CURRENT branch (Linux Kernel 5.10)
Feature Support Status Remarks
Shutdown OK
Reboot OK
Suspend to RAM Not Supported USB host controller refuses to enter suspend mode
2.5G Ethernet
(2.5G speed)
OK
TX offload disabled by default, can be enabled for better performance
2.5G Ethernet
(1G speed)
Performance issue
Requires hardware fix.
Main Power/UPS status OK
Status can be read from sysfs
Battery Charging OK Status can be read from sysfs
UPS configuration
OK Auto shutdown after 10 min of power loss.
USB Type C - Host OK use dwc3-0-host overlay. Enable P13 jumper to be able to use USB 2.0 device.
USB Type C - Gadget OK use overlay to enable USB device mode. refer to this link
USB Type C - DisplayPort OK
eMMC Boot OK
SPI Boot Not Supported
Recovery Button OK To use maskrom, jumper P13 must be enabled.
USB LED Not Supported usbport led trigger does not support activity and only works with USB 2.0 device
LAN LED OK
 default to eth0 activity
Wake On LAN Not Supported Suspend still have issue
Armbian 21.02
Edited by aprayoga
Update to Armbian 21.02
LEGACY branch (Linux Kernel 4.4)
Shutdown Partial Fails to shutdown PMIC and triggers crash, HDD already parked
Reboot Partial
Similar like shutdown but Watchdog triggers the reboot so it appears successful
Suspend to RAM Not Supported Fails to resume operation after wake up
2.5G Ethernet
(2.5G speed)
OK
2.5G Ethernet
(1G speed)
Performance issue Requires hardware fix.
Main Power/UPS Status OK Status can be read from sysfs
Battery Charging Status Not Supported
UPS configuration OK
USB Type C - Gadget OK Use g_mass_storage kernel module
eMMC Boot OK
Recovery Button OK
LAN LED Not Supported
Armbian 21.02
Edited by aprayoga
Shutdown OK
Reboot OK
2.5G Ethernet
(2.5G speed)
OK
2.5G Ethernet
(1G speed)
Performance issue
UPS configuration
eMMC Boot OK
LAN LED Supported  default to eth0 activity
Armbian 21.02
Note:
- UPS action will be changed into based on battery voltage threshold rather than countdown timer. (PR 2259)
- To change LAN LED network device, change eth0 on /etc/systemd/system/helios64-heartbeat-led.service at line 9 into eth1
  • Igor unpinned this topic
