
#[0;10m    3 root      20   0       0      0      0 S   0.0  0.0   0:00.01 ksoftirqd/0        #[0;10m#[39;49m#[K
#[0;10m    5 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 kworker/0:0H        #[0;10m#[39;49m#[K
#[0;10m    6 root      20   0       0      0      0 S   0.0  0.0   0:00.10 kworker/u16:0        #[0;10m#[39;49m#[K
#[0;10m    7 root      rt   0       0      0      0 S   0.0  0.0   0:00.01 migration/0        #[0;10m#[39;49m#[K
#[0;10m    8 root      20   0       0      0      0 S   0.0  0.0   0:00.16 rcu_preempt        #[0;10m#[39;49m#[K
#[0;10m    9 root      20   0       0      0      0 S   0.0  0.0   0:00.00 rcu_bh        #[0;10m#[39;49m#[K
#[0;10m   10 root      20   0       0      0      0 S   0.0  0.0   0:00.00 rcu_sched        #[0;10m#[39;49m#[K
#[0;10m   11 root      rt   0       0      0      0 S   0.0  0.0   0:00.00 watchdog/0        #[0;10m#[39;49m#[K
#[0;10m   12 root      rt   0       0      0      0 S   0.0  0.0   0:00.00 watchdog/1        #[0;10m#[39;49m#[K
#[0;10m   13 root      rt   0       0      0      0 S   0.0  0.0   0:00.01 migration/1        #[0;10m#[39;49m#[K
#[0;10m   14 root      20   0       0      0      0 S   0.0  0.0   0:00.00 ksoftirqd/1        #[0;10m#[39;49m#[K
#[0;10m   15 root      20   0       0      0      0 S   0.0  0.0   0:00.00 kworker/1:0        #[0;10m#[39;49m#[K
#[0;10m   16 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 kworker/1:0H        #[0;10m#[39;49m#[K
#[0;10m   17 root      rt   0       0      0      0 S   0.0  0.0   0:00.00 watchdog/2        #[0;10m#[39;49m#[K
#[0;10m   18 root      rt   0       0      0      0 S   0.0  0.0   0:00.01 migration/2        #[0;10m#[39;49m#[K
#[0;10m   19 root      20   0       0      0      0 S   0.0  0.0   0:00.00 ksoftirqd/2        #[0;10m#[39;49m#[K
#[0;10m   21 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 kworker/2:0H        #[0;10m#[39;49m#[K
#[0;10m   22 root      rt   0       0      0      0 S   0.0  0.0   0:00.00 watchdog/3        #[0;10m#[39;49m#[K
#[0;10m   23 root      rt   0       0      0      0 S   0.0  0.0   0:00.00 migration/3        #[0;10m#[39;49m#[K
#[0;10m   24 root      20   0       0      0      0 S   0.0  0.0   0:00.00 ksoftirqd/3        #[0;10m#[39;49m#[K
#[0;10m   26 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 kworker/3:0H        #[0;10m#[39;49m#[K
#[0;10m   27 root      rt   0       0      0      0 S   0.0  0.0   0:00.00 watchdog/4        #[0;10m#[39;49m#[K
#[0;10m   28 root      rt   0       0      0      0 S   0.0  0.0   0:00.00 migration/4        #[0;10m#[39;49m#[K
#[0;10m   29 root      20   0       0      0      0 S   0.0  0.0   0:00.02 ksoftirqd/4        #[0;10m#[39;49m#[K
#[0;10m   31 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 kworker/4:0H        #[0;10m#[39;49m#[K
#[0;10m   32 root      rt   0       0      0      0 S   0.0  0.0   0:00.00 watchdog/5        #[0;10m#[39;49m#[K
#[0;10m   33 root      rt   0       0      0      0 S   0.0  0.0   0:00.01 migration/5        #[0;10m#[39;49m#[K
#[0;10m   34 root      20   0       0      0      0 S   0.0  0.0   0:00.02 ksoftirqd/5        #[0;10m#[39;49m#[K
#[0;10m   36 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 kworker/5:0H        #[0;10m#[39;49m#[K
#[0;10m   37 root      rt   0       0      0      0 S   0.0  0.0   0:00.00 watchdog/6        #[0;10m#[39;49m#[K
#[0;10m   38 root      rt   0       0      0      0 S   0.0  0.0   0:00.00 migration/6        #[0;10m#[39;49m#[K
#[0;10m   39 root      20   0       0      0      0 S   0.0  0.0   0:00.01 ksoftirqd/6        #[0;10m#[39;49m#[K
#[0;10m   41 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 kworker/6:0H        #[0;10m#[39;49m#[K
#[0;10m   42 root      rt   0       0      0      0 S   0.0  0.0   0:00.00 watchdog/7        #[0;10m#[39;49m#[K
#[0;10m   43 root      rt   0       0      0      0 S   0.0  0.0   0:00.00 migration/7        #[0;10m#[39;49m#[K
#[0;10m   44 root      20   0       0      0      0 S   0.0  0.0   0:00.01 ksoftirqd/7        #[0;10m#[39;49m#[K
#[0;10m   45 root      20   0       0      0      0 S   0.0  0.0   0:00.00 kworker/7:0        #[0;10m#[39;49m#[K
#[0;10m   46 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 kworker/7:0H        #[0;10m#[39;49m#[K
#[0;10m   47 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 khelper        #[0;10m#[39;49m#[K
#[0;10m   48 root      20   0       0      0      0 S   0.0  0.0   0:00.06 kdevtmpfs        #[0;10m#[39;49m#[K
#[0;10m   49 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 netns        #[0;10m#[39;49m#[K
#[0;10m   50 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 writeback        #[0;10m#[39;49m#[K
#[0;10m   51 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 bioset        #[0;10m#[39;49m#[K
#[0;10m   52 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 crypto        #[0;10m#[39;49m#[K
#[0;10m   53 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 kblockd        #[0;10m#[39;49m#[K
#[0;10m   54 root      20   0       0      0      0 S   0.0  0.0   0:00.04 khubd        #[0;10m#[39;49m#[K
#[0;10m   58 root     -51   0       0      0      0 S   0.0  0.0   0:00.00 irq/512-s2mps11        #[0;10m#[39;49m#[K
#[0;10m   59 root      20   0       0      0      0 S   0.0  0.0   0:00.00 kworker/4:1        #[0;10m#[39;49m#[K
#[0;10m   72 root      20   0       0      0      0 S   0.0  0.0   0:00.00 ion_noncontig_h        #[0;10m#[39;49m#[K
#[0;10m   73 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 devfreq_wq        #[0;10m#[39;49m#[K
#[0;10m   74 root      20   0       0      0      0 S   0.0  0.0   0:00.26 kworker/5:1        #[0;10m#[39;49m#[K
#[0;10m   75 root      20   0       0      0      0 S   0.0  0.0   0:00.26 kworker/0:1        #[0;10m#[39;49m#[K
#[0;10m   76 root      20   0       0      0      0 S   0.0  0.0   0:00.12 kworker/2:1        #[0;10m#[39;49m#[K
#[0;10m   77 root      20   0       0      0      0 S   0.0  0.0   0:00.10 kworker/3:1        #[0;10m#[39;49m#[K
#[0;10m   78 root      20   0       0      0      0 S   0.0  0.0   0:00.18 kworker/1:1        #[0;10m#[39;49m#[K
#[0;10m   79 root      20   0       0      0      0 S   0.0  0.0   0:00.09 kworker/6:1        #[0;10m#[39;49m#[K
#[0;10m   80 root      20   0       0      0      0 S   0.0  0.0   0:00.10 kworker/7:1        #[0;10m#[39;49m#[K#[68;1H
#[?25h#[?0c#[Ksystemd-+-2*[agetty]
        |-cron
        |-dbus-daemon
        |-dhclient
        |-haveged
        |-login---bash---pstree
        |-ntpd---ntpd
        |-rsyslogd-+-{in:imklog}
        |          |-{in:imuxsock}
        |          `-{rs:main Q:Reg}
        |-sshd
        |-systemd---(sd-pam)
        |-systemd-journal
        |-systemd-logind
        |-systemd-udevd
        `-wicd---wicd-monitor
What docs should I be looking at to understand this output?
At this point I CAN ssh in. When I do, putty pops up a message about the host key being different than the one cached, which seems like a good message. putty or any other ssh works fine. It prompted me to add the user and everything else went great. I am posting this message from armbian before upgrading to 5.16. Which, BTW, last time appeared to go well.
I am saving this particular SD for consistency but I have another one I'm willing to start over with as many times as you fellows wish. If you need photos I've finally figured that out also. Cameras ...
log.txt
Well, with a giant capitalized message stating to be patient and not interrupt the first boot, no, I didn't touch anything for quite a while ;]
With a fresh image booted I waited just a few moments and hit enter, and there, yes a prompt. Waited for a moment, then logged in as root and it took me through the user data and started the desktop. Connected to my wifi, ran an update and upgrade, and all went well. Lather, rinse, repeat, did this several times consistently.
It's hypercritical to hit the enter key at what appears to be a hang ... embarrassing but I really thought I had to wait! Wile I'm no guru, I'm not new to linux, I really should have tried something so simple as hitting the enter key.
BUT, on the ride I learned a heck of alot of what's happening with armbian boot, and you guys made figuring out what I thought was a problem, fun. And at least I know all my hardware is good lol. I'm certainly on my way to learning armbian, and you've given me the confidence to stick with this one and 'get good at it.'
Thanks!
Have you tried
because
either the script waits for "enter" or pushing enter created an interrupt that feeds random pool
we cannot say which solution is correct.
@Technicavolous
ok, so the random pool is full (not depleted). we can close this kind of problem
thanks for the feedback
note: usually /proc/sys/kernel/random/poolsize=4096
so max entropy_avail=4095
but values > 4000 are barely seen as each new process in the system use data from the entropy pool in more recent linux kernels
Every time I check entropy it is a 4 digit number, but sometimes is less than 4096, one time was 1200 something. I never even knew 'entropy' was part of the kernel. I thought it was space and time but that's another forum ;]
@Technicavolous we could ask Igor to add a "Space and Time" section in forum.armbian.com B) and then we call the Men-In-Black to clean the thread.
the random pool is so important as it is so needed in the symmetric ciphers (to reduce replay attacks), to generate private keys for asymmetric stuff and to randomize memory space  / process to counter stuff like buffer overflow attacks
empty random pool = unsafe system (embedded systems often randomness/entropy is lacking)
I feel like a grandpa writing this :rolleyes:
