Fourdee Posted July 11, 2016 Posted July 11, 2016 Hi all, Creating a DietPi image for BPi Pro based on ARMbian. I finally got a chance to test do_expand_rootfs() from /etc/init.d/firstrun. Now works with multiple partitions, thanks for doing that Having an issue with the onboard WiFi on the BPi Pro (Lemaker). It appears to be enable, active and ready for use, however, I can not get it to scan/connect to a SSID, or even work in AP mode. Built the image using your excellent build tools: [ o.k. ] Building [ Armbian 5.17 Bananapipro Debian jessie default ] root@DietPi:~# iwlist wlan0 scan wlan0 No scan results Fails to set country code. Always returns 00. root@DietPi:~# iw reg set GB root@DietPi:~# iw reg get country 00: DFS-UNSET (2402 - 2472 @ 40), (6, 20), (N/A) (2457 - 2482 @ 40), (6, 20), (N/A), NO-IR (2474 - 2494 @ 20), (6, 20), (N/A), NO-OFDM, NO-IR (5170 - 5250 @ 40), (6, 20), (N/A), NO-IR (5735 - 5835 @ 40), (6, 20), (N/A), NO-IR root@DietPi:~# uname -a Linux DietPi 3.4.112-sun7i #1 SMP PREEMPT Mon Jul 11 11:51:44 BST 2016 armv7l GNU/Linux root@DietPi:~# lsmod Module Size Used by ap6211 624694 0 brcmfmac 96753 0 brcmutil 4804 1 brcmfmac spidev 6366 0 a20_tp 3333 0 8021q 18601 0 garp 6068 1 8021q stp 2028 1 garp llc 5357 2 stp,garp sunxi_ir 4013 0 Is cfg80211 built into kernel? root@DietPi:~# modprobe cfg80211 root@DietPi:~# lsmod Module Size Used by spidev 6366 0 ap6211 624694 0 a20_tp 3333 0 8021q 18601 0 garp 6068 1 8021q stp 2028 1 garp llc 5357 2 stp,garp sunxi_ir 4013 0 root@DietPi:~# dmesg | grep ap6211 [ 451.514454] [ap6211] --->The Drive has been modified for BananaPro by LeMaker team<--- [ 451.517353] [ap6211] select wifi ap6211 [ 451.520712] [ap6211] Initializing ap6211. [ 451.525891] [ap6211] Succeed to set the gpio ap6211_wl_vdd_en to 0 [ 451.531355] [ap6211] Succeed to set the gpio ap6211_wl_regon to 1 [ 451.734606] [ap6211] WLAN placed in POWER ON [ 451.926840] [ap6211] Linux Kernel SDIO/MMC Driver [ 451.943795] [ap6211] Broadcom Dongle Host Driver: register interface [wlan0] MAC: 00:90:4c:11:22:33 [ 451.950442] [ap6211] Succeed to set the gpio ap6211_wl_regon to 0 [ 452.030664] ap6210: exports duplicate symbol bcmsdh_probe (owned by ap6211) [ 452.040690] ap6210: exports duplicate symbol bcmsdh_probe (owned by ap6211) [ 452.181233] [ap6211] WLAN placed in RESET [ 504.259810] [ap6211] Dongle Host Driver, version 1.28.23.3 (r). [ 504.266857] [ap6211] Compiled in drivers/net/wireless/ap6211 on Jul 11 2016 at 11:49:23. [ 504.271955] [ap6211] Succeed to set the gpio ap6211_wl_regon to 1 [ 504.475418] [ap6211] WLAN going back to live [ 504.704716] [ap6211] dhd_bus_devreset: WLAN ON [ 504.710694] [ap6211] Final fw_path=/lib/firmware/ap6210/fw_bcm40181a2.bin [ 504.716351] [ap6211] Final nv_path=/lib/firmware/ap6210/nvram_ap6210.txt [ 504.722860] [ap6211] download firmware /lib/firmware/ap6210/fw_bcm40181a2.bin [ 504.995352] [ap6211] Dongle ready, protocol version 4 [ 505.000034] [ap6211] Dongle ready, protocol version 4 [ 505.010310] [ap6211] Firmware up: op_mode=0x0001, Broadcom Dongle Host Driver mac=e0:76:d0:03:54:f4 [ 505.027629] [ap6211] Firmware version = wl0: Apr 22 2013 14:50:00 version 5.90.195.89.6 FWID 01-b30a427d [ 505.030627] [ap6211] Chip: a962 Rev 1 Pkg 9 [ 512.519653] [ap6211] Escan set error (-16) [ 512.521861] [ap6211] error (-16) [ 512.525283] [ap6211] Scan err = (-16), busy?-16 [ 512.527963] [ap6211] scan error (-16) [ 581.110543] [ap6211] scan is not ready root@DietPi:~# ifconfig -a bond0 Link encap:Ethernet HWaddr 00:00:00:00:00:00 BROADCAST MASTER MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:0 (0.0 TX bytes:0 (0.0 eth0 Link encap:Ethernet HWaddr 02:8e:02:c2:64:56 inet addr:192.168.0.133 Bcast:192.168.0.255 Mask:255.255.255.0 inet6 addr: fe80::8e:2ff:fec2:6456/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:821 errors:0 dropped:0 overruns:0 frame:0 TX packets:586 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:80449 (78.5 KiB) TX bytes:85245 (83.2 KiB) Interrupt:117 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:16436 Metric:1 RX packets:136 errors:0 dropped:0 overruns:0 frame:0 TX packets:136 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:11472 (11.2 KiB) TX bytes:11472 (11.2 KiB) tunl0 Link encap:IPIP Tunnel HWaddr NOARP MTU:1480 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:0 (0.0 TX bytes:0 (0.0 wlan0 Link encap:Ethernet HWaddr e0:76:d0:03:54:f4 inet6 addr: fe80::e276:d0ff:fe03:54f4/64 Scope:Link UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:14 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 TX bytes:3260 (3.1 KiB) /etc/network/interfaces: # Local auto lo iface lo inet loopback # Ethernet allow-hotplug eth0 iface eth0 inet dhcp metric 0 address 192.168.0.100 netmask 255.255.255.0 gateway 192.168.0.1 #dns-nameservers 8.8.8.8 8.8.4.4 # Wifi allow-hotplug wlan0 iface wlan0 inet dhcp metric 1 address 192.168.0.100 netmask 255.255.255.0 gateway 192.168.0.1 wireless-essid FuzonWifi wireless-key xxxxxxxxxxxxxxxxxxxxxxxx wireless-mode Managed wireless-power off wpa-ssid FuzonWifi wpa-psk xxxxxxxxxxxxxxxxxxxxxxxx #dns-nameservers 8.8.8.8 8.8.4.4 Any help would be greatly appreciated!
Igor Posted July 11, 2016 Posted July 11, 2016 We could have mixed up something around firmware on recent firmware rework - AFAIK the rest is unchanged for a while. I am unable to check / out of office.
Fourdee Posted July 11, 2016 Author Posted July 11, 2016 We could have mixed up something around firmware on recent firmware rework - AFAIK the rest is unchanged for a while. I am unable to check / out of office. Thanks Igor. When you get back into office , please let me know if you need any additional info, and, if there are any tests I can run to help debug.
Igor Posted July 11, 2016 Posted July 11, 2016 Unfortunatelly, that won't be soon You will need to test this on your own. My first and only hunch at the moment is trying to load the driver with stock / firmware from some older image, perhaps from this pack: https://github.com/igorpecovnik/lib/blob/next/bin/linux-firmware.zip
wildcat_paris Posted July 11, 2016 Posted July 11, 2016 @Fourdee feel free to use [ spoiler ] [ /spoiler ] tags (without spaces) for long logs (please!)
Fourdee Posted July 12, 2016 Author Posted July 12, 2016 Ok, tried using ap6210 instead of ap6211 as per: http://wiki.lemaker.org/BananaPro/Pi:WiFi_configuration root@DietPi:~# modprobe -v ap6210 insmod /lib/modules/3.4.112-sun7i/kernel/drivers/net/wireless/ap6210/ap6210.ko modprobe: ERROR: could not insert 'ap6210': Operation not permitted root@DietPi:~# dmesg | grep ap6210 [ 418.331180] [ap6210] bluetooth is disable in script.fex. [ 418.336457] [ap6210] [dhd_module_init] get wl_host_wake gpio failed I also tried loading the following (gpio) additional modules, as per this link: https://github.com/armStrapTools/ap6210/issues/2#issuecomment-46096001. However, the modules appear to be built into kernel. root@DietPi:~# modprobe gpio_sunxi root@DietPi:~# modprobe pwm_sunxi root@DietPi:~# modprobe sunxi_gmac root@DietPi:~# modprobe disp root@DietPi:~# modprobe sunxi_cedar_mod root@DietPi:~# lsmod Module Size Used by spidev 6366 0 a20_tp 3333 0 8021q 18601 0 garp 6068 1 8021q stp 2028 1 garp llc 5357 2 stp,garp sunxi_ir 4013 0 sg 23859 0 Managed to get the ap6210 module loaded by install this package: http://forum.armbian.com/index.php/topic/340-banana-pi-pro-m1plus-no-wifi-armbian-45/#entry2138 root@DietPi:~# lsmod Module Size Used by wifi_gpio 6375 0 spidev 6366 0 ap6210 624553 0 a20_tp 3365 0 8021q 18593 0 garp 6072 1 8021q stp 2032 1 garp llc 5365 2 stp,garp sunxi_ir 4037 0 sg 23805 0 Still fails to scan: root@DietPi:~# iwlist wlan0 scan wlan0 No scan results root@DietPi:~# dmesg | grep ap6210 [ 6.389476] [ap6210] --->The Drive has been modified for BananaPro by LeMaker team<--- [ 6.392512] [ap6210] select wifi ap6210 [ 6.395927] [ap6210] Initializing ap6210. [ 6.401154] [ap6210] Succeed to set the gpio ap6210_wl_vdd_en to 0 [ 6.406634] [ap6210] Succeed to set the gpio ap6210_wl_regon to 1 [ 6.821078] [ap6210] WLAN placed in POWER ON [ 6.969660] [ap6210] Linux Kernel SDIO/MMC Driver [ 7.002693] [ap6210] Broadcom Dongle Host Driver: register interface [wlan0] MAC: 00:90:4c:11:22:33 [ 7.008050] [ap6210] Succeed to set the gpio ap6210_wl_regon to 0 [ 7.402288] [ap6210] WLAN placed in RESET [ 8.297867] bcmdhd: exports duplicate symbol bcmsdh_probe (owned by ap6210) [ 8.321743] bcmdhd: exports duplicate symbol bcmsdh_probe (owned by ap6210) [ 8.360219] bcm4330: exports duplicate symbol bcmsdh_probe (owned by ap6210) [ 8.370828] bcm4330: exports duplicate symbol bcmsdh_probe (owned by ap6210) [ 76.841378] [ap6210] Dongle Host Driver, version 1.28.23.3 (r). [ 76.848483] [ap6210] Compiled in drivers/net/wireless/ap6210 on Sep 30 2015 at 14:15:34. [ 76.853556] [ap6210] Succeed to set the gpio ap6210_wl_regon to 1 [ 77.030559] [ap6210] WLAN going back to live [ 77.264234] [ap6210] dhd_bus_devreset: WLAN ON [ 77.270228] [ap6210] Final fw_path=/lib/firmware/ap6210/fw_bcm40181a2.bin [ 77.275901] [ap6210] Final nv_path=/lib/firmware/ap6210/nvram_ap6210.txt [ 77.282410] [ap6210] download firmware /lib/firmware/ap6210/fw_bcm40181a2.bin [ 77.553626] [ap6210] Dongle ready, protocol version 4 [ 77.558314] [ap6210] Dongle ready, protocol version 4 [ 77.568628] [ap6210] Firmware up: op_mode=0x0001, Broadcom Dongle Host Driver mac=e0:76:d0:03:54:f4 [ 77.586143] [ap6210] Firmware version = wl0: Apr 22 2013 14:50:00 version 5.90.195.89.6 FWID 01-b30a427d [ 77.589137] [ap6210] Chip: a962 Rev 1 Pkg 9 [ 78.900382] [ap6210] scan is not ready apt-get remove linux-firmware-image-sun7i && apt-get install linux-firmware-image-banana root@DietPi:~# lsmod Module Size Used by wifi_gpio 6375 0 spidev 6366 0 ap6210 624553 0 a20_tp 3365 0 8021q 18593 0 garp 6072 1 8021q stp 2032 1 garp llc 5365 2 stp,garp sunxi_ir 4037 0 sg 23805 0 root@DietPi:~# iwlist wlan0 scan wlan0 No scan results root@DietPi:~# dmesg | grep ap6210 .................... [ 139.984454] [ap6210] Firmware up: op_mode=0x0001, Broadcom Dongle Host Driver mac=e0:76:d0:03:54:f4 [ 140.002005] [ap6210] Firmware version = wl0: Apr 22 2013 14:50:00 version 5.90.195.89.6 FWID 01-b30a427d [ 140.005006] [ap6210] Chip: a962 Rev 1 Pkg 9 [ 141.317466] [ap6210] scan is not ready root@DietPi:~# modprobe -rf ap6210 root@DietPi:~# modprobe ap6211 modprobe: FATAL: Module ap6211 not found. Not sure what else to try. I'll write Armbian_5.14_Bananapipro_Debian_jessie_3.4.112 and test.
Fourdee Posted July 12, 2016 Author Posted July 12, 2016 Same results with Armbian_5.14_Bananapipro_Debian_jessie_3.4.112: root@bananapipro:~# modprobe ap6210 modprobe: ERROR: could not insert 'ap6210': No such device root@bananapipro:~# modprobe ap6211 root@bananapipro:~# iwlist wlan0 scan wlan0 No scan results root@bananapipro:~# dmesg | grep ap6211 [ 115.824928] [ap6211] --->The Drive has been modified for BananaPro by LeMaker team<--- [ 115.827897] [ap6211] select wifi ap6211 [ 115.831592] [ap6211] Initializing ap6211. [ 115.836902] [ap6211] Succeed to set the gpio ap6211_wl_vdd_en to 0 [ 115.842218] [ap6211] Succeed to set the gpio ap6211_wl_regon to 1 [ 116.046074] [ap6211] WLAN placed in POWER ON [ 116.240488] [ap6211] Linux Kernel SDIO/MMC Driver [ 116.268157] [ap6211] Broadcom Dongle Host Driver: register interface [wlan0] MAC: 00:90:4c:11:22:33 [ 116.274576] [ap6211] Succeed to set the gpio ap6211_wl_regon to 0 [ 116.316005] ap6210: exports duplicate symbol bcmsdh_probe (owned by ap6211) [ 116.329771] ap6210: exports duplicate symbol bcmsdh_probe (owned by ap6211) [ 116.491371] [ap6211] WLAN placed in RESET [ 148.460828] [ap6211] Dongle Host Driver, version 1.28.23.3 (r). [ 148.467891] [ap6211] Compiled in drivers/net/wireless/ap6211 on Jun 22 2016 at 17:42:25. [ 148.473064] [ap6211] Succeed to set the gpio ap6211_wl_regon to 1 [ 148.676814] [ap6211] WLAN going back to live [ 148.913189] [ap6211] dhd_bus_devreset: WLAN ON [ 148.919489] [ap6211] Final fw_path=/lib/firmware/ap6210/fw_bcm40181a2.bin [ 148.925146] [ap6211] Final nv_path=/lib/firmware/ap6210/nvram_ap6210.txt [ 148.931907] [ap6211] download firmware /lib/firmware/ap6210/fw_bcm40181a2.bin [ 149.203569] [ap6211] Dongle ready, protocol version 4 [ 149.208259] [ap6211] Dongle ready, protocol version 4 [ 149.218519] [ap6211] Firmware up: op_mode=0x0001, Broadcom Dongle Host Driver mac=e0:76:d0:03:54:f4 [ 149.235841] [ap6211] Firmware version = wl0: Mar 10 2014 14:59:50 version 5.90.195.89.18 FWID 01-b13c09c7 [ 149.238882] [ap6211] Chip: a962 Rev 1 Pkg 9 [ 150.563168] [ap6211] scan is not ready Is anyone with a BPi Pro able to write Armbian_5.14_Bananapipro_Debian_jessie_3.4.112 and confirm the results above?
Fourdee Posted July 13, 2016 Author Posted July 13, 2016 Tested with BPi Pro Raspbian official image and it works fine. Is this executing some sort of hacky workaround? root@lemaker:~# modprobe -v ap6210 insmod /lib/modules/3.4.103/kernel/drivers/net/wireless/ap6210/ap6210.ko Message from syslogd@lemaker at Jul 13 15:33:03 ... kernel:[ 206.932534] Internal error: Oops: 7 [#1] PREEMPT SMP ARM Segmentation fault root@lemaker:~# Message from syslogd@lemaker at Jul 13 15:33:03 ... kernel:[ 207.825032] Process modprobe (pid: 2524, stack limit = 0xee2dc2f0) Message from syslogd@lemaker at Jul 13 15:33:03 ... kernel:[ 207.834511] Stack: (0xee2dde10 to 0xee2de000) Message from syslogd@lemaker at Jul 13 15:33:03 ... kernel:[ 207.845987] de00: bf0f7be0 bf38fd 84 c034f6c0 00000000 Message from syslogd@lemaker at Jul 13 15:33:03 ... kernel:[ 207.861282] de20: f04fe000 c034f6e0 bf38fd84 00000000 c034f6c0 c034da 88 ef023860 ee528bb8 Message from syslogd@lemaker at Jul 13 15:33:03 ... kernel:[ 207.876575] de40: bf38fd84 c08ef540 ee4ff380 c034eacc bf384818 c02c51 84 ef023800 bf38fd84 Message from syslogd@lemaker at Jul 13 15:33:03 ... kernel:[ 207.891869] de60: bf38f870 c0914100 00000000 f04fe000 bf3ba000 c034fc 04 bf3978b8 bf38f870 Message from syslogd@lemaker at Jul 13 15:33:03 ... kernel:[ 207.907162] de80: c0914100 00000000 f04fe000 bf3ba038 bf3978b8 ee2dc0 00 c0914100 00000000 Message from syslogd@lemaker at Jul 13 15:33:03 ... kernel:[ 207.922456] dea0: f04fe000 c00085b8 8040003f d07fbc60 80000013 bf3ba0 00 00000001 ee2dc000 Message from syslogd@lemaker at Jul 13 15:33:03 ... kernel:[ 207.937750] dec0: ee2dded4 c005b984 ef002180 ee2dc000 0000cbaf bf3978 b8 bf397900 00000001 Message from syslogd@lemaker at Jul 13 15:33:03 ... kernel:[ 207.953044] dee0: ee797480 f04fe000 bf3978b8 00000001 0000cbaf c007f5 8c bf3978c4 00007fff Message from syslogd@lemaker at Jul 13 15:33:03 ... kernel:[ 207.968338] df00: 00000000 b6f55948 00000124 00000000 c007d1f0 b6f559 48 bf3979f4 bf3978c4 Message from syslogd@lemaker at Jul 13 15:33:03 ... kernel:[ 207.983632] df20: ee2dc000 f056a784 f04fe000 000b0f07 f0570428 f05701 90 f05a2358 00071df8 Message from syslogd@lemaker at Jul 13 15:33:03 ... kernel:[ 207.998925] df40: 00081fb8 bf3918e8 000003fe 0000003c 0000003d 000000 32 00000036 00000015 Message from syslogd@lemaker at Jul 13 15:33:03 ... kernel:[ 208.014218] df60: 00000000 bf375180 00000006 00000000 00000000 000000 00 00000000 c0815ffc Message from syslogd@lemaker at Jul 13 15:33:03 ... kernel:[ 208.029512] df80: 08000071 00000000 00040000 b7751398 00000080 c000eb 04 ee2dc000 00000000 Message from syslogd@lemaker at Jul 13 15:33:03 ... kernel:[ 208.044806] dfa0: 00000000 c000e980 00000000 00040000 b6c8c000 000b0f 07 b6f55948 b6c8c000 Message from syslogd@lemaker at Jul 13 15:33:03 ... kernel:[ 208.060100] dfc0: 00000000 00040000 b7751398 00000080 b7751290 000b0f 07 b6f55948 00000000 Message from syslogd@lemaker at Jul 13 15:33:03 ... kernel:[ 208.075394] dfe0: 00000000 bebe491c b6f4cfb4 b6eb80d4 60000010 b6c8c0 00 00000000 00010074 Message from syslogd@lemaker at Jul 13 15:33:03 ... kernel:[ 208.227399] Code: e5884188 13a00001 e8bd81f0 e8bd81f0 (e5100008) dmesg [ 206.617273] [ap6210] --->The Drive has been modified for BananaPro by LeMaker team<--- [ 206.620153] [ap6210] select wifi ap6210 [ 206.640571] sysfs: cannot create duplicate filename '/devices/platform/ap6210_gpio_wifi.0' [ 206.642445] Modules linked in: ap6210(+) mali_drm drm mali ump [last unloaded: ap6210] [ 206.727144] [<c0350d1c>] (platform_device_add+0x100/0x1d4) from [<bf3ba388>] (ap6210_gpio_wifi_init+0x100/0x14c [ap6210]) [ 206.737402] [<bf3ba388>] (ap6210_gpio_wifi_init+0x100/0x14c [ap6210]) from [<bf3ba038>] (dhd_module_init+0x38/0x288 [ap6210]) [ 206.746156] [<bf3ba038>] (dhd_module_init+0x38/0x288 [ap6210]) from [<c00085b8>] (do_one_initcall+0x34/0x174) [ 206.793225] kobject_add_internal failed for ap6210_gpio_wifi.0 with -EEXIST, don't try to register things with the same name in the same directory. [ 206.795109] Modules linked in: ap6210(+) mali_drm drm mali ump [last unloaded: ap6210] [ 206.859961] [<c0350d1c>] (platform_device_add+0x100/0x1d4) from [<bf3ba388>] (ap6210_gpio_wifi_init+0x100/0x14c [ap6210]) [ 206.870311] [<bf3ba388>] (ap6210_gpio_wifi_init+0x100/0x14c [ap6210]) from [<bf3ba038>] (dhd_module_init+0x38/0x288 [ap6210]) [ 206.879083] [<bf3ba038>] (dhd_module_init+0x38/0x288 [ap6210]) from [<c00085b8>] (do_one_initcall+0x34/0x174) [ 206.939673] Modules linked in: ap6210(+) mali_drm drm mali ump [last unloaded: ap6210] [ 208.159398] [<c034fc04>] (driver_register+0x78/0x12c) from [<bf3ba038>] (dhd_module_init+0x38/0x288 [ap6210]) [ 208.178025] [<bf3ba038>] (dhd_module_init+0x38/0x288 [ap6210]) from [<c00085b8>] (do_one_initcall+0x34/0x174)
Igor Posted July 28, 2016 Posted July 28, 2016 Image built today from sources. modprobe ap6211 dmesg | grep ap6211 [ 102.814856] [ap6211] --->The Drive has been modified for BananaPro by LeMaker team<--- [ 102.818131] [ap6211] select wifi ap6211 [ 102.823217] [ap6211] Initializing ap6211. [ 102.828485] [ap6211] Succeed to set the gpio ap6211_wl_vdd_en to 0 [ 102.833803] [ap6211] Succeed to set the gpio ap6211_wl_regon to 1 [ 103.039964] [ap6211] WLAN placed in POWER ON [ 103.227529] [ap6211] Linux Kernel SDIO/MMC Driver [ 103.243971] [ap6211] Broadcom Dongle Host Driver: register interface [wlan0] MAC: 00:90:4c:11:22:33 [ 103.249510] [ap6211] Succeed to set the gpio ap6211_wl_regon to 0 [ 103.458339] [ap6211] WLAN placed in RESET [ 103.723750] ap6210: exports duplicate symbol bcmsdh_probe (owned by ap6211) [ 103.732250] ap6210: exports duplicate symbol bcmsdh_probe (owned by ap6211) [ 116.496845] [ap6211] Dongle Host Driver, version 1.28.23.3 (r). [ 116.503904] [ap6211] Compiled in drivers/net/wireless/ap6211 on Jul 28 2016 at 18:02:45. [ 116.509697] [ap6211] Succeed to set the gpio ap6211_wl_regon to 1 [ 116.714965] [ap6211] WLAN going back to live [ 116.950881] [ap6211] dhd_bus_devreset: WLAN ON [ 116.957350] [ap6211] Final fw_path=/lib/firmware/ap6210/fw_bcm40181a2.bin [ 116.963026] [ap6211] Final nv_path=/lib/firmware/ap6210/nvram_ap6210.txt [ 116.970251] [ap6211] download firmware /lib/firmware/ap6210/fw_bcm40181a2.bin [ 117.235133] [ap6211] Dongle ready, protocol version 4 [ 117.239816] [ap6211] Dongle ready, protocol version 4 [ 117.249959] [ap6211] Firmware up: op_mode=0x0001, Broadcom Dongle Host Driver mac=98:3b:16:e9:6c:98 [ 117.267178] [ap6211] Firmware version = wl0: Mar 10 2014 14:59:50 version 5.90.195.89.18 FWID 01-b13c09c7 [ 117.270182] [ap6211] Chip: a962 Rev 1 Pkg 9 I configure wlan0 adapter in /etc/network/interfaces - SSID and password, then: ifconfig wlan0 up iwconfig wlan0 wlan0 IEEE 802.11 ESSID:"" Mode:Managed Frequency:2.412 GHz Access Point: Not-Associated Bit Rate:65 Mb/s Tx-Power:32 dBm Retry min limit:7 RTS thr:off Fragment thr:off Power Managementmode:All packets received Everything work's well. I also tried AP mode (modprobe ap6211 op_mode=2) and it works fine.
Fourdee Posted July 28, 2016 Author Posted July 28, 2016 Image built today from sources. Everything work's well. I also tried AP mode (modprobe ap6211 op_mode=2) and it works fine. Thanks Igor, i'll try it out. Curious, will this get rolled out to the armbian repo, under one of these packages as a update? linux-jessie-root-bananapipro linux-image-sun7i linux-headers-sun7i linux-firmware-image-sun7i linux-u-boot-bananapipro-default
Igor Posted July 28, 2016 Posted July 28, 2016 With small changes which were done recently and are not yet properly documented (sorry about that). It actually might have effect on this. - linux-firmware-image-sun7i + armbian-hostapd-jessie armbian-tools-jessie armbian-firmware Files in repository are around 3 weeks old so no warranty that this is fixed but worth trying.
Fourdee Posted July 29, 2016 Author Posted July 29, 2016 With small changes which were done recently and are not yet properly documented (sorry about that). It actually might have effect on this. - linux-firmware-image-sun7i+ armbian-hostapd-jessie armbian-tools-jessie armbian-firmwareFiles in repository are around 3 weeks old so no warranty that this is fixed but worth trying. Thanks Igor, Seems these packages armbian-tools-jessie armbian-firmware are not available. root@DietPi:~# apt-get install armbian-tools-jessie armbian-firmware Reading package lists... Done Building dependency tree Reading state information... Done E: Unable to locate package armbian-tools-jessie E: Unable to locate package armbian-firmware root@DietPi:~# cat /etc/apt/sources.list.d/armbian.list deb http://apt.armbian.com jessie main root@DietPi:~# apt-cache search armbian | grep '^armbian-' armbian-hostapd - Patched hostapd armbian-tools - Armbian tools, sunxi, temper Installed armbian-tools armbian-hostapd , still no wifi: wlan0 Interface doesn't support scanning. I'll compile the image and report back.
Fourdee Posted August 4, 2016 Author Posted August 4, 2016 Fresh installation of Armbian_5.17_Bananapipro_Debian_jessie_3.4.112.img, built today. Scan now works, but it wont connect. Tried both DHCP (times out) and STATIC, with WiFi creds set in network interfaces: root@bananapipro:~# iwconfig wlan0 wlan0 IEEE 802.11 ESSID:"" Mode:Managed Frequency:2.412 GHz Access Point: Not-Associated Bit Rate:65 Mb/s Tx-Power:32 dBm Retry min limit:7 RTS thr:off Fragment thr:off Power Management:off wlan0 Link encap:Ethernet HWaddr e0:76:d0:03:54:f4 inet addr:192.168.0.188 Bcast:192.168.0.255 Mask:255.255.255.0 inet6 addr: fe80::e276:d0ff:fe03:54f4/64 Scope:Link UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:11 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 TX bytes:910 (910.0 Same issues with setting country code, not saving changes. root@bananapipro:~# iw reg set GB root@bananapipro:~# iw reg get country 00: DFS-UNSET (2402 - 2472 @ 40), (6, 20), (N/A) (2457 - 2482 @ 40), (6, 20), (N/A), NO-IR (2474 - 2494 @ 20), (6, 20), (N/A), NO-OFDM, NO-IR (5170 - 5250 @ 40), (6, 20), (N/A), NO-IR (5735 - 5835 @ 40), (6, 20), (N/A), NO-IR
