Firfly-rk3399 have not been booting up reasent images from Armbian
15 hours ago, piter75 said:
Both look perfectly well except for the fact that the latest one does not boot :(
Can you also try one of the v20.02.7 images available in the archive? https://archive.armbian.com/firefly-rk3399/archive/
I'd like to find the most precise point where it stopped working.
This image Armbian_20.02.7_Firefly-rk3399_bullseye_legacy_4.4.213  - legacy did work.  Will try current next.
And this is the messages from the serial output from ttyFIQ0
In
soft reset
SRX
Channel 0: DDR3, 800MHz
Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB
Channel 1: DDR3, 800MHz
256B stride
ch 0 ddrconfig = 0x101, ddrsize = 0x2020
ch 1 ddrconfig = 0x101, ddrsize = 0x2020
pmugrf_os_reg[2] = 0x3AA17AA1, stride = 0xD
OUT
Boot1: 2019-03-14, version: 1.19
CPUId = 0x0
ChipType = 0x10, 307
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=119276MB
FwPartOffset=2000 , 100000
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=61056MB
FwPartOffset=2000 , 0
StorageInit ok = 65578
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT 0x3380ec0 signature is wrong
recovery gpt...
recovery gpt fail!
LoadTrust Addr:0x4000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xa5474
RunBL31 0x40000
NOTICE:  BL31: v1.3(debug):42583b6
NOTICE:  BL31: Built : 07:55:13, Oct 15 2019
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    plat_rockchip_pmu_init(1190): pd status 3e
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will K
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2020.01-armbian (Mar 28 2020 - 16:55:52 +0100)
Model: Firefly-RK3399 Board
DRAM:  3.9 GiB
PMIC:  RK808
MMC:   dwmmc@fe320000: 1, sdhci@fe330000: 0
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In:    serial@ff1a0000
Out:   serial@ff1a0000
Err:   serial@ff1a0000
rockchip_dnl_key_pressed: adc_channel_single_shot fail!
Net:   eth0: ethernet@fe300000
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc0(part 0) is current device
** No partition table - mmc 0 **
mmc1 is current device
Scanning mmc 1:1...
2940 bytes read in 6 ms (478.5 KiB/s)
## Executing script at 00500000
Boot script loaded from mmc 1
151 bytes read in 5 ms (29.3 KiB/s)
7990082 bytes read in 345 ms (22.1 MiB/s)
20559880 bytes read in 877 ms (22.4 MiB/s)
101691 bytes read in 13 ms (7.5 MiB/s)
## Loading init Ramdisk from Legacy Image at 06000000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Data Size:    7990018 Bytes = 7.6 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 01f00000
   Booting using the fdt blob at 0x1f00000
   Loading Ramdisk to f5784000, end f5f22b02 ... OK
ERROR: reserving fdt memory region failed (addr=0 size=0)
   Loading Device Tree to 00000000f5702000, end 00000000f5783fff ... OK
Starting kernel ...
Armbian 20.02.7 Bullseye ttyFIQ0
firefly-rk3399 login:
CTRL-A Z for help | 1500000 8N1 | NOR | Minicom 2.7.1 | VT102 | Online 32:43 | ttyUSB0
Current - Armbian_20.02.7_Firefly-rk3399_buster_current_5.4.28_desktop is not working,
this is the output.
DDR Version 1.24 20191016
In
256B stride
OUT
CPUId = 0x0
ChipType = 0x10, 243
SdmmcInit=2 0
BootCapSize=100000
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=61056MB
StorageInit ok = 65063
SecureMode = 0
recovery gpt...
recovery gpt fail!
No find bl30.bin
No find bl32.bin
RunBL31 0x40000
INFO:    SPSR = 0x3c9
U-Boot 2020.01-armbian (Mar 28 2020 - 17:02:29 +0100)
DRAM:  3.9 GiB
PMIC:  RK808
In:    serial@ff1a0000
Scanning mmc 1:1...
2940 bytes read in 7 ms (410.2 KiB/s)
102 bytes read in 5 ms (19.5 KiB/s)
7285953 bytes read in 316 ms (22 MiB/s)
20787712 bytes read in 884 ms (22.4 MiB/s)
74432 bytes read in 12 ms (5.9 MiB/s)
2698 bytes read in 9 ms (292 KiB/s)
Applying kernel provided DT fixup script (rockchip-fixup.scr)
## Executing script at 39000000
   Image Name:   uInitrd
   Data Size:    7285889 Bytes = 6.9 MiB
   Loading Ramdisk to f582f000, end f5f21c81 ... OK
   Loading Device Tree to 00000000f57b4000, end 00000000f582efff ... OK
Starting kernel ...
CTRL-A Z for help | 1500000 8N1 | NOR | Minicom 2.7.1 | VT102 | Online 33:18 | ttyUSB0
Perhaps some issues with the dtb file with the current kernel as balbes150 did suggest.
As an assumption, it is possible that u-boot specifies the name of the DTB file, which is not suitable for recent kernels. You can try to force the use of a different DTB (via armbianuEnv.txt) and try to check other DTB options. Sometimes there are "miracles" and someone else's DTB can work.
This did it!  Did add - device_tree=/boot/dtb/rockchip/firefly-rk3399.dtb in armbianEnv.txt and start 20.02.7 kernel 5.4.28 from Mars 28
In
256B stride
OUT
CPUId = 0x0
ChipType = 0x10, 244
SdmmcInit=2 0
BootCapSize=100000
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=61056MB
StorageInit ok = 65106
SecureMode = 0
recovery gpt...
recovery gpt fail!
No find bl30.bin
No find bl32.bin
RunBL31 0x40000
WARNING: check_cpu_wfie: 1, 0, 69632, error!
WARNING: check_cpu_wfie: 1, 1, 139264, error!
INFO:    plat_rockchip_pmu_init(1190): pd status e
INFO:    SPSR = 0x3c9
DRAM:  3.9 GiB
PMIC:  RK808
In:    serial@ff1a0000
Scanning mmc 1:1...
152 bytes read in 6 ms (24.4 KiB/s)
7285953 bytes read in 315 ms (22.1 MiB/s)
2698 bytes read in 10 ms (262.7 KiB/s)
   Image Name:   uInitrd
Starting kernel ...
Armbian 20.02.7 Buster ttyS2
CTRL-A Z for help | 1500000 8N1 | NOR | Minicom 2.7.1 | VT102 | Online 35:15 | ttyUSB0
But it was not sufficient to bring up Armbian_20.08.1_Firefly-rk3399_focal_current_5.8.6.img
( do always clean the SD between the attempts with - dd if=/dev/zero of=/dev/sdc bs=4096 status=progress)
This is a good reading about dtb and overlays - https://www.raspberrypi.org/documentation/configuration/device-tree.md
This is the error message from - Armbian_20.05.1_Firefly-rk3399_focal_current_5.4.43.img.xz
It hangs on -
[    3.197491] rk808-rtc rk808-rtc: registered as rtc0
[    3.198558] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    3.199193] fan53555-reg: supplied by vcc_sys
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.4.43-rockchip64 (root@builder) (gcc version 8.3.0 (GNU Toolchain for the A-0
[    0.000000] Machine model: Firefly-RK3399 Board
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 128 MiB at 0x00000000ecc00000
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000] NUMA: NODE_DATA [mem 0xf77e2800-0xf77e3fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA32    [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.0
[    0.000000] percpu: Embedded 23 pages/cpu s53592 r8192 d32424 u94208
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 999432
[    0.000000] Policy zone: DMA32
[    0.000000] Kernel command line: root=UUID=65c6f601-0fdf-4eba-81e0-5d7346e31be4 rootwait rootfstype=ext1
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.000000] Memory: 3813528K/4061184K available (11964K kernel code, 1414K rwdata, 4656K rodata, 1024K )
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[    0.000000]  Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: no VLPI support, no direct LPI support
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000
[    0.000000] ITS [mem 0xfee20000-0xfee3ffff]
[    0.000000] ITS@0x00000000fee20000: allocated 65536 Devices @f6c80000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000000f6c40000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000000f6c50000
[    0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cp}
[    0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[    0.000000] random: get_random_bytes called from start_kernel+0x2f8/0x484 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns:s
[    0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001569] Console: colour dummy device 80x25
[    0.002562] printk: console [tty1] enabled
[    0.002682] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS ()
[    0.002724] pid_max: default: 32768 minimum: 301
[    0.002876] LSM: Security Framework initializing
[    0.002925] Yama: becoming mindful.
[    0.003112] AppArmor: AppArmor initialized
[    0.003209] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.003260] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.003344] *** VALIDATE tmpfs ***
[    0.004048] *** VALIDATE proc ***
[    0.004375] *** VALIDATE cgroup1 ***
[    0.004400] *** VALIDATE cgroup2 ***
[    0.027777] ASID allocator initialised with 32768 entries
[    0.035774] rcu: Hierarchical SRCU implementation.
[    0.045946] Platform MSI: interrupt-controller@fee20000 domain created
[    0.046416] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.048683] EFI services will not be available.
[    0.056500] smp: Bringing up secondary CPUs ...
[    0.088742] Detected VIPT I-cache on CPU1
[    0.088780] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.088797] GICv3: CPU1: using allocated LPI pending table @0x00000000f6c60000
[    0.088845] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.120832] Detected VIPT I-cache on CPU2
[    0.120860] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.120875] GICv3: CPU2: using allocated LPI pending table @0x00000000f6c70000
[    0.120909] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.152948] Detected VIPT I-cache on CPU3
[    0.152976] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.152991] GICv3: CPU3: using allocated LPI pending table @0x00000000f6d00000
[    0.153024] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.185079] CPU features: detected: EL2 vector hardening
[    0.185090] ARM_SMCCC_ARCH_WORKAROUND_1 missing from firmware
[    0.185099] Detected PIPT I-cache on CPU4
[    0.185130] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000
[    0.185144] GICv3: CPU4: using allocated LPI pending table @0x00000000f6d10000
[    0.185181] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
[    0.217199] Detected PIPT I-cache on CPU5
[    0.217226] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000
[    0.217239] GICv3: CPU5: using allocated LPI pending table @0x00000000f6d20000
[    0.217267] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
[    0.217402] smp: Brought up 1 node, 6 CPUs
[    0.217793] SMP: Total of 6 processors activated.
[    0.217816] CPU features: detected: 32-bit EL0 Support
[    0.217840] CPU features: detected: CRC32 instructions
[    0.219065] CPU: All CPU(s) started at EL2
[    0.219127] alternatives: patching kernel code
[    0.222454] devtmpfs: initialized
[    0.242509] Registered cp15_barrier emulation handler
[    0.242554] Registered setend emulation handler
[    0.243077] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 764504178510000s
[    0.243163] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.249247] xor: measuring software checksum speed
[    0.289310]    8regs     :  1188.000 MB/sec
[    0.329337]    32regs    :  2756.000 MB/sec
[    0.369412]    arm64_neon:  2345.000 MB/sec
[    0.369427] xor: using function: 32regs (2756.000 MB/sec)
[    0.369536] pinctrl core: initialized pinctrl subsystem
[    0.370415] DMI not present or invalid.
[    0.370805] NET: Registered protocol family 16
[    0.386631] DMA: preallocated 2048 KiB pool for atomic allocations
[    0.386656] audit: initializing netlink subsys (disabled)
[    0.386872] audit: type=2000 audit(0.384:1): state=initialized audit_enabled=0 res=1
[    0.388262] cpuidle: using governor menu
[    0.388576] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.389919] Serial: AMBA PL011 UART driver
[    0.430182] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.430209] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.430227] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.430244] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.440198] cryptd: max_cpu_qlen set to 1000
[    0.525810] raid6: neonx8   gen()  1324 MB/s
[    0.593955] raid6: neonx8   xor()  1191 MB/s
[    0.662139] raid6: neonx4   gen()  1005 MB/s
[    0.730232] raid6: neonx4   xor()   996 MB/s
[    0.798386] raid6: neonx2   gen()   927 MB/s
[    0.866539] raid6: neonx2   xor()  1082 MB/s
[    0.934682] raid6: neonx1   gen()   718 MB/s
[    1.002812] raid6: neonx1   xor()   831 MB/s
[    1.070973] raid6: int64x8  gen()   718 MB/s
[    1.139115] raid6: int64x8  xor()   532 MB/s
[    1.207221] raid6: int64x4  gen()   642 MB/s
[    1.275346] raid6: int64x4  xor()   554 MB/s
[    1.343468] raid6: int64x2  gen()   471 MB/s
[    1.411594] raid6: int64x2  xor()   499 MB/s
[    1.479888] raid6: int64x1  gen()   345 MB/s
[    1.547871] raid6: int64x1  xor()   338 MB/s
[    1.547885] raid6: using algorithm neonx8 gen() 1324 MB/s
[    1.547898] raid6: .... xor() 1191 MB/s, rmw enabled
[    1.547912] raid6: using neon recovery algorithm
[    1.549504] vcc3v3_pcie: supplied by dc_12v
[    1.550483] vcc_sys: supplied by dc_12v
[    1.550963] iommu: Default domain type: Translated
[    1.553256] vgaarb: loaded
[    1.553726] SCSI subsystem initialized
[    1.554207] usbcore: registered new interface driver usbfs
[    1.554272] usbcore: registered new interface driver hub
[    1.554381] usbcore: registered new device driver usb
[    1.554995] pps_core: LinuxPPS API ver. 1 registered
[    1.555012] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.555040] PTP clock support registered
[    1.555297] EDAC MC: Ver: 3.0.0
[    1.556310] NetLabel: Initializing
[    1.556327] NetLabel:  domain hash size = 128
[    1.556339] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    1.556412] NetLabel:  unlabeled traffic allowed by default
[    1.556876] clocksource: Switched to clocksource arch_sys_counter
[    1.557095] VFS: Disk quotas dquot_6.6.0
[    1.557172] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.557268] *** VALIDATE ramfs ***
[    1.557292] *** VALIDATE hugetlbfs ***
[    1.557970] AppArmor: AppArmor Filesystem Enabled
[    1.566917] thermal_sys: Registered thermal governor 'fair_share'
[    1.566922] thermal_sys: Registered thermal governor 'bang_bang'
[    1.566943] thermal_sys: Registered thermal governor 'step_wise'
[    1.566958] thermal_sys: Registered thermal governor 'user_space'
[    1.566973] thermal_sys: Registered thermal governor 'power_allocator'
[    1.567536] NET: Registered protocol family 2
[    1.568287] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    1.568471] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    1.569040] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[    1.569719] TCP: Hash tables configured (established 32768 bind 32768)
[    1.569904] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    1.570074] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    1.570417] NET: Registered protocol family 1
[    1.570458] PCI: CLS 0 bytes, default 64
[    1.570656] Trying to unpack rootfs image as initramfs...
[    1.843399] Freeing initrd memory: 16244K
[    1.844491] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    1.844893] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    1.845386] kvm [1]: IPA Size Limit: 40bits
[    1.846019] kvm [1]: vgic-v2@fff20000
[    1.846060] kvm [1]: GIC system register CPU interface enabled
[    1.846281] kvm [1]: vgic interrupt IRQ10
[    1.846530] kvm [1]: Hyp mode initialized successfully
[    2.159767] Initialise system trusted keyrings
[    2.159819] Key type blacklist registered
[    2.160000] workingset: timestamp_bits=44 max_order=20 bucket_order=0
[    2.165741] zbud: loaded
[    2.167537] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    2.168363] fuse: init (API version 7.31)
[    2.168460] *** VALIDATE fuse ***
[    2.168479] *** VALIDATE fuse ***
[    2.169748] Platform Keyring initialized
[    2.205408] Key type asymmetric registered
[    2.205433] Asymmetric key parser 'x509' registered
[    2.205500] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    2.205731] io scheduler mq-deadline registered
[    2.205751] io scheduler kyber registered
[    2.205919] io scheduler bfq registered
[    2.208989] vcc5v0_host: supplied by vcc_sys
[    2.220690] rockchip-pcie f8000000.pcie: no vpcie12v regulator found
[    2.220732] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[    2.220763] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[    2.220794] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[    2.776914] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[    2.777014] rockchip-pcie: probe of f8000000.pcie failed with error -110
[    2.782652] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    2.782680] dma-pl330 ff6d0000.dma-controller:       DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events2
[    2.783917] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    2.783943] dma-pl330 ff6e0000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Event6
[    2.787186] pwm-regulator: supplied by regulator-dummy
[    2.787452] vcc3v3_sys: supplied by vcc_sys
[    2.788607] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    2.791469] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 38, base_baud = 1500000) is a 16550A
[    2.792259] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 39, base_baud = 1500000) is a 16550A
[    2.903979] printk: console [ttyS2] enabled
[    2.905468] Serial: AMBA driver
[    2.906995] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    2.918257] loop: module loaded
[    2.922944] libphy: Fixed MDIO Bus: probed
[    2.923631] tun: Universal TUN/TAP device driver, 1.6
[    2.925086] thunder_xcv, ver 1.0
[    2.925418] thunder_bgx, ver 1.0
[    2.925746] nicpf, ver 1.0
[    2.926948] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    2.927469] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    2.928039] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.6.0-k
[    2.928658] igb: Copyright (c) 2007-2014 Intel Corporation.
[    2.929218] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    2.929914] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    2.930691] sky2: driver version 1.30
[    2.931649] VFIO - User Level meta-driver version: 0.3
[    2.938490] OF: graph: no port node found in /syscon@ff770000/usb2-phy@e450/otg-port
[    2.946565] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.947166] ehci-pci: EHCI PCI platform driver
[    2.947598] ehci-platform: EHCI generic platform driver
[    2.950300] ehci-platform fe380000.usb: EHCI Host Controller
[    2.950828] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[    2.951655] ehci-platform fe380000.usb: irq 31, io mem 0xfe380000
[    2.964910] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[    2.965696] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[    2.966438] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.967084] usb usb1: Product: EHCI Host Controller
[    2.967525] usb usb1: Manufacturer: Linux 5.4.43-rockchip64 ehci_hcd
[    2.968093] usb usb1: SerialNumber: fe380000.usb
[    2.969032] hub 1-0:1.0: USB hub found
[    2.969404] hub 1-0:1.0: 1 port detected
[    2.972281] ehci-platform fe3c0000.usb: EHCI Host Controller
[    2.972805] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[    2.973629] ehci-platform fe3c0000.usb: irq 33, io mem 0xfe3c0000
[    2.988905] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[    2.989659] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[    2.990399] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.991045] usb usb2: Product: EHCI Host Controller
[    2.991484] usb usb2: Manufacturer: Linux 5.4.43-rockchip64 ehci_hcd
[    2.992052] usb usb2: SerialNumber: fe3c0000.usb
[    2.992941] hub 2-0:1.0: USB hub found
[    2.993311] hub 2-0:1.0: 1 port detected
[    2.994246] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.994811] ohci-pci: OHCI PCI platform driver
[    2.995254] ohci-platform: OHCI generic platform driver
[    2.995927] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[    2.996540] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[    2.997385] ohci-platform fe3a0000.usb: irq 32, io mem 0xfe3a0000
[    3.061206] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
[    3.061946] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.062593] usb usb3: Product: Generic Platform OHCI controller
[    3.063124] usb usb3: Manufacturer: Linux 5.4.43-rockchip64 ohci_hcd
[    3.063691] usb usb3: SerialNumber: fe3a0000.usb
[    3.064556] hub 3-0:1.0: USB hub found
[    3.064943] hub 3-0:1.0: 1 port detected
[    3.065775] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[    3.066388] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[    3.067189] ohci-platform fe3e0000.usb: irq 34, io mem 0xfe3e0000
[    3.129103] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
[    3.129845] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.130491] usb usb4: Product: Generic Platform OHCI controller
[    3.131022] usb usb4: Manufacturer: Linux 5.4.43-rockchip64 ohci_hcd
[    3.131590] usb usb4: SerialNumber: fe3e0000.usb
[    3.132459] hub 4-0:1.0: USB hub found
[    3.132829] hub 4-0:1.0: 1 port detected
[    3.134387] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.134897] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 5
[    3.135748] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[    3.136599] xhci-hcd xhci-hcd.0.auto: irq 227, io mem 0xfe800000
[    3.137523] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[    3.138263] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.138910] usb usb5: Product: xHCI Host Controller
[    3.139350] usb usb5: Manufacturer: Linux 5.4.43-rockchip64 xhci-hcd
[    3.139919] usb usb5: SerialNumber: xhci-hcd.0.auto
[    3.140812] hub 5-0:1.0: USB hub found
[    3.141202] hub 5-0:1.0: 1 port detected
[    3.141845] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.142347] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 6
[    3.143038] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    3.143682] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    3.144528] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[    3.145284] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.145931] usb usb6: Product: xHCI Host Controller
[    3.146371] usb usb6: Manufacturer: Linux 5.4.43-rockchip64 xhci-hcd
[    3.146939] usb usb6: SerialNumber: xhci-hcd.0.auto
[    3.147839] hub 6-0:1.0: USB hub found
[    3.148208] hub 6-0:1.0: 1 port detected
[    3.149043] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    3.149552] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 7
[    3.150389] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[    3.151269] xhci-hcd xhci-hcd.1.auto: irq 228, io mem 0xfe900000
[    3.152158] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[    3.152915] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.153562] usb usb7: Product: xHCI Host Controller
[    3.154001] usb usb7: Manufacturer: Linux 5.4.43-rockchip64 xhci-hcd
[    3.154570] usb usb7: SerialNumber: xhci-hcd.1.auto
[    3.155454] hub 7-0:1.0: USB hub found
[    3.155823] hub 7-0:1.0: 1 port detected
[    3.156466] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    3.156994] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 8
[    3.157687] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[    3.158336] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
[    3.159172] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[    3.159911] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.160557] usb usb8: Product: xHCI Host Controller
[    3.161012] usb usb8: Manufacturer: Linux 5.4.43-rockchip64 xhci-hcd
[    3.161580] usb usb8: SerialNumber: xhci-hcd.1.auto
[    3.162465] hub 8-0:1.0: USB hub found
[    3.162835] hub 8-0:1.0: 1 port detected
[    3.163670] usbcore: registered new interface driver usb-storage
[    3.166705] mousedev: PS/2 mouse device common for all mice
[    3.168386] i2c /dev entries driver
[    3.171201] rk808 0-001b: chip id: 0x0
[    3.175700] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    3.176280] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    3.176935] DCDC_REG1: supplied by vcc_sys
[    3.178213] DCDC_REG2: supplied by vcc_sys
[    3.179116] DCDC_REG3: supplied by vcc_sys
[    3.179734] DCDC_REG4: supplied by vcc_sys
[    3.180692] LDO_REG1: supplied by vcc_sys
[    3.182301] LDO_REG2: supplied by vcc_sys
[    3.182857] vcc2v8_dvp: Bringing 3000000uV into 2800000-2800000uV
[    3.184273] LDO_REG3: supplied by vcc_sys
[    3.185739] LDO_REG4: supplied by vcc_sys
[    3.187184] LDO_REG5: supplied by vcc_sys
[    3.188519] LDO_REG6: supplied by vcc_sys
[    3.190004] LDO_REG7: supplied by vcc_sys
[    3.191321] LDO_REG8: supplied by vcc_sys
[    3.192780] SWITCH_REG1: supplied by vcc3v3_sys
[    3.193506] SWITCH_REG2: supplied by vcc3v3_sys
And u-boot printenv
printenv
altbootcmd=setenv boot_syslinux_conf extlinux/extlinux-rollback.conf;run distro_bootcmd
arch=arm
baudrate=1500000
board=evb_rk3399
board_name=evb_rk3399
boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr}
boot_efi_binary=if fdt addr ${fdt_addr_r}; then bootefi bootmgr ${fdt_addr_r};else bootefi bootmgr ${fdtcontroladdr};fi;load ${devtype} ${devnumi
boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}${boot_syslinux_conf}
boot_net_usb_start=usb start
boot_pci_enum=pci enum
boot_prefixes=/ /boot/
boot_script_dhcp=boot.scr.uimg
boot_scripts=boot.scr.uimg boot.scr
boot_syslinux_conf=extlinux/extlinux.conf
boot_targets=mmc1 mmc0 nvme0 usb0 pxe dhcp sf0
bootcmd=run distro_bootcmd
bootcmd_dhcp=run boot_net_usb_start; run boot_pci_enum; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;setenv efi_fdtf;
bootcmd_mmc0=devnum=0; run mmc_boot
bootcmd_mmc1=devnum=1; run mmc_boot
bootcmd_nvme0=devnum=0; run nvme_boot
bootcmd_pxe=run boot_net_usb_start; run boot_pci_enum; dhcp; if pxe get; then pxe boot; fi
bootcmd_sf0=busnum=0; run sf_boot
bootcmd_usb0=devnum=0; run usb_boot
bootdelay=0
cpu=armv8
cpuid#=544d463939322e3030000000000d898a
distro_bootcmd=setenv nvme_need_init; for target in ${boot_targets}; do run bootcmd_${target}; done
efi_dtb_prefixes=/ /dtb/ /dtb/current/
eth1addr=26:e0:17:46:a8:c0
ethaddr=26:e0:17:46:a8:a0
fdt_addr_r=0x01f00000
fdtcontroladdr=f5f194d0
fdtfile=rockchip/rk3399-firefly.dtb
kernel_addr_r=0x02080000
load_efi_dtb=load ${devtype} ${devnum}:${distro_bootpart} ${fdt_addr_r} ${prefix}${efi_fdtfile}
mmc_boot=if mmc dev ${devnum}; then devtype=mmc; run scan_dev_for_boot_part; fi
nvme_boot=run boot_pci_enum; run nvme_init; if nvme dev ${devnum}; then devtype=nvme; run scan_dev_for_boot_part; fi
nvme_init=if ${nvme_need_init}; then setenv nvme_need_init false; nvme scan; fi
partitions=uuid_disk=${uuid_gpt_disk};name=loader1,start=32K,size=4000K,uuid=${uuid_gpt_loader1};name=loader2,start=8MB,size=4MB,uuid=${uuid_gpt;
pxefile_addr_r=0x00600000
ramdisk_addr_r=0x06000000
scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run sc;
scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devt
scan_dev_for_efi=setenv efi_fdtfile ${fdtfile}; for prefix in ${efi_dtb_prefixes}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefie
scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${boot_syslinux_conf}; then echo Found ${prefix}${boot_syslinui
scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-e
scan_sf_for_scripts=${devtype} read ${scriptaddr} ${script_offset_f} ${script_size_f}; source ${scriptaddr}; echo SCRIPT FAILED: continuing...
script_offset_f=0xffe000
script_size_f=0x2000
scriptaddr=0x00500000
serial#=19d9d710df333dee
sf_boot=if sf probe ${busnum}; then devtype=sf; run scan_sf_for_scripts; fi
soc=rk3399
stderr=serial@ff1a0000
stdin=serial@ff1a0000
stdout=serial@ff1a0000
usb_boot=usb start; if usb dev ${devnum}; then devtype=usb; run scan_dev_for_boot_part; fi
vendor=rockchip
Environment size: 4774/32764 bytes
Side node;
this is  a perfect image for firefly-rk3399 - Armbian_20.02.7_Firefly-rk3399_bullseye_legacy_4.4.213.img - (debian 11 and kernel 4.4.213) - then after apt update && apt upgrade; apt install tasksel - tasksel - xfce4 - arbian-config,
install full firmware and bluetooth support, apt install gnome-bluetooth -
9 часов назад, denni_isl сказал:
Could not get the newest ones to work from
Without exact data (UART log, settings of the DTB used , exact image name) no one will help you.
The image is Armbian_20.05.1_Firefly-rk3399_focal_curent_5.4.43 - the with rk3399-firefly.dtb - and I did work - but not now ?
Armbian bullseye 4.4.213 and rk3399-firefly.dtb does always work - and is just fine image for this board.
Just experimenting with newer kernel.
This is where it halts - votages and RTL
[    3.176916] SWITCH_REG1: supplied by vcc3v3_sys
[    3.177620] SWITCH_REG2: supplied by vcc3v3_sys
[    3.181586] rk808-rtc rk808-rtc: registered as rtc0
[    3.182638] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    3.183271] fan53555-reg: supplied by vcc_sys
UART
4 20191016
In
256B stride
OUT
CPUId = 0x0
SdmmcInit=2 0
BootCapSize=100000
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=61056MB
StorageInit ok = 65217
SecureMode = 0
recovery gpt...
recovery gpt fail!
No find bl30.bin
No find bl32.bin
Load OK, addr=0x200000, size=0xa6028
RunBL31 0x40000
ialization. SMC`s destined for OPTEE will return SMC_UNK
INFO:    SPSR = 0x3c9
U-Boot 2020.04-armbian (May 30 2020 - 13:23:50 +0200)
SoC: Rockchip rk3399
Reset cause: POR
DRAM:  3.9 GiB
PMIC:  RK808
In:    serial@ff1a0000
Scanning mmc 1:1...
2940 bytes read in 5 ms (574.2 KiB/s)
102 bytes read in 4 ms (24.4 KiB/s)
16635430 bytes read in 709 ms (22.4 MiB/s)
19601920 bytes read in 832 ms (22.5 MiB/s)
74464 bytes read in 11 ms (6.5 MiB/s)
2698 bytes read in 8 ms (329.1 KiB/s)
   Image Name:   uInitrd
   Data Size:    16635366 Bytes = 15.9 MiB
   Loading Ramdisk to f4f45000, end f5f225e6 ... OK
   Loading Device Tree to 00000000f4eca000, end 00000000f4f44fff ... OK
Starting kernel ...
 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #20.
05.1 SMP PREEMPT Sat May 30 13:30:37 CEST 2020
e4 rootwait rootfstype=ext4 console=ttyS2,1500000 console=tty1 consoleblank=0 lo
glevel=7 ubootpart=a1fc9015-01 usb-storage.quirks=   cgroup_enable=cpuset cgroup
_memory=1 cgroup_enable=memory swapaccount=1
, linear)
linear)
data, 4656K rodata, 1024K init, 542K bss, 116584K reserved, 131072K cma-reserved
fies.
0
0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
h crng_init=0
 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 43980
46511097ns
[    0.001577] Console: colour dummy device 80x25
[    0.002576] printk: console [tty1] enabled
[    0.002699] Calibrating delay loop (skipped), value calculated using timer fr
equency.. 48.00 BogoMIPS (lpj=96000)
[    0.002741] pid_max: default: 32768 minimum: 301
[    0.002895] LSM: Security Framework initializing
[    0.002944] Yama: becoming mindful.
[    0.003132] AppArmor: AppArmor initialized
[    0.003231] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, line
ar)
[    0.003283] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes,
 linear)
[    0.003365] *** VALIDATE tmpfs ***
[    0.004070] *** VALIDATE proc ***
[    0.004398] *** VALIDATE cgroup1 ***
[    0.004423] *** VALIDATE cgroup2 ***
[    0.027796] ASID allocator initialised with 32768 entries
[    0.035792] rcu: Hierarchical SRCU implementation.
[    0.045955] Platform MSI: interrupt-controller@fee20000 domain created
[    0.046395] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee2
0000 domain created
[    0.048673] EFI services will not be available.
[    0.056488] smp: Bringing up secondary CPUs ...
[    0.088729] Detected VIPT I-cache on CPU1
[    0.088766] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.088783] GICv3: CPU1: using allocated LPI pending table @0x00000000f6c6000
0
[    0.088831] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.120820] Detected VIPT I-cache on CPU2
[    0.120849] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.120864] GICv3: CPU2: using allocated LPI pending table @0x00000000f6c7000
0
[    0.120899] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.152933] Detected VIPT I-cache on CPU3
[    0.152961] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.152976] GICv3: CPU3: using allocated LPI pending table @0x00000000f6d0000
0
[    0.153009] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.185064] CPU features: detected: EL2 vector hardening
[    0.185074] ARM_SMCCC_ARCH_WORKAROUND_1 missing from firmware
[    0.185083] Detected PIPT I-cache on CPU4
[    0.185114] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000
[    0.185128] GICv3: CPU4: using allocated LPI pending table @0x00000000f6d1000
0
[    0.185165] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
[    0.217182] Detected PIPT I-cache on CPU5
[    0.217209] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000
[    0.217222] GICv3: CPU5: using allocated LPI pending table @0x00000000f6d2000
0
[    0.217250] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
[    0.217385] smp: Brought up 1 node, 6 CPUs
[    0.217779] SMP: Total of 6 processors activated.
[    0.217802] CPU features: detected: 32-bit EL0 Support
[    0.217825] CPU features: detected: CRC32 instructions
[    0.219053] CPU: All CPU(s) started at EL2
[    0.219116] alternatives: patching kernel code
[    0.222426] devtmpfs: initialized
[    0.242462] Registered cp15_barrier emulation handler
[    0.242506] Registered setend emulation handler
[    0.243045] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma
x_idle_ns: 7645041785100000 ns
[    0.243131] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.249219] xor: measuring software checksum speed
[    0.289292]    8regs     :  1188.000 MB/sec
[    0.329318]    32regs    :  2756.000 MB/sec
[    0.369394]    arm64_neon:  2345.000 MB/sec
[    0.369409] xor: using function: 32regs (2756.000 MB/sec)
[    0.369518] pinctrl core: initialized pinctrl subsystem
[    0.370398] DMI not present or invalid.
[    0.370787] NET: Registered protocol family 16
[    0.373865] DMA: preallocated 2048 KiB pool for atomic allocations
[    0.373892] audit: initializing netlink subsys (disabled)
[    0.374119] audit: type=2000 audit(0.372:1): state=initialized audit_enabled=
0 res=1
[    0.375501] cpuidle: using governor menu
[    0.375837] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.377171] Serial: AMBA PL011 UART driver
[    0.417267] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.417291] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.417308] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.417325] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.427654] cryptd: max_cpu_qlen set to 1000
[    0.513770] raid6: neonx8   gen()  1330 MB/s
[    0.581906] raid6: neonx8   xor()  1189 MB/s
[    0.650097] raid6: neonx4   gen()  1022 MB/s
[    0.718191] raid6: neonx4   xor()   995 MB/s
[    0.786346] raid6: neonx2   gen()   927 MB/s
[    0.854502] raid6: neonx2   xor()  1082 MB/s
[    0.922630] raid6: neonx1   gen()   718 MB/s
[    0.990801] raid6: neonx1   xor()   832 MB/s
[    1.058945] raid6: int64x8  gen()   708 MB/s
[    1.127097] raid6: int64x8  xor()   532 MB/s
[    1.195299] raid6: int64x4  gen()   640 MB/s
[    1.263368] raid6: int64x4  xor()   554 MB/s
[    1.331582] raid6: int64x2  gen()   472 MB/s
[    1.399620] raid6: int64x2  xor()   500 MB/s
[    1.467802] raid6: int64x1  gen()   344 MB/s
[    1.535931] raid6: int64x1  xor()   338 MB/s
[    1.535945] raid6: using algorithm neonx8 gen() 1330 MB/s
[    1.535958] raid6: .... xor() 1189 MB/s, rmw enabled
[    1.535972] raid6: using neon recovery algorithm
[    1.537568] vcc3v3_pcie: supplied by dc_12v
[    1.538537] vcc_sys: supplied by dc_12v
[    1.539016] iommu: Default domain type: Translated
[    1.541304] vgaarb: loaded
[    1.541784] SCSI subsystem initialized
[    1.542260] usbcore: registered new interface driver usbfs
[    1.542320] usbcore: registered new interface driver hub
[    1.542423] usbcore: registered new device driver usb
[    1.543007] pps_core: LinuxPPS API ver. 1 registered
[    1.543023] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome
[    1.543052] PTP clock support registered
[    1.543331] EDAC MC: Ver: 3.0.0
[    1.544336] NetLabel: Initializing
[    1.544352] NetLabel:  domain hash size = 128
[    1.544365] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    1.544437] NetLabel:  unlabeled traffic allowed by default
[    1.544901] clocksource: Switched to clocksource arch_sys_counter
[    1.545119] VFS: Disk quotas dquot_6.6.0
[    1.545198] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.545298] *** VALIDATE ramfs ***
[    1.545321] *** VALIDATE hugetlbfs ***
[    1.545990] AppArmor: AppArmor Filesystem Enabled
[    1.554950] thermal_sys: Registered thermal governor 'fair_share'
[    1.554954] thermal_sys: Registered thermal governor 'bang_bang'
[    1.554975] thermal_sys: Registered thermal governor 'step_wise'
[    1.554990] thermal_sys: Registered thermal governor 'user_space'
[    1.555005] thermal_sys: Registered thermal governor 'power_allocator'
[    1.555580] NET: Registered protocol family 2
[    1.556334] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 3276
8 bytes, linear)
[    1.556517] TCP established hash table entries: 32768 (order: 6, 262144 bytes
, linear)
[    1.557088] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linea
r)
[    1.557767] TCP: Hash tables configured (established 32768 bind 32768)
[    1.557947] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    1.558115] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    1.558436] NET: Registered protocol family 1
[    1.558484] PCI: CLS 0 bytes, default 64
[    1.558689] Trying to unpack rootfs image as initramfs...
[    1.831040] Freeing initrd memory: 16244K
[    1.832125] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counte
rs available
[    1.832496] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counte
rs available
[    1.833016] kvm [1]: IPA Size Limit: 40bits
[    1.833645] kvm [1]: vgic-v2@fff20000
[    1.833687] kvm [1]: GIC system register CPU interface enabled
[    1.833908] kvm [1]: vgic interrupt IRQ10
[    1.834161] kvm [1]: Hyp mode initialized successfully
[    2.147668] Initialise system trusted keyrings
[    2.147725] Key type blacklist registered
[    2.147907] workingset: timestamp_bits=44 max_order=20 bucket_order=0
[    2.153655] zbud: loaded
[    2.155441] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    2.156289] fuse: init (API version 7.31)
[    2.156385] *** VALIDATE fuse ***
[    2.156404] *** VALIDATE fuse ***
[    2.157685] Platform Keyring initialized
[    2.193309] Key type asymmetric registered
[    2.193334] Asymmetric key parser 'x509' registered
[    2.193399] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2
46)
[    2.193634] io scheduler mq-deadline registered
[    2.193654] io scheduler kyber registered
[    2.193822] io scheduler bfq registered
[    2.196856] vcc5v0_host: supplied by vcc_sys
[    2.208594] rockchip-pcie f8000000.pcie: no vpcie12v regulator found
[    2.208635] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[    2.208667] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[    2.208697] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[    2.760942] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[    2.761040] rockchip-pcie: probe of f8000000.pcie failed with error -110
[    2.766669] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-2
41330
[    2.766697] dma-pl330 ff6d0000.dma-controller:       DBUFF-32x8bytes Num_Chan
s-6 Num_Peri-12 Num_Events-12
[    2.767923] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-2
41330
[    2.767949] dma-pl330 ff6e0000.dma-controller:       DBUFF-128x8bytes Num_Cha
ns-8 Num_Peri-20 Num_Events-16
[    2.771150] pwm-regulator: supplied by regulator-dummy
[    2.771413] vcc3v3_sys: supplied by vcc_sys
[    2.772563] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    2.775440] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 38, base_baud =
[    2.776235] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 39, base_baud =
[    2.887994] printk: console [ttyS2] enabled
[    2.889464] Serial: AMBA driver
[    2.891001] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    2.902224] loop: module loaded
[    2.906946] libphy: Fixed MDIO Bus: probed
[    2.907625] tun: Universal TUN/TAP device driver, 1.6
[    2.909080] thunder_xcv, ver 1.0
[    2.909412] thunder_bgx, ver 1.0
[    2.909748] nicpf, ver 1.0
[    2.910955] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    2.911475] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    2.912045] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.6.0-k
[    2.912665] igb: Copyright (c) 2007-2014 Intel Corporation.
[    2.913219] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version
 2.4.0-k
[    2.913916] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    2.914699] sky2: driver version 1.30
[    2.915648] VFIO - User Level meta-driver version: 0.3
[    2.922204] OF: graph: no port node found in /syscon@ff770000/usb2-phy@e450/o
tg-port
[    2.930248] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.930851] ehci-pci: EHCI PCI platform driver
[    2.931282] ehci-platform: EHCI generic platform driver
[    2.933983] ehci-platform fe380000.usb: EHCI Host Controller
[    2.934509] ehci-platform fe380000.usb: new USB bus registered, assigned bus
number 1
[    2.935335] ehci-platform fe380000.usb: irq 31, io mem 0xfe380000
[    2.948934] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[    2.949697] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bc
dDevice= 5.04
[    2.950437] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=
1
[    2.951084] usb usb1: Product: EHCI Host Controller
[    2.951524] usb usb1: Manufacturer: Linux 5.4.43-rockchip64 ehci_hcd
[    2.952093] usb usb1: SerialNumber: fe380000.usb
[    2.953037] hub 1-0:1.0: USB hub found
[    2.953408] hub 1-0:1.0: 1 port detected
[    2.956282] ehci-platform fe3c0000.usb: EHCI Host Controller
[    2.956805] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus
number 2
[    2.957636] ehci-platform fe3c0000.usb: irq 33, io mem 0xfe3c0000
[    2.972930] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[    2.973705] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bc
dDevice= 5.04
[    2.974446] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=
1
[    2.975092] usb usb2: Product: EHCI Host Controller
[    2.975530] usb usb2: Manufacturer: Linux 5.4.43-rockchip64 ehci_hcd
[    2.976099] usb usb2: SerialNumber: fe3c0000.usb
[    2.976993] hub 2-0:1.0: USB hub found
[    2.977365] hub 2-0:1.0: 1 port detected
[    2.978299] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.978866] ohci-pci: OHCI PCI platform driver
[    2.979308] ohci-platform: OHCI generic platform driver
[    2.980006] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[    2.980620] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus
number 3
[    2.981444] ohci-platform fe3a0000.usb: irq 32, io mem 0xfe3a0000
[    3.045223] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bc
dDevice= 5.04
[    3.045964] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=
1
[    3.046610] usb usb3: Product: Generic Platform OHCI controller
[    3.047141] usb usb3: Manufacturer: Linux 5.4.43-rockchip64 ohci_hcd
[    3.047708] usb usb3: SerialNumber: fe3a0000.usb
[    3.048595] hub 3-0:1.0: USB hub found
[    3.048997] hub 3-0:1.0: 1 port detected
[    3.049823] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[    3.050436] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus
number 4
[    3.051232] ohci-platform fe3e0000.usb: irq 34, io mem 0xfe3e0000
[    3.113119] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bc
dDevice= 5.04
[    3.113860] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=
1
[    3.114507] usb usb4: Product: Generic Platform OHCI controller
[    3.115038] usb usb4: Manufacturer: Linux 5.4.43-rockchip64 ohci_hcd
[    3.115605] usb usb4: SerialNumber: fe3e0000.usb
[    3.116482] hub 4-0:1.0: USB hub found
[    3.116853] hub 4-0:1.0: 1 port detected
[    3.118435] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.118943] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus nu
mber 5
[    3.119776] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110
[    3.120631] xhci-hcd xhci-hcd.0.auto: irq 227, io mem 0xfe800000
[    3.121557] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bc
dDevice= 5.04
[    3.122298] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=
1
[    3.122945] usb usb5: Product: xHCI Host Controller
[    3.123385] usb usb5: Manufacturer: Linux 5.4.43-rockchip64 xhci-hcd
[    3.123954] usb usb5: SerialNumber: xhci-hcd.0.auto
[    3.124846] hub 5-0:1.0: USB hub found
[    3.125237] hub 5-0:1.0: 1 port detected
[    3.125879] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.126381] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus nu
mber 6
[    3.127079] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    3.127724] usb usb6: We don't know the algorithms for LPM for this host, dis
abling LPM.
[    3.128574] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bc
dDevice= 5.04
[    3.129330] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=
1
[    3.129976] usb usb6: Product: xHCI Host Controller
[    3.130416] usb usb6: Manufacturer: Linux 5.4.43-rockchip64 xhci-hcd
[    3.130983] usb usb6: SerialNumber: xhci-hcd.0.auto
[    3.131872] hub 6-0:1.0: USB hub found
[    3.132242] hub 6-0:1.0: 1 port detected
[    3.133073] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    3.133579] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus nu
mber 7
[    3.134410] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe64 hci version 0x110
[    3.135291] xhci-hcd xhci-hcd.1.auto: irq 228, io mem 0xfe900000
[    3.136184] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bc
dDevice= 5.04
[    3.136942] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=
1
[    3.137589] usb usb7: Product: xHCI Host Controller
[    3.138030] usb usb7: Manufacturer: Linux 5.4.43-rockchip64 xhci-hcd
[    3.138598] usb usb7: SerialNumber: xhci-hcd.1.auto
[    3.139476] hub 7-0:1.0: USB hub found
[    3.139852] hub 7-0:1.0: 1 port detected
[    3.140494] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    3.141022] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus nu
mber 8
[    3.141715] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[    3.142360] usb usb8: We don't know the algorithms for LPM for this host, dis
abling LPM.
[    3.143204] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bc
dDevice= 5.04
[    3.143943] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=
1
[    3.144589] usb usb8: Product: xHCI Host Controller
[    3.145044] usb usb8: Manufacturer: Linux 5.4.43-rockchip64 xhci-hcd
[    3.145612] usb usb8: SerialNumber: xhci-hcd.1.auto
[    3.146496] hub 8-0:1.0: USB hub found
[    3.146873] hub 8-0:1.0: 1 port detected
[    3.147712] usbcore: registered new interface driver usb-storage
[    3.150730] mousedev: PS/2 mouse device common for all mice
[    3.152408] i2c /dev entries driver
[    3.155389] rk808 0-001b: chip id: 0x0
[    3.159845] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    3.160421] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    3.161073] DCDC_REG1: supplied by vcc_sys
[    3.162322] DCDC_REG2: supplied by vcc_sys
[    3.163235] DCDC_REG3: supplied by vcc_sys
[    3.163850] DCDC_REG4: supplied by vcc_sys
[    3.164802] LDO_REG1: supplied by vcc_sys
[    3.166420] LDO_REG2: supplied by vcc_sys
[    3.166976] vcc2v8_dvp: Bringing 3000000uV into 2800000-2800000uV
[    3.168386] LDO_REG3: supplied by vcc_sys
[    3.169857] LDO_REG4: supplied by vcc_sys
[    3.171322] LDO_REG5: supplied by vcc_sys
[    3.172634] LDO_REG6: supplied by vcc_sys
[    3.174127] LDO_REG7: supplied by vcc_sys
[    3.175439] LDO_REG8: supplied by vcc_sys
This is strange - "and totally easy going ".
After starting the board with bullseye 4.4.213 SD card
and then right away starting with fresh 5.4.43-rockchip64 SD card then it all of a sudden did boot up.
Then armbian-config - sytem - boot and flash to emmc - but 5.4.43 does not boot now from emmc- same UART messages as from the SD card.
Edit:
Did boot from 4.4.213 sd card, shut down, remove sd card, reset button, stop u-boot - run bootcmd_mmc1, and 5.4.43 did boot up from emmc.  apt update; apt upgrde and reboot now and reboots so it is working.
¾ÛÃÂBÏp¢ÿß߱ÿÅãppÿ¸â<f¯  * ÿü~|þ8ñäÎ%Î# @!#BR$èÈ DDR Vers                       i
on 1.24 20191016
In
256B stride
OUT
CPUId = 0x0
SdmmcInit=2 0
BootCapSize=100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 67430
SecureMode = 0
recovery gpt...
recovery gpt fail!
No find bl30.bin
No find bl32.bin
RunBL31 0x40000
INFO:    SPSR = 0x3c9
Reset cause: POR
DRAM:  3.9 GiB
PMIC:  RK808
In:    serial@ff1a0000
=> mmc list
dwmmc@fe320000: 1
sdhci@fe330000: 0 (eMMC)
=> run bootcmd_mmc1
Card did not respond to voltage select!
=> run bootcmd_mmc0
Scanning mmc 0:1...
2940 bytes read in 18 ms (159.2 KiB/s)
Boot script loaded from mmc 0
151 bytes read in 13 ms (10.7 KiB/s)
16635430 bytes read in 1598 ms (9.9 MiB/s)
19601920 bytes read in 1877 ms (10 MiB/s)
74464 bytes read in 36 ms (2 MiB/s)
2698 bytes read in 38 ms (69.3 KiB/s)
   Image Name:   uInitrd
Starting kernel ...
[    0.000000] Kernel command line: root=UUID=87943fe2-4952-4e4e-9ca7-f46b0661c6
96 rootwait rootfstype=ext4 console=ttyS2,1500000 console=tty1 consoleblank=0 lo
glevel=7 ubootpart=5b6d7869-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:
u   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
, linear)
linear)
fies.
0
h crng_init=0
46511097ns
[    0.001478] Console: colour dummy device 80x25
[    0.002479] printk: console [tty1] enabled
[    0.002599] Calibrating delay loop (skipped), value calculated using timer fr
[    0.002641] pid_max: default: 32768 minimum: 301
[    0.002795] LSM: Security Framework initializing
[    0.002844] Yama: becoming mindful.
[    0.003033] AppArmor: AppArmor initialized
[    0.003130] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, line
ar)
[    0.003183] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes,
 linear)
[    0.003266] *** VALIDATE tmpfs ***
[    0.003971] *** VALIDATE proc ***
[    0.004301] *** VALIDATE cgroup1 ***
[    0.004327] *** VALIDATE cgroup2 ***
[    0.027785] ASID allocator initialised with 32768 entries
[    0.035780] rcu: Hierarchical SRCU implementation.
[    0.045945] Platform MSI: interrupt-controller@fee20000 domain created
[    0.046365] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee2
0000 domain created
[    0.048486] EFI services will not be available.
[    0.056316] smp: Bringing up secondary CPUs ...
[    0.088554] Detected VIPT I-cache on CPU1
[    0.088591] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.088608] GICv3: CPU1: using allocated LPI pending table @0x00000000f6c6000
0
[    0.088656] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.120645] Detected VIPT I-cache on CPU2
[    0.120675] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.120689] GICv3: CPU2: using allocated LPI pending table @0x00000000f6c7000
0
[    0.120724] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.152759] Detected VIPT I-cache on CPU3
[    0.152787] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.152801] GICv3: CPU3: using allocated LPI pending table @0x00000000f6d0000
0
[    0.152833] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    5.353148] CPU4: failed to come online
[    5.353378] CPU4: failed in unknown state : 0x0
[   10.481558] CPU5: failed to come online
[   10.481583] CPU5: failed in unknown state : 0x0
[   10.481680] smp: Brought up 1 node, 4 CPUs
[   10.481702] SMP: Total of 4 processors activated.
[   10.481726] CPU features: detected: 32-bit EL0 Support
[   10.481750] CPU features: detected: CRC32 instructions
[   10.482774] CPU: All CPU(s) started at EL2
[   10.482822] alternatives: patching kernel code
[   10.485840] devtmpfs: initialized
[   10.505896] Registered cp15_barrier emulation handler
[   10.505941] Registered setend emulation handler
[   10.506458] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma
[   10.506543] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[   10.512557] xor: measuring software checksum speed
[   10.549784]    8regs     :  1187.000 MB/sec
[   10.589864]    32regs    :  1362.000 MB/sec
[   10.629948]    arm64_neon:  1126.000 MB/sec
[   10.629971] xor: using function: 32regs (1362.000 MB/sec)
[   10.630052] pinctrl core: initialized pinctrl subsystem
[   10.631346] DMI not present or invalid.
[   10.631843] NET: Registered protocol family 16
[   10.639138] DMA: preallocated 2048 KiB pool for atomic allocations
[   10.639178] audit: initializing netlink subsys (disabled)
[   10.639439] audit: type=2000 audit(10.620:1): state=initialized audit_enabled
=0 res=1
[   10.641563] cpuidle: using governor menu
[   10.642175] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[   10.644193] Serial: AMBA PL011 UART driver
[   10.702390] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[   10.702432] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[   10.702460] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[   10.702486] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[   10.712650] cryptd: max_cpu_qlen set to 1000
[   10.798374] raid6: neonx8   gen()   759 MB/s
[   10.866518] raid6: neonx8   xor()   727 MB/s
[   10.934688] raid6: neonx4   gen()   739 MB/s
[   11.002811] raid6: neonx4   xor()   709 MB/s
[   11.070952] raid6: neonx2   gen()   565 MB/s
[   11.139128] raid6: neonx2   xor()   588 MB/s
[   11.207392] raid6: neonx1   gen()   378 MB/s
[   11.275472] raid6: neonx1   xor()   445 MB/s
[   11.343618] raid6: int64x8  gen()   582 MB/s
[   11.411818] raid6: int64x8  xor()   380 MB/s
[   11.480037] raid6: int64x4  gen()   492 MB/s
[   11.548137] raid6: int64x4  xor()   370 MB/s
[   11.616326] raid6: int64x2  gen()   338 MB/s
[   11.684502] raid6: int64x2  xor()   301 MB/s
[   11.752841] raid6: int64x1  gen()   221 MB/s
[   11.820837] raid6: int64x1  xor()   229 MB/s
[   11.820859] raid6: using algorithm neonx8 gen() 759 MB/s
[   11.820880] raid6: .... xor() 727 MB/s, rmw enabled
[   11.820901] raid6: using neon recovery algorithm
[   11.823191] vcc3v3_pcie: supplied by dc_12v
[   11.824549] vcc_sys: supplied by dc_12v
[   11.825279] iommu: Default domain type: Translated
[   11.828342] vgaarb: loaded
[   11.829111] SCSI subsystem initialized
[   11.829776] usbcore: registered new interface driver usbfs
[   11.829874] usbcore: registered new interface driver hub
[   11.830022] usbcore: registered new device driver usb
[   11.830874] pps_core: LinuxPPS API ver. 1 registered
[   11.830898] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome
[   11.830955] PTP clock support registered
[   11.831305] EDAC MC: Ver: 3.0.0
[   11.832701] NetLabel: Initializing
[   11.832725] NetLabel:  domain hash size = 128
[   11.832744] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[   11.832903] NetLabel:  unlabeled traffic allowed by default
[   11.833616] clocksource: Switched to clocksource arch_sys_counter
[   11.833999] VFS: Disk quotas dquot_6.6.0
[   11.834111] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[   11.834241] *** VALIDATE ramfs ***
[   11.834278] *** VALIDATE hugetlbfs ***
[   11.835272] AppArmor: AppArmor Filesystem Enabled
[   11.845901] thermal_sys: Registered thermal governor 'fair_share'
[   11.845907] thermal_sys: Registered thermal governor 'bang_bang'
[   11.845939] thermal_sys: Registered thermal governor 'step_wise'
[   11.845963] thermal_sys: Registered thermal governor 'user_space'
[   11.845986] thermal_sys: Registered thermal governor 'power_allocator'
[   11.846804] NET: Registered protocol family 2
[   11.847765] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 3276
8 bytes, linear)
[   11.847951] TCP established hash table entries: 32768 (order: 6, 262144 bytes
, linear)
[   11.848516] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linea
r)
[   11.849268] TCP: Hash tables configured (established 32768 bind 32768)
[   11.849490] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[   11.849760] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[   11.850213] NET: Registered protocol family 1
[   11.850271] PCI: CLS 0 bytes, default 64
[   11.850578] Trying to unpack rootfs image as initramfs...
[   12.269522] Freeing initrd memory: 16244K
[   12.270810] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counte
rs available
[   12.271032] hw perfevents: /pmu_a72: failed to probe PMU!
[   12.271059] hw perfevents: /pmu_a72: failed to register PMU devices!
[   12.271673] kvm [1]: IPA Size Limit: 40bits
[   12.272512] kvm [1]: vgic-v2@fff20000
[   12.272556] kvm [1]: GIC system register CPU interface enabled
[   12.272714] kvm [1]: vgic interrupt IRQ10
[   12.272910] kvm [1]: Hyp mode initialized successfully
[   12.722424] Initialise system trusted keyrings
[   12.722515] Key type blacklist registered
[   12.722779] workingset: timestamp_bits=44 max_order=20 bucket_order=0
[   12.731806] zbud: loaded
[   12.734561] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[   12.735770] fuse: init (API version 7.31)
[   12.735913] *** VALIDATE fuse ***
[   12.735941] *** VALIDATE fuse ***
[   12.737780] Platform Keyring initialized
[   12.780707] Key type asymmetric registered
[   12.780742] Asymmetric key parser 'x509' registered
[   12.780836] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2
46)
[   12.781117] io scheduler mq-deadline registered
[   12.781143] io scheduler kyber registered
[   12.781406] io scheduler bfq registered
[   12.785439] vcc5v0_host: supplied by vcc_sys
[   12.801520] rockchip-pcie f8000000.pcie: no vpcie12v regulator found
[   12.801579] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[   12.801648] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[   12.801694] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[   13.329694] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[   13.329838] rockchip-pcie: probe of f8000000.pcie failed with error -110
[   13.337376] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-2
41330
[   13.337418] dma-pl330 ff6d0000.dma-controller:       DBUFF-32x8bytes Num_Chan
[   13.339407] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-2
41330
[   13.339446] dma-pl330 ff6e0000.dma-controller:       DBUFF-128x8bytes Num_Cha
[   13.343925] pwm-regulator: supplied by regulator-dummy
[   13.344285] vcc3v3_sys: supplied by vcc_sys
[   13.345920] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[   13.349781] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 38, base_baud =
[   13.350885] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 39, base_baud =
[   13.459889] printk: console [ttyS2] enabled
[   13.461854] Serial: AMBA driver
[   13.463791] cacheinfo: Unable to detect cache hierarchy for CPU 0
[   13.479672] loop: module loaded
[   13.485930] libphy: Fixed MDIO Bus: probed
[   13.486829] tun: Universal TUN/TAP device driver, 1.6
[   13.488624] thunder_xcv, ver 1.0
[   13.488981] thunder_bgx, ver 1.0
[   13.489349] nicpf, ver 1.0
[   13.490903] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[   13.491434] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[   13.492035] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.6.0-k
[   13.492664] igb: Copyright (c) 2007-2014 Intel Corporation.
[   13.493225] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version
 2.4.0-k
[   13.493952] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[   13.494843] sky2: driver version 1.30
[   13.495990] VFIO - User Level meta-driver version: 0.3
[   13.503369] OF: graph: no port node found in /syscon@ff770000/usb2-phy@e450/o
tg-port
[   13.513351] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   13.514001] ehci-pci: EHCI PCI platform driver
[   13.514468] ehci-platform: EHCI generic platform driver
[   13.517283] ehci-platform fe380000.usb: EHCI Host Controller
[   13.517845] ehci-platform fe380000.usb: new USB bus registered, assigned bus
number 1
[   13.518719] ehci-platform fe380000.usb: irq 31, io mem 0xfe380000
[   13.533649] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[   13.534522] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bc
dDevice= 5.04
[   13.535276] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=
1
[   13.535935] usb usb1: Product: EHCI Host Controller
[   13.536384] usb usb1: Manufacturer: Linux 5.4.43-rockchip64 ehci_hcd
[   13.536964] usb usb1: SerialNumber: fe380000.usb
[   13.538079] hub 1-0:1.0: USB hub found
[   13.538467] hub 1-0:1.0: 1 port detected
[   13.541564] ehci-platform fe3c0000.usb: EHCI Host Controller
[   13.542123] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus
number 2
[   13.542995] ehci-platform fe3c0000.usb: irq 33, io mem 0xfe3c0000
[   13.557646] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[   13.558483] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bc
dDevice= 5.04
[   13.559238] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=
1
[   13.559896] usb usb2: Product: EHCI Host Controller
[   13.560347] usb usb2: Manufacturer: Linux 5.4.43-rockchip64 ehci_hcd
[   13.560926] usb usb2: SerialNumber: fe3c0000.usb
[   13.561965] hub 2-0:1.0: USB hub found
[   13.562362] hub 2-0:1.0: 1 port detected
[   13.563557] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   13.564139] ohci-pci: OHCI PCI platform driver
[   13.564626] ohci-platform: OHCI generic platform driver
[   13.565415] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[   13.566071] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus
number 3
[   13.566928] ohci-platform fe3a0000.usb: irq 32, io mem 0xfe3a0000
[   13.629888] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bc
dDevice= 5.04
[   13.630644] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=
1
[   13.631302] usb usb3: Product: Generic Platform OHCI controller
[   13.631844] usb usb3: Manufacturer: Linux 5.4.43-rockchip64 ohci_hcd
[   13.632424] usb usb3: SerialNumber: fe3a0000.usb
[   13.633458] hub 3-0:1.0: USB hub found
[   13.633868] hub 3-0:1.0: 1 port detected
[   13.634887] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[   13.635524] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus
number 4
[   13.636414] ohci-platform fe3e0000.usb: irq 34, io mem 0xfe3e0000
[   13.697992] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bc
dDevice= 5.04
[   13.698747] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=
1
[   13.699406] usb usb4: Product: Generic Platform OHCI controller
[   13.699947] usb usb4: Manufacturer: Linux 5.4.43-rockchip64 ohci_hcd
[   13.700527] usb usb4: SerialNumber: fe3e0000.usb
[   13.701570] hub 4-0:1.0: USB hub found
[   13.701978] hub 4-0:1.0: 1 port detected
[   13.704085] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[   13.704609] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus nu
mber 5
[   13.705508] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110
[   13.706405] xhci-hcd xhci-hcd.0.auto: irq 227, io mem 0xfe800000
[   13.707498] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bc
dDevice= 5.04
[   13.708254] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=
1
[   13.708912] usb usb5: Product: xHCI Host Controller
[   13.709361] usb usb5: Manufacturer: Linux 5.4.43-rockchip64 xhci-hcd
[   13.709961] usb usb5: SerialNumber: xhci-hcd.0.auto
[   13.711021] hub 5-0:1.0: USB hub found
[   13.711417] hub 5-0:1.0: 1 port detected
[   13.712224] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[   13.712741] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus nu
mber 6
[   13.713449] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[   13.714152] usb usb6: We don't know the algorithms for LPM for this host, dis
abling LPM.
[   13.715055] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bc
dDevice= 5.04
[   13.715808] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=
1
[   13.716467] usb usb6: Product: xHCI Host Controller
[   13.716915] usb usb6: Manufacturer: Linux 5.4.43-rockchip64 xhci-hcd
[   13.717495] usb usb6: SerialNumber: xhci-hcd.0.auto
[   13.718560] hub 6-0:1.0: USB hub found
[   13.718948] hub 6-0:1.0: 1 port detected
[   13.719980] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[   13.720503] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus nu
mber 7
[   13.721371] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe64 hci version 0x110
[   13.722314] xhci-hcd xhci-hcd.1.auto: irq 228, io mem 0xfe900000
[   13.723368] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bc
dDevice= 5.04
[   13.724122] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=
1
[   13.724781] usb usb7: Product: xHCI Host Controller
[   13.725230] usb usb7: Manufacturer: Linux 5.4.43-rockchip64 xhci-hcd
[   13.725829] usb usb7: SerialNumber: xhci-hcd.1.auto
[   13.726869] hub 7-0:1.0: USB hub found
[   13.727256] hub 7-0:1.0: 1 port detected
[   13.728028] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[   13.728544] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus nu
mber 8
[   13.729252] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[   13.729959] usb usb8: We don't know the algorithms for LPM for this host, dis
abling LPM.
[   13.730869] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bc
dDevice= 5.04
[   13.731622] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=
1
[   13.732281] usb usb8: Product: xHCI Host Controller
[   13.732729] usb usb8: Manufacturer: Linux 5.4.43-rockchip64 xhci-hcd
[   13.733309] usb usb8: SerialNumber: xhci-hcd.1.auto
[   13.734365] hub 8-0:1.0: USB hub found
[   13.734752] hub 8-0:1.0: 1 port detected
[   13.735853] usbcore: registered new interface driver usb-storage
[   13.739973] mousedev: PS/2 mouse device common for all mice
[   13.742174] i2c /dev entries driver
[   13.745866] rk808 0-001b: chip id: 0x0
[   13.751218] rk808-regulator rk808-regulator: there is no dvs0 gpio
[   13.751820] rk808-regulator rk808-regulator: there is no dvs1 gpio
[   13.752477] DCDC_REG1: supplied by vcc_sys
[   13.753852] DCDC_REG2: supplied by vcc_sys
[   13.754891] DCDC_REG3: supplied by vcc_sys
[   13.755642] DCDC_REG4: supplied by vcc_sys
[   13.756685] LDO_REG1: supplied by vcc_sys
[   13.758412] LDO_REG2: supplied by vcc_sys
[   13.758999] vcc2v8_dvp: Bringing 3000000uV into 2800000-2800000uV
[   13.760515] LDO_REG3: supplied by vcc_sys
[   13.762068] LDO_REG4: supplied by vcc_sys
[   13.763678] LDO_REG5: supplied by vcc_sys
[   13.765108] LDO_REG6: supplied by vcc_sys
[   13.766700] LDO_REG7: supplied by vcc_sys
[   13.768172] LDO_REG8: supplied by vcc_sys
[   13.769936] SWITCH_REG1: supplied by vcc3v3_sys
[   13.770731] SWITCH_REG2: supplied by vcc3v3_sys
[   13.775121] rk808-rtc rk808-rtc: registered as rtc0
[   13.776318] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[   13.776970] fan53555-reg: supplied by vcc_sys
[   13.778528] vcc1v8_s3: supplied by vcc_1v8
[   13.779703] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[   13.780351] fan53555-reg: supplied by vcc_sys
[   13.791373] sdhci: Secure Digital Host Controller Interface driver
[   13.791946] sdhci: Copyright(c) Pierre Ossman
[   13.792376] Synopsys Designware Multimedia Card Interface Driver
[   13.794713] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode
[   13.795401] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[   13.796026] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[   13.796630] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 28,32 bit
 host data width,256 deep fifo
[   13.797925] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[   13.798472] mmc_host mmc0: card is non-removable.
[   13.812181] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz,
actual 400000HZ div = 0)
[   13.826531] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode
[   13.827220] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[   13.827845] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[   13.828449] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 29,32 bit
[   13.829543] dwmmc_rockchip fe320000.dwmmc: Got CD GPIO
[   13.843132] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz,
[   13.848272] random: fast init done
[   13.857434] sdhci-pltfm: SDHCI platform and OF driver helper
[   13.859051] mmc0: queuing unknown CIS tuple 0x80 (2 bytes)
[   13.859928] mmc2: CQHCI version 5.10
[   13.861148] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[   13.863266] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[   13.866610] mmc0: queuing unknown CIS tuple 0x80 (7 bytes)
[   13.886306] mmc2: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using A
DMA
[   13.889645] ledtrig-cpu: registered to indicate activity on CPUs
[   13.891246] hidraw: raw HID events driver (C) Jiri Kosina
[   13.891965] usbcore: registered new interface driver usbhid
[   13.892498] usbhid: USB HID core driver
[   13.897655] usb 2-1: new high-speed USB device number 2 using ehci-platform
[   13.898902] NET: Registered protocol family 10
[   13.924205] mmc_host mmc0: Bus speed (slot 0) = 148500000Hz (slot req 1500000
00Hz, actual 148500000HZ div = 0)
[   13.957403] mmc2: Command Queue Engine enabled
[   13.957883] mmc2: new HS400 Enhanced strobe MMC card at address 0001
[   13.958760] Segment Routing with IPv6
[   13.959236] NET: Registered protocol family 17
[   13.959789] 8021q: 802.1Q VLAN Support v1.8
[   13.960255] Key type dns_resolver registered
[   13.961508] registered taskstats version 1
[   13.961931] Loading compiled-in X.509 certificates
[   13.963379] mmcblk2: mmc2:0001 DJNB4R 116 GiB
[   13.964068] mmcblk2boot0: mmc2:0001 DJNB4R partition 1 4.00 MiB
[   13.964902] mmcblk2boot1: mmc2:0001 DJNB4R partition 2 4.00 MiB
[   13.965859] mmcblk2rpmb: mmc2:0001 DJNB4R partition 3 4.00 MiB, chardev (242:
0)
[   13.967930]  mmcblk2: p1
[   13.977234] Loaded X.509 cert 'Build time autogenerated kernel key: eb38ca326
c9339fc39852f9def87df0c9705ea82'
[   13.978362] zswap: loaded using pool lzo/zbud
[   13.978992] Key type ._fscrypt registered
[   13.979364] Key type .fscrypt registered
[   13.982746] Btrfs loaded, crc32c=crc32c-generic
[   13.983295] Key type big_key registered
[   14.010424] Key type encrypted registered
[   14.010853] AppArmor: AppArmor sha1 policy hashing enabled
[   14.066483] usb 2-1: New USB device found, idVendor=1a40, idProduct=0201, bcd
Device= 1.00
[   14.067246] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[   14.067895] usb 2-1: Product: USB 2.0 Hub [MTT]
[   14.069139] hub 2-1:1.0: USB hub found
[   14.069589] hub 2-1:1.0: 7 ports detected
[   14.087240] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[   14.088953] rk808-rtc rk808-rtc: setting system clock to 2021-02-11T14:56:22
UTC (1613055382)
[   14.089755] of_cfs_init
[   14.090021] of_cfs_init: OK
[   14.092089] Freeing unused kernel memory: 1024K
[   14.092621] Run /init as init process
[   14.193818] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 199
[   14.198480] mmc0: new ultra high speed SDR104 SDIO card at address 0001
[   14.369715] usb 2-1.2: new high-speed USB device number 3 using ehci-platform
[   14.478858] usb 2-1.2: New USB device found, idVendor=0bda, idProduct=a811, b
cdDevice= 2.00
[   14.479637] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber
=3
[   14.480308] usb 2-1.2: Product: 802.11ac WLAN Adapter
[   14.480782] usb 2-1.2: Manufacturer: Realtek
[   14.481186] usb 2-1.2: SerialNumber: 00e04c000001
[   14.565668] usb 2-1.3: new high-speed USB device number 4 using ehci-platform
[   14.674477] usb 2-1.3: New USB device found, idVendor=1a40, idProduct=0101, b
cdDevice= 1.11
[   14.675253] usb 2-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber
=0
[   14.675921] usb 2-1.3: Product: USB 2.0 Hub
[   14.677192] hub 2-1.3:1.0: USB hub found
[   14.677736] hub 2-1.3:1.0: 4 ports detected
[   14.719647] pwm-backlight backlight: backlight supply power not found, using
dummy regulator
[   14.799558] rk_gmac-dwmac fe300000.ethernet: IRQ eth_wake_irq not found
[   14.800181] rk_gmac-dwmac fe300000.ethernet: IRQ eth_lpi not found
[   14.805862] rk_gmac-dwmac fe300000.ethernet: PTP uses main clock
[   14.806631] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[   14.807284] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[   14.807806] rk_gmac-dwmac fe300000.ethernet: RX delay(0x11).
[   14.808336] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[   14.809007] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[   14.809683] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[   14.815305] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[   14.816184] rk_gmac-dwmac fe300000.ethernet: User ID: 0x10, Synopsys ID: 0x35
[   14.816854] rk_gmac-dwmac fe300000.ethernet:         DWMAC1000
[   14.817338] rk_gmac-dwmac fe300000.ethernet: DMA HW capability register suppo
rted
[   14.818060] rk_gmac-dwmac fe300000.ethernet: RX Checksum Offload Engine suppo
rted
[   14.818747] rk_gmac-dwmac fe300000.ethernet: COE Type 2
[   14.819226] rk_gmac-dwmac fe300000.ethernet: TX Checksum insertion supported
[   14.819868] rk_gmac-dwmac fe300000.ethernet: Wake-Up On Lan supported
[   14.820510] rk_gmac-dwmac fe300000.ethernet: Normal descriptors
[   14.821059] rk_gmac-dwmac fe300000.ethernet: Ring mode enabled
[   14.821594] rk_gmac-dwmac fe300000.ethernet: Enable RX Mitigation via HW Watc
hdog Timer
[   14.846635] rockchip-vop ff8f0000.vop: Adding to iommu group 1
[   14.851002] rockchip-vop ff900000.vop: Adding to iommu group 2
[   14.875358] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_compo
nent_ops [rockchipdrm])
[   14.882821] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_compo
[   14.884029] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a
 with HDCP (DWC HDMI 2.0 TX PHY)
[   14.886425] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_
rockchip_ops [rockchipdrm])
[   14.887300] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[   14.887899] [drm] No driver support for vblank timestamp query.
[   14.961776] libphy: stmmac: probed
[   14.962128] RTL8211E Gigabit Ethernet stmmac-0:00: attached PHY driver [RTL82
11E Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[   14.963257] RTL8211E Gigabit Ethernet stmmac-0:01: attached PHY driver [RTL82
11E Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[   15.047396] Console: switching to colour frame buffer device 240x67
[   15.085667] usb 2-1.3.2: new full-speed USB device number 5 using ehci-platfo
rm
[   15.265137] rockchip-drm display-subsystem: fb0: rockchipdrmfb frame buffer d
evice
[   15.306453] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem o
n minor 0
[   15.320613] usb 2-1.3.2: language id specifier not provided by device, defaul
ting to English
[   15.330738] usb 2-1.3.2: New USB device found, idVendor=0c45, idProduct=7403,
 bcdDevice= 0.01
[   15.331849] usb 2-1.3.2: New USB device strings: Mfr=1, Product=2, SerialNumb
er=0
[   15.336740] input: HID 0c45:7403 as /devices/platform/fe3c0000.usb/usb2/2-1/2
-1.3/2-1.3.2/2-1.3.2:1.0/0003:0C45:7403.0001/input/input1
[   15.398803] hid-generic 0003:0C45:7403.0001: input,hidraw0: USB HID v1.00 Key
board [HID 0c45:7403] on usb-fe3c0000.usb-1.3.2/input0
[   15.402695] input: HID 0c45:7403 as /devices/platform/fe3c0000.usb/usb2/2-1/2
-1.3/2-1.3.2/2-1.3.2:1.1/0003:0C45:7403.0002/input/input2
[   15.404806] hid-generic 0003:0C45:7403.0002: input,hidraw1: USB HID v1.10 Mou
se [HID 0c45:7403] on usb-fe3c0000.usb-1.3.2/input1
[   15.627509] EXT4-fs (mmcblk2p1): mounted filesystem with ordered data mode. O
pts: (null)
[   15.979843] systemd[1]: Inserted module 'autofs4'
[   16.020445] systemd[1]: systemd 245.4-4ubuntu3.1 running in system mode. (+PA
M +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +
GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-h
ierarchy=hybrid)
[   16.024470] systemd[1]: Detected architecture arm64.
[   16.053245] systemd[1]: Set hostname to <firefly-rk3399>.
[   16.161497] ttyS2 - failed to request DMA
[   16.393479] systemd[1]: /lib/systemd/system/dbus.socket:5: ListenStream= refe
rences a path below legacy directory /var/run/, updating /var/run/dbus/system_bu
s_socket → /run/dbus/system_bus_socket; please update the unit file accordingly.
[   16.543932] systemd[1]: /lib/systemd/system/rk3399-bluetooth.service:11: Supp
ort for option SysVStartPriority= has been removed and it is ignored
[   16.730047] random: systemd: uninitialized urandom read (16 bytes read)
[   16.731359] systemd[1]: system-modprobe.slice: unit configures an IP firewall
, but the local system does not support BPF/cgroup firewalling.
[   16.732985] systemd[1]: (This warning is only shown for the first unit using
IP firewalling.)
[   16.738939] systemd[1]: Created slice system-modprobe.slice.
[   16.740610] random: systemd: uninitialized urandom read (16 bytes read)
[   16.743396] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   16.778539] random: systemd: uninitialized urandom read (16 bytes read)
[   16.797841] systemd[1]: Created slice User and Session Slice.
[   16.833577] systemd[1]: Started Dispatch Password Requests to Console Directo
ry Watch.
[   16.870046] systemd[1]: Started Forward Password Requests to Wall Directory W
atch.
[   16.907799] systemd[1]: Set up automount Arbitrary Executable File Formats Fi
le System Automount Point.
[   16.945259] systemd[1]: Reached target Local Encrypted Volumes.
[   16.982154] systemd[1]: Reached target Remote File Systems.
[   17.018582] systemd[1]: Reached target Slices.
[   17.054546] systemd[1]: Reached target Swap.
[   17.090178] systemd[1]: Reached target System Time Set.
[   17.126701] systemd[1]: Listening on Syslog Socket.
[   17.163008] systemd[1]: Listening on fsck to fsckd communication Socket.
[   17.199169] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   17.236183] systemd[1]: Listening on Journal Audit Socket.
[   17.272265] systemd[1]: Listening on Journal Socket (/dev/log).
[   17.308435] systemd[1]: Listening on Journal Socket.
[   17.343904] systemd[1]: Listening on udev Control Socket.
[   17.378370] systemd[1]: Listening on udev Kernel Socket.
[   17.418757] systemd[1]: Mounting Huge Pages File System...
[   17.458841] systemd[1]: Mounting POSIX Message Queue File System...
[   17.498813] systemd[1]: Mounting Kernel Debug File System...
[   17.532745] systemd[1]: Condition check resulted in Kernel Trace File System
being skipped.
[   17.556694] systemd[1]: Starting Restore / save the current clock...
[   17.596818] systemd[1]: Starting Set the console keyboard layout...
[   17.638194] systemd[1]: Starting Create list of static device nodes for the c
urrent kernel...
[   17.673027] systemd[1]: Condition check resulted in Load Kernel Module drm be
ing skipped.
[   17.680360] systemd[1]: Started Nameserver information manager.
[   17.724100] systemd[1]: Reached target Network (Pre).
[   17.758514] systemd[1]: Condition check resulted in Set Up Additional Binary
Formats being skipped.
[   17.775625] systemd[1]: Condition check resulted in File System Check on Root
 Device being skipped.
[   17.800635] systemd[1]: Starting Load Kernel Modules...
[   17.838722] systemd[1]: Starting Remount Root and Kernel File Systems...
[   17.863140] udc-core: couldn't find an available UDC - added [g_serial] to li
st of pending drivers
[   17.881677] EXT4-fs (mmcblk2p1): re-mounted. Opts: commit=600,errors=remount-
ro
[   17.906210] systemd[1]: Starting udev Coldplug all Devices...
[   17.946937] systemd[1]: Mounted Huge Pages File System.
[   17.977865] systemd[1]: Mounted POSIX Message Queue File System.
[   18.008841] systemd[1]: Mounted Kernel Debug File System.
[   18.043433] systemd[1]: Finished Restore / save the current clock.
[   18.078422] systemd[1]: Finished Create list of static device nodes for the c
urrent kernel.
[   18.118946] systemd[1]: Finished Load Kernel Modules.
[   18.154925] systemd[1]: Finished Remount Root and Kernel File Systems.
[   18.198852] systemd[1]: Mounting FUSE Control File System...
[   18.235650] systemd[1]: Mounting Kernel Configuration File System...
[   18.266675] systemd[1]: Condition check resulted in Rebuild Hardware Database
 being skipped.
[   18.282281] systemd[1]: Condition check resulted in Platform Persistent Stora
ge Archival being skipped.
[   18.303736] systemd[1]: Starting Load/Save Random Seed...
[   18.340354] systemd[1]: Starting Apply Kernel Variables...
[   18.377340] systemd[1]: Starting Create System Users...
[   19.853857] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4356-sdio fo
r chip BCM4356/2
[   22.897752] brcmfmac: brcmf_sdio_readshared: invalid sdpcm_shared address 0xF
E8B0174
[   22.904073] brcmfmac: brcmf_sdio_readshared: unable to obtain sdpcm_shared in
fo: rv=-22 (addr=0xfe8b0174)
Armbian 20.05.1 Focal ttyS2
firefly-rk3399 login: steini
Password:
 _____ _           __ _         ____  _  ____________ ___   ___
|  ___(_)_ __ ___ / _| |_   _  |  _ \| |/ /___ /___ // _ \ / _ \
| |_  | | '__/ _ \ |_| | | | | | |_) | ' /  |_ \ |_ \ (_) | (_) |
|  _| | | | |  __/  _| | |_| | |  _ <| . \ ___) |__) \__, |\__, |
|_|   |_|_|  \___|_| |_|\__, | |_| \_\_|\_\____/____/  /_/   /_/
                        |___/
Welcome to Armbian Focal with Linux 5.4.43-rockchip64
No end-user support: community creations
System load:   2.87 0.78 0.26   Up time:       0 min
Memory usage:  3 % of 3869MB    IP:            192.168.1.17
CPU temp:      34°C
Usage of /:    2% of 113G
Last login: Thu Feb 11 14:07:12 UTC 2021 on ttyS2
To run a command as administrator (user "root"), use "sudo <command>".
See "man sudo_root" for details.
steini@firefly-rk3399:~$
There are always 3 small boot partitions on the mmc and some u-boot there - Boot1: 2019-03-14, version: 1.19
Is it possible to wipe those partitions clean without bricking the firefly-rk3399 board?
mmcblk1boot0 179:64   0     4M  1 disk
mmcblk1boot1 179:96   0     4M  1 disk
mmcblk1rpmb  179:128  0     4M  0 disk
17 часов назад, denni_isl сказал:
 Show the UART log when starting the system with eMMC (when no external SD\USB media is connected)
What system is installed in eMMC ?
16 часов назад, denni_isl сказал:
You can completely erase all eMMC if you run any version of Armbian that sees eMMC when running from an external media.
Now it boots  Armbian 21.02.1 Focal with Linux 5.10.12-rockchip64 successfully every time from emmc.
To those of consern about /dev/mmcblk2boot0 and /dev/mmcblk2boot1 and RPMB partitiones.
This is http://trac.gateworks.com/wiki/MMC some info about hardware partitions on some emmc.   "man mmc-utils" and  "sudo dpkg -L mtd-utils"  and man mmc
UART
DDR Version 1.24 20191016
In
soft reset
SRX
Channel 0: DDR3, 800MHz
Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB
Channel 1: DDR3, 800MHz
256B stride
ch 0 ddrconfig = 0x101, ddrsize = 0x2020
ch 1 ddrconfig = 0x101, ddrsize = 0x2020
pmugrf_os_reg[2] = 0x3AA17AA1, stride = 0xD
OUT
CPUId = 0x0
ChipType = 0x10, 308
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=119276MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 67989
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT 0x3380ec0 signature is wrong
recovery gpt...
recovery gpt fail!
LoadTrust Addr:0x4000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
RunBL31 0x40000
NOTICE:  BL31: v1.3(debug):42583b6
NOTICE:  BL31: Built : 07:55:13, Oct 15 2019
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
WARNING: check_cpu_wfie: 1, 0, 69632, error!
WARNING: check_cpu_wfie: 1, 1, 139264, error!
INFO:    plat_rockchip_pmu_init(1190): pd status e
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE iniK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
Reset cause: RST
Model: Firefly-RK3399 Board
DRAM:  3.9 GiB
PMIC:  RK808
MMC:   dwmmc@fe320000: 1, sdhci@fe330000: 0
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In:    serial@ff1a0000
Out:   serial@ff1a0000
Err:   serial@ff1a0000
Net:   eth0: ethernet@fe300000
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
## Executing script at 00500000
176 bytes read in 14 ms (11.7 KiB/s)
15254210 bytes read in 1467 ms (9.9 MiB/s)
28582400 bytes read in 2729 ms (10 MiB/s)
76162 bytes read in 36 ms (2 MiB/s)
376 bytes read in 28 ms (12.7 KiB/s)
Applying kernel provided DT overlay rockchip-rk3399-opp-2ghz.dtbo
2698 bytes read in 32 ms (82 KiB/s)
Applying kernel provided DT fixup script (rockchip-fixup.scr)
## Executing script at 39000000
## Loading init Ramdisk from Legacy Image at 06000000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Data Size:    15254146 Bytes = 14.5 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 01f00000
   Booting using the fdt blob at 0x1f00000
   Loading Ramdisk to f5096000, end f5f22282 ... OK
   Loading Device Tree to 00000000f501b000, end 00000000f5095fff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.10.12-rockchip64 (root@beast) (aarch64-linux-gnu1
[    0.000000] Machine model: Firefly-RK3399 Board
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 128 MiB at 0x00000000ed000000
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000000f7fffff]
[    0.000000] NUMA: NODE_DATA [mem 0xf77e2100-0xf77e3fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000200000-0x000000003fffffff]
[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000f7ffffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.0
[    0.000000] percpu: Embedded 32 pages/cpu s94040 r8192 d28840 u131072
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 999432
[    0.000000] Policy zone: DMA32
[    0.000000] Kernel command line: root=UUID=87943fe2-4952-4e4e-9ca7-f46b0661c1
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 byte)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes,)
[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x000000003bfff000-0x000000003ffff0)
[    0.000000] Memory: 3739892K/4061184K available (14848K kernel code, 2632K r)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 ji.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000
[    0.000000] ITS [mem 0xfee20000-0xfee3ffff]
[    0.000000] ITS@0x00000000fee20000: allocated 65536 Devices @40100000 (flat,)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000000400d0000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000000400e000
[    0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0}
[    0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@1}
[    0.000000] random: get_random_bytes called from start_kernel+0x698/0x850 wi0
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycless
[    0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398s
[    0.001302] Console: colour dummy device 80x25
[    0.002369] printk: console [tty1] enabled
[    0.002506] Calibrating delay loop (skipped), value calculated using timer f)
[    0.002553] pid_max: default: 32768 minimum: 301
[    0.002735] LSM: Security Framework initializing
[    0.002791] Yama: becoming mindful.
[    0.002944] AppArmor: AppArmor initialized
[    0.003062] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, lin)
[    0.003115] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.006725] rcu: Hierarchical SRCU implementation.
[    0.007947] Platform MSI: interrupt-controller@fee20000 domain created
[    0.008455] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@feed
[    0.010614] EFI services will not be available.
[    0.011317] smp: Bringing up secondary CPUs ...
[    0.012408] Detected VIPT I-cache on CPU1
[    0.012451] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.012470] GICv3: CPU1: using allocated LPI pending table @0x00000000400f000
[    0.012539] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.013655] Detected VIPT I-cache on CPU2
[    0.013688] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.013703] GICv3: CPU2: using allocated LPI pending table @0x000000004018000
[    0.013752] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.014857] Detected VIPT I-cache on CPU3
[    0.014890] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.014906] GICv3: CPU3: using allocated LPI pending table @0x000000004019000
[    0.014952] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    5.098337] CPU4: failed to come online
[    5.098573] CPU4: failed in unknown state : 0x0
[   10.228877] CPU5: failed to come online
[   10.228907] CPU5: failed in unknown state : 0x0
[   10.229010] smp: Brought up 1 node, 4 CPUs
[   10.229034] SMP: Total of 4 processors activated.
[   10.229061] CPU features: detected: 32-bit EL0 Support
[   10.229088] CPU features: detected: CRC32 instructions
[   10.229114] CPU features: detected: 32-bit EL1 Support
[   10.251015] CPU: All CPU(s) started at EL2
[   10.251097] alternatives: patching kernel code
[   10.254451] devtmpfs: initialized
[   10.281607] Registered cp15_barrier emulation handler
[   10.281662] Registered setend emulation handler
[   10.282020] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ms
[   10.282106] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[   10.288615] pinctrl core: initialized pinctrl subsystem
[   10.289716] DMI not present or invalid.
[   10.290580] NET: Registered protocol family 16
[   10.294284] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[   10.295354] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic als
[   10.296178] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic s
[   10.296296] audit: initializing netlink subsys (disabled)
[   10.296577] audit: type=2000 audit(10.272:1): state=initialized audit_enable1
[   10.298560] thermal_sys: Registered thermal governor 'fair_share'
[   10.298570] thermal_sys: Registered thermal governor 'bang_bang'
[   10.298599] thermal_sys: Registered thermal governor 'step_wise'
[   10.298624] thermal_sys: Registered thermal governor 'user_space'
[   10.299390] cpuidle: using governor menu
[   10.299998] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[   10.300187] ASID allocator initialised with 65536 entries
[   10.302301] Serial: AMBA PL011 UART driver
[   10.386743] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[   10.386790] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[   10.386819] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[   10.386848] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[   10.393265] cryptd: max_cpu_qlen set to 1000
[   10.470908] raid6: neonx8   gen()  1054 MB/s
[   10.539054] raid6: neonx8   xor()   780 MB/s
[   10.607202] raid6: neonx4   gen()  1080 MB/s
[   10.675356] raid6: neonx4   xor()   774 MB/s
[   10.743517] raid6: neonx2   gen()  1018 MB/s
[   10.811661] raid6: neonx2   xor()   709 MB/s
[   10.879807] raid6: neonx1   gen()   885 MB/s
[   10.947947] raid6: neonx1   xor()   607 MB/s
[   11.016089] raid6: int64x8  gen()   745 MB/s
[   11.084247] raid6: int64x8  xor()   392 MB/s
[   11.152397] raid6: int64x4  gen()   831 MB/s
[   11.220530] raid6: int64x4  xor()   424 MB/s
[   11.288679] raid6: int64x2  gen()   707 MB/s
[   11.356845] raid6: int64x2  xor()   375 MB/s
[   11.425002] raid6: int64x1  gen()   526 MB/s
[   11.493132] raid6: int64x1  xor()   274 MB/s
[   11.493156] raid6: using algorithm neonx4 gen() 1080 MB/s
[   11.493179] raid6: .... xor() 774 MB/s, rmw enabled
[   11.493201] raid6: using neon recovery algorithm
[   11.495993] vcc3v3_pcie: supplied by dc_12v
[   11.498051] vcc_sys: supplied by dc_12v
[   11.498694] iommu: Default domain type: Translated
[   11.503538] vgaarb: loaded
[   11.504358] SCSI subsystem initialized
[   11.505131] usbcore: registered new interface driver usbfs
[   11.505233] usbcore: registered new interface driver hub
[   11.505347] usbcore: registered new device driver usb
[   11.506278] pps_core: LinuxPPS API ver. 1 registered
[   11.506305] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giom>
[   11.506369] PTP clock support registered
[   11.506774] EDAC MC: Ver: 3.0.0
[   11.508645] NetLabel: Initializing
[   11.508672] NetLabel:  domain hash size = 128
[   11.508692] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[   11.508829] NetLabel:  unlabeled traffic allowed by default
[   11.509726] clocksource: Switched to clocksource arch_sys_counter
[   11.723483] VFS: Disk quotas dquot_6.6.0
[   11.723622] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[   11.724994] AppArmor: AppArmor Filesystem Enabled
[   11.738325] NET: Registered protocol family 2
[   11.739608] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 327)
[   11.739886] TCP established hash table entries: 32768 (order: 6, 262144 byte)
[   11.740460] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, line)
[   11.741213] TCP: Hash tables configured (established 32768 bind 32768)
[   11.741468] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[   11.741659] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[   11.742213] NET: Registered protocol family 1
[   11.742277] NET: Registered protocol family 44
[   11.742312] PCI: CLS 0 bytes, default 64
[   11.742637] Trying to unpack rootfs image as initramfs...
[   13.051599] Freeing initrd memory: 14896K
[   13.053049] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counte
[   13.053334] hw perfevents: /pmu_a72: failed to probe PMU!
[   13.053366] hw perfevents: /pmu_a72: failed to register PMU devices!
[   13.054330] kvm [1]: IPA Size Limit: 40 bits
[   13.056109] kvm [1]: vgic-v2@fff20000
[   13.056162] kvm [1]: GIC system register CPU interface enabled
[   13.056359] kvm [1]: vgic interrupt IRQ18
[   13.056607] kvm [1]: Hyp mode initialized successfully
[   13.069224] Initialise system trusted keyrings
[   13.069313] Key type blacklist registered
[   13.069620] workingset: timestamp_bits=44 max_order=20 bucket_order=0
[   13.080788] zbud: loaded
[   13.083643] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[   13.084918] fuse: init (API version 7.32)
[   13.087045] integrity: Platform Keyring initialized
[   13.160372] xor: measuring software checksum speed
[   13.168505]    8regs           :  1220 MB/sec
[   13.175575]    32regs          :  1402 MB/sec
[   13.184628]    arm64_neon      :  1093 MB/sec
[   13.184653] xor: using function: 32regs (1402 MB/sec)
[   13.184684] Key type asymmetric registered
[   13.184707] Asymmetric key parser 'x509' registered
[   13.184786] Block layer SCSI generic (bsg) driver version 0.4 loaded (major )
[   13.185018] io scheduler mq-deadline registered
[   13.185045] io scheduler kyber registered
[   13.185271] io scheduler bfq registered
[   13.190590] vcc5v0_host: supplied by vcc_sys
[   13.209993] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
[   13.210064] OF: /pcie@f8000000: Missing device_type
[   13.210123] rockchip-pcie f8000000.pcie:      MEM 0x00fa000000..0x00fbdfffff0
[   13.210176] rockchip-pcie f8000000.pcie:       IO 0x00fbe00000..0x00fbefffff0
[   13.211445] rockchip-pcie f8000000.pcie: no vpcie12v regulator found
[   13.211498] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[   13.211546] rockchip-pcie f8000000.pcie: supply vpcie1v8 not found, using dur
[   13.211811] rockchip-pcie f8000000.pcie: supply vpcie0v9 not found, using dur
[   13.737815] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[   13.738644] rockchip-pcie: probe of f8000000.pcie failed with error -110
[   13.748450] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-0
[   13.748495] dma-pl330 ff6d0000.dma-controller:       DBUFF-32x8bytes Num_Cha2
[   13.750996] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-0
[   13.751037] dma-pl330 ff6e0000.dma-controller:       DBUFF-128x8bytes Num_Ch6
[   13.758065] vcc3v3_sys: supplied by vcc_sys
[   13.758210] vdd_log: supplied by regulator-dummy
[   13.760078] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[   13.764859] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 46, base_baud =A
[   13.765137] serial serial0: tty port ttyS0 registered
[   13.766475] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 47, base_baud =A
[   13.880664] printk: console [ttyS2] enabled
[   13.882992] Serial: AMBA driver
[   13.885137] cacheinfo: Unable to detect cache hierarchy for CPU 0
[   13.903742] loop: module loaded
[   13.911326] libphy: Fixed MDIO Bus: probed
[   13.912686] tun: Universal TUN/TAP device driver, 1.6
[   13.914636] thunder_xcv, ver 1.0
[   13.915007] thunder_bgx, ver 1.0
[   13.915374] nicpf, ver 1.0
[   13.917056] e1000e: Intel(R) PRO/1000 Network Driver
[   13.917513] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[   13.918152] igb: Intel(R) Gigabit Ethernet Network Driver
[   13.918646] igb: Copyright (c) 2007-2014 Intel Corporation.
[   13.919215] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[   13.919786] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[   13.920690] sky2: driver version 1.30
[   13.921969] VFIO - User Level meta-driver version: 0.3
[   13.933408] OF: graph: no port node found in /syscon@ff770000/usb2-phy@e450/t
[   13.956144] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   13.956782] ehci-pci: EHCI PCI platform driver
[   13.957249] ehci-platform: EHCI generic platform driver
[   13.960338] ehci-platform fe380000.usb: EHCI Host Controller
[   13.960886] ehci-platform fe380000.usb: new USB bus registered, assigned bus1
[   13.961834] ehci-platform fe380000.usb: irq 39, io mem 0xfe380000
[   13.977756] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[   13.978703] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, b0
[   13.979460] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber1
[   13.980119] usb usb1: Product: EHCI Host Controller
[   13.980567] usb usb1: Manufacturer: Linux 5.10.12-rockchip64 ehci_hcd
[   13.981154] usb usb1: SerialNumber: fe380000.usb
[   13.982395] hub 1-0:1.0: USB hub found
[   13.982795] hub 1-0:1.0: 1 port detected
[   13.986303] ehci-platform fe3c0000.usb: EHCI Host Controller
[   13.986849] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus2
[   13.987768] ehci-platform fe3c0000.usb: irq 41, io mem 0xfe3c0000
[   14.001744] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[   14.002684] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, b0
[   14.003438] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber1
[   14.004097] usb usb2: Product: EHCI Host Controller
[   14.004546] usb usb2: Manufacturer: Linux 5.10.12-rockchip64 ehci_hcd
[   14.005132] usb usb2: SerialNumber: fe3c0000.usb
[   14.006325] hub 2-0:1.0: USB hub found
[   14.006731] hub 2-0:1.0: 1 port detected
[   14.008219] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   14.008805] ohci-pci: OHCI PCI platform driver
[   14.009324] ohci-platform: OHCI generic platform driver
[   14.010309] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[   14.010943] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus3
[   14.011841] ohci-platform fe3a0000.usb: irq 40, io mem 0xfe3a0000
[   14.074043] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, b0
[   14.074797] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber1
[   14.075457] usb usb3: Product: Generic Platform OHCI controller
[   14.075998] usb usb3: Manufacturer: Linux 5.10.12-rockchip64 ohci_hcd
[   14.076584] usb usb3: SerialNumber: fe3a0000.usb
[   14.077811] hub 3-0:1.0: USB hub found
[   14.078211] hub 3-0:1.0: 1 port detected
[   14.079599] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[   14.080233] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus4
[   14.081134] ohci-platform fe3e0000.usb: irq 42, io mem 0xfe3e0000
[   14.142021] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, b0
[   14.142777] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber1
[   14.143436] usb usb4: Product: Generic Platform OHCI controller
[   14.143977] usb usb4: Manufacturer: Linux 5.10.12-rockchip64 ohci_hcd
[   14.144563] usb usb4: SerialNumber: fe3e0000.usb
[   14.145750] hub 4-0:1.0: USB hub found
[   14.146147] hub 4-0:1.0: 1 port detected
[   14.148742] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[   14.149272] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus n5
[   14.150210] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110
[   14.151091] xhci-hcd xhci-hcd.0.auto: irq 77, io mem 0xfe800000
[   14.152261] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, b0
[   14.153018] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber1
[   14.153676] usb usb5: Product: xHCI Host Controller
[   14.154204] usb usb5: Manufacturer: Linux 5.10.12-rockchip64 xhci-hcd
[   14.154794] usb usb5: SerialNumber: xhci-hcd.0.auto
[   14.156003] hub 5-0:1.0: USB hub found
[   14.156403] hub 5-0:1.0: 1 port detected
[   14.157289] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[   14.157839] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus n6
[   14.158550] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[   14.159253] usb usb6: We don't know the algorithms for LPM for this host, di.
[   14.160223] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, b0
[   14.160978] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber1
[   14.161636] usb usb6: Product: xHCI Host Controller
[   14.162148] usb usb6: Manufacturer: Linux 5.10.12-rockchip64 xhci-hcd
[   14.162737] usb usb6: SerialNumber: xhci-hcd.0.auto
[   14.163911] hub 6-0:1.0: USB hub found
[   14.164308] hub 6-0:1.0: 1 port detected
[   14.165561] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[   14.166124] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus n7
[   14.167054] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe64 hci version 0x110
[   14.167989] xhci-hcd xhci-hcd.1.auto: irq 78, io mem 0xfe900000
[   14.169161] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, b0
[   14.169947] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber1
[   14.170608] usb usb7: Product: xHCI Host Controller
[   14.171059] usb usb7: Manufacturer: Linux 5.10.12-rockchip64 xhci-hcd
[   14.171645] usb usb7: SerialNumber: xhci-hcd.1.auto
[   14.172846] hub 7-0:1.0: USB hub found
[   14.173247] hub 7-0:1.0: 1 port detected
[   14.174159] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[   14.174678] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus n8
[   14.175389] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[   14.176092] usb usb8: We don't know the algorithms for LPM for this host, di.
[   14.177033] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, b0
[   14.177818] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber1
[   14.178478] usb usb8: Product: xHCI Host Controller
[   14.178927] usb usb8: Manufacturer: Linux 5.10.12-rockchip64 xhci-hcd
[   14.179513] usb usb8: SerialNumber: xhci-hcd.1.auto
[   14.180693] hub 8-0:1.0: USB hub found
[   14.181090] hub 8-0:1.0: 1 port detected
[   14.182493] usbcore: registered new interface driver usb-storage
[   14.186508] mousedev: PS/2 mouse device common for all mice
[   14.188847] i2c /dev entries driver
[   14.202005] rk808 0-001b: chip id: 0x0
[   14.207403] rk808-regulator rk808-regulator: there is no dvs0 gpio
[   14.208018] rk808-regulator rk808-regulator: there is no dvs1 gpio
[   14.209590] vdd_center: supplied by vcc_sys
[   14.210842] vdd_cpu_l: supplied by vcc_sys
[   14.211615] vcc_ddr: supplied by vcc_sys
[   14.212739] vcc_1v8: supplied by vcc_sys
[   14.214614] vcc1v8_dvp: supplied by vcc_sys
[   14.215356] vcc2v8_dvp: Bringing 3000000uV into 2800000-2800000uV
[   14.216854] vcc2v8_dvp: supplied by vcc_sys
[   14.218549] vcc1v8_pmu: supplied by vcc_sys
[   14.220269] vcc_sdio: supplied by vcc_sys
[   14.221824] vcca3v0_codec: supplied by vcc_sys
[   14.223538] vcc_1v5: supplied by vcc_sys
[   14.225105] vcca1v8_codec: supplied by vcc_sys
[   14.226867] vcc_3v0: supplied by vcc_sys
[   14.227670] vcc3v3_s3: supplied by vcc3v3_sys
[   14.228563] vcc3v3_s0: supplied by vcc3v3_sys
[   14.233287] rk808-rtc rk808-rtc: registered as rtc0
[   14.234343] rk808-rtc rk808-rtc: setting system clock to 2021-02-12T10:29:49)
[   14.239072] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[   14.241042] vcc1v8_s3: supplied by vcc_1v8
[   14.241552] vdd_cpu_b: supplied by vcc_sys
[   14.245848] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[   14.247811] vdd_gpu: supplied by vcc_sys
[   14.256604] dw_wdt ff848000.watchdog: No valid TOPs array specified
[   14.260357] sdhci: Secure Digital Host Controller Interface driver
[   14.260938] sdhci: Copyright(c) Pierre Ossman
[   14.261376] Synopsys Designware Multimedia Card Interface Driver
[   14.263584] sdhci-pltfm: SDHCI platform and OF driver helper
[   14.263999] dwmmc_rockchip fe310000.mmc: IDMAC supports 32-bit address mode.
[   14.264403] dwmmc_rockchip fe320000.mmc: IDMAC supports 32-bit address mode.
[   14.264777] dwmmc_rockchip fe310000.mmc: Using internal DMA controller.
[   14.265400] dwmmc_rockchip fe320000.mmc: Using internal DMA controller.
[   14.266034] dwmmc_rockchip fe310000.mmc: Version ID is 270a
[   14.266636] dwmmc_rockchip fe320000.mmc: Version ID is 270a
[   14.266879] mmc2: CQHCI version 5.10
[   14.267229] dwmmc_rockchip fe310000.mmc: DW MMC controller at irq 36,32 bit o
[   14.267713] dwmmc_rockchip fe320000.mmc: DW MMC controller at irq 37,32 bit o
[   14.268620] dwmmc_rockchip fe310000.mmc: allocated mmc-pwrseq
[   14.268857] ledtrig-cpu: registered to indicate activity on CPUs
[   14.269145] dwmmc_rockchip fe320000.mmc: Got CD GPIO
[   14.269684] mmc_host mmc0: card is non-removable.
[   14.271809] hid: raw HID events driver (C) Jiri Kosina
[   14.272566] usbcore: registered new interface driver usbhid
[   14.273077] usbhid: USB HID core driver
[   14.280854] drop_monitor: Initializing network drop monitor service
[   14.282209] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz,)
[   14.282756] NET: Registered protocol family 10
[   14.285405] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz,)
[   14.289827] mmc2: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using A
[   14.298975] random: fast init done
[   14.332472] mmc0: queuing unknown CIS tuple 0x80 (2 bytes)
[   14.333949] Segment Routing with IPv6
[   14.334439] NET: Registered protocol family 17
[   14.335049] 8021q: 802.1Q VLAN Support v1.8
[   14.335519] Key type dns_resolver registered
[   14.336810] registered taskstats version 1
[   14.337204] Loading compiled-in X.509 certificates
[   14.337830] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[   14.339967] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[   14.341792] usb 2-1: new high-speed USB device number 2 using ehci-platform
[   14.343464] mmc0: queuing unknown CIS tuple 0x80 (7 bytes)
[   14.344301] Loaded X.509 cert 'Build time autogenerated kernel key: f47c1788'
[   14.349969] zswap: loaded using pool zstd/z3fold
[   14.350842] Key type ._fscrypt registered
[   14.351219] Key type .fscrypt registered
[   14.351582] Key type fscrypt-provisioning registered
[   14.355410] Btrfs loaded, crc32c=crc32c-generic
[   14.363226] mmc2: Command Queue Engine enabled
[   14.363704] mmc2: new HS400 Enhanced strobe MMC card at address 0001
[   14.365436] mmcblk2: mmc2:0001 DJNB4R 116 GiB
[   14.366349] mmcblk2boot0: mmc2:0001 DJNB4R partition 1 4.00 MiB
[   14.367263] mmcblk2boot1: mmc2:0001 DJNB4R partition 2 4.00 MiB
[   14.368085] mmcblk2rpmb: mmc2:0001 DJNB4R partition 3 4.00 MiB, chardev (243)
[   14.370571]  mmcblk2: p1
[   14.382041] Key type encrypted registered
[   14.382494] AppArmor: AppArmor sha1 policy hashing enabled
[   14.405235] mmc_host mmc0: Bus speed (slot 0) = 148500000Hz (slot req 150000)
[   14.469141] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[   14.470630] of_cfs_init
[   14.470909] of_cfs_init: OK
[   14.475411] Freeing unused kernel memory: 4352K
[   14.481868] Run /init as init process
[   14.502635] usb 2-1: New USB device found, idVendor=1a40, idProduct=0201, bc0
[   14.503402] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[   14.504055] usb 2-1: Product: USB 2.0 Hub [MTT]
[   14.505504] hub 2-1:1.0: USB hub found
[   14.506134] hub 2-1:1.0: 7 ports detected
[   14.670641] dwmmc_rockchip fe310000.mmc: Successfully tuned phase to 202
[   14.676517] mmc0: new ultra high speed SDR104 SDIO card at address 0001
[   14.801829] usb 2-1.3: new high-speed USB device number 3 using ehci-platform
[   14.910645] usb 2-1.3: New USB device found, idVendor=1a40, idProduct=0101, 1
[   14.911428] usb 2-1.3: New USB device strings: Mfr=0, Product=1, SerialNumbe0
[   14.912099] usb 2-1.3: Product: USB 2.0 Hub
[   14.913649] hub 2-1.3:1.0: USB hub found
[   14.914533] hub 2-1.3:1.0: 4 ports detected
[   15.232071] pwm-backlight backlight: supply power not found, using dummy regr
[   15.329849] usb 2-1.3.2: new full-speed USB device number 4 using ehci-platfm
[   15.555881] rk_gmac-dwmac fe300000.ethernet: IRQ eth_wake_irq not found
[   15.556513] rk_gmac-dwmac fe300000.ethernet: IRQ eth_lpi not found
[   15.557298] rk_gmac-dwmac fe300000.ethernet: PTP uses main clock
[   15.560033] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[   15.560704] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[   15.561228] rk_gmac-dwmac fe300000.ethernet: RX delay(0x11).
[   15.561815] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[   15.562560] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[   15.563250] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[   15.568874] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[   15.569963] rk_gmac-dwmac fe300000.ethernet: User ID: 0x10, Synopsys ID: 0x35
[   15.570673] rk_gmac-dwmac fe300000.ethernet:         DWMAC1000
[   15.571193] rk_gmac-dwmac fe300000.ethernet: DMA HW capability register suppd
[   15.571210] usb 2-1.3.2: language id specifier not provided by device, defauh
[   15.571880] rk_gmac-dwmac fe300000.ethernet: RX Checksum Offload Engine suppd
[   15.573314] rk_gmac-dwmac fe300000.ethernet: COE Type 2
[   15.573910] rk_gmac-dwmac fe300000.ethernet: TX Checksum insertion supported
[   15.574559] rk_gmac-dwmac fe300000.ethernet: Wake-Up On Lan supported
[   15.575325] rk_gmac-dwmac fe300000.ethernet: Normal descriptors
[   15.575874] rk_gmac-dwmac fe300000.ethernet: Ring mode enabled
[   15.576477] rk_gmac-dwmac fe300000.ethernet: Enable RX Mitigation via HW Watr
[   15.582273] usb 2-1.3.2: New USB device found, idVendor=0c45, idProduct=74031
[   15.583076] usb 2-1.3.2: New USB device strings: Mfr=1, Product=2, SerialNum0
[   15.587678] input: HID 0c45:7403 as /devices/platform/fe3c0000.usb/usb2/2-1/1
[   15.595454] rockchip-vop ff8f0000.vop: Adding to iommu group 2
[   15.597199] rockchip-vop ff900000.vop: Adding to iommu group 3
[   15.630792] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_comp)
[   15.631838] [drm] unsupported AFBC format[3231564e]
[   15.647160] hid-generic 0003:0C45:7403.0001: input,hidraw0: USB HID v1.00 Ke0
[   15.649129] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_comp)
[   15.651173] input: HID 0c45:7403 as /devices/platform/fe3c0000.usb/usb2/2-1/2
[   15.652991] hid-generic 0003:0C45:7403.0002: input,hidraw1: USB HID v1.10 Mo1
[   15.655049] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11)
[   15.663260] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi)
[   15.747726] libphy: stmmac: probed
[   15.747752] RTL8211E Gigabit Ethernet stmmac-0:00: attached PHY driver [RTL8)
[   15.747768] RTL8211E Gigabit Ethernet stmmac-0:01: attached PHY driver [RTL8)
[   15.795969] Console: switching to colour frame buffer device 240x67
[   15.900572] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame be
[   15.938858] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem 0
[   16.217746] EXT4-fs (mmcblk2p1): mounted filesystem with ordered data mode. )
[   16.659565] systemd[1]: Inserted module 'autofs4'
[   16.712564] systemd[1]: systemd 245.4-4ubuntu3.4 running in system mode. (+P)
[   16.716965] systemd[1]: Detected architecture arm64.
[   16.753405] systemd[1]: Set hostname to <firefly-rk3399>.
[   16.863208] dw-apb-uart ff1a0000.serial: forbid DMA for kernel console
[   17.204792] systemd[1]: /lib/systemd/system/dbus.socket:5: ListenStream= ref.
[   17.617376] random: systemd: uninitialized urandom read (16 bytes read)
[   17.625132] systemd[1]: Created slice system-modprobe.slice.
[   17.626865] random: systemd: uninitialized urandom read (16 bytes read)
[   17.630236] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   17.631746] random: systemd: uninitialized urandom read (16 bytes read)
[   17.634793] systemd[1]: Created slice User and Session Slice.
[   17.636701] systemd[1]: Started Forward Password Requests to Wall Directory .
[   17.639797] systemd[1]: Set up automount Arbitrary Executable File Formats F.
[   17.658931] systemd[1]: Reached target User and Group Name Lookups.
[   17.693228] systemd[1]: Reached target Remote File Systems.
[   17.726897] systemd[1]: Reached target Slices.
[   17.760095] systemd[1]: Reached target Swap.
[   17.793200] systemd[1]: Reached target System Time Set.
[   17.830080] systemd[1]: Listening on Syslog Socket.
[   17.864357] systemd[1]: Listening on fsck to fsckd communication Socket.
[   17.898301] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   17.933114] systemd[1]: Listening on Journal Audit Socket.
[   17.966984] systemd[1]: Listening on Journal Socket (/dev/log).
[   18.000856] systemd[1]: Listening on Journal Socket.
[   18.034419] systemd[1]: Listening on udev Control Socket.
[   18.067511] systemd[1]: Listening on udev Kernel Socket.
[   18.107907] systemd[1]: Mounting Huge Pages File System...
[   18.148874] systemd[1]: Mounting POSIX Message Queue File System...
[   18.188727] systemd[1]: Mounting Kernel Debug File System...
[   18.228216] systemd[1]: Mounting Kernel Trace File System...
[   18.268954] systemd[1]: Starting Restore / save the current clock...
[   18.310065] systemd[1]: Starting Set the console keyboard layout...
[   18.352156] systemd[1]: Starting Create list of static device nodes for the .
[   18.386140] systemd[1]: Condition check resulted in Load Kernel Module drm b.
[   18.393420] systemd[1]: Started Nameserver information manager.
[   18.438004] systemd[1]: Reached target Network (Pre).
[   18.471642] systemd[1]: Condition check resulted in Set Up Additional Binary.
[   18.487655] systemd[1]: Condition check resulted in File System Check on Roo.
[   18.513070] systemd[1]: Starting Load Kernel Modules...
[   18.551950] systemd[1]: Starting Remount Root and Kernel File Systems...
[   18.592513] systemd[1]: Starting udev Coldplug all Devices...
[   18.611087] udc-core: couldn't find an available UDC - added [g_serial] to ls
[   18.618064] EXT4-fs (mmcblk2p1): re-mounted. Opts: commit=600,errors=remounto
[   18.666029] systemd[1]: Mounted Huge Pages File System.
[   18.696843] systemd[1]: Mounted POSIX Message Queue File System.
[   18.727546] systemd[1]: Mounted Kernel Debug File System.
[   18.758283] systemd[1]: Mounted Kernel Trace File System.
[   18.793273] systemd[1]: Finished Restore / save the current clock.
[   18.828113] systemd[1]: Finished Create list of static device nodes for the .
[   18.869055] systemd[1]: Finished Load Kernel Modules.
[   18.903567] systemd[1]: Finished Remount Root and Kernel File Systems.
[   18.949617] systemd[1]: Mounting FUSE Control File System...
[   18.987317] systemd[1]: Mounting Kernel Configuration File System...
[   19.021514] systemd[1]: Condition check resulted in Rebuild Hardware Databas.
[   19.037099] systemd[1]: Condition check resulted in Platform Persistent Stor.
[   19.059565] systemd[1]: Starting Load/Save Random Seed...
[   19.097519] systemd[1]: Starting Apply Kernel Variables...
[   19.136912] systemd[1]: Starting Create System Users...
[   21.445268] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4356-sdio f2
[   21.555818] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4356-sdio f2
[   21.585099] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4356/2 wl0: Mar  40
Armbian 21.02.1 Focal ttyS2
Show the UART log of the attempt to launch the last Armbian image (which is not working for you). Important. You should not change anything on the SD card after recording. You should not stop the u-boot startup process, I need a "clean" u-boot log when trying to start. And show the content armbianEnv.txt a system that does not start.
1 час назад, denni_isl сказал:
I'm not asking you about eMMC, but about launching from external media.
ArmbianEnv.txt
verbosity=7
bootlogo=false
overlay_prefix=rockchip
rootdev=UUID=76c21c43-8ec8-4c56-a741-6fd8602eed2e
rootfstype=ext4
mainline focal 5.10.y from https://www.armbian.com/firefly-rk3399/
sd card boot up does not get any further than - starting kernel.......
UART:
d@A~PÐ
      '@Î8DDR Version 1.24 20191016
In
256B stride
OUT
CPUId = 0x0
ChipType = 0x10, 243
SdmmcInit=2 0
BootCapSize=100000
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=61056MB
FwPartOffset=2000 , 0
StorageInit ok = 345547
SecureMode = 0
recovery gpt...
recovery gpt fail!
No find bl30.bin
No find bl32.bin
Load OK, addr=0x200000, size=0xbaecc
RunBL31 0x40000
INFO:    plat_rockchip_pmu_init(1190): pd status 3e
INFO:    SPSR = 0x3c9
U-Boot 2020.10-armbian (Feb 03 2021 - 22:38:38 +0100)
SoC: Rockchip rk3399
Reset cause: POR
DRAM:  3.9 GiB
PMIC:  RK808
Cannot find regulator pwm init_voltage
MMC:   mmc@fe310000: 2, mmc@fe320000: 1, sdhci@fe330000: 0
In:    serial@ff1a0000
mmc1 is current device
Scanning mmc 1:1...
3185 bytes read in 5 ms (622.1 KiB/s)
Boot script loaded from mmc 1
117 bytes read in 4 ms (28.3 KiB/s)
15339358 bytes read in 659 ms (22.2 MiB/s)
28582400 bytes read in 1213 ms (22.5 MiB/s)
76162 bytes read in 11 ms (6.6 MiB/s)
2698 bytes read in 7 ms (376 KiB/s)
## Executing script at 09000000
Moving Image from 0x2080000 to 0x2200000, end=3de0000
   Image Name:   uInitrd
   Data Size:    15339294 Bytes = 14.6 MiB
   Loading Ramdisk to f507d000, end f5f1df1e ... OK
   Loading Device Tree to 00000000f5002000, end 00000000f507cfff ... OK
Starting kernel ...
Vondering if this has something to do with AppArmor or the hardware partitions
grep APPARMOR /boot/config-*
CONFIG_SECURITY_APPARMOR=y
CONFIG_SECURITY_APPARMOR_HASH=y
CONFIG_SECURITY_APPARMOR_HASH_DEFAULT=y
# CONFIG_SECURITY_APPARMOR_DEBUG is not set
CONFIG_DEFAULT_SECURITY_APPARMOR=y
This is from successful Armbian 21.02.1 Focal with Linux 5.10.12-rockchip64 emmc boot
>D"`¥���{ڎV>�H�������(@���
                            �{�����۷}�"a��DDR Version 1.24 20191016
In
256B stride
OUT
CPUId = 0x0
SdmmcInit=2 0
BootCapSize=100000
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=61056MB
StorageInit ok = 176393
SecureMode = 0
recovery gpt...
recovery gpt fail!
No find bl30.bin
No find bl32.bin
Load OK, addr=0x200000, size=0xbaa44
RunBL31 0x40000
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
INFO:    SPSR = 0x3c9
U-Boot 2020.10-armbian (Jan 05 2021 - 00:01:40 +0100)
Reset cause: POR
DRAM:  3.9 GiB
PMIC:  RK808
In:    serial@ff1a0000
Scanning mmc 1:1...
8817201 bytes read in 378 ms (22.2 MiB/s)
20768776 bytes read in 883 ms (22.4 MiB/s)
101691 bytes read in 11 ms (8.8 MiB/s)
   Image Name:   uInitrd
   Data Size:    8817137 Bytes = 8.4 MiB
   Loading Ramdisk to f56b6000, end f5f1e9f1 ... OK
ERROR: reserving fdt memory region failed (addr=0 size=0)
   Loading Device Tree to 00000000f5634000, end 00000000f56b5fff ... OK
Starting kernel ...
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.213-rk3399 (root@desktop) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) ) #1 SMP Tue Dec 15 09:09:52 0
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x0000000000000000, size 0 MiB
[    0.000000] PERCPU: Embedded 20 pages/cpu @ffffffc0f7ed5000 s42216 r8192 d31512 u81920
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 999432
[    0.000000] Kernel command line: root=UUID=bac3e4b8-d724-4859-a0f1-59069ae5db6f rootwait rootfstype=ext4 console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=7 ubootpart=c71
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] software IO TLB: mapped [mem 0xeec00000-0xf2c00000] (64MB)
[    0.000000] Memory: 3891344K/4061184K available (11582K kernel code, 1402K rwdata, 6136K rodata, 1088K init, 1954K bss, 169840K reserved, 0K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000   (   246 GB)
[    0.000000]       .init : 0xffffff80091e0000 - 0xffffff80092f0000   (  1088 KB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008bd0000   ( 11584 KB)
[    0.000000]     .rodata : 0xffffff8008bd0000 - 0xffffff80091e0000   (  6208 KB)
[    0.000000]       .data : 0xffffff80092f0000 - 0xffffff800944e808   (  1403 KB)
[    0.000000]     vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000   (     8 GB maximum)
[    0.000000]               0xffffffbdc0008000 - 0xffffffbdc3e00000   (    61 MB actual)
[    0.000000]     fixed   : 0xffffffbffe7fb000 - 0xffffffbffec00000   (  4116 KB)
[    0.000000]     PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000   (    16 MB)
[    0.000000]     memory  : 0xffffffc000200000 - 0xffffffc0f8000000   (  3966 MB)
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 64.
[    0.000000]  RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000
[    0.000000] ITS: allocated 65536 Devices @ee900000 (psz 64K, shr 0)
[    0.000000] GIC: using LPI property table @0x00000000ee890000
[    0.000000] ITS: Allocated 1792 chunks for LPIs
[    0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000
[    0.000000] CPU0: using LPI pending table @0x00000000ee8a0000
[    0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[    0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work
[    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001447] Console: colour dummy device 80x25
[    0.003326] console [tty1] enabled
[    0.003371] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.003436] pid_max: default: 32768 minimum: 301
[    0.003616] Security Framework initialized
[    0.003653] Yama: becoming mindful.
[    0.003698] AppArmor: AppArmor disabled by boot time parameter
[    0.003778] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.003818] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.004589] Initializing cgroup subsys io
[    0.004634] Initializing cgroup subsys memory
[    0.004693] Initializing cgroup subsys devices
[    0.004733] Initializing cgroup subsys freezer
[    0.004771] Initializing cgroup subsys net_cls
[    0.004810] Initializing cgroup subsys perf_event
[    0.004849] Initializing cgroup subsys net_prio
[    0.004892] Initializing cgroup subsys hugetlb
[    0.004928] Initializing cgroup subsys pids
[    0.004995] ftrace: allocating 41777 entries in 164 pages
[    0.118121] sched-energy: Sched-energy-costs installed from DT
[    0.118169] CPU0: update cpu_capacity 401
[    0.118248] ASID allocator initialised with 32768 entries
[    0.121165] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.121760] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.123133] Detected VIPT I-cache on CPU1
[    0.123164] CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.123194] CPU1: using LPI pending table @0x00000000eeb30000
[    0.123241] CPU1: update cpu_capacity 401
[    0.123245] CPU1: Booted secondary processor [410fd034]
[    0.123784] Detected VIPT I-cache on CPU2
[    0.123804] CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.123831] CPU2: using LPI pending table @0x00000000eeb60000
[    0.123859] CPU2: update cpu_capacity 401
[    0.123862] CPU2: Booted secondary processor [410fd034]
[    0.124376] Detected VIPT I-cache on CPU3
[    0.124396] CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.124423] CPU3: using LPI pending table @0x00000000eebb0000
[    0.124449] CPU3: update cpu_capacity 401
[    0.124453] CPU3: Booted secondary processor [410fd034]
[    0.124976] Detected PIPT I-cache on CPU4
[    0.125002] CPU4: found redistributor 100 region 0:0x00000000fef80000
[    0.125040] CPU4: using LPI pending table @0x00000000eebf0000
[    0.125077] CPU4: update cpu_capacity 1024
[    0.125080] CPU4: Booted secondary processor [410fd082]
[    0.125636] Detected PIPT I-cache on CPU5
[    0.125654] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[    0.125689] CPU5: using LPI pending table @0x00000000ee020000
[    0.125715] CPU5: update cpu_capacity 1024
[    0.125718] CPU5: Booted secondary processor [410fd082]
[    0.125805] Brought up 6 CPUs
[    0.126520] SMP: Total of 6 processors activated.
[    0.126554] CPU features: detected feature: GIC system register CPU interface
[    0.126591] CPU features: detected feature: 32-bit EL0 Support
[    0.126627] CPU: All CPU(s) started at EL2
[    0.126697] alternatives: patching kernel code
[    0.128103] devtmpfs: initialized
[    0.145204] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.145262] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.145729] xor: measuring software checksum speed
[    0.185159]    8regs     :  2855.000 MB/sec
[    0.225220]    8regs_prefetch:  2558.000 MB/sec
[    0.265282]    32regs    :  3211.000 MB/sec
[    0.305342]    32regs_prefetch:  2840.000 MB/sec
[    0.305362] xor: using function: 32regs (3211.000 MB/sec)
[    0.305398] pinctrl core: initialized pinctrl subsystem
[    0.306192] NET: Registered protocol family 16
[    0.317982] cpuidle: using governor ladder
[    0.330005] cpuidle: using governor menu
[    0.330043] Registered FIQ tty driver
[    0.330332] vdso: 2 pages (1 code @ ffffff8008bd6000, 1 data @ ffffff80092f5000)
[    0.330386] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.330565] DMA: preallocated 256 KiB pool for atomic allocations
[    0.353604] console [pstore-1] enabled
[    0.353631] pstore: Registered ramoops as persistent store backend
[    0.353656] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[    0.425650] console [ttyFIQ0] enabled
[    0.426202] Registered fiq debugger ttyFIQ0
[    0.501728] raid6: int64x1  gen()   450 MB/s
[    0.569763] raid6: int64x1  xor()   414 MB/s
[    0.637935] raid6: int64x2  gen()   755 MB/s
[    0.706006] raid6: int64x2  xor()   609 MB/s
[    0.774101] raid6: int64x4  gen()   938 MB/s
[    0.842182] raid6: int64x4  xor()   673 MB/s
[    0.910295] raid6: int64x8  gen()   863 MB/s
[    0.978388] raid6: int64x8  xor()   608 MB/s
[    1.046494] raid6: neonx1   gen()   909 MB/s
[    1.114626] raid6: neonx1   xor()   676 MB/s
[    1.182699] raid6: neonx2   gen()  1518 MB/s
[    1.250818] raid6: neonx2   xor()   986 MB/s
[    1.318908] raid6: neonx4   gen()  1794 MB/s
[    1.387026] raid6: neonx4   xor()  1143 MB/s
[    1.455113] raid6: neonx8   gen()  1700 MB/s
[    1.523217] raid6: neonx8   xor()  1245 MB/s
[    1.523608] raid6: using algorithm neonx4 gen() 1794 MB/s
[    1.524102] raid6: .... xor() 1143 MB/s, rmw enabled
[    1.524560] raid6: using intx1 recovery algorithm
[    1.529031] iommu: Adding device ff650000.vpu_service to group 0
[    1.529664] iommu: Adding device ff660000.rkvdec to group 1
[    1.530279] iommu: Adding device ff8f0000.vop to group 2
[    1.530867] iommu: Adding device ff900000.vop to group 3
[    1.531475] iommu: Adding device ff910000.cif_isp to group 4
[    1.532434] rk_iommu ff650800.iommu: can't get sclk
[    1.533139] rk_iommu ff660480.iommu: can't get sclk
[    1.533796] rk_iommu ff8f3f00.iommu: can't get sclk
[    1.534408] rk_iommu ff903f00.iommu: can't get sclk
[    1.535032] rk_iommu ff914000.iommu: can't get sclk
[    1.535851] SCSI subsystem initialized
[    1.536538] usbcore: registered new interface driver usbfs
[    1.537084] usbcore: registered new interface driver hub
[    1.537653] usbcore: registered new device driver usb
[    1.538205] media: Linux media interface: v0.10
[    1.538654] Linux video capture interface: v2.00
[    1.539150] pps_core: LinuxPPS API ver. 1 registered
[    1.539611] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.540456] PTP clock support registered
[    1.541970] Advanced Linux Sound Architecture Driver Initialized.
[    1.543369] NetLabel: Initializing
[    1.543692] NetLabel:  domain hash size = 128
[    1.544093] NetLabel:  protocols = UNLABELED CIPSOv4
[    1.544582] NetLabel:  unlabeled traffic allowed by default
[    1.545344] rockchip-cpuinfo cpuinfo: Serial         : 19d9d710df333dee
[    1.546482] clocksource: Switched to clocksource arch_sys_counter
[    1.592935] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[    1.593780] NET: Registered protocol family 2
[    1.594641] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    1.595566] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes)
[    1.597011] TCP: Hash tables configured (established 32768 bind 32768)
[    1.597699] UDP hash table entries: 2048 (order: 5, 196608 bytes)
[    1.598396] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes)
[    1.599353] NET: Registered protocol family 1
[    1.600449] Trying to unpack rootfs image as initramfs...
[    2.031118] Freeing initrd memory: 8608K
[    2.031976] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    2.032812] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    2.035121] kvm [1]: 8-bit VMID
[    2.035423] kvm [1]: Hyp mode initialized successfully
[    2.036018] kvm [1]: interrupt-controller@fff20000 IRQ10
[    2.036709] kvm [1]: timer IRQ12
[    2.040237] audit: initializing netlink subsys (disabled)
[    2.040789] audit: type=2000 audit(1.964:1): initialized
[    2.041667] Initialise system trusted keyring
[    2.042442] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    2.050386] VFS: Disk quotas dquot_6.6.0
[    2.050950] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    2.053026] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    2.054204] fuse init (API version 7.23)
[    2.055166] JFS: nTxBlock = 8192, nTxLock = 65536
[    2.060502] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[    2.062931] Key type big_key registered
[    2.063304]
[    2.063304] TEE Core Framework initialization (ver 1:0.1)
[    2.063960] TEE armv7 Driver initialization
[    2.064786] tz_tee_probe: name="armv7sec", id=0, pdev_name="armv7sec.0"
[    2.065390] TEE core: Alloc the misc device "opteearmtz00" (id=0)
[    2.066121] TEE Core: Register the misc device "opteearmtz00" (id=0,minor=62)
[    2.072270] Key type asymmetric registered
[    2.072660] Asymmetric key parser 'x509' registered
[    2.073289] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    2.074112] io scheduler noop registered
[    2.074513] io scheduler deadline registered (default)
[    2.075019] io scheduler cfq registered
[    2.076873] phy phy-ff770000.syscon:usb2-phy@e460.1: Failed to get VBUS supply regulator
[    2.082690] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[    2.083301] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[    2.083904] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[    2.084483] rockchip-pcie f8000000.pcie: no bus-scan-delay-ms in device tree, default 0 ms
[    2.085237] rockchip-pcie f8000000.pcie: missing "memory-region" property
[    2.085856] PCI host bridge /pcie@f8000000 ranges:
[    2.086308]   MEM 0xfa000000..0xfbdfffff -> 0xfa000000
[    2.086797]    IO 0xfbe00000..0xfbefffff -> 0xfbe00000
[    2.738538] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[    2.739191] rockchip-pcie f8000000.pcie: deferred probe failed
[    2.739954] rockchip-pcie: probe of f8000000.pcie failed with error -110
[    2.741778] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[    2.742726] rk-vcodec ff650000.vpu_service: probe device
[    2.743462] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[    2.744629] rk-vcodec ff650000.vpu_service: could not find power_model node
[    2.745268] rk-vcodec ff650000.vpu_service: init success
[    2.745993] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[    2.746968] rk-vcodec ff660000.rkvdec: probe device
[    2.747626] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[    2.748643] rk-vcodec ff660000.rkvdec: could not find power_model node
[    2.749237] rk-vcodec ff660000.rkvdec: init success
[    2.751194] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    2.751894] dma-pl330 ff6d0000.dma-controller:       DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[    2.754145] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    2.754859] dma-pl330 ff6e0000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    2.756704] rockchip-system-monitor rockchip-system-monitor: system monitor probe
Trying to boot legacy Armbian_20.11.10_Firefly-rk3399_bionic_legacy_4.4.213_desktop
12.02.2021 в 20:11, denni_isl сказал:
ArmbianEnv.txt
What dtbs are included in the image ? Add a line to armbianEnv specifying how DTB should be enforced.
How does one do that correctly?
Did try -
fdtfile=rk3399-firefly.dtb
4 hours ago, balbes150 said:
fdtfile=rockchip/rk3399-firefly.dtb
verbosity=7
bootlogo=false
rootdev=UUID=e4ee432b-e6cf-43d2-aca5-c26b7fca040e
rootfstype=ext4
In
256B stride
OUT
CPUId = 0x0
SdmmcInit=2 0
BootCapSize=100000
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=61056MB
StorageInit ok = 65347
SecureMode = 0
recovery gpt...
recovery gpt fail!
No find bl30.bin
No find bl32.bin
RunBL31 0x40000
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SK
INFO:    SPSR = 0x3c9
Reset cause: POR
DRAM:  3.9 GiB
PMIC:  RK808
In:    serial@ff1a0000
Scanning mmc 1:1...
153 bytes read in 4 ms (37.1 KiB/s)
15339744 bytes read in 652 ms (22.4 MiB/s)
28582400 bytes read in 1210 ms (22.5 MiB/s)
2698 bytes read in 8 ms (329.1 KiB/s)
   Image Name:   uInitrd
   Data Size:    15339680 Bytes = 14.6 MiB
   Loading Ramdisk to f507d000, end f5f1e0a0 ... OK
Starting kernel ...
5 hours ago, balbes150 said:
Try using other dtbs (roc-pc-plus, roc-mezzanine, rock-pi-4b etc)
Some progress,  rk3399-nanopi-m4.dtb does bring everyting up exept hdmi - the others on the list did just end at Starting kernel .....
rk3399-orangepi-4.dtb does also bring up the board.
verbosity=7
bootlogo=false
#fdtfile=rockchip/rk3399-firefly.dtb
#fdtfile=rockchip/rk3399-roc-pc-plus.dtb
#fdtfile=rockchip/rk3399-roc-pc.dtb
#fdtfile=rockchip/rk3399-rock-pi-4b.dtb
#fdtfile=rockchip/rk3399-rockpro64.dtb
#fdtfile=rockchip/rk3399-roc-pc-mezzanine.dtb
fdtfile=rockchip/rk3399-nanopi-m4.dtb
#fdtfile=rockchip/rk3399-orangepi-4.dtb
rootfstype=ext4
ïDDR Version 1.24 20191016
In
256B stride
OUT
CPUId = 0x0
ChipType = 0x10, 241
SdmmcInit=2 0
BootCapSize=100000
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=61056MB
StorageInit ok = 259304
SecureMode = 0
recovery gpt...
recovery gpt fail!
No find bl30.bin
No find bl32.bin
RunBL31 0x40000
INFO:    SPSR = 0x3c9
Reset cause: POR
DRAM:  3.9 GiB
PMIC:  RK808
In:    serial@ff1a0000
Scanning mmc 1:1...
434 bytes read in 5 ms (84 KiB/s)
28582400 bytes read in 1211 ms (22.5 MiB/s)
75124 bytes read in 11 ms (6.5 MiB/s)
   Image Name:   uInitrd
Starting kernel ...
[    0.000000] Machine model: FriendlyElec NanoPi M4
[    0.000000] Kernel command line: root=UUID=e4ee432b-e6cf-43d2-aca5-c26b7fca01
[    0.000000] Memory: 3739812K/4061184K available (14848K kernel code, 2632K r)
[    0.001369] Console: colour dummy device 80x25
[    0.002432] printk: console [tty1] enabled
[    0.002572] Calibrating delay loop (skipped), value calculated using timer f)
[    0.002619] pid_max: default: 32768 minimum: 301
[    0.002799] LSM: Security Framework initializing
[    0.002855] Yama: becoming mindful.
[    0.003010] AppArmor: AppArmor initialized
[    0.003127] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, lin)
[    0.003182] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.006796] rcu: Hierarchical SRCU implementation.
[    0.007999] Platform MSI: interrupt-controller@fee20000 domain created
[    0.008524] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@feed
[    0.010823] EFI services will not be available.
[    0.011532] smp: Bringing up secondary CPUs ...
[    0.012628] Detected VIPT I-cache on CPU1
[    0.012672] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.012689] GICv3: CPU1: using allocated LPI pending table @0x00000000400f000
[    0.012757] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.013869] Detected VIPT I-cache on CPU2
[    0.013903] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.013918] GICv3: CPU2: using allocated LPI pending table @0x000000004018000
[    0.013965] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.015068] Detected VIPT I-cache on CPU3
[    0.015101] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.015117] GICv3: CPU3: using allocated LPI pending table @0x000000004019000
[    0.015163] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.016296] CPU features: detected: Spectre-v2
[    0.016304] CPU features: detected: Spectre-v4
[    0.016309] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.016317] Detected PIPT I-cache on CPU4
[    0.016354] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000
[    0.016369] GICv3: CPU4: using allocated LPI pending table @0x00000000401a000
[    0.016418] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
[    0.017477] Detected PIPT I-cache on CPU5
[    0.017507] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000
[    0.017520] GICv3: CPU5: using allocated LPI pending table @0x00000000401b000
[    0.017558] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
[    0.017728] smp: Brought up 1 node, 6 CPUs
[    0.018139] SMP: Total of 6 processors activated.
[    0.018165] CPU features: detected: 32-bit EL0 Support
[    0.018190] CPU features: detected: CRC32 instructions
[    0.018216] CPU features: detected: 32-bit EL1 Support
[    0.044870] CPU: All CPU(s) started at EL2
[    0.044965] alternatives: patching kernel code
[    0.048683] devtmpfs: initialized
[    0.065882] Registered cp15_barrier emulation handler
[    0.065922] Registered setend emulation handler
[    0.066166] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ms
[    0.066246] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.069226] pinctrl core: initialized pinctrl subsystem
[    0.069904] DMI not present or invalid.
[    0.070480] NET: Registered protocol family 16
[    0.073833] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.075240] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic als
[    0.075987] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic s
[    0.076104] audit: initializing netlink subsys (disabled)
[    0.076443] audit: type=2000 audit(0.076:1): state=initialized audit_enabled1
[    0.077705] thermal_sys: Registered thermal governor 'fair_share'
[    0.077713] thermal_sys: Registered thermal governor 'bang_bang'
[    0.077735] thermal_sys: Registered thermal governor 'step_wise'
[    0.077750] thermal_sys: Registered thermal governor 'user_space'
[    0.078232] cpuidle: using governor menu
[    0.078574] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.078807] ASID allocator initialised with 65536 entries
[    0.080058] Serial: AMBA PL011 UART driver
[    0.138355] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.138384] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.138403] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.138422] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.144925] cryptd: max_cpu_qlen set to 1000
[    0.224295] raid6: neonx8   gen()  1665 MB/s
[    0.292451] raid6: neonx8   xor()  1212 MB/s
[    0.360635] raid6: neonx4   gen()  1696 MB/s
[    0.428800] raid6: neonx4   xor()  1246 MB/s
[    0.496988] raid6: neonx2   gen()  1511 MB/s
[    0.565151] raid6: neonx2   xor()  1152 MB/s
[    0.633324] raid6: neonx1   gen()  1185 MB/s
[    0.701501] raid6: neonx1   xor()   928 MB/s
[    0.769669] raid6: int64x8  gen()   995 MB/s
[    0.837858] raid6: int64x8  xor()   578 MB/s
[    0.905989] raid6: int64x4  gen()   990 MB/s
[    0.974128] raid6: int64x4  xor()   591 MB/s
[    1.042291] raid6: int64x2  gen()   928 MB/s
[    1.110449] raid6: int64x2  xor()   524 MB/s
[    1.178608] raid6: int64x1  gen()   723 MB/s
[    1.246760] raid6: int64x1  xor()   391 MB/s
[    1.246775] raid6: using algorithm neonx4 gen() 1696 MB/s
[    1.246790] raid6: .... xor() 1246 MB/s, rmw enabled
[    1.246805] raid6: using neon recovery algorithm
[    1.251027] vcc5v0_sys: supplied by vdd_5v
[    1.251186] vbus_typec: supplied by vdd_5v
[    1.251286] vcc5v0_core: supplied by vdd_5v
[    1.251717] vcc3v3_sys: supplied by vcc5v0_core
[    1.251807] vcc3v0_sd: supplied by vcc3v3_sys
[    1.251921] vcc5v0_usb1: supplied by vcc5v0_sys
[    1.252400] vcc5v0_usb2: supplied by vcc5v0_sys
[    1.252860] iommu: Default domain type: Translated
[    1.256287] vgaarb: loaded
[    1.256815] SCSI subsystem initialized
[    1.257335] usbcore: registered new interface driver usbfs
[    1.257395] usbcore: registered new interface driver hub
[    1.257454] usbcore: registered new device driver usb
[    1.258110] pps_core: LinuxPPS API ver. 1 registered
[    1.258128] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giom>
[    1.258159] PTP clock support registered
[    1.258461] EDAC MC: Ver: 3.0.0
[    1.259741] NetLabel: Initializing
[    1.259761] NetLabel:  domain hash size = 128
[    1.259775] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    1.259860] NetLabel:  unlabeled traffic allowed by default
[    1.260392] clocksource: Switched to clocksource arch_sys_counter
[    1.383526] VFS: Disk quotas dquot_6.6.0
[    1.383622] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.384523] AppArmor: AppArmor Filesystem Enabled
[    1.395397] NET: Registered protocol family 2
[    1.396336] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 327)
[    1.396625] TCP established hash table entries: 32768 (order: 6, 262144 byte)
[    1.397167] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, line)
[    1.397847] TCP: Hash tables configured (established 32768 bind 32768)
[    1.398060] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    1.398236] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    1.398585] NET: Registered protocol family 1
[    1.398629] NET: Registered protocol family 44
[    1.398652] PCI: CLS 0 bytes, default 64
[    1.398889] Trying to unpack rootfs image as initramfs...
[    2.505029] Freeing initrd memory: 14980K
[    2.506266] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counte
[    2.506717] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counte
[    2.507421] kvm [1]: IPA Size Limit: 40 bits
[    2.508617] kvm [1]: vgic-v2@fff20000
[    2.508665] kvm [1]: GIC system register CPU interface enabled
[    2.508938] kvm [1]: vgic interrupt IRQ18
[    2.509257] kvm [1]: Hyp mode initialized successfully
[    2.520913] Initialise system trusted keyrings
[    2.520973] Key type blacklist registered
[    2.521235] workingset: timestamp_bits=44 max_order=20 bucket_order=0
[    2.527635] zbud: loaded
[    2.529403] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    2.530247] fuse: init (API version 7.32)
[    2.531623] integrity: Platform Keyring initialized
[    2.597614] xor: measuring software checksum speed
[    2.601543]    8regs           :  2531 MB/sec
[    2.604947]    32regs          :  2917 MB/sec
[    2.609076]    arm64_neon      :  2399 MB/sec
[    2.609092] xor: using function: 32regs (2917 MB/sec)
[    2.609114] Key type asymmetric registered
[    2.609129] Asymmetric key parser 'x509' registered
[    2.609180] Block layer SCSI generic (bsg) driver version 0.4 loaded (major )
[    2.609388] io scheduler mq-deadline registered
[    2.609406] io scheduler kyber registered
[    2.609546] io scheduler bfq registered
[    2.628163] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
[    2.628210] OF: /pcie@f8000000: Missing device_type
[    2.628251] rockchip-pcie f8000000.pcie:      MEM 0x00fa000000..0x00fbdfffff0
[    2.628288] rockchip-pcie f8000000.pcie:       IO 0x00fbe00000..0x00fbefffff0
[    2.629196] rockchip-pcie f8000000.pcie: no vpcie12v regulator found
[    2.629238] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[    2.636958] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-0
[    2.636989] dma-pl330 ff6d0000.dma-controller:       DBUFF-32x8bytes Num_Cha2
[    2.638483] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-0
[    2.638510] dma-pl330 ff6e0000.dma-controller:       DBUFF-128x8bytes Num_Ch6
[    2.644418] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    2.647947] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 47, base_baud =A
[    2.648141] serial serial0: tty port ttyS0 registered
[    2.649003] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 48, base_baud =A
[    2.764309] printk: console [ttyS2] enabled
[    2.766064] Serial: AMBA driver
[    2.767805] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    2.780279] loop: module loaded
[    2.786078] libphy: Fixed MDIO Bus: probed
[    2.787094] tun: Universal TUN/TAP device driver, 1.6
[    2.788649] thunder_xcv, ver 1.0
[    2.788988] thunder_bgx, ver 1.0
[    2.789322] nicpf, ver 1.0
[    2.790677] e1000e: Intel(R) PRO/1000 Network Driver
[    2.791125] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    2.791698] igb: Intel(R) Gigabit Ethernet Network Driver
[    2.792183] igb: Copyright (c) 2007-2014 Intel Corporation.
[    2.792736] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    2.793296] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    2.794119] sky2: driver version 1.30
[    2.795161] VFIO - User Level meta-driver version: 0.3
[    2.804636] OF: graph: no port node found in /syscon@ff770000/usb2-phy@e450/t
[    2.821452] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.822061] ehci-pci: EHCI PCI platform driver
[    2.822502] ehci-platform: EHCI generic platform driver
[    2.825366] ehci-platform fe380000.usb: EHCI Host Controller
[    2.825898] ehci-platform fe380000.usb: new USB bus registered, assigned bus1
[    2.826743] ehci-platform fe380000.usb: irq 39, io mem 0xfe380000
[    2.840411] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[    2.841221] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, b0
[    2.841963] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber1
[    2.842610] usb usb1: Product: EHCI Host Controller
[    2.843049] usb usb1: Manufacturer: Linux 5.10.12-rockchip64 ehci_hcd
[    2.843625] usb usb1: SerialNumber: fe380000.usb
[    2.844684] hub 1-0:1.0: USB hub found
[    2.845066] hub 1-0:1.0: 1 port detected
[    2.848199] ehci-platform fe3c0000.usb: EHCI Host Controller
[    2.848750] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus2
[    2.849575] ehci-platform fe3c0000.usb: irq 41, io mem 0xfe3c0000
[    2.864409] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[    2.865187] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, b0
[    2.865928] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber1
[    2.866574] usb usb2: Product: EHCI Host Controller
[    2.867014] usb usb2: Manufacturer: Linux 5.10.12-rockchip64 ehci_hcd
[    2.867590] usb usb2: SerialNumber: fe3c0000.usb
[    2.868562] hub 2-0:1.0: USB hub found
[    2.868940] hub 2-0:1.0: 1 port detected
[    2.870034] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.870605] ohci-pci: OHCI PCI platform driver
[    2.871057] ohci-platform: OHCI generic platform driver
[    2.871852] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[    2.872497] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus3
[    2.873344] ohci-platform fe3a0000.usb: irq 40, io mem 0xfe3a0000
[    2.936624] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, b0
[    2.937365] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber1
[    2.938011] usb usb3: Product: Generic Platform OHCI controller
[    2.938542] usb usb3: Manufacturer: Linux 5.10.12-rockchip64 ohci_hcd
[    2.939116] usb usb3: SerialNumber: fe3a0000.usb
[    2.940050] hub 3-0:1.0: USB hub found
[    2.940460] hub 3-0:1.0: 1 port detected
[    2.941513] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[    2.942129] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus4
[    2.942947] ohci-platform fe3e0000.usb: irq 42, io mem 0xfe3e0000
[    3.004592] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, b0
[    3.005333] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber1
[    3.005979] usb usb4: Product: Generic Platform OHCI controller
[    3.006509] usb usb4: Manufacturer: Linux 5.10.12-rockchip64 ohci_hcd
[    3.007084] usb usb4: SerialNumber: fe3e0000.usb
[    3.008018] hub 4-0:1.0: USB hub found
[    3.008428] hub 4-0:1.0: 1 port detected
[    3.010324] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.010837] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus n5
[    3.011690] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110
[    3.012575] xhci-hcd xhci-hcd.0.auto: irq 78, io mem 0xfe800000
[    3.013513] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, b0
[    3.014255] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber1
[    3.014901] usb usb5: Product: xHCI Host Controller
[    3.015341] usb usb5: Manufacturer: Linux 5.10.12-rockchip64 xhci-hcd
[    3.015916] usb usb5: SerialNumber: xhci-hcd.0.auto
[    3.016928] hub 5-0:1.0: USB hub found
[    3.017315] hub 5-0:1.0: 1 port detected
[    3.018019] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.018524] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus n6
[    3.019217] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    3.019874] usb usb6: We don't know the algorithms for LPM for this host, di.
[    3.020787] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, b0
[    3.021529] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber1
[    3.022175] usb usb6: Product: xHCI Host Controller
[    3.022613] usb usb6: Manufacturer: Linux 5.10.12-rockchip64 xhci-hcd
[    3.023189] usb usb6: SerialNumber: xhci-hcd.0.auto
[    3.024149] hub 6-0:1.0: USB hub found
[    3.024586] hub 6-0:1.0: 1 port detected
[    3.025530] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    3.026040] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus n7
[    3.026888] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe64 hci version 0x110
[    3.027776] xhci-hcd xhci-hcd.1.auto: irq 79, io mem 0xfe900000
[    3.028746] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, b0
[    3.029487] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber1
[    3.030133] usb usb7: Product: xHCI Host Controller
[    3.030572] usb usb7: Manufacturer: Linux 5.10.12-rockchip64 xhci-hcd
[    3.031149] usb usb7: SerialNumber: xhci-hcd.1.auto
[    3.032127] hub 7-0:1.0: USB hub found
[    3.032536] hub 7-0:1.0: 1 port detected
[    3.033238] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    3.033742] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus n8
[    3.034453] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[    3.035111] usb usb8: We don't know the algorithms for LPM for this host, di.
[    3.035970] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, b0
[    3.036727] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber1
[    3.037373] usb usb8: Product: xHCI Host Controller
[    3.037814] usb usb8: Manufacturer: Linux 5.10.12-rockchip64 xhci-hcd
[    3.038388] usb usb8: SerialNumber: xhci-hcd.1.auto
[    3.039352] hub 8-0:1.0: USB hub found
[    3.039728] hub 8-0:1.0: 1 port detected
[    3.040679] usbcore: registered new interface driver usb-storage
[    3.043770] mousedev: PS/2 mouse device common for all mice
[    3.045653] i2c /dev entries driver
[    3.054564] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    3.056744] vdd_cpu_b: supplied by vcc3v3_sys
[    3.060420] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[    3.062548] vdd_gpu: supplied by vcc3v3_sys
[    3.067240] rk808 0-001b: chip id: 0x0
[    3.071843] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    3.072494] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    3.073950] vdd_center: supplied by vcc3v3_sys
[    3.075010] vdd_cpu_l: supplied by vcc3v3_sys
[    3.075733] vcc_ddr: supplied by vcc3v3_sys
[    3.076948] vcc_1v8: supplied by vcc3v3_sys
[    3.078685] vcc1v8_cam: supplied by vcc3v3_sys
[    3.079375] vcc3v0_touch: Bringing 2800000uV into 3000000-3000000uV
[    3.080827] vcc3v0_touch: supplied by vcc3v3_sys
[    3.082442] vcc1v8_pmupll: supplied by vcc3v3_sys
[    3.084071] vcc_sdio: supplied by vcc3v3_sys
[    3.085541] vcca3v0_codec: supplied by vcc3v3_sys
[    3.087167] vcc_1v5: supplied by vcc3v3_sys
[    3.088641] vcca1v8_codec: supplied by vcc3v3_sys
[    3.090278] vcc_3v0: supplied by vcc3v3_sys
[    3.091018] vcc3v3_s3: supplied by vcc3v3_sys
[    3.091799] vcc3v3_s0: supplied by vcc3v3_sys
[    3.096015] rk808-rtc rk808-rtc: registered as rtc0
[    3.096587] random: fast init done
[    3.097392] rk808-rtc rk808-rtc: setting system clock to 2013-01-18T08:50:10)
[    3.104708] dw_wdt ff848000.watchdog: No valid TOPs array specified
[    3.107384] sdhci: Secure Digital Host Controller Interface driver
[    3.107942] sdhci: Copyright(c) Pierre Ossman
[    3.108359] Synopsys Designware Multimedia Card Interface Driver
[    3.110306] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.110931] dwmmc_rockchip fe310000.mmc: IDMAC supports 32-bit address mode.
[    3.111177] dwmmc_rockchip fe320000.mmc: IDMAC supports 32-bit address mode.
[    3.111609] dwmmc_rockchip fe310000.mmc: Using internal DMA controller.
[    3.112240] dwmmc_rockchip fe320000.mmc: Using internal DMA controller.
[    3.112852] dwmmc_rockchip fe310000.mmc: Version ID is 270a
[    3.112901] mmc2: CQHCI version 5.10
[    3.113453] dwmmc_rockchip fe320000.mmc: Version ID is 270a
[    3.113555] dwmmc_rockchip fe320000.mmc: DW MMC controller at irq 37,32 bit o
[    3.114091] dwmmc_rockchip fe310000.mmc: DW MMC controller at irq 36,32 bit o
[    3.114388] ledtrig-cpu: registered to indicate activity on CPUs
[    3.115141] dwmmc_rockchip fe320000.mmc: Got CD GPIO
[    3.115237] dwmmc_rockchip fe310000.mmc: allocated mmc-pwrseq
[    3.115249] mmc_host mmc0: card is non-removable.
[    3.116788] hid: raw HID events driver (C) Jiri Kosina
[    3.119067] usbcore: registered new interface driver usbhid
[    3.119569] usbhid: USB HID core driver
[    3.123764] vcc1v8_s3: supplied by vcc_1v8
[    3.124213] vcca1v8_s3: supplied by vcc1v8_s3
[    3.126549] drop_monitor: Initializing network drop monitor service
[    3.127923] NET: Registered protocol family 10
[    3.128601] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz,)
[    3.130109] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz,)
[    3.139025] mmc2: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using A
[    3.173266] Segment Routing with IPv6
[    3.173704] NET: Registered protocol family 17
[    3.174358] 8021q: 802.1Q VLAN Support v1.8
[    3.174795] Key type dns_resolver registered
[    3.175517] mmc0: queuing unknown CIS tuple 0x80 (2 bytes)
[    3.175744] registered taskstats version 1
[    3.176442] Loading compiled-in X.509 certificates
[    3.177648] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[    3.179759] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[    3.180457] Loaded X.509 cert 'Build time autogenerated kernel key: f47c1788'
[    3.183136] mmc0: queuing unknown CIS tuple 0x80 (7 bytes)
[    3.187511] zswap: loaded using pool zstd/z3fold
[    3.188372] Key type ._fscrypt registered
[    3.188777] Key type .fscrypt registered
[    3.189133] Key type fscrypt-provisioning registered
[    3.192590] Btrfs loaded, crc32c=crc32c-generic
[    3.193671] mmc_host mmc1: Bus speed (slot 0) = 148500000Hz (slot req 150000)
[    3.195918] dwmmc_rockchip fe320000.mmc: All phases bad!
[    3.196423] mmc1: tuning execution failed: -5
[    3.196825] mmc1: error -5 whilst initialising SD card
[    3.208431] usb 2-1: new high-speed USB device number 2 using ehci-platform
[    3.211402] mmc2: Command Queue Engine enabled
[    3.211825] mmc2: new HS200 MMC card at address 0001
[    3.213068] mmcblk2: mmc2:0001 DJNB4R 116 GiB
[    3.213718] mmcblk2boot0: mmc2:0001 DJNB4R partition 1 4.00 MiB
[    3.214493] mmcblk2boot1: mmc2:0001 DJNB4R partition 2 4.00 MiB
[    3.215263] mmcblk2rpmb: mmc2:0001 DJNB4R partition 3 4.00 MiB, chardev (243)
[    3.215910] Key type encrypted registered
[    3.216303] AppArmor: AppArmor sha1 policy hashing enabled
[    3.217138]  mmcblk2: p1
[    3.220499] mmc_host mmc1: Bus speed (slot 0) = 300000Hz (slot req 300000Hz,)
[    3.240996] mmc_host mmc0: Bus speed (slot 0) = 148500000Hz (slot req 150000)
[    3.265766] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
[    3.266438] rockchip-pcie f8000000.pcie:      MEM 0x00fa000000..0x00fbdfffff0
[    3.267206] rockchip-pcie f8000000.pcie:       IO 0x00fbe00000..0x00fbefffff0
[    3.268872] rockchip-pcie f8000000.pcie: no vpcie12v regulator found
[    3.269479] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[    3.270228] vcca0v9_s3: supplied by vcc1v8_s3
[    3.282363] mmc_host mmc1: Bus speed (slot 0) = 148500000Hz (slot req 150000)
[    3.284550] dwmmc_rockchip fe320000.mmc: All phases bad!
[    3.285033] mmc1: tuning execution failed: -5
[    3.313208] mmc_host mmc1: Bus speed (slot 0) = 300000Hz (slot req 300000Hz,)
[    3.356253] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 5000000)
[    3.357244] mmc1: new high speed SDXC card at address 0001
[    3.358842] mmcblk1: mmc1:0001 EC2QT 59.6 GiB
[    3.362357]  mmcblk1: p1
[    3.365054] usb 2-1: New USB device found, idVendor=1a40, idProduct=0201, bc0
[    3.365794] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    3.366431] usb 2-1: Product: USB 2.0 Hub [MTT]
[    3.367442] hub 2-1:1.0: USB hub found
[    3.367921] hub 2-1:1.0: 7 ports detected
[    3.501235] dwmmc_rockchip fe310000.mmc: Successfully tuned phase to 198
[    3.504675] mmc0: new ultra high speed SDR104 SDIO card at address 0001
[    3.656408] usb 2-1.3: new high-speed USB device number 3 using ehci-platform
[    3.765045] usb 2-1.3: New USB device found, idVendor=1a40, idProduct=0101, 1
[    3.765795] usb 2-1.3: New USB device strings: Mfr=0, Product=1, SerialNumbe0
[    3.766449] usb 2-1.3: Product: USB 2.0 Hub
[    3.767444] hub 2-1.3:1.0: USB hub found
[    3.767914] hub 2-1.3:1.0: 4 ports detected
[    3.796460] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[    3.797936] rockchip-pcie: probe of f8000000.pcie failed with error -110
[    3.802764] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    3.803867] of_cfs_init
[    3.804136] of_cfs_init: OK
[    3.808110] Freeing unused kernel memory: 4352K
[    3.824526] Run /init as init process
[    3.848455] usb 2-1.4: new high-speed USB device number 4 using ehci-platform
[    3.970805] usb 2-1.4: New USB device found, idVendor=0d8c, idProduct=0004, 8
[    3.971566] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumbe0
[    3.972220] usb 2-1.4: Product: USB2.0 High-Speed True HD Audio
[    3.972771] usb 2-1.4: Manufacturer: C-Media Electronics Inc.
[    3.978166] input: C-Media Electronics Inc. USB2.0 High-Speed True HD Audio 1
[    4.036895] hid-generic 0003:0D8C:0004.0001: input,hidraw0: USB HID v1.00 De2
[    4.164428] usb 2-1.3.2: new full-speed USB device number 5 using ehci-platfm
[    4.403326] usb 2-1.3.2: language id specifier not provided by device, defauh
[    4.413063] usb 2-1.3.2: New USB device found, idVendor=0c45, idProduct=74031
[    4.413840] usb 2-1.3.2: New USB device strings: Mfr=1, Product=2, SerialNum0
[    4.417884] input: HID 0c45:7403 as /devices/platform/fe3c0000.usb/usb2/2-1/2
[    4.477426] hid-generic 0003:0C45:7403.0002: input,hidraw1: USB HID v1.00 Ke0
[    4.480840] input: HID 0c45:7403 as /devices/platform/fe3c0000.usb/usb2/2-1/3
[    4.482498] hid-generic 0003:0C45:7403.0003: input,hidraw2: USB HID v1.10 Mo1
[    4.521989] rk_gmac-dwmac fe300000.ethernet: IRQ eth_wake_irq not found
[    4.522618] rk_gmac-dwmac fe300000.ethernet: IRQ eth_lpi not found
[    4.523387] rk_gmac-dwmac fe300000.ethernet: PTP uses main clock
[    4.524343] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[    4.531370] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[    4.531914] rk_gmac-dwmac fe300000.ethernet: RX delay(0x11).
[    4.532478] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[    4.533171] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[    4.533806] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[    4.539395] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[    4.544497] rk_gmac-dwmac fe300000.ethernet: User ID: 0x10, Synopsys ID: 0x35
[    4.545154] rk_gmac-dwmac fe300000.ethernet:         DWMAC1000
[    4.545628] rk_gmac-dwmac fe300000.ethernet: DMA HW capability register suppd
[    4.546298] rk_gmac-dwmac fe300000.ethernet: RX Checksum Offload Engine suppd
[    4.546965] rk_gmac-dwmac fe300000.ethernet: COE Type 2
[    4.547435] rk_gmac-dwmac fe300000.ethernet: TX Checksum insertion supported
[    4.548063] rk_gmac-dwmac fe300000.ethernet: Wake-Up On Lan supported
[    4.548770] rk_gmac-dwmac fe300000.ethernet: Normal descriptors
[    4.549306] rk_gmac-dwmac fe300000.ethernet: Ring mode enabled
[    4.549830] rk_gmac-dwmac fe300000.ethernet: Enable RX Mitigation via HW Watr
[    4.551752] libphy: stmmac: probed
[    4.577498] rockchip-vop ff8f0000.vop: Adding to iommu group 2
[    4.585802] rockchip-vop ff900000.vop: Adding to iommu group 3
[    4.600700] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_comp)
[    4.601749] [drm] unsupported AFBC format[3231564e]
[    4.617284] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_comp)
[    4.624974] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11)
[    4.629871] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi)
[    5.664448] rk3x-i2c ff160000.i2c: timeout, ipd: 0x91, state: 2
[    6.688457] rk3x-i2c ff160000.i2c: timeout, ipd: 0x80, state: 2
[    7.712429] rk3x-i2c ff160000.i2c: timeout, ipd: 0x80, state: 2
[    8.736428] rk3x-i2c ff160000.i2c: timeout, ipd: 0x80, state: 2
[    9.760432] rk3x-i2c ff160000.i2c: timeout, ipd: 0x80, state: 2
[    9.811482] Console: switching to colour frame buffer device 128x48
[    9.866429] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame be
[    9.881302] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem 0
[   10.194556] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode)
[   11.084598] systemd[1]: System time before build time, advancing clock.
[   11.113044] systemd[1]: Inserted module 'autofs4'
[   11.198627] systemd[1]: systemd 245.4-4ubuntu3.4 running in system mode. (+P)
[   11.202847] systemd[1]: Detected architecture arm64.
[   11.256531] systemd[1]: Set hostname to <firefly-rk3399>.
[   11.377704] dw-apb-uart ff1a0000.serial: forbid DMA for kernel console
[   11.701684] systemd[1]: /lib/systemd/system/dbus.socket:5: ListenStream= ref.
[   11.936452] rk3x-i2c ff160000.i2c: timeout, ipd: 0x80, state: 2
[   12.036055] random: systemd: uninitialized urandom read (16 bytes read)
[   12.044911] systemd[1]: Created slice system-modprobe.slice.
[   12.053902] random: systemd: uninitialized urandom read (16 bytes read)
[   12.059981] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   12.069057] random: systemd: uninitialized urandom read (16 bytes read)
[   12.074953] systemd[1]: Created slice User and Session Slice.
[   12.084208] systemd[1]: Started Forward Password Requests to Wall Directory .
[   12.094081] systemd[1]: Set up automount Arbitrary Executable File Formats F.
[   12.103730] systemd[1]: Reached target User and Group Name Lookups.
[   12.112825] systemd[1]: Reached target Remote File Systems.
[   12.122142] systemd[1]: Reached target Slices.
[   12.131379] systemd[1]: Reached target Swap.
[   12.140576] systemd[1]: Reached target System Time Set.
[   12.150289] systemd[1]: Listening on Syslog Socket.
[   12.160019] systemd[1]: Listening on fsck to fsckd communication Socket.
[   12.169546] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   12.179908] systemd[1]: Listening on Journal Audit Socket.
[   12.189625] systemd[1]: Listening on Journal Socket (/dev/log).
[   12.199278] systemd[1]: Listening on Journal Socket.
[   12.209063] systemd[1]: Listening on udev Control Socket.
[   12.218462] systemd[1]: Listening on udev Kernel Socket.
[   12.232899] systemd[1]: Mounting Huge Pages File System...
[   12.246817] systemd[1]: Mounting POSIX Message Queue File System...
[   12.261190] systemd[1]: Mounting Kernel Debug File System...
[   12.275265] systemd[1]: Mounting Kernel Trace File System...
[   12.290608] systemd[1]: Starting Restore / save the current clock...
[   12.304601] systemd[1]: Starting Set the console keyboard layout...
[   12.319690] systemd[1]: Starting Create list of static device nodes for the .
[   12.329139] systemd[1]: Condition check resulted in Load Kernel Module drm b.
[   12.338977] systemd[1]: Started Nameserver information manager.
[   12.349403] systemd[1]: Reached target Network (Pre).
[   12.362023] systemd[1]: Condition check resulted in Set Up Additional Binary.
[   12.366941] systemd[1]: Condition check resulted in File System Check on Roo.
[   12.383039] systemd[1]: Starting Load Kernel Modules...
[   12.396316] systemd[1]: Starting Remount Root and Kernel File Systems...
[   12.410016] systemd[1]: Starting udev Coldplug all Devices...
[   12.425457] systemd[1]: Mounted Huge Pages File System.
[   12.435019] systemd[1]: Mounted POSIX Message Queue File System.
[   12.444486] systemd[1]: Mounted Kernel Debug File System.
[   12.450498] EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remounto
[   12.461899] systemd[1]: Mounted Kernel Trace File System.
[   12.474059] systemd[1]: Finished Restore / save the current clock.
[   12.486332] systemd[1]: Finished Create list of static device nodes for the .
[   12.502240] systemd[1]: Finished Load Kernel Modules.
[   12.515583] systemd[1]: Finished Remount Root and Kernel File Systems.
[   12.531957] systemd[1]: Mounting FUSE Control File System...
[   12.546977] systemd[1]: Mounting Kernel Configuration File System...
[   12.562385] systemd[1]: Condition check resulted in Rebuild Hardware Databas.
[   12.573771] systemd[1]: Condition check resulted in Platform Persistent Stor.
[   12.593079] systemd[1]: Starting Load/Save Random Seed...
[   12.614547] systemd[1]: Starting Apply Kernel Variables...
[   12.628716] systemd[1]: Starting Create System Users...
[   12.642029] systemd[1]: Mounted FUSE Control File System.
[   12.651715] systemd[1]: Mounted Kernel Configuration File System.
[   12.960459] rk3x-i2c ff160000.i2c: timeout, ipd: 0x80, state: 2
[   13.984426] rk3x-i2c ff160000.i2c: timeout, ipd: 0x80, state: 2
[   14.278961] OF: graph: no port node found in /i2c@ff3d0000/typec-portc@22
[   14.650544] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4356-sdio f2
[   14.834441] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4356-sdio f2
[   14.849024] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4356/2 wl0: Mar  40
[   15.012442] rk3x-i2c ff160000.i2c: timeout, ipd: 0x80, state: 2
[   16.032485] rk3x-i2c ff160000.i2c: timeout, ipd: 0x80, state: 2
firefly-rk3399 login: root (automatic login)
 _____ _           __ _         ____  _  ____________ ___   ___
|  ___(_)_ __ ___ / _| |_   _  |  _ \| |/ /___ /___ // _ \ / _ \
| |_  | | '__/ _ \ |_| | | | | | |_) | ' /  |_ \ |_ \ (_) | (_) |
|  _| | | | |  __/  _| | |_| | |  _ <| . \ ___) |__) \__, |\__, |
|_|   |_|_|  \___|_| |_|\__, | |_| \_\_|\_\____/____/  /_/   /_/
                        |___/
Welcome to Armbian 21.02.1 Focal with Linux 5.10.12-rockchip64
No end-user support: community creations
System load:   50%              Up time:       1 min
Memory usage:  8% of 3.71G      IP:
CPU temp:      44°C            Usage of /:    5% of 59G
[ General system configuration (beta): armbian-config ]
New to Armbian? Documentation: https://docs.armbian.com Support: https://forum.m
New root password:
Password:
                        |___/
System load:   9%               Up time:       3 min
Memory usage:  4% of 3.71G      IP:
CPU temp:      36°C            Usage of /:    5% of 59G
[ 0 security updates available, 2 updates total: apt upgrade ]
Last check: 2021-02-04 13:28
Last login: Thu Feb  4 13:28:27 UTC 2021 on tty1
New root password: ******
Repeat password: ******
Choose default system command shell:
1) bash
2) zsh
Shell: BASH
Creating a new user account. Press <Ctrl-C> to abort
Desktop environment will not be enabled if you abort the new user creation
Please provide a username (eg. your forename):
Please provide a username (eg. your forename): denni
Create password: ******
Please provide your real name: Denni
Dear Denni, your account denni has been created and is sudo enabled.
Please use this account for your daily work from now on.
Now starting desktop environment...
root@firefly-rk3399:~# [  271.040440] rk3x-i2c ff160000.i2c: timeout, ipd: 0x802
[  272.064473] rk3x-i2c ff160000.i2c: timeout, ipd: 0x80, state: 2
[  273.088518] rk3x-i2c ff160000.i2c: timeout, ipd: 0x80, state: 2
[  274.112476] rk3x-i2c ff160000.i2c: timeout, ipd: 0x80, state: 2
[  275.136477] rk3x-i2c ff160000.i2c: timeout, ipd: 0x80, state: 2
[  276.160482] rk3x-i2c ff160000.i2c: timeout, ipd: 0x80, state: 2
[  277.184482] rk3x-i2c ff160000.i2c: timeout, ipd: 0x80, state: 2
[  278.208473] rk3x-i2c ff160000.i2c: timeout, ipd: 0x80, state: 2
[  279.232475] rk3x-i2c ff160000.i2c: timeout, ipd: 0x80, state: 2
[  280.256474] rk3x-i2c ff160000.i2c: timeout, ipd: 0x80, state: 2
[  282.097381] rockchip-i2s ff8a0000.i2s: Fail to set mclk -22
[  282.097876] rockchip-i2s ff8a0000.i2s: ASoC: error at snd_soc_dai_set_sysclk2
[  282.099116] rockchip-i2s ff8a0000.i2s: Fail to set mclk -22
[  282.099607] rockchip-i2s ff8a0000.i2s: ASoC: error at snd_soc_dai_set_sysclk2
[  282.100847] rockchip-i2s ff8a0000.i2s: Fail to set mclk -22
[  282.101338] rockchip-i2s ff8a0000.i2s: ASoC: error at snd_soc_dai_set_sysclk2
[  282.102598] rockchip-i2s ff8a0000.i2s: Fail to set mclk -22
[  282.103088] rockchip-i2s ff8a0000.i2s: ASoC: error at snd_soc_dai_set_sysclk2
[  282.104367] rockchip-i2s ff8a0000.i2s: Fail to set mclk -22
[  282.104896] rockchip-i2s ff8a0000.i2s: ASoC: error at snd_soc_dai_set_sysclk2
[  282.106309] rockchip-i2s ff8a0000.i2s: Fail to set mclk -22
[  282.106801] rockchip-i2s ff8a0000.i2s: ASoC: error at snd_soc_dai_set_sysclk2
[  287.222137] rockchip-i2s ff8a0000.i2s: Fail to set mclk -22
[  287.222735] rockchip-i2s ff8a0000.i2s: ASoC: error at snd_soc_dai_set_sysclk2
[  287.328397] rk3x-i2c ff160000.i2c: timeout, ipd: 0x80, state: 2
[  288.352397] rk3x-i2c ff160000.i2c: timeout, ipd: 0x80, state: 2
[  289.376515] rk3x-i2c ff160000.i2c: timeout, ipd: 0x80, state: 2
[  290.400461] rk3x-i2c ff160000.i2c: timeout, ipd: 0x80, state: 2
[  291.424437] rk3x-i2c ff160000.i2c: timeout, ipd: 0x80, state: 2
But no hdmi connection - just UART
^C
root@firefly-rk3399:~# ls
root@firefly-rk3399:~# uname -a
Linux firefly-rk3399 5.10.12-rockchip64 #21.02.1 SMP PREEMPT Wed Feb 3 20:55:02x
root@firefly-rk3399:~# cat /etc/os-release
NAME="Ubuntu"
VERSION="20.04.2 LTS (Focal Fossa)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Armbian 21.02.1 Focal"
VERSION_ID="20.04"
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-pol"
VERSION_CODENAME=focal
UBUNTU_CODENAME=focal
apt update - apt upgrade
and the new image boots up
[   44.293412] rockchip-i2s ff8a0000.i2s: Fail to set mclk -22
[   44.293904] rockchip-i2s ff8a0000.i2s: ASoC: error at snd_soc_dai_set_sysclk2
denni@firefly-rk3399:~$ [   49.359286] rockchip-i2s ff8a0000.i2s: Fail to set m2
[   49.359820] rockchip-i2s ff8a0000.i2s: ASoC: error at snd_soc_dai_set_sysclk2
^C
denni@firefly-rk3399:~$ ls
Desktop
Desktop
denni@firefly-rk3399:~$ uname -a
Linux firefly-rk3399 5.10.16-rockchip64 #21.02.2 SMP PREEMPT Sun Feb 14 21:35:0x
And the legacy kernel that does always boot up - mbian 21.02.1 Bullseye with Linux 4.4.213-rk3399.
[    2.715597] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-2
41330
[    2.716296] dma-pl330 ff6d0000.dma-controller:       DBUFF-32x8bytes Num_Chan
[    2.718568] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-2
41330
[    2.719281] dma-pl330 ff6e0000.dma-controller:       DBUFF-128x8bytes Num_Cha
[    2.721123] rockchip-system-monitor rockchip-system-monitor: system monitor p
robe
[    2.723158] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[    2.724419] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud =
1500000) is a 16550A
[    2.725735] ff370000.serial: ttyS4 at MMIO 0xff370000 (irq = 38, base_baud =
[    2.727589] [drm] Initialized drm 1.1.0 20060810
[    2.731608] [drm] Rockchip DRM driver version: v1.0.1
[    2.732402] rockchip-drm display-subsystem: dmc is disabled
[    2.733201] rockchip-vop ff900000.vop: missing rockchip,grf property
[    2.734035] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffffff8
008c77d50)
[    2.734821] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[    2.735575] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffffff8
008c77d50)
[    2.736356] ERROR: Bad of_node_put() on /hdmi@ff940000/ports/port/endpoint@1
[    2.736997] CPU: 5 PID: 1 Comm: swapper/0 Not tainted 4.4.213-rk3399 #14
[    2.737608] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (
DT)
[    2.738287] Call trace:
[    2.738536] [<ffffff800808803c>] dump_backtrace+0x0/0x21c
[    2.739035] [<ffffff800808827c>] show_stack+0x24/0x30
[    2.739500] [<ffffff80084e3c68>] dump_stack+0xa4/0xcc
[    2.739965] [<ffffff80089946c4>] of_node_release+0x3c/0xb0
[    2.740474] [<ffffff80084e5f4c>] kobject_put+0x168/0x1a4
[    2.740959] [<ffffff8008993cfc>] of_node_put+0x24/0x30
[    2.741435] [<ffffff800898f480>] __of_get_next_child+0x34/0x60
[    2.741968] [<ffffff800898f4ec>] of_get_next_child+0x40/0x64
[    2.742487] [<ffffff8008992f80>] of_graph_get_next_endpoint+0xf0/0x134
[    2.743080] [<ffffff8008610954>] drm_of_find_possible_crtcs+0x68/0xe4
[    2.743671] [<ffffff8008612fe0>] dw_hdmi_rockchip_bind+0xb8/0x5b8
[    2.744230] [<ffffff8008644b6c>] component_bind_all+0x134/0x200
[    2.744773] [<ffffff800861a73c>] rockchip_drm_bind+0x494/0x192c
[    2.745317] [<ffffff80086446a8>] try_to_bring_up_master.part.2+0xa0/0x114
[    2.745931] [<ffffff80086447ec>] component_master_add_with_match+0xd0/0x124
[    2.746568] [<ffffff80089c137c>] rockchip_drm_platform_probe+0x270/0x28c
[    2.747183] [<ffffff800864c440>] platform_drv_probe+0x5c/0xb0
[    2.747714] [<ffffff800864a270>] driver_probe_device+0x244/0x3a0
[    2.748268] [<ffffff800864a420>] __driver_attach+0x54/0xa0
[    2.748776] [<ffffff80086482d8>] bus_for_each_dev+0x88/0x98
[    2.749284] [<ffffff8008649bac>] driver_attach+0x30/0x3c
[    2.749769] [<ffffff8008649784>] bus_add_driver+0x1ec/0x230
[    2.750278] [<ffffff800864afa8>] driver_register+0xa0/0xd8
[    2.750786] [<ffffff800864c384>] __platform_driver_register+0x58/0x64
[    2.751377] [<ffffff8009214d28>] rockchip_drm_platform_driver_init+0x1c/0x24
[    2.752014] [<ffffff8008083134>] do_one_initcall+0x18c/0x194
[    2.752535] [<ffffff80091e0db8>] kernel_init_freeable+0x210/0x214
[    2.753091] [<ffffff8008bb8868>] kernel_init+0x18/0xfc
[    2.753564] [<ffffff8008082ef0>] ret_from_fork+0x10/0x20
[    2.754281] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[    2.754906] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus
 driver
[    2.755709] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a
 with HDCP (DWC HDMI 2.0 TX PHY)
[    2.757377] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffffff
8008c6ce18)
[    2.758120] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.758719] [drm] No driver support for vblank timestamp query.
[    2.759456] rockchip-drm display-subsystem: failed to parse loader memory
[    3.089513] rockchip-vop ff900000.vop: [drm:vop_crtc_enable] Update mode to 1
920x1080p60, type: 11
[    3.211203] Console: switching to colour frame buffer device 240x67
[    3.292438] rockchip-drm display-subsystem: fb0:  frame buffer device
[    3.326809] rc_core: IR keymap rc-cec not found
[    3.327372] Registered IR keymap rc-empty
[    3.327955] rc rc0: RC for dw_hdmi as /devices/platform/ff940000.hdmi/rc/rc0
[    3.329306] input: RC for dw_hdmi as /devices/platform/ff940000.hdmi/rc/rc0/i
nput0
[    3.330694] Unable to detect cache hierarchy for CPU 0
[    3.332494] brd: module loaded
[    3.339973] loop: module loaded
[    3.340919] lkdtm: No crash points registered, enable through debugfs
[    3.345252] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[    3.346102] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[    3.346810] rk_gmac-dwmac fe300000.ethernet: RX delay(0x11).
[    3.347502] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[    3.348470] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[    3.349290] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[    3.355013] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[    3.355834] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    3.356437]  Ring mode enabled
[    3.356801]  DMA HW capability register supported
[    3.357368]  Normal descriptors
[    3.357780]  RX Checksum Offload Engine supported (type 2)
[    3.358427]  TX Checksum insertion supported
[    3.358952]  Wake-Up On Lan supported
[    3.359439]  Enable RX Mitigation via HW Watchdog Timer
[    3.445760] libphy: stmmac: probed
[    3.446177] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[    3.446954] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[    3.449641] usbcore: registered new interface driver rndis_wlan
[    3.450642] Rockchip WiFi SYS interface (V1.00) ...
[    3.451399] usbcore: registered new interface driver cdc_ether
[    3.452137] usbcore: registered new interface driver rndis_host
[    3.454702] rockchip-dwc3 usb0: failed to get drvdata dwc3
[    3.460307] rockchip-dwc3 usb1: fail to get drvdata hcd
[    3.462689] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.463523] ehci-pci: EHCI PCI platform driver
[    3.464129] ehci-platform: EHCI generic platform driver
[    3.476363] ehci-platform fe3c0000.usb: EHCI Host Controller
[    3.484759] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus
number 1
[    3.493289] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[    3.510784] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[    3.519190] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    3.527526] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=
1
[    3.535925] usb usb1: Product: EHCI Host Controller
[    3.544120] usb usb1: Manufacturer: Linux 4.4.213-rk3399 ehci_hcd
[    3.552473] usb usb1: SerialNumber: fe3c0000.usb
[    3.561173] hub 1-0:1.0: USB hub found
[    3.565000] hub 1-0:1.0: 1 port detected
[    3.569424] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.573472] ohci-platform: OHCI generic platform driver
[    3.577952] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[    3.582227] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus
number 2
[    3.586482] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[    3.646905] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[    3.650925] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=
1
[    3.654957] usb usb2: Product: Generic Platform OHCI controller
[    3.658849] usb usb2: Manufacturer: Linux 4.4.213-rk3399 ohci_hcd
[    3.662701] usb usb2: SerialNumber: fe3e0000.usb
[    3.666891] hub 2-0:1.0: USB hub found
[    3.670502] hub 2-0:1.0: 1 port detected
[    3.675091] usbcore: registered new interface driver cdc_acm
[    3.678798] cdc_acm: USB Abstract Control Model driver for USB modems and ISD
N adapters
[    3.682758] usbcore: registered new interface driver cdc_wdm
[    3.686530] usbcore: registered new interface driver usbserial
[    3.690231] usbcore: registered new interface driver usbserial_generic
[    3.693959] usbserial: USB Serial support registered for generic
[    3.698623] usbcore: registered new interface driver iforce
[    3.702291] usbcore: registered new interface driver xpad
[    3.706025] usbcore: registered new interface driver usbtouchscreen
[    3.709626] <<-GTP-INFO->> GTP driver installing
[    3.713489] .. rk pwm remotectl v1.1 init
[    3.717114] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input
1
[    3.721098] remotectl-pwm ff420030.pwm: Missing psci property in the DT.
[    3.724952] sensor_register_slave:mma8452,id=17
[    3.728477] sensor_register_slave:lis3dh,id=7
[    3.731977] sensor_register_slave:mma7660,id=18
[    3.735466] sensor_register_slave:lsm303d,id=22
[    3.738937] sensor_register_slave:mpu6880_acc,id=24
[    3.742429] sensor_register_slave:mpu6500_acc,id=25
[    3.745896] sensor_register_slave:lsm330_acc,id=26
[    3.749328] sensor_register_slave:akm8975,id=30
[    3.752715] sensor_register_slave:akm8963,id=31
[    3.756071] sensor_register_slave:l3g4200d,id=45
[    3.759415] sensor_register_slave:l3g20d,id=46
[    3.762706] sensor_register_slave:ewtsa,id=47
[    3.765981] sensor_register_slave:lsm330_gyro,id=51
[    3.769284] sensor_register_slave:cm3217,id=53
[    3.772536] sensor_register_slave:cm3218,id=54
[    3.776217] i2c /dev entries driver
[    3.780652] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    3.784218] fan53555-reg: supplied by vcc5v0_sys
[    3.789771] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[    3.793298] fan53555-reg: supplied by vcc5v0_sys
[    3.799465] rk808 0-001b: Pmic Chip id: 0x0
[    3.805897] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    3.809412] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    3.812926] DCDC_REG1: supplied by vcc3v3_sys
[    3.816911] DCDC_REG2: supplied by vcc3v3_sys
[    3.820708] DCDC_REG3: supplied by vcc3v3_sys
[    3.824181] DCDC_REG4: supplied by vcc3v3_sys
[    3.827786] LDO_REG1: supplied by vcc3v3_sys
[    3.832035] LDO_REG2: supplied by vcc3v3_sys
[    3.836109] LDO_REG3: supplied by vcc3v3_sys
[    3.840167] LDO_REG4: supplied by vcc3v3_sys
[    3.844144] LDO_REG5: supplied by vcc3v3_sys
[    3.848076] LDO_REG6: supplied by vcc3v3_sys
[    3.851969] LDO_REG7: supplied by vcc3v3_sys
[    3.855833] LDO_REG8: supplied by vcc3v3_sys
[    3.859642] SWITCH_REG1: supplied by vcc3v3_sys
[    3.862830] SWITCH_REG2: supplied by vcc3v3_sys
[    3.869022] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[    3.872472] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80097d
2000
[    3.876345] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80097d
4000
[    3.878773] usb 1-1: new high-speed USB device number 2 using ehci-platform
[    3.882559] rockchip-pinctrl pinctrl: pin gpio4-17 already requested by ff940
000.hdmi; cannot claim for ff130000.i2c
[    3.886013] rockchip-pinctrl pinctrl: pin-145 (ff130000.i2c) status -22
[    3.889118] rockchip-pinctrl pinctrl: could not request pin 145 (gpio4-17) fr
om group i2c3-xfer  on device rockchip-pinctrl
[    3.892687] rk3x-i2c ff130000.i2c: Error applying setting, reverse things bac
k
[    3.896324] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff80097d
6000
[    3.900802] fusb302 4-0022: Can't get property of role, set role to default D
RP
[    3.913184] fusb302 4-0022: port 0 probe success with role ROLE_MODE_DRP, try
_role ROLE_MODE_NONE
[    3.916850] input: Typec_Headphone as /devices/platform/ff3d0000.i2c/i2c-4/4-
0022/input/input2
[    3.920558] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80097d
8000
[    3.925313] rk-ov13850 1-0010: probing...
[    3.928408] rk-ov13850 1-0010: probing successful
[    3.932328] usbcore: registered new interface driver uvcvideo
[    3.935601] USB Video Class driver (1.1.1)
[    3.940503] Boot mode: normal
[    3.944683] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, tem
perature=2147483647
[    3.948494] rockchip-thermal ff260000.tsadc: tsadc is probed successfully!
[    3.952614] dw_wdt ff848000.watchdog: Should better to setup a 'resets' prope
rty in dt, that must been named with reset
[    3.956976] device-mapper: uevent: version 1.0.3
[    3.960646] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-d
evel@redhat.com
[    3.965007] cpu cpu0: bin=1
[    3.968302] cpu cpu0: leakage=31
[    3.983498] cpu cpu0: temp=36250, pvtm=149844 (150419 + -575)
[    3.987195] cpu cpu0: pvtm-volt-sel=2
[    3.990547] cpu cpu0: bin-scale=12
[    3.994150] cpu cpu4: bin=1
[    3.997461] cpu cpu4: leakage=55
[    4.011520] usb 1-1: New USB device found, idVendor=1a40, idProduct=0201
[    4.012904] cpu cpu4: temp=36250, pvtm=160111 (160466 + -355)
[    4.012979] cpu cpu4: pvtm-volt-sel=3
[    4.013025] cpu cpu4: bin-scale=1
[    4.014216] cpu cpu0: avs=0
[    4.014321] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[    4.014974] cpu cpu0: failed to find power_model node
[    4.016027] cpu cpu4: avs=0
[    4.016047] cpu cpu4: Failed to get scale rate, 1
[    4.016133] cpu cpu4: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[    4.018934] cpu cpu4: failed to find power_model node
[    4.019705] sdhci: Secure Digital Host Controller Interface driver
[    4.019706] sdhci: Copyright(c) Pierre Ossman
[    4.019709] Synopsys Designware Multimedia Card Interface Driver
[    4.020191] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode
[    4.020211] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[    4.020221] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[    4.020246] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit
 host data width,256 deep fifo
[    4.020293] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[    4.020294] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[    4.020692] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode
[    4.020706] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[    4.020712] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[    4.020727] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit
[    4.020788] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[    4.020882] vcc_sd: unsupportable voltage range: 3300000-3000000uV
[    4.020891] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000
done
[    4.020894] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000
done
[    4.034836] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz,
actual 400000HZ div = 0)
[    4.050802] vcc_sd: unsupportable voltage range: 3300000-3000000uV
[    4.050807] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000
done
[    4.050810] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000
done
[    4.050826] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[    4.051069] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.052424] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[    4.052426] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[    4.081052] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    4.083047] usb 1-1: Product: USB 2.0 Hub [MTT]
[    4.085261] hub 1-1:1.0: USB hub found
[    4.086808] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using A
DMA
[    4.087381] ledtrig-cpu: registered to indicate activity on CPUs
[    4.087410] hidraw: raw HID events driver (C) Jiri Kosina
[    4.087564] usbcore: registered new interface driver usbhid
[    4.087565] usbhid: USB HID core driver
[    4.087634] ashmem: initialized
[    4.097837] hub 1-1:1.0: 7 ports detected
[    4.101353] Initializing XFRM netlink socket
[    4.103370] NET: Registered protocol family 10
[    4.105454] lib80211: common routines for IEEE802.11 drivers
[    4.107306] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    4.109181] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    4.110887] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6354
[    4.112712] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    4.114531] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gp
io.
[    4.116411] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wa
ke_irq = 3, flags = 0.
[    4.118388] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found
[    4.120242] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    4.121887] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    4.123530] [BT_RFKILL]: Enter rfkill_rk_init
[    4.125321] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_
gpios = 83.
[    4.127299] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_
gpio = 9.
[    4.129223] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_g
pio = 90.
[    4.131132] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_h
ost_irq = 4.
[    4.134046] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[    4.136862] [BT_RFKILL]: Request irq for bt wakeup host
[    4.139541] [BT_RFKILL]: ** disable irq
[    4.141131] [BT_RFKILL]: bt shut off power
[    4.162830] [BT_RFKILL]: bt_default device registered.
[    4.164573] Key type dns_resolver registered
[    4.166195] sensor_register_slave:mpu6880_gyro,id=50
[    4.167877] Error: Driver 'ov7750' is already registered, aborting...
[    4.169640] Error: Driver 'ov8858' is already registered, aborting...
[    4.171448] Error: Driver 'sc031gs' is already registered, aborting...
[    4.173645] cif_isp10_v4l2_drv_probe: CIF ISP10 driver version: v0.2.3
[    4.175497] cif_isp10_pltfrm_dev_init(886) ERR: could not get default pinstat
e
[    4.177320] cif_isp10_pltfrm_dev_init WARN: could not get pins_sleep pinstate
[    4.179125] cif_isp10_pltfrm_dev_init WARN: could not get pins_inactive pinst
ate
[    4.192123] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[    4.194181] mmcblk1: mmc1:0001 DJNB4R 116 GiB
[    4.196310] mmcblk1boot0: mmc1:0001 DJNB4R partition 1 4.00 MiB
[    4.198586] mmcblk1boot1: mmc1:0001 DJNB4R partition 2 4.00 MiB
[    4.201016] mmcblk1rpmb: mmc1:0001 DJNB4R partition 3 4.00 MiB
[    4.203467]  mmcblk1: p1
[    4.206921] rk-ov13850.ov_camera_module_write_config(180) ERR: no active sens
or configuration
[    4.207698] rk-ov13850.ov_camera_module_write_config(231) ERR: failed with er
ror -14
[    4.211004] rk-ov13850.pltfrm_camera_module_read_reg(1035) ERR: i2c read from
 offset 0x0000300a failed with error -6
[    4.213333] rk-ov13850.pltfrm_camera_module_read_reg(1035) ERR: i2c read from
 offset 0x0000300b failed with error -6
[    4.215466] rk-ov13850.ov13850_check_camera_id(1858) ERR: register read faile
d, camera module powered off?
[    4.217519] rk-ov13850.ov13850_check_camera_id(1876) ERR: failed with error (
-6)
[    4.219412] rk-ov13850.ov_camera_module_attach(254) ERR: failed with error -6
[    4.221253] cif_isp10_img_src_v4l2_i2c_subdev_to_img_src(59) ERR: failed with
 error -6
[    4.223149] cif_isp10_img_src_to_img_src(70) ERR: to_img_src failed!
[    4.224901] cif_isp10_img_src_to_img_src(78) ERR: failed with error -14
[    4.226681] cif_isp10_img_srcs_init(1105) ERR: failed with error -14
[    4.228437] cif_isp10_create(6101) ERR: cif_isp10_img_srcs_init failed
[    4.230202] cif_isp10_create(6139) ERR: failed with error -14
[    4.232310] Registered cp15_barrier emulation handler
[    4.234097] Registered setend emulation handler
[    4.237205] registered taskstats version 1
[    4.238788] Loading compiled-in X.509 certificates
[    4.241697] Btrfs loaded, integrity-checker=on
[    4.243344] BTRFS: selftest: Running btrfs free space cache tests
[    4.245054] BTRFS: selftest: Running extent only tests
[    4.246653] BTRFS: selftest: Running bitmap only tests
[    4.248246] BTRFS: selftest: Running bitmap and extent tests
[    4.249874] BTRFS: selftest: Running space stealing from bitmap to extent
[    4.251874] BTRFS: selftest: Free space cache tests finished
[    4.253501] BTRFS: selftest: Running extent buffer operation tests
[    4.254058] BTRFS: selftest: Running btrfs_split_item tests
[    4.256839] BTRFS: selftest: Running find delalloc tests
[    4.362023] BTRFS: selftest: Running btrfs_get_extent tests
[    4.363777] BTRFS: selftest: Running hole first btrfs_get_extent test
[    4.365484] BTRFS: selftest: Running outstanding_extents tests
[    4.367164] BTRFS: selftest: Running qgroup tests
[    4.368692] BTRFS: selftest: Qgroup basic add
[    4.370210] BTRFS: selftest: Qgroup multiple refs test
[    4.371016] usb 1-1.3: new high-speed USB device number 3 using ehci-platform
[    4.421950] Key type encrypted registered
[    4.424547] rga2: Driver loaded successfully ver:3.02
[    4.426594] rga2: Module initialized.
[    4.429008] phy phy-ff770000.syscon:usb2-phy@e450.7: Failed to get VBUS suppl
y regulator
[    4.436002] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller
[    4.442452] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus nu
mber 3
[    4.449041] xhci-hcd xhci-hcd.8.auto: hcc params 0x0220fe64 hci version 0x110
 quirks 0x06030010
[    4.455655] xhci-hcd xhci-hcd.8.auto: irq 229, io mem 0xfe800000
[    4.462245] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    4.468676] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=
1
[    4.475157] usb usb3: Product: xHCI Host Controller
[    4.481446] usb usb3: Manufacturer: Linux 4.4.213-rk3399 xhci-hcd
[    4.487891] usb usb3: SerialNumber: xhci-hcd.8.auto
[    4.495299] hub 3-0:1.0: USB hub found
[    4.501613] hub 3-0:1.0: 1 port detected
[    4.508044] usb 1-1.3: New USB device found, idVendor=1a40, idProduct=0101
[    4.508520] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller
[    4.508858] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus nu
mber 4
[    4.508905] usb usb4: We don't know the algorithms for LPM for this host, dis
abling LPM.
[    4.508950] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[    4.508953] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=
1
[    4.508955] usb usb4: Product: xHCI Host Controller
[    4.508957] usb usb4: Manufacturer: Linux 4.4.213-rk3399 xhci-hcd
[    4.508959] usb usb4: SerialNumber: xhci-hcd.8.auto
[    4.509228] hub 4-0:1.0: USB hub found
[    4.509239] hub 4-0:1.0: 1 port detected
[    4.510171] xhci-hcd xhci-hcd.8.auto: remove, state 1
[    4.510182] usb usb4: USB disconnect, device number 1
[    4.526447] xhci-hcd xhci-hcd.8.auto: Host not halted after 16000 microsecond
s.
[    4.526450] xhci-hcd xhci-hcd.8.auto: Host controller not halted, aborting re
set.
[    4.526481] xhci-hcd xhci-hcd.8.auto: USB bus 4 deregistered
[    4.526577] xhci-hcd xhci-hcd.8.auto: remove, state 1
[    4.526586] usb usb3: USB disconnect, device number 1
[    4.526928] xhci-hcd xhci-hcd.8.auto: USB bus 3 deregistered
[    4.531712] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[    4.531867] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus nu
mber 3
[    4.531986] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220fe64 hci version 0x110
 quirks 0x06030010
[    4.532010] xhci-hcd xhci-hcd.9.auto: irq 230, io mem 0xfe900000
[    4.532117] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    4.532120] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=
1
[    4.532122] usb usb3: Product: xHCI Host Controller
[    4.532124] usb usb3: Manufacturer: Linux 4.4.213-rk3399 xhci-hcd
[    4.532126] usb usb3: SerialNumber: xhci-hcd.9.auto
[    4.532344] hub 3-0:1.0: USB hub found
[    4.532356] hub 3-0:1.0: 1 port detected
[    4.532492] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[    4.532568] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus nu
mber 4
[    4.532595] usb usb4: We don't know the algorithms for LPM for this host, dis
abling LPM.
[    4.532637] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[    4.532639] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=
1
[    4.532641] usb usb4: Product: xHCI Host Controller
[    4.532643] usb usb4: Manufacturer: Linux 4.4.213-rk3399 xhci-hcd
[    4.532644] usb usb4: SerialNumber: xhci-hcd.9.auto
[    4.532842] hub 4-0:1.0: USB hub found
[    4.532854] hub 4-0:1.0: 1 port detected
[    4.536757] ehci-platform fe380000.usb: EHCI Host Controller
[    4.536972] ehci-platform fe380000.usb: new USB bus registered, assigned bus
number 5
[    4.537048] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[    4.546972] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[    4.547190] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[    4.547196] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=
1
[    4.547200] usb usb5: Product: EHCI Host Controller
[    4.547204] usb usb5: Manufacturer: Linux 4.4.213-rk3399 ehci_hcd
[    4.547208] usb usb5: SerialNumber: fe380000.usb
[    4.547849] hub 5-0:1.0: USB hub found
[    4.547874] hub 5-0:1.0: 1 port detected
[    4.548761] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[    4.549051] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus
number 6
[    4.549165] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[    4.606963] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    4.606967] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=
1
[    4.606970] usb usb6: Product: Generic Platform OHCI controller
[    4.606973] usb usb6: Manufacturer: Linux 4.4.213-rk3399 ohci_hcd
[    4.606976] usb usb6: SerialNumber: fe3a0000.usb
[    4.607641] hub 6-0:1.0: USB hub found
[    4.607665] hub 6-0:1.0: 1 port detected
[    4.608733] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode
[    4.608768] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[    4.608776] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[    4.608800] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit
[    4.608869] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[    4.608872] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[    4.609155] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[    4.626910] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz,
[    4.642965] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[    4.643824] asoc-simple-card hdmi-codec: i2s-hifi <-> ff8a0000.i2s mapping ok
[    4.645994] rockchip-spdif ff870000.spdif: Missing dma channel for stream: 0
[    4.645996] rockchip-spdif ff870000.spdif: ASoC: pcm constructor failed: -22
[    4.645999] asoc-simple-card spdif-sound: ASoC: can't create pcm ff870000.spd
if-dit-hifi :-22
[    4.646001] asoc-simple-card spdif-sound: ASoC: failed to instantiate card -2
2
[    4.647082] asoc-simple-card: probe of spdif-sound failed with error -22
[    4.648035] input: gpio-keys as /devices/platform/gpio-keys/input/input3
[    4.648095] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.22 (r
-20191105-2)(20191120-1)
[    4.648097] ======== dhd_wlan_init_plat_data ========
[    4.648100] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[    4.648104] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=70, oob_irq_flags=0x
414
[    4.648105] dhd_wlan_init_gpio: WL_REG_ON=-1
[    4.648106] dhd_wifi_platform_load: Enter
[    4.648108] Power-up adapter 'DHD generic adapter'
[    4.648125] wifi_platform_set_power = 1
[    4.648126] ======== PULL WL_REG_ON(-1) HIGH! ========
[    4.648128] [WLAN_RFKILL]: rockchip_wifi_power: 1
[    4.648130] [WLAN_RFKILL]: wifi turn on power. -1
[    4.651315] rk808-rtc rk808-rtc: setting system clock to 2021-02-16 12:14:44
UTC (1613477684)
[    4.651326] of_cfs_init
[    4.651367] of_cfs_init: OK
[    4.662490] ALSA device list:
[    4.662492]   #0: Dummy 1
[    4.662493]   #1: Loopback 1
[    4.662494]   #2: HDMI-CODEC
[    4.677195] vendor storage:20190527 ret = 0
[    4.685630] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[    4.687192] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[    4.688754] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[    4.691559] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[    4.746936] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000
Hz, actual 50000000HZ div = 0)
[    4.756413] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 316
[    4.759550] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[    4.759575] mmc2: new ultra high speed SDR104 SDIO card at address 0001
[    4.924471] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber
=0
[    4.924474] usb 1-1.3: Product: USB 2.0 Hub
[    4.925204] hub 1-1.3:1.0: USB hub found
[    4.925440] hub 1-1.3:1.0: 4 ports detected
[    4.938247] Freeing unused kernel memory: 1088K
[    4.950908] wifi_platform_bus_enumerate device present 1
[    4.950911] ======== Card detection to detect SDIO card! ========
[    4.950915] mmc2:mmc host rescan start!
[    4.967106] bcmsdh_register: register client driver
[    4.971257] bcmsdh_sdmmc_probe: Enter num=1
[    4.991782] bcmsdh_sdmmc_probe: Enter num=2
[    4.998982] usb 1-1.4: new high-speed USB device number 4 using ehci-platform
[    5.023238] bus num (host idx)=2, slot num (rca)=1
[    5.023246] found adapter info 'DHD generic adapter'
[    5.023465] sdioh_attach: set sd_f2_blocksize 256
[    5.023666] sdioh_attach: sd clock rate = 0
[    5.024305] dhdsdio_probe : no mutex held. set lock
[    5.024731] F1 signature read @0x18000000=0x17224356
[    5.028997] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x2 pkg:0x2
[    5.029421] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[    5.029493] [dhd] dhd_conf_set_chiprev : chip=0x4354, chiprev=2
[    5.029676] [dhd] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[    5.029974] [dhd] CFG80211-ERROR) wl_setup_wiphy : SAE support
[    5.030262] [dhd] CFG80211-ERROR) wl_init_prof : wl_init_prof: No profile
[    5.030772] dhd_attach(): thread:dhd_watchdog_thread:df started
[    5.030946] dhd_attach(): thread:dhd_dpc:e0 started
[    5.031176] dhd_attach(): thread:dhd_rxf:e1 started
[    5.031183] dhd_deferred_work_init: work queue initialized
[    5.031186] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 -> mode 2
[    5.031206] dhd_bus_set_default_min_res_mask: Unhandled chip id
[    5.031428] sdioh_cis_read: func_cis_ptr[0]=0x10ac
[    5.039124] Dongle Host Driver, version 1.579.77.41.22 (r-20191105-2)(2019112
0-1)
[    5.039612] Register interface [wlan0]  MAC: cc:4b:73:1d:de:88
[    5.039612]
[    5.039845] dhd_tcpack_suppress_set: TCP ACK Suppress mode 2 -> mode 0
[    5.039854] dhd_wl_ioctl: returning as busstate=0
[    5.039857] dhd_dbg_detach_pkt_monitor, 2204
[    5.039859] dhd_bus_devreset: == Power OFF ==
[    5.040051] bcmsdh_oob_intr_unregister: Enter
[    5.040053] bcmsdh_oob_intr_unregister: irq is not registered
[    5.040060] dhd_txglom_enable: enable 0
[    5.040062] dhd_bus_devreset:  WLAN OFF DONE
[    5.040096] wifi_platform_set_power = 0
[    5.040098] ======== PULL WL_REG_ON(-1) LOW! ========
[    5.040101] [WLAN_RFKILL]: rockchip_wifi_power: 0
[    5.040348] [WLAN_RFKILL]: wifi shut off power.
[    5.040352] dhdsdio_probe : the lock is released.
[    5.040466] dhd_module_init: Exit err=0
[    5.126471] usb 1-1.4: New USB device found, idVendor=0d8c, idProduct=0004
[    5.126476] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber
=0
[    5.126480] usb 1-1.4: Product: USB2.0 High-Speed True HD Audio
[    5.126483] usb 1-1.4: Manufacturer: C-Media Electronics Inc.
[    5.136284] input: C-Media Electronics Inc. USB2.0 High-Speed True HD Audio a
s /devices/platform/fe3c0000.usb/usb1/1-1/1-1.4/1-1.4:1.2/0003:0D8C:0004.0001/in
put/input4
[    5.191899] hid-generic 0003:0D8C:0004.0001: input,hidraw0: USB HID v1.00 Dev
ice [C-Media Electronics Inc. USB2.0 High-Speed True HD Audio] on usb-fe3c0000.u
sb-1.4/input2
[    5.226938] usb 1-1.3.2: new full-speed USB device number 5 using ehci-platfo
rm
[    5.354240] usb 1-1.3.2: language id specifier not provided by device, defaul
ting to English
[    5.367890] usb 1-1.3.2: New USB device found, idVendor=0c45, idProduct=7403
[    5.372284] usb 1-1.3.2: New USB device strings: Mfr=1, Product=2, SerialNumb
er=0
[    5.385234] input: HID 0c45:7403 as /devices/platform/fe3c0000.usb/usb1/1-1/1
-1.3/1-1.3.2/1-1.3.2:1.0/0003:0C45:7403.0002/input/input5
[    5.447664] hid-generic 0003:0C45:7403.0002: input,hidraw1: USB HID v1.00 Key
board [HID 0c45:7403] on usb-fe3c0000.usb-1.3.2/input0
[    5.456558] input: HID 0c45:7403 as /devices/platform/fe3c0000.usb/usb1/1-1/1
-1.3/1-1.3.2/1-1.3.2:1.1/0003:0C45:7403.0003/input/input6
[    5.475144] hid-generic 0003:0C45:7403.0003: input,hidraw2: USB HID v1.10 Mou
se [HID 0c45:7403] on usb-fe3c0000.usb-1.3.2/input1
[    5.836406] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. O
pts: (null)
[    6.066050] ip_tables: (C) 2000-2006 Netfilter Core Team
[    6.076387] cgroup: cgroup2: unknown option "nsdelegate,memory_recursiveprot"
[    6.085257] cgroup: cgroup2: unknown option "nsdelegate"
[    6.100623] systemd[1]: systemd 247.3-1 running in system mode. (+PAM +AUDIT
+SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +A
CL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hier
archy=unified)
[    6.116078] systemd[1]: Detected architecture arm64.
[    6.143150] systemd[1]: Set hostname to <firefly-rk3399>.
[    6.215610] systemd-sysv-generator[287]: SysV service '/etc/init.d/hostapd' l
acks a native systemd unit file. Automatically generating a unit file for compat
ibility. Please update package to include a native systemd unit file, in order t
o make it more safe and robust.
[    6.230969] systemd-sysv-generator[287]: SysV service '/etc/init.d/cpufrequti
ls' lacks a native systemd unit file. Automatically generating a unit file for c
ompatibility. Please update package to include a native systemd unit file, in or
der to make it more safe and robust.
[    6.244755] systemd-sysv-generator[287]: SysV service '/etc/init.d/rng-tools-
debian' lacks a native systemd unit file. Automatically generating a unit file f
or compatibility. Please update package to include a native systemd unit file, i
n order to make it more safe and robust.
[    6.264045] systemd-sysv-generator[287]: SysV service '/etc/init.d/loadcpufre
q' lacks a native systemd unit file. Automatically generating a unit file for co
mpatibility. Please update package to include a native systemd unit file, in ord
[    6.280473] systemd-sysv-generator[287]: SysV service '/etc/init.d/sysfsutils
' lacks a native systemd unit file. Automatically generating a unit file for com
patibility. Please update package to include a native systemd unit file, in orde
[    6.499813] systemd[1]: /lib/systemd/system/rk3399-bluetooth.service:11: Supp
ort for option SysVStartPriority= has been removed and it is ignored
[    6.541842] systemd[1]: Queued start job for default target Graphical Interfa
ce.
[    6.552391] random: systemd: uninitialized urandom read (16 bytes read, 114 b
its of entropy available)
[    6.561649] systemd[1]: system-getty.slice: unit configures an IP firewall, b
ut the local system does not support BPF/cgroup firewalling.
[    6.571151] systemd[1]: (This warning is only shown for the first unit using
IP firewalling.)
[    6.582220] systemd[1]: Created slice system-getty.slice.
[    6.597416] random: systemd: uninitialized urandom read (16 bytes read, 115 b
[    6.605919] systemd[1]: Created slice system-modprobe.slice.
[    6.620764] random: systemd: uninitialized urandom read (16 bytes read, 115 b
[    6.629310] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    6.644496] random: systemd: uninitialized urandom read (16 bytes read, 115 b
[    6.653044] systemd[1]: Created slice User and Session Slice.
[    6.668385] random: systemd: uninitialized urandom read (16 bytes read, 116 b
[    6.676625] systemd[1]: Started Dispatch Password Requests to Console Directo
ry Watch.
[    6.691877] random: systemd: uninitialized urandom read (16 bytes read, 116 b
[    6.699884] systemd[1]: Started Forward Password Requests to Wall Directory W
atch.
[    6.715243] random: systemd: uninitialized urandom read (16 bytes read, 116 b
[    6.723591] systemd[1]: Set up automount Arbitrary Executable File Formats Fi
le System Automount Point.
[    6.739011] random: systemd: uninitialized urandom read (16 bytes read, 116 b
[    6.746912] systemd[1]: Reached target Local Encrypted Volumes.
[    6.761833] random: systemd: uninitialized urandom read (16 bytes read, 116 b
[    6.769707] systemd[1]: Reached target Paths.
[    6.784358] random: systemd: uninitialized urandom read (16 bytes read, 116 b
[    6.792256] systemd[1]: Reached target Remote File Systems.
[    6.807148] systemd[1]: Reached target Slices.
[    6.822028] systemd[1]: Reached target Swap.
[    6.836710] systemd[1]: Reached target System Time Set.
[    6.851830] systemd[1]: Listening on Syslog Socket.
[    6.866849] systemd[1]: Listening on fsck to fsckd communication Socket.
[    6.881920] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    6.896928] systemd[1]: Listening on Journal Audit Socket.
[    6.911491] systemd[1]: Listening on Journal Socket (/dev/log).
[    6.926262] systemd[1]: Listening on Journal Socket.
[    6.940907] systemd[1]: Listening on udev Control Socket.
[    6.954704] systemd[1]: Listening on udev Kernel Socket.
[    6.970139] systemd[1]: Mounting Huge Pages File System...
[    6.991626] systemd[1]: Mounting POSIX Message Queue File System...
[    7.007353] systemd[1]: Mounting Kernel Debug File System...
[    7.027439] systemd[1]: Mounting Kernel Trace File System...
[    7.048290] systemd[1]: Starting Restore / save the current clock...
[    7.067670] systemd[1]: Starting Set the console keyboard layout...
[    7.082897] systemd[1]: Starting Create list of static device nodes for the c
urrent kernel...
[    7.093284] systemd[1]: Starting Load Kernel Module configfs...
[    7.101531] systemd[1]: Starting Load Kernel Module drm...
[    7.108444] systemd[1]: Starting Load Kernel Module fuse...
[    7.115882] systemd[1]: Started Nameserver information manager.
[    7.121674] systemd[1]: Reached target Network (Pre).
[    7.127048] systemd[1]: Condition check resulted in Set Up Additional Binary
Formats being skipped.
[    7.129852] systemd[1]: Condition check resulted in File System Check on Root
 Device being skipped.
[    7.135299] systemd[1]: Starting Load Kernel Modules...
[    7.141467] systemd[1]: Starting Remount Root and Kernel File Systems...
[    7.148009] systemd[1]: Starting Coldplug All udev Devices...
[    7.157223] systemd[1]: Mounted Huge Pages File System.
[    7.161885] systemd[1]: Mounted POSIX Message Queue File System.
[    7.167878] systemd[1]: Mounted Kernel Debug File System.
[    7.172375] systemd[1]: Mounted Kernel Trace File System.
[    7.177138] systemd[1]: Finished Restore / save the current clock.
[    7.182059] systemd[1]: Finished Create list of static device nodes for the c
urrent kernel.
[    7.183911] EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-
ro
[    7.190908] systemd[1]: modprobe@configfs.service: Succeeded.
[    7.193520] systemd[1]: Finished Load Kernel Module configfs.
[    7.198630] systemd[1]: modprobe@drm.service: Succeeded.
[    7.201177] systemd[1]: Finished Load Kernel Module drm.
[    7.205920] systemd[1]: modprobe@fuse.service: Succeeded.
[    7.208646] systemd[1]: Finished Load Kernel Module fuse.
[    7.213484] systemd[1]: Finished Set the console keyboard layout.
[    7.218711] systemd[1]: Finished Load Kernel Modules.
[    7.223539] systemd[1]: Finished Remount Root and Kernel File Systems.
[    7.230128] systemd[1]: Mounting FUSE Control File System...
[    7.236549] systemd[1]: Mounting Kernel Configuration File System...
[    7.242313] systemd[1]: Condition check resulted in Rebuild Hardware Database
 being skipped.
[    7.245101] systemd[1]: Condition check resulted in Platform Persistent Stora
ge Archival being skipped.
[    7.249682] systemd[1]: Starting Load/Save Random Seed...
[    7.256465] systemd[1]: Starting Apply Kernel Variables...
[    7.263347] systemd[1]: Starting Create System Users...
[    7.272182] systemd[1]: Mounted FUSE Control File System.
[    7.277220] systemd[1]: Mounted Kernel Configuration File System.
[    7.284007] systemd[1]: Finished Apply Kernel Variables.
[    7.292972] systemd[1]: Finished Create System Users.
[    7.299370] systemd[1]: Starting Create Static Device Nodes in /dev...
[    7.327860] systemd[1]: Finished Create Static Device Nodes in /dev.
[    7.332680] systemd[1]: Reached target Local File Systems (Pre).
[    7.339087] systemd[1]: Mounting /tmp...
[    7.345271] systemd[1]: Starting Rule-based Manager for Device Events and Fil
es...
[    7.352014] systemd[1]: Mounted /tmp.
[    7.356700] systemd[1]: Reached target Local File Systems.
[    7.363082] systemd[1]: Starting Armbian ZRAM config...
[    7.369815] systemd[1]: Starting Set console font and keymap...
[    7.375052] systemd[1]: Finished Coldplug All udev Devices.
[    7.383284] systemd[1]: Starting Helper to synchronize boot up for ifupdown..
[    7.388948] systemd[1]: Finished Set console font and keymap.
[    7.395439] random: nonblocking pool is initialized
[    7.395793] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
[    7.414032] systemd[1]: Starting Raise network interfaces...
[    7.418897] systemd[1]: Finished Load/Save Random Seed.
[    7.424327] systemd[1]: Condition check resulted in First Boot Complete being
 skipped.
[    7.426986] systemd[1]: Condition check resulted in Store a System Token in a
n EFI Variable being skipped.
[    7.429776] systemd[1]: Condition check resulted in Commit a transient machin
e-id on disk being skipped.
[    7.447577] systemd[1]: Started Rule-based Manager for Device Events and File
s.
[    7.550149] dhd_ioctl_entry: Interface is down
[    7.550680] zram: Added device: zram0
[    7.552306] zram: Added device: zram1
[    7.556394] zram: Added device: zram2
[    7.628698] dhd_ioctl_entry: Interface is down
[    7.630148] asoc-simple-card rt5640-sound: rt5640-aif1 <-> ff890000.i2s mappi
ng ok
[    7.693475] usbcore: registered new interface driver snd-usb-audio
[    7.730174] mali ff9a0000.gpu: leakage=32
[    7.738076] systemd[1]: Reached target Hardware activated USB gadget.
[    7.749362] systemd[1]: Found device /dev/ttyFIQ0.
[    7.750912] zram0: detected capacity change from 0 to 1997332480
[    7.765330] mali ff9a0000.gpu: temp=35625, pvtm=122719 (122995 + -276)
[    7.781389] mali ff9a0000.gpu: pvtm-volt-sel=1
[    7.788771] mali ff9a0000.gpu: avs=0
[    7.789479] Adding 1950516k swap on /dev/zram0.  Priority:5 extents:1 across:
1950516k SS
[    7.799809] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[    7.805522] mali ff9a0000.gpu: Protected mode not available
[    7.811868] mali ff9a0000.gpu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[    7.817460] mali ff9a0000.gpu: Using configured power model mali-simple-power
-model, and fallback mali-simple-power-model
[    7.823487] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfr
eq.c; [Line] : 423; [Func] : kbase_devfreq_init(); success initing power_model_s
imple.
[    7.832424] mali ff9a0000.gpu: Probed as mali0
[    7.835836] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfk
ill Watch.
[    7.891096] cfg80211: World regulatory domain updated:
[    7.891101] cfg80211:  DFS Master region: unset
[    7.891102] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gai
n, max_eirp), (dfs_cac_time)
[    7.891106] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 m
Bm), (N/A)
[    7.891109] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUT
O), (N/A, 2000 mBm), (N/A)
[    7.891110] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 m
Bm), (N/A)
[    7.891113] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AU
TO), (N/A, 2000 mBm), (N/A)
[    7.891115] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AU
TO), (N/A, 2000 mBm), (0 s)
[    7.891117] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000
mBm), (0 s)
[    7.891118] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 m
Bm), (N/A)
[    7.891120] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0
mBm), (N/A)
[    7.916398] zram1: detected capacity change from 0 to 52428800
[    8.019838] systemd[1]: Finished Armbian ZRAM config.
[    8.163515] systemd[1]: Finished Raise network interfaces.
[    8.206232] systemd[1]: Starting Armbian memory supported logging...
[    8.222010] systemd[1]: Condition check resulted in Set Up Additional Binary
[    8.230184] systemd[1]: Condition check resulted in Store a System Token in a
[    8.238549] systemd[1]: Condition check resulted in Rebuild Hardware Database
 being skipped.
[    8.247843] systemd[1]: Condition check resulted in Commit a transient machin
[    8.254039] systemd[1]: Condition check resulted in Platform Persistent Stora
[    8.262305] systemd[1]: Starting Load/Save RF Kill Switch Status...
[    8.263371] EXT4-fs (zram1): mounted filesystem without journal. Opts: discar
d
[    8.302926] [BT_RFKILL]: ENABLE UART_RTS
[    8.407232] [BT_RFKILL]: DISABLE UART_RTS
[    8.428072] [BT_RFKILL]: bt turn on power
[    8.458636] systemd[1]: Started Load/Save RF Kill Switch Status.
[    8.822267] systemd[1]: Condition check resulted in Set Up Additional Binary
[    8.828250] systemd[1]: Condition check resulted in Store a System Token in a
[    8.834492] systemd[1]: Condition check resulted in Rebuild Hardware Database
 being skipped.
[    8.840441] systemd[1]: Condition check resulted in Commit a transient machin
[    8.846413] systemd[1]: Condition check resulted in Platform Persistent Stora
[   11.226203] systemd[1]: Finished Armbian memory supported logging.
[   11.235614] systemd[1]: Starting Journal Service...
[   11.440482] systemd[1]: Started Journal Service.
[   11.498922] systemd-journald[617]: Received client request to flush runtime j
ournal.
[   11.501868] systemd-journald[617]: File /var/log/journal/9037e8e7d867444d9fdc
d3f434a08594/system.journal corrupted or uncleanly shut down, renaming and repla
cing.
[   11.505601] systemd-journald[617]: Failed to open system journal: No space le
ft on device
[   12.160892] nr_pdflush_threads exported in /proc is scheduled for removal
[   25.040538] [BT_RFKILL]: ENABLE UART_RTS
[   25.115568] proc: unrecognized mount option "hidepid=invisible" or missing va
lue
[   25.142853] [BT_RFKILL]: DISABLE UART_RTS
[   25.145040] [BT_RFKILL]: bt turn on power
[   25.173878] ttyS0 - failed to request DMA, use interrupt mode
[   25.516223] proc: unrecognized mount option "hidepid=invisible" or missing va
lue
[   25.803304] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   25.835563] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   25.836399] dhd_open: Enter ffffffc0dc5b9000
[   25.836811] dhd_open : no mutex held. set lock
[   25.837225]
[   25.837225] Dongle Host Driver, version 1.579.77.41.22 (r-20191105-2)(2019112
0-1)
[   25.838041] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[   25.838564] wifi_platform_set_power = 1
[   25.838964] ======== PULL WL_REG_ON(-1) HIGH! ========
[   25.839427] [WLAN_RFKILL]: rockchip_wifi_power: 1
[   25.839850] [WLAN_RFKILL]: wifi turn on power. -1
[   26.142846] sdio_reset_comm():
[   26.174812] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz,
[   26.194274] mmc_host mmc2: Bus speed (slot 0) = 100000Hz (slot req 100000Hz,
actual 100000HZ div = 0)
[   26.253527] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[   26.260279] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[   26.266782] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[   26.278536] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[   26.503415] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000
[   26.517443] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 316
[   26.518131] sdioh_start: set sd_f2_blocksize 256
[   26.519074]
[   26.519074]
[   26.519074] dhd_bus_devreset: == WLAN ON ==
[   26.519854] F1 signature read @0x18000000=0x17224356
[   26.524642] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x2 pkg:0x2
[   26.525841] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[   26.526527] dhd_bus_set_default_min_res_mask: Unhandled chip id
[   26.528067] dhd_os_open_image: /lib/firmware/rkwifi/config.txt (204 bytes) op
en success
[   26.529715] [dhd] dhd_conf_read_country : ccode = ALL
[   26.530181] [dhd] dhd_conf_read_country : regrev = 0
[   26.530643] [dhd] dhd_conf_read_sdio_params : dhd_doflow = 1
[   26.531260] [dhd] dhd_conf_read_others : srl = 15
[   26.531712] [dhd] dhd_conf_read_others : lrl = 15
[   26.532173] [dhd] dhd_conf_set_path_params : Final fw_path=/lib/firmware/rkwi
fi/fw_bcm4356a2_ag.bin
[   26.532981] [dhd] dhd_conf_set_path_params : Final nv_path=/lib/firmware/rkwi
fi/nvram_ap6356.txt
[   26.533758] [dhd] dhd_conf_set_path_params : Final clm_path=/lib/firmware/rkw
ifi/clm_bcm4356a2_ag.blob
[   26.534579] [dhd] dhd_conf_set_path_params : Final conf_path=/lib/firmware/rk
wifi/config.txt
[   26.536082] dhd_os_open_image: /lib/firmware/rkwifi/fw_bcm4356a2_ag.bin (5554
12 bytes) open success
[   26.625107] dhd_os_open_image: /lib/firmware/rkwifi/nvram_ap6356.txt (4006 by
tes) open success
[   26.626240] NVRAM version: AP6356_NVRAM_V1.1_20141015
[   26.628701] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeed
ed.
[   26.690828] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[   26.691647] bcmsdh_oob_intr_register: HW_OOB irq=70 flags=0x4
[   26.692324] dhd_get_memdump_info: File [/data/misc/wifi/.memdump.info] doesn'
t exist
[   26.693010] dhd_get_memdump_info: MEMDUMP ENABLED = 2
[   26.693732] Disable tdls_auto_op failed. -1
[   26.694106] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 -> mode 1
[   26.695663] dhd_apply_default_clm: Ignore clm file /lib/firmware/rkwifi/clm_b
cm4356a2_ag.blob
[   26.697897] Firmware up: op_mode=0x0005, MAC=cc:4b:73:1d:de:88
[   26.703811] dhd_preinit_ioctls Set scancache failed -23
[   26.711572]   Driver: 1.579.77.41.22 (r-20191105-2)(20191120-1)
[   26.711572]   Firmware: wl0: Jun 16 2015 14:25:06 version 7.35.184.r1 (TOB) (
r559293) FWID 01-b22ae69c
[   26.711572]   CLM: 7.10.16 (2014-02-13 17:00:38)
[   26.713543] dhd_txglom_enable: enable 1
[   26.713884] [dhd] dhd_conf_set_txglom_params : txglom_mode=copy
[   26.714402] [dhd] dhd_conf_set_txglom_params : txglomsize=36, deferred_tx_len
=0
[   26.715071] [dhd] dhd_conf_set_txglom_params : txinrx_thres=128, dhd_txminmax
=-1
[   26.715716] [dhd] dhd_conf_set_txglom_params : tx_max_offset=0, txctl_tmo_fix
=300
[   26.716375] [dhd] dhd_conf_get_disable_proptx : fw_proptx=1, disable_proptx=-
1
[   26.717802] dhd_wlfc_hostreorder_init(): successful bdcv2 tlv signaling, 64
[   26.719794] dhd_pno_init: Support Android Location Service
[   26.755500] dhd_wlfc_enable: ret=0
[   26.755823] [dhd] CFG80211-ERROR) wl_cfg80211_event : Event handler is not cr
eated
[   26.756492] [dhd] CFG80211-ERROR) wl_cfg80211_event : Event handler is not cr
eated
[   26.757160] [dhd] CFG80211-ERROR) wl_cfg80211_event : Event handler is not cr
eated
[   26.758126] rtt_do_get_ioctl: failed to send getbuf proxd iovar (CMD ID : 1),
 status=-23
[   26.758855] dhd_rtt_init : FTM is not supported
[   26.759260] dhd_preinit_ioctls: SensorHub diabled 0
[   26.760091] dhd_preinit_ioctls failed to set ShubHub disable
[   26.760965] dhd_ndo_get_version: failed, retcode = -23
[   26.761803] dhd_wl_ioctl_get_intiovar: get int iovar wnm_bsstrans_resp failed
, ERR -23
[   26.762494] failed to get wnm_bsstrans_resp
[   26.763892] failed to set WNM capabilities
[   26.764513] [dhd] dhd_conf_set_country : set country ALL, revision 0
[   26.764522] [dhd] CFG80211-ERROR) wl_cfg80211_event : Event handler is not cr
eated
[   26.766108] [dhd] CONFIG-ERROR) dhd_conf_set_bufiovar : country setting faile
d -2, len=12
[   26.767725] [dhd] dhd_conf_set_country : Country code: US (US/0)
[   26.772824] [dhd-wlan0] wl_android_wifi_on : Success
[   26.829186] dhd_open : the lock is released.
[   26.829567] dhd_open: Exit ret=0
[   26.879412] NET: Registered protocol family 17
[   26.949255] P2P interface registered
[   26.949624] wl_cfgp2p_add_p2p_disc_if: wdev: ffffffc0ee1f9800, wdev->net:
       (null)
[   26.975477] WLC_E_IF: NO_IF set, event Ignored
[   26.977425] P2P interface started
[   27.024548] [drm] unsupported connector property: hdmi_color_depth_capacity
[   34.627636] [dhd-wlan0] wl_cfg80211_connect : Connecting with 10:da:43:b4:37:
23 ssid "kaffi-5G", len (8), sec=wpa2psk/mfpc/516, channel=44
[   34.627636]
[   34.629542] dhd_dbg_start_pkt_monitor, 1724
[   34.691424] [dhd-wlan0] wl_iw_event : Link UP with 10:da:43:b4:37:23
[   34.692010] [dhd-wlan0] wl_ext_iapsta_event : Link UP with 10:da:43:b4:37
:23
[   34.692733] [dhd-wlan0] wl_notify_connect_status : wl_bss_connect_done succee
ded with 10:da:43:b4:37:23
[   34.712805] cfg80211: Regulatory domain changed to country: DE
[   34.713343] cfg80211:  DFS Master region: ETSI
[   34.713725] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gai
[   34.714591] cfg80211:   (2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A, 2000 m
Bm), (N/A)
[   34.715343] cfg80211:   (5150000 KHz - 5250000 KHz @ 80000 KHz, 200000 KHz AU
TO), (N/A, 2301 mBm), (N/A)
[   34.716176] cfg80211:   (5250000 KHz - 5350000 KHz @ 80000 KHz, 200000 KHz AU
[   34.717004] cfg80211:   (5470000 KHz - 5725000 KHz @ 160000 KHz), (N/A, 2698
mBm), (0 s)
[   34.717717] cfg80211:   (5725000 KHz - 5875000 KHz @ 80000 KHz), (N/A, 1397 m
Bm), (N/A)
[   34.718418] cfg80211:   (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 40
00 mBm), (N/A)
[   35.046478] [dhd-wlan0] wl_notify_connect_status : wl_bss_connect_done succee
ded with 10:da:43:b4:37:23 vndr_oui: 00-10-18
[   37.190153] tty_port_close_start: tty->count = 1 port count = 2.
Armbian 21.02.1 Bullseye ttyFIQ0
3 часа назад, denni_isl сказал:
I expected this, the reason is not correct (not correct) data for DTB. To solve the problem, I need to have the test equipment. I sent a request to Fyrefly, but for now it's the New Year in China and the response will be after it.
Hi there,
with current 21.02.01_focal_current_5.10.12 image, I was update armbianEnv.txt and boot.scr to enable earlycon, set verbosity to 7 and add fdtfile=rockchip/rk3399-firefly.dtb, then use rkdeveloptool write image to emmc, after u-boot stage, the "Starting kernel" stage was hanged with this message output
3184 bytes read in 16 ms (194.3 KiB/s)
## Executing script at 00500000
Boot script loaded from mmc 0
153 bytes read in 13 ms (10.7 KiB/s)
15339358 bytes read in 1494 ms (9.8 MiB/s)
28582400 bytes read in 2737 ms (10 MiB/s)
76162 bytes read in 40 ms (1.8 MiB/s)
2698 bytes read in 30 ms (86.9 KiB/s)
Applying kernel provided DT fixup script (rockchip-fixup.scr)
## Executing script at 09000000
Moving Image from 0x2080000 to 0x2200000, end=3de0000
## Loading init Ramdisk from Legacy Image at 06000000 ...
   Image Name:   uInitrd
   Data Size:    15339294 Bytes = 14.6 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 01f00000
   Booting using the fdt blob at 0x1f00000
   Loading Ramdisk to f507d000, end f5f1df1e ... OK
   Loading Device Tree to 00000000f5002000, end 00000000f507cfff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.10.12-rockchip64 (root@beast) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #21.02.1 SMP PREEMPT Wed Feb 3 20:55:02 CET 2021
[    0.000000] Machine model: Firefly-RK3399 Board
[    0.000000] earlycon: uart0 at MMIO32 0x00000000ff1a0000 (options '1500000n8')
[    0.000000] printk: bootconsole [uart0] enabled
also i have changed fdtfile to rk3399-nanopi-m4, rk3399-roc-pc and other dtbs, there was not any changed but hanged with same message.
My board is CORE-3399-JD4(http://wiki.t-firefly.com/en/Core-3399-JD4/started.html) "core board" with "mother board", it similar with AIO-3399-JD4(http://wiki.t-firefly.com/en/AIO-3399J/started.html)
Let me known if need more info :)
4 часа назад, luuray сказал:
Write the full name of the image.
This is a completely different device than the one discussed in this topic. As far as I know, this module is intended for use as part of other equipment , you did not specify which equipment it is used as part of. You did not provide a description of what happens to the main hardware that contains this module. Perhaps in the image that you are trying to disable further output to the UART console, I recommend trying the ArmbianTV image, there the output to the UART console is not disabled and there should be full information about the startup process.
I received Fyrefly samples today, including Firefly-rk3399. The first tests showed. Yes, indeed, the official images for this model from the official download page (I have only checked the main kernel so far) do not work, i.e., as described earlier, u-boot starts, transfers control to the kernel, and that's the end of it. But there is also good news, I checked the image from Firefly-Station P1 and it worked perfectly without any additional settings. I.e. I wrote the image to the SD card, connected the SD card to Firefly-rk3399, turned on the power and the system automatically started. Works LAN HDMI Wifi HDMI sound. BT does not work and instead of shutting down, the system restarts. I briefly checked the system with the 4.4 kernel (for P1), the main components work, including analog sound. I checked the launch of Libreelec - the system starts and works with HW.   :)
Thanks denni_isl for diligently checking builds and reporting your experiences and balbes150 et al. for support.
I also ran into the same issue of Armbian_21.02.3_Firefly-rk3399_focal_current_5.10.21.img.xz not booting from SD.
FYI There is a problem with some PCIe kernel bits (resulting in error -110 in dmesg and preventing normal bus operation) in older kernels which is reported as fixed sometime in 5.8 so 4.4 doesn't work for me - I need a more recent build 5.9+ to be able to use my M.2 device. It would be great if the issue(s) behind those more recent builds not booting is/are found/fixed so that the PCIe fix can be confirmed.
