PaoloC Posted November 5, 2020 Posted November 5, 2020 Armbianmonitor: http://ix.io/2D4H Hi All, I'm trying to enable SPI2 on a A20 Olinuxino LIME board. I found an old post on this forum regarding LIME2, so I try the same and in armbianEnv.txt I add the lines: overlays=spi2 spi-spidev param_spidev_spi_bus=2 param_spi2_bus_pins=b At reboot, the message: Failed to load '/boot/dtb/overlay/sun7i-a20-spi2.dtbo' I think because the file is not found Only SPI0 is active How can I enable SPI2 ? Thanks in advance PaoloC
