sucotronic Posted November 16, 2020 Posted November 16, 2020 I've repurposed an old TV android box with armbian, just using the Olimex based image. It works peferectly, but I'm seeing a constant constant cpu usage by kworkers: root@lime:~# uname -r 4.19.62-sunxi root@lime:~# ps auxk -%cpu | head USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND root 5740 8.8 0.0 0 0 ? I 10:27 1:19 [kworker/1:0-eve] root 4444 4.6 0.0 0 0 ? I 10:17 1:10 [kworker/0:0-eve] root 1 0.3 0.5 25848 5448 ? Ss 10:01 0:09 /sbin/init root 147 0.2 0.0 0 0 ? I< 10:01 0:05 [kworker/1:1H-kb] root 195 0.1 0.0 0 0 ? I< 10:01 0:04 [kworker/0:2H-kb] root 205 0.1 0.3 24544 4052 ? Ss 10:01 0:02 /lib/systemd/systemd-journald root 2 0.0 0.0 0 0 ? S 10:01 0:00 [kthreadd] root 3 0.0 0.0 0 0 ? I< 10:01 0:00 [rcu_gp] root 4 0.0 0.0 0 0 ? I< 10:01 0:00 [rcu_par_gp] Tried to debug looking into sys dumps: root@lime:~# echo l > /proc/sysrq-trigger root@lime:~# dmesg | tail -100 ... [ 2489.669676] sysrq: SysRq : Show backtrace of all active CPUs [ 2489.675658] NMI backtrace for cpu 1 [ 2489.675676] CPU: 1 PID: 2958 Comm: bash Not tainted 4.19.62-sunxi #5.92 [ 2489.675683] Hardware name: Allwinner sun7i (A20) Family [ 2489.675731] [<c010d74d>] (unwind_backtrace) from [<c010a2f1>] (show_stack+0x11/0x14) [ 2489.675757] [<c010a2f1>] (show_stack) from [<c08fc121>] (dump_stack+0x69/0x78) [ 2489.675782] [<c08fc121>] (dump_stack) from [<c09003a3>] (nmi_cpu_backtrace+0x8f/0x90) [ 2489.675804] [<c09003a3>] (nmi_cpu_backtrace) from [<c0900453>] (nmi_trigger_cpumask_backtrace+0xaf/0xe0) [ 2489.675828] [<c0900453>] (nmi_trigger_cpumask_backtrace) from [<c060c311>] (__handle_sysrq+0x7d/0x114) [ 2489.675850] [<c060c311>] (__handle_sysrq) from [<c060c75d>] (write_sysrq_trigger+0x49/0x54) [ 2489.675873] [<c060c75d>] (write_sysrq_trigger) from [<c0290b65>] (proc_reg_write+0x45/0x64) [ 2489.675900] [<c0290b65>] (proc_reg_write) from [<c023ef13>] (vfs_write+0x77/0x144) [ 2489.675924] [<c023ef13>] (vfs_write) from [<c023f105>] (ksys_write+0x49/0x98) [ 2489.675945] [<c023f105>] (ksys_write) from [<c0101001>] (ret_fast_syscall+0x1/0x62) [ 2489.675954] Exception stack(0xecac3fa8 to 0xecac3ff0) [ 2489.675970] 3fa0: 00000002 01131408 00000001 01131408 00000002 00000000 [ 2489.675987] 3fc0: 00000002 01131408 b6eb0d60 00000004 01131408 00000002 00000000 00000000 [ 2489.675998] 3fe0: 00000000 beb107fc b6e131bb b6e4fcf6 [ 2489.676010] Sending NMI from CPU 1 to CPUs 0: [ 2489.676300] NMI backtrace for cpu 0 [ 2489.676308] CPU: 0 PID: 205 Comm: systemd-journal Not tainted 4.19.62-sunxi #5.92 [ 2489.676313] Hardware name: Allwinner sun7i (A20) Family [ 2489.676317] PC is at fput+0x0/0x94 [ 2489.676320] LR is at path_openat+0x269/0xe0c [ 2489.676326] pc : [<c023fed0>] lr : [<c024985d>] psr: a00f0033 [ 2489.676330] sp : ed84fe40 ip : 014e8905 fp : c0e04d48 [ 2489.676335] r10: eb92a240 r9 : ffffe000 r8 : fffff000 [ 2489.676340] r7 : ed84ff70 r6 : 08010800 r5 : fffffffe r4 : ed84fec0 [ 2489.676345] r3 : 00000000 r2 : 00000011 r1 : 00000000 r0 : eb92a240 [ 2489.676351] Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA Thumb Segment none [ 2489.676356] Control: 50c5387d Table: 6d8dc06a DAC: 00000051 [ 2489.676362] CPU: 0 PID: 205 Comm: systemd-journal Not tainted 4.19.62-sunxi #5.92 [ 2489.676367] Hardware name: Allwinner sun7i (A20) Family [ 2489.676372] [<c010d74d>] (unwind_backtrace) from [<c010a2f1>] (show_stack+0x11/0x14) [ 2489.676378] [<c010a2f1>] (show_stack) from [<c08fc121>] (dump_stack+0x69/0x78) [ 2489.676384] [<c08fc121>] (dump_stack) from [<c090036d>] (nmi_cpu_backtrace+0x59/0x90) [ 2489.676390] [<c090036d>] (nmi_cpu_backtrace) from [<c010c5d9>] (handle_IPI+0x85/0x2c0) [ 2489.676395] [<c010c5d9>] (handle_IPI) from [<c05c9c7f>] (gic_handle_irq+0x67/0x68) [ 2489.676401] [<c05c9c7f>] (gic_handle_irq) from [<c0101a65>] (__irq_svc+0x65/0x94) [ 2489.676406] Exception stack(0xed84fdf0 to 0xed84fe38) [ 2489.676412] fde0: eb92a240 00000000 00000011 00000000 [ 2489.676418] fe00: ed84fec0 fffffffe 08010800 ed84ff70 fffff000 ffffe000 eb92a240 c0e04d48 [ 2489.676424] fe20: 014e8905 ed84fe40 c024985d c023fed0 a00f0033 ffffffff [ 2489.676429] [<c0101a65>] (__irq_svc) from [<c023fed0>] (fput+0x0/0x94) [ 2489.676434] [<c023fed0>] (fput) from [<ed8402c0>] (0xed8402c0) I suspect that something is happening with interrupts, so inspected /proc/interrupts, and have seen two very high values in "sunxi-mmc" and "Rescheduling interrupts": root@lime:~# cat /proc/interrupts CPU0 CPU1 18: 0 0 GICv2 29 Level arch_timer 19: 132351 137260 GICv2 30 Level arch_timer 22: 0 0 GICv2 54 Level timer@1c20c00 23: 0 0 GICv2 113 Level sun5i_timer0 24: 0 0 GICv2 152 Level arm-pmu 25: 0 0 GICv2 153 Level arm-pmu 26: 0 0 GICv2 59 Level 1c02000.dma-controller 27: 0 0 GICv2 76 Level 1c0c000.lcd-controller 28: 0 0 GICv2 77 Level 1c0d000.lcd-controller 29: 1228805 0 GICv2 64 Level sunxi-mmc 30: 0 0 GICv2 70 Level musb-hdrc.1.auto 31: 0 0 GICv2 71 Level ehci_hcd:usb1 32: 0 0 GICv2 96 Level ohci_hcd:usb3 36: 0 0 GICv2 72 Level ehci_hcd:usb2 37: 0 0 GICv2 97 Level ohci_hcd:usb4 40: 0 0 GICv2 56 Level 1c20d00.rtc 44: 2723 0 GICv2 61 Level sun4i_gpadc_irq_chip 45: 6 0 GICv2 33 Level ttyS0 46: 692 0 GICv2 39 Level mv64xxx_i2c 47: 4 0 GICv2 40 Level mv64xxx_i2c 48: 0 0 GICv2 101 Level gp 49: 0 0 GICv2 102 Level gpmmu 50: 0 0 GICv2 103 Level pp0 51: 0 0 GICv2 104 Level ppmmu0 52: 0 0 GICv2 106 Level pp1 53: 0 0 GICv2 107 Level ppmmu1 55: 16900 0 GICv2 117 Level eth0 62: 0 0 sunxi_pio_edge 1 Edge 1c0f000.mmc cd 65: 1 0 sunxi_pio_edge 4 Edge usb0-id-det 66: 0 0 sunxi_pio_edge 5 Edge usb0-vbus-det 93: 0 0 sunxi-nmi 0 Level axp20x_irq_chip 127: 0 0 axp20x_irq_chip 33 Edge axp20x-pek-dbr 128: 0 0 axp20x_irq_chip 34 Edge axp20x-pek-dbf 133: 2722 0 sun4i_gpadc_irq_chip 1 Edge temp_data 134: 0 0 sun4i_gpadc_irq_chip 0 Edge fifo_data IPI0: 0 0 CPU wakeup interrupts IPI1: 0 0 Timer broadcast interrupts IPI2: 26187 512258 Rescheduling interrupts IPI3: 312 262 Function call interrupts IPI4: 0 0 CPU stop interrupts IPI5: 2553 2019 IRQ work interrupts IPI6: 0 0 completion interrupts Is this normal in an A20 board or something fixable by configuration/tunning/whatever?
TRS-80 Posted November 16, 2020 Posted November 16, 2020 (edited) On 11/16/2020 at 9:55 AM, sucotronic said: an old TV android box Expand On 11/16/2020 at 9:55 AM, sucotronic said: Is this normal in an A20 board Expand The problem (as I understand it) likely is not "an A20 board" but rather "[some random] old TV Android box." On 11/16/2020 at 9:55 AM, sucotronic said: Is [...] fixable by configuration/tunning/whatever? Expand Maybe, maybe not. Could be simple or complex. But it will be up to you (and/or others) to dig and find out (as it is not Supported device). What you may find (after spending some (a lot?) of time) is that there are good reasons that Armbian does not support every random board out there (and especially, TV boxes). Or, maybe you get lucky and get it working better (in which case, please share your findings here). It actually sounds to me like you are a little bit into a decent investigation already. Maybe you know more than me. I, personally, do not want to get involved in (potentially lengthy) investigations. And therefore I stick (strictly) to the list of Supported Devices. In fact, I use that as a starting point for any hardware purchases. But maybe you like a challenge? Good luck! Edited November 16, 2020 by TRS-80 clarity
hexdump Posted November 16, 2020 Posted November 16, 2020 i think it could be a generic a20 problem - maybe have a look at: https://forum.armbian.com/topic/7575-k-worker-problem-on-a20-based-boards/ https://forum.armbian.com/topic/14282-headless-systems-and-sun4i_drm_hdmi-a10a20/ https://superuser.com/questions/1515001/debian-10-buster-on-cubietruck-with-bug-in-sun4i-drm-hdmi best wishes - hexdump 3
sucotronic Posted November 17, 2020 Author Posted November 17, 2020 On 11/16/2020 at 7:21 PM, hexdump said: i think it could be a generic a20 problem - maybe have a look at: https://forum.armbian.com/topic/7575-k-worker-problem-on-a20-based-boards/ https://forum.armbian.com/topic/14282-headless-systems-and-sun4i_drm_hdmi-a10a20/ https://superuser.com/questions/1515001/debian-10-buster-on-cubietruck-with-bug-in-sun4i-drm-hdmi best wishes - hexdump Expand Wow, that was a very helpful answer, thanks a lot!! With that info I can just blacklist that modules (anyway, I'm not interested in using the ADC functionality of the A20 :P) and now the system shows proper low cpu usage: root@lime:~# cat /etc/modprobe.d/fix.conf blacklist sun4i_gpadc sun4i_gpadc_iio root@lime:~# ps auxk -cpu | head USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND root 1 0.0 0.5 26932 5332 ? Ss 00:07 0:07 /sbin/init root 2 0.0 0.0 0 0 ? S 00:07 0:00 [kthreadd] root 3 0.0 0.0 0 0 ? I< 00:07 0:00 [rcu_gp] root 4 0.0 0.0 0 0 ? I< 00:07 0:00 [rcu_par_gp] root 8 0.0 0.0 0 0 ? I< 00:07 0:00 [mm_percpu_wq] root 9 0.0 0.0 0 0 ? S 00:07 0:00 [ksoftirqd/0] root 10 0.0 0.0 0 0 ? I 00:07 0:23 [rcu_sched] root 11 0.0 0.0 0 0 ? I 00:07 0:00 [rcu_bh] root 12 0.0 0.0 0 0 ? S 00:07 0:00 [migration/0] 1
