NotAnExpert Posted November 27, 2020 Posted November 27, 2020 Last night we lost power to the whole house, I had to manually start the NAS and when I tried to access my data there was nothing but empty shares. After checking OpenMediaVault Web UI and checking around, the file system status shows as "missing" and there is nothing under RAID Management and all the disks show properly under Storage > Disks. The NAS is set up as a Raid 6 on ext4 with five 12 TB drives. For starters, I wonder why the internal battery did not graciously shut down Helios64 as to avoid this from happening given that power outages are a rather common issue. Then, how do I get my file system back? After browsing some forums I noticed this info may seem important: lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT sda 8:0 0 10.9T 0 disk sdb 8:16 0 10.9T 0 disk sdc 8:32 0 10.9T 0 disk sdd 8:48 0 10.9T 0 disk sde 8:64 0 10.9T 0 disk mmcblk1 179:0 0 14.6G 0 disk └─mmcblk1p1 179:1 0 14.4G 0 part / mmcblk1boot0 179:32 0 4M 1 disk mmcblk1boot1 179:64 0 4M 1 disk cat /etc/fstab UUID=dabb3dbf-8631-4051-a032-c0b97eb285bd / ext4 defaults,noatime,nodiratime,commit=600,errors=remount-ro 0 1 tmpfs /tmp tmpfs defaults,nosuid 0 0 # >>> [openmediavault] /dev/disk/by-label/data /srv/dev-disk-by-label-data ext4 defaults,nofail,user_xattr,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,acl0 2 # <<< [openmediavault] cat /etc/mdadm/mdadm.conf # This file is auto-generated by openmediavault (https://www.openmediavault.org) # WARNING: Do not edit this file, your changes will get lost. # mdadm.conf # # Please refer to mdadm.conf(5) for information about this file. # # by default, scan all partitions (/proc/partitions) for MD superblocks. # alternatively, specify devices to scan, using wildcards if desired. # Note, if no DEVICE line is present, then "DEVICE partitions" is assumed. # To avoid the auto-assembly of RAID devices a pattern that CAN'T match is # used if no RAID devices are configured. DEVICE partitions # auto-create devices with Debian standard permissions CREATE owner=root group=disk mode=0660 auto=yes # automatically tag new arrays as belonging to the local system HOMEHOST <system> # instruct the monitoring daemon where to send mail alerts # definitions of existing MD arrays ARRAY /dev/md/helios64:0 metadata=1.2 name=helios64:0 UUID=f2188013:e3cdc6dd:c8a55f0d:d0e9c602 cat /proc/mdstat Personalities : [linear] [multipath] [raid0] [raid1] [raid6] [raid5] [raid4] [raid10] md0 : inactive sde[4](S) sdc[2](S) sda[0](S) sdd[3](S) sdb[1](S) 58593766400 blocks super 1.2 unused devices: <none> fsck /dev/disk/by-label/ fsck from util-linux 2.33.1 e2fsck 1.44.5 (15-Dec-2018) fsck.ext2: No such file or directory while trying to open /dev/disk/by-label/ Possibly non-existent device? I don't want to lose data even if I have it backed up so I don't want to try to fix it blindly. And given that this could happen again to others and myself it would be very helpful to find a recovery method that others could use. 0 Quote
gprovost Posted November 27, 2020 Posted November 27, 2020 From the look of it your raid array is in inactive state. md0 : inactive sde[4](S) sdc[2](S) sda[0](S) sdd[3](S) sdb[1](S) Can you show the output of the following command : mdadm -D /dev/md0 Also send us the link created by the following command : armbianmonitor -u 3 hours ago, NotAnExpert said: For starters, I wonder why the internal battery did not graciously shut down Helios64 as to avoid this from happening given that power outages are a rather common issue. The graceful shutdown after 10min on battery was unfortunately not implemented yet :-/ It is in the upcoming update. 0 Quote
NotAnExpert Posted November 28, 2020 Author Posted November 28, 2020 mdadm -D /dev/md0 /dev/md0: Version : 1.2 Raid Level : raid0 Total Devices : 5 Persistence : Superblock is persistent State : inactive Working Devices : 5 Name : helios64:0 (local to host helios64) UUID : f2188013:e3cdc6dd:c8a55f0d:d0e9c602 Events : 26341 Number Major Minor RaidDevice - 8 64 - /dev/sde - 8 32 - /dev/sdc - 8 0 - /dev/sda - 8 48 - /dev/sdd - 8 16 - /dev/sdb armbianmonitor -u http://ix.io/2FKq Got a UPS for it in the meantime. 0 Quote
gprovost Posted November 28, 2020 Posted November 28, 2020 Can you try mdadm --run /dev/md0 to reactivate the array Not sure why your array is deactivate though. Maybe some settings were saved up in OMV. Then you can check again the status of the array with mdadm -D /dev/md0 and cat /proc/mdstat 0 Quote
NotAnExpert Posted November 29, 2020 Author Posted November 29, 2020 Thanks! I tried and got the following: mdadm --run /dev/md0 mdadm: failed to start array /dev/md/helios64:0: Input/output error mdadm -D /dev/md0 /dev/md0: Version : 1.2 Creation Time : Thu Nov 5 22:00:27 2020 Raid Level : raid6 Used Dev Size : 18446744073709551615 Raid Devices : 5 Total Devices : 2 Persistence : Superblock is persistent Update Time : Thu Nov 26 07:13:29 2020 State : active, FAILED, Not Started Active Devices : 2 Working Devices : 2 Failed Devices : 0 Spare Devices : 0 Layout : left-symmetric Chunk Size : 512K Consistency Policy : unknown Name : helios64:0 (local to host helios64) UUID : f2188013:e3cdc6dd:c8a55f0d:d0e9c602 Events : 26352 Number Major Minor RaidDevice State - 0 0 0 removed - 0 0 1 removed - 0 0 2 removed - 0 0 3 removed - 0 0 4 removed - 8 32 2 sync /dev/sdc - 8 0 0 sync /dev/sda cat /proc/mdstat Personalities : [linear] [multipath] [raid0] [raid1] [raid6] [raid5] [raid4] [raid10] md0 : inactive sdc[2] sda[0] 23437506560 blocks super 1.2 unused devices: <none> 0 Quote
gprovost Posted December 3, 2020 Posted December 3, 2020 Can you do : mdadm --examine /dev/sd[abcde] and post output here That will define what we can do next : force re adding device to the array or recreating it (last resort). https://raid.wiki.kernel.org/index.php/RAID_Recovery Have you tried something on your own when you realized the array was missing ? If yes I need to know which command you did or what action you did in OMV. 0 Quote
NotAnExpert Posted December 4, 2020 Author Posted December 4, 2020 This is the output: mdadm --examine /dev/sd[abcde] /dev/sda: Magic : a92b4efc Version : 1.2 Feature Map : 0x1 Array UUID : f2188013:e3cdc6dd:c8a55f0d:d0e9c602 Name : helios64:0 (local to host helios64) Creation Time : Thu Nov 5 22:00:27 2020 Raid Level : raid6 Raid Devices : 5 Avail Dev Size : 23437506560 (11175.87 GiB 12000.00 GB) Array Size : 35156259840 (33527.62 GiB 36000.01 GB) Data Offset : 264192 sectors Super Offset : 8 sectors Unused Space : before=264112 sectors, after=0 sectors State : clean Device UUID : ae15b2cf:d55f6fcf:1e4ef3c5:1824b2c7 Internal Bitmap : 8 sectors from superblock Update Time : Thu Nov 26 07:13:29 2020 Bad Block Log : 512 entries available at offset 56 sectors Checksum : 1e6baa82 - correct Events : 26352 Layout : left-symmetric Chunk Size : 512K Device Role : Active device 0 Array State : AAA.. ('A' == active, '.' == missing, 'R' == replacing) /dev/sdb: Magic : a92b4efc Version : 1.2 Feature Map : 0x1 Array UUID : f2188013:e3cdc6dd:c8a55f0d:d0e9c602 Name : helios64:0 (local to host helios64) Creation Time : Thu Nov 5 22:00:27 2020 Raid Level : raid6 Raid Devices : 5 Avail Dev Size : 23437506560 (11175.87 GiB 12000.00 GB) Array Size : 35156259840 (33527.62 GiB 36000.01 GB) Data Offset : 264192 sectors Super Offset : 8 sectors Unused Space : before=264112 sectors, after=0 sectors State : clean Device UUID : e6c4d356:a1021369:2fcd3661:deaa4406 Internal Bitmap : 8 sectors from superblock Update Time : Wed Nov 25 23:33:03 2020 Bad Block Log : 512 entries available at offset 56 sectors Checksum : 1909966b - correct Events : 26341 Layout : left-symmetric Chunk Size : 512K Device Role : Active device 1 Array State : AAAAA ('A' == active, '.' == missing, 'R' == replacing) /dev/sdc: Magic : a92b4efc Version : 1.2 Feature Map : 0x1 Array UUID : f2188013:e3cdc6dd:c8a55f0d:d0e9c602 Name : helios64:0 (local to host helios64) Creation Time : Thu Nov 5 22:00:27 2020 Raid Level : raid6 Raid Devices : 5 Avail Dev Size : 23437506560 (11175.87 GiB 12000.00 GB) Array Size : 35156259840 (33527.62 GiB 36000.01 GB) Data Offset : 264192 sectors Super Offset : 8 sectors Unused Space : before=264112 sectors, after=0 sectors State : clean Device UUID : 31f197dd:6f6d0545:fbc627a6:53582fd4 Internal Bitmap : 8 sectors from superblock Update Time : Thu Nov 26 07:13:29 2020 Bad Block Log : 512 entries available at offset 56 sectors Checksum : 8e9940b8 - correct Events : 26352 Layout : left-symmetric Chunk Size : 512K Device Role : Active device 2 Array State : AAA.. ('A' == active, '.' == missing, 'R' == replacing) /dev/sdd: Magic : a92b4efc Version : 1.2 Feature Map : 0x1 Array UUID : f2188013:e3cdc6dd:c8a55f0d:d0e9c602 Name : helios64:0 (local to host helios64) Creation Time : Thu Nov 5 22:00:27 2020 Raid Level : raid6 Raid Devices : 5 Avail Dev Size : 23437506560 (11175.87 GiB 12000.00 GB) Array Size : 35156259840 (33527.62 GiB 36000.01 GB) Data Offset : 264192 sectors Super Offset : 8 sectors Unused Space : before=264112 sectors, after=0 sectors State : clean Device UUID : 3296b043:2025da1d:edc6e9eb:99e57e34 Internal Bitmap : 8 sectors from superblock Update Time : Wed Nov 25 23:33:03 2020 Bad Block Log : 512 entries available at offset 56 sectors Checksum : 739abeb1 - correct Events : 26341 Layout : left-symmetric Chunk Size : 512K Device Role : Active device 3 Array State : AAAAA ('A' == active, '.' == missing, 'R' == replacing) /dev/sde: Magic : a92b4efc Version : 1.2 Feature Map : 0x1 Array UUID : f2188013:e3cdc6dd:c8a55f0d:d0e9c602 Name : helios64:0 (local to host helios64) Creation Time : Thu Nov 5 22:00:27 2020 Raid Level : raid6 Raid Devices : 5 Avail Dev Size : 23437506560 (11175.87 GiB 12000.00 GB) Array Size : 35156259840 (33527.62 GiB 36000.01 GB) Data Offset : 264192 sectors Super Offset : 8 sectors Unused Space : before=264112 sectors, after=0 sectors State : clean Device UUID : ecf702ec:8dec71e2:a7f465fa:86b78694 Internal Bitmap : 8 sectors from superblock Update Time : Wed Nov 25 23:33:03 2020 Bad Block Log : 512 entries available at offset 56 sectors Checksum : 4f08e782 - correct Events : 26341 Layout : left-symmetric Chunk Size : 512K Device Role : Active device 4 Array State : AAAAA ('A' == active, '.' == missing, 'R' == replacing) ======= Regarding what I tried When I noticed I couldn’t access the files and folders on my computer I tried other computers. Then I went to OMV front end and changed the workgroup thinking it was just a Windows issue and when that didn’t work I removed the shares from Samba, did not delete them from Access Right Management > Shared Folders. At that point I realized the filesystem was missing and mounting was disabled. I did nothing else either in OPV web interface or through SSH commands except for the info and commands you have requested. Thank you! 1 Quote
gprovost Posted December 4, 2020 Posted December 4, 2020 At first glance, things look pretty good so it should be easy reassemble the array. The reason it didn' t happen automatically it's because the event count between sda, sdc is different from sdb, sdd, sde. Fortunately the difference is very small, so data on the RAID should still be ok. First you need to stop the array mdadm --stop /dev/md0 Let's try to re assemble without --force option mdadm /dev/md0 --assemble /dev/sd[abcde] Let us know if it works. If yes then you array should start the syncing process (cat /prod/mdstat), you could share the output of mdadm -D /dev/md0 If if fails, please show the output. Next step, if previous one failed, it's to try assemble with --force option. Please take note that if --force is used you might end up with few file corrupted (whatever writing operation that happen in the difference of event count, in your case the difference of event count is very small). mdadm /dev/md0 --assemble --force /dev/sd[abcde] Same here, share output of cat /prod/mdstat and mdadm -D /dev/md0 2 Quote
NotAnExpert Posted December 4, 2020 Author Posted December 4, 2020 Thanks! Ran the commands, the non-forced assembly failed but the forced fixed the issue. I have been checking files and folders and have not found anything wrong yet. Appreciate your help and detailed instructions! mdadm --stop /dev/md0 mdadm: stopped /dev/md0 mdadm /dev/md0 --assemble /dev/sd[abcde] mdadm: /dev/md0 assembled from 2 drives - not enough to start the array mdadm /dev/md0 --assemble --force /dev/sd[abcde] mdadm: forcing event count in /dev/sdb(1) from 26341 upto 26352 mdadm: forcing event count in /dev/sdd(3) from 26341 upto 26352 mdadm: forcing event count in /dev/sde(4) from 26341 upto 26352 mdadm: clearing FAULTY flag for device 3 in /dev/md0 for /dev/sdd mdadm: clearing FAULTY flag for device 4 in /dev/md0 for /dev/sde mdadm: Marking array /dev/md0 as 'clean' mdadm: /dev/md0 has been started with 5 drives. cat /proc/mdstat Personalities : [linear] [multipath] [raid0] [raid1] [raid6] [raid5] [raid4] [raid10] md0 : active (auto-read-only) raid6 sda[0] sde[4] sdd[3] sdc[2] sdb[1] 35156259840 blocks super 1.2 level 6, 512k chunk, algorithm 2 [5/5] [UUUUU] bitmap: 0/88 pages [0KB], 65536KB chunk unused devices: <none> mdadm -D /dev/md0 /dev/md0: Version : 1.2 Creation Time : Thu Nov 5 22:00:27 2020 Raid Level : raid6 Array Size : 35156259840 (33527.62 GiB 36000.01 GB) Used Dev Size : 11718753280 (11175.87 GiB 12000.00 GB) Raid Devices : 5 Total Devices : 5 Persistence : Superblock is persistent Intent Bitmap : Internal Update Time : Thu Nov 26 07:13:29 2020 State : clean Active Devices : 5 Working Devices : 5 Failed Devices : 0 Spare Devices : 0 Layout : left-symmetric Chunk Size : 512K Consistency Policy : bitmap Name : helios64:0 (local to host helios64) UUID : f2188013:e3cdc6dd:c8a55f0d:d0e9c602 Events : 26352 Number Major Minor RaidDevice State 0 8 0 0 active sync /dev/sda 1 8 16 1 active sync /dev/sdb 2 8 32 2 active sync /dev/sdc 3 8 48 3 active sync /dev/sdd 4 8 64 4 active sync /dev/sde ============================================================= After running commands I went back to OMV web UI and raid was listed with clean state. Under filesystem I selected the raid6 “data” and mounted it. Added shares to Samba and all data is accessible. 2 Quote
gabrielle.5 Posted December 29, 2020 Posted December 29, 2020 Hi I had the same situation except there was no power loss. At the morning I saw the red led blinking and there was no access to anything. I have raid6 with 4 drives + one missing (I need to buy one and add) mdadm -D /dev/md0 /dev/md0: Version : 1.2 Raid Level : raid0 Total Devices : 5 Persistence : Superblock is persistent State : inactive Working Devices : 5 Name : helios64:0 (local to host helios64) UUID : 7530fb03:c90e2f01:e0d78a6e:14097e55 Events : 107318 Number Major Minor RaidDevice - 8 1 - /dev/sda1 - 8 65 - /dev/sde1 - 8 49 - /dev/sdd1 - 8 33 - /dev/sdc1 - 8 17 - /dev/sdb1 mdadm -E /dev/sda1 /dev/sda1: Magic : a92b4efc Version : 1.2 Feature Map : 0x1 Array UUID : 7530fb03:c90e2f01:e0d78a6e:14097e55 Name : helios64:0 (local to host helios64) Creation Time : Sun Dec 27 16:58:41 2020 Raid Level : raid6 Raid Devices : 5 Avail Dev Size : 11720583168 (5588.81 GiB 6000.94 GB) Array Size : 17580874752 (16766.43 GiB 18002.82 GB) Data Offset : 264192 sectors Super Offset : 8 sectors Unused Space : before=264112 sectors, after=0 sectors State : active Device UUID : 78ccd511:bbb3a836:60faeece:2fbccc9c Internal Bitmap : 8 sectors from superblock Update Time : Tue Dec 29 10:17:01 2020 Bad Block Log : 512 entries available at offset 32 sectors Checksum : f954d241 - correct Events : 107318 Layout : left-symmetric Chunk Size : 512K Device Role : Active device 0 Array State : AA.AA ('A' == active, '.' == missing, 'R' == replacing) After stopping and reassembling the array with the force option I have access to files. cat /proc/mdstat Personalities : [linear] [multipath] [raid0] [raid1] [raid6] [raid5] [raid4] [raid10] md0 : active raid6 sda1[0] sde1[4] sdd1[3] sdb1[1] 17580874752 blocks super 1.2 level 6, 512k chunk, algorithm 2 [5/4] [UU_UU] [>....................] resync = 0.2% (12862976/5860291584) finish=1082.6min speed=90012K/sec bitmap: 44/44 pages [176KB], 65536KB chunk unused devices: <none> 1. I don't understand what MD is resyncing, there were 4 active drives and are 4 active drives - nothing changed, so why resyncing? 2. I'm really concerned about this situation - there was no reason to that situation, there was no power outage nor any other reason I see, it just stopped working at the night 0 Quote
gprovost Posted January 4, 2021 Posted January 4, 2021 Did you dig into the syslog history to see what was the event that resulted in the array to be inactive ? Since you are running at RAID6 with one missing drive, as soon as you will have one drive that drops, the raid will move to inactive state by safety. So maybe look at ATA event. 0 Quote
brunof Posted February 10, 2021 Posted February 10, 2021 (edited) Good morning. Sorry for my English. I have the exact same problem, but with a difference when I use the commands: mdadm /dev/md0 --assemble /dev/sd[abc] root@Server-Archivos:~# mdadm /dev/md127 --assemble /dev/sd[abc] mdadm: /dev/sda is busy - skipping mdadm: /dev/sdb is busy - skipping mdadm: /dev/sdc is busy - skipping I leave the same information to know if you can help me. Spoiler Linux Server-Archivos 4.19.0-0.bpo.5-amd64 #1 SMP Debian 4.19.37-4~bpo9+1 (2019- 06-19) x86_64 The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Tue Feb 9 21:23:47 2021 from 10.200.0.1 root@Server-Archivos:~# lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT sda 8:0 0 465.8G 0 disk sdb 8:16 0 465.8G 0 disk sdc 8:32 0 465.8G 0 disk sdd 8:48 0 465.8G 0 disk ├─sdd1 8:49 0 512M 0 part /boot/efi ├─sdd2 8:50 0 459.3G 0 part / └─sdd3 8:51 0 6G 0 part [SWAP] root@Server-Archivos:~# cat /proc/mdstat Personalities : [linear] [multipath] [raid0] [raid1] [raid6] [raid5] [raid4] [raid10] md127 : inactive sdb[1](S) sda[0](S) sdc[2](S) 1464766536 blocks super 1.2 unused devices: <none> root@Server-Archivos:~# mdadm -D /dev/md127 /dev/md127: Version : 1.2 Raid Level : raid0 Total Devices : 3 Persistence : Superblock is persistent State : inactive Name : Server-Archivos:Datos (local to host Server-Archivos) UUID : c5da7d95:c8cd6594:261f77d3:6d594c7c Events : 5169 Number Major Minor RaidDevice - 8 32 - /dev/sdc - 8 0 - /dev/sda - 8 16 - /dev/sdb root@Server-Archivos:~# mdadm -D /dev/md127 /dev/md127: Version : 1.2 Raid Level : raid0 Total Devices : 3 Persistence : Superblock is persistent State : inactive Name : Server-Archivos:Datos (local to host Server-Archivos) UUID : c5da7d95:c8cd6594:261f77d3:6d594c7c Events : 5169 Number Major Minor RaidDevice - 8 32 - /dev/sdc - 8 0 - /dev/sda - 8 16 - /dev/sdb root@Server-Archivos:~# armbianmonitor -u -bash: armbianmonitor: command not found root@Server-Archivos:~# mdadm --run /dev/md127 mdadm: failed to start array /dev/md/Server-Archivos:Datos: Input/output error root@Server-Archivos:~# mdadm -D /dev/md127 /dev/md127: Version : 1.2 Creation Time : Fri Jul 26 09:15:43 2019 Raid Level : raid5 Used Dev Size : 488255488 (465.64 GiB 499.97 GB) Raid Devices : 3 Total Devices : 2 Persistence : Superblock is persistent Update Time : Thu Nov 3 14:16:56 2016 State : active, degraded, Not Started Active Devices : 2 Working Devices : 2 Failed Devices : 0 Spare Devices : 0 Layout : left-symmetric Chunk Size : 512K Name : Server-Archivos:Datos (local to host Server-Archivos) UUID : c5da7d95:c8cd6594:261f77d3:6d594c7c Events : 5169 Number Major Minor RaidDevice State - 0 0 0 removed 1 8 16 1 active sync /dev/sdb 2 8 32 2 active sync /dev/sdc root@Server-Archivos:~# cat /proc /mdstat cat: /proc: Is a directory cat: /mdstat: No such file or directory root@Server-Archivos:~# cat /proc/mdstat Personalities : [linear] [multipath] [raid0] [raid1] [raid6] [raid5] [raid4] [raid10] md127 : inactive sdb[1] sdc[2] 976511024 blocks super 1.2 unused devices: <none> root@Server-Archivos:~# mdadm --examine /dev/sd[abc] /dev/sda: Magic : a92b4efc Version : 1.2 Feature Map : 0x1 Array UUID : c5da7d95:c8cd6594:261f77d3:6d594c7c Name : Server-Archivos:Datos (local to host Server-Archivos) Creation Time : Fri Jul 26 09:15:43 2019 Raid Level : raid5 Raid Devices : 3 Avail Dev Size : 976511024 (465.64 GiB 499.97 GB) Array Size : 976510976 (931.27 GiB 999.95 GB) Used Dev Size : 976510976 (465.64 GiB 499.97 GB) Data Offset : 262144 sectors Super Offset : 8 sectors Unused Space : before=262056 sectors, after=48 sectors State : active Device UUID : 7a9f424a:b1acf2cf:5f503af6:8df121f2 Internal Bitmap : 8 sectors from superblock Update Time : Thu Nov 3 14:16:53 2016 Bad Block Log : 512 entries available at offset 72 sectors Checksum : 1a1f3ca9 - correct Events : 3339 Layout : left-symmetric Chunk Size : 512K Device Role : Active device 0 Array State : AAA ('A' == active, '.' == missing, 'R' == replacing) /dev/sdb: Magic : a92b4efc Version : 1.2 Feature Map : 0x1 Array UUID : c5da7d95:c8cd6594:261f77d3:6d594c7c Name : Server-Archivos:Datos (local to host Server-Archivos) Creation Time : Fri Jul 26 09:15:43 2019 Raid Level : raid5 Raid Devices : 3 Avail Dev Size : 976511024 (465.64 GiB 499.97 GB) Array Size : 976510976 (931.27 GiB 999.95 GB) Used Dev Size : 976510976 (465.64 GiB 499.97 GB) Data Offset : 262144 sectors Super Offset : 8 sectors Unused Space : before=262056 sectors, after=48 sectors State : active Device UUID : 9264e6f2:c65b4e79:7fa33f9e:911f3c73 Internal Bitmap : 8 sectors from superblock Update Time : Thu Nov 3 14:16:56 2016 Bad Block Log : 512 entries available at offset 72 sectors Checksum : 953f3922 - correct Events : 5169 Layout : left-symmetric Chunk Size : 512K Device Role : Active device 1 Array State : .AA ('A' == active, '.' == missing, 'R' == replacing) /dev/sdc: Magic : a92b4efc Version : 1.2 Feature Map : 0x1 Array UUID : c5da7d95:c8cd6594:261f77d3:6d594c7c Name : Server-Archivos:Datos (local to host Server-Archivos) Creation Time : Fri Jul 26 09:15:43 2019 Raid Level : raid5 Raid Devices : 3 Avail Dev Size : 976511024 (465.64 GiB 499.97 GB) Array Size : 976510976 (931.27 GiB 999.95 GB) Used Dev Size : 976510976 (465.64 GiB 499.97 GB) Data Offset : 262144 sectors Super Offset : 8 sectors Unused Space : before=262056 sectors, after=48 sectors State : active Device UUID : ed154b12:ee8c47ec:da3932ae:34a4aef9 Internal Bitmap : 8 sectors from superblock Update Time : Thu Nov 3 14:16:56 2016 Bad Block Log : 512 entries available at offset 72 sectors Checksum : be0236a4 - correct Events : 5169 Layout : left-symmetric Chunk Size : 512K Device Role : Active device 2 Array State : .AA ('A' == active, '.' == missing, 'R' == replacing) root@Server-Archivos:~# mdadm --stop /dev/md127 mdadm: stopped /dev/md127 root@Server-Archivos:~# mdadm /dev/md127 --assemble /dev/sd[abc] mdadm: /dev/sda is busy - skipping mdadm: /dev/sdb is busy - skipping mdadm: /dev/sdc is busy - skipping This is the syslog. Spoiler Feb 10 08:52:33 Server-Archivos liblogging-stdlog: [origin software="rsyslogd" swVersion="8.24.0" x-pid="654" x-info="http://www.rsyslog.com"] rsyslogd was HUPed Feb 10 08:52:49 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 08:53:19 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 08:53:49 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 08:54:19 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 08:54:49 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 08:55:19 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 08:55:49 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 08:56:14 Server-Archivos dhclient[846]: DHCPREQUEST of 10.200.0.174 on enp0s25 to 10.200.0.1 port 67 Feb 10 08:56:14 Server-Archivos dhclient[846]: DHCPACK of 10.200.0.174 from 10.200.0.1 Feb 10 08:56:14 Server-Archivos systemd[1]: Reloading Samba SMB Daemon. Feb 10 08:56:14 Server-Archivos systemd[1]: Reloaded Samba SMB Daemon. Feb 10 08:56:14 Server-Archivos dhclient[846]: bound to 10.200.0.174 -- renewal in 283 seconds. Feb 10 08:56:19 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 08:56:50 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 08:57:20 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 08:57:50 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 08:58:20 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 08:58:50 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 08:59:20 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 08:59:50 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:00:01 Server-Archivos CRON[1442]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1) Feb 10 09:00:20 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:00:50 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:00:52 Server-Archivos systemd[1]: Starting Cleanup of Temporary Directories... Feb 10 09:00:52 Server-Archivos systemd[1]: Started Cleanup of Temporary Directories. Feb 10 09:00:57 Server-Archivos dhclient[846]: DHCPREQUEST of 10.200.0.174 on enp0s25 to 10.200.0.1 port 67 Feb 10 09:00:57 Server-Archivos dhclient[846]: DHCPACK of 10.200.0.174 from 10.200.0.1 Feb 10 09:00:57 Server-Archivos systemd[1]: Reloading Samba SMB Daemon. Feb 10 09:00:57 Server-Archivos systemd[1]: Reloaded Samba SMB Daemon. Feb 10 09:00:57 Server-Archivos dhclient[846]: bound to 10.200.0.174 -- renewal in 275 seconds. Feb 10 09:01:20 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:01:51 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:02:21 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:02:51 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:03:21 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:03:51 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:04:21 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:04:51 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:05:21 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:05:33 Server-Archivos dhclient[846]: DHCPREQUEST of 10.200.0.174 on enp0s25 to 10.200.0.1 port 67 Feb 10 09:05:33 Server-Archivos dhclient[846]: DHCPACK of 10.200.0.174 from 10.200.0.1 Feb 10 09:05:33 Server-Archivos systemd[1]: Reloading Samba SMB Daemon. Feb 10 09:05:33 Server-Archivos systemd[1]: Reloaded Samba SMB Daemon. Feb 10 09:05:33 Server-Archivos dhclient[846]: bound to 10.200.0.174 -- renewal in 285 seconds. Feb 10 09:05:51 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:06:22 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:06:52 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:07:22 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:07:32 Server-Archivos systemd[1]: Starting Daily apt download activities... Feb 10 09:07:32 Server-Archivos systemd[1]: Started Daily apt download activities. Feb 10 09:07:32 Server-Archivos systemd[1]: apt-daily.timer: Adding 3h 22min 25.792508s random time. Feb 10 09:07:32 Server-Archivos systemd[1]: apt-daily.timer: Adding 4h 6min 26.131669s random time. Feb 10 09:07:52 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:08:22 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:08:52 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:09:00 Server-Archivos systemd[1]: Starting Clean php session files... Feb 10 09:09:00 Server-Archivos systemd[1]: Started Clean php session files. Feb 10 09:09:01 Server-Archivos CRON[1759]: (root) CMD ( [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi) Feb 10 09:09:02 Server-Archivos systemd[1]: dev-disk-by\x2dlabel-Raid5.device: Job dev-disk-by\x2dlabel-Raid5.device/start timed out. Feb 10 09:09:02 Server-Archivos systemd[1]: Timed out waiting for device dev-disk-by\x2dlabel-Raid5.device. Feb 10 09:09:02 Server-Archivos systemd[1]: Dependency failed for /srv/dev-disk-by-label-Raid5. Feb 10 09:09:02 Server-Archivos systemd[1]: srv-dev\x2ddisk\x2dby\x2dlabel\x2dRaid5.mount: Job srv-dev\x2ddisk\x2dby\x2dlabel\x2dRaid5.mount/start failed with result 'dependency'. Feb 10 09:09:02 Server-Archivos systemd[1]: Dependency failed for File System Check on /dev/disk/by-label/Raid5. Feb 10 09:09:02 Server-Archivos systemd[1]: systemd-fsck@dev-disk-by\x2dlabel-Raid5.service: Job systemd-fsck@dev-disk-by\x2dlabel-Raid5.service/start failed with result 'dependency'. Feb 10 09:09:02 Server-Archivos systemd[1]: dev-disk-by\x2dlabel-Raid5.device: Job dev-disk-by\x2dlabel-Raid5.device/start failed with result 'timeout'. Feb 10 09:09:22 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:09:52 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:10:18 Server-Archivos dhclient[846]: DHCPREQUEST of 10.200.0.174 on enp0s25 to 10.200.0.1 port 67 Feb 10 09:10:18 Server-Archivos dhclient[846]: DHCPACK of 10.200.0.174 from 10.200.0.1 Feb 10 09:10:18 Server-Archivos systemd[1]: Reloading Samba SMB Daemon. Feb 10 09:10:18 Server-Archivos systemd[1]: Reloaded Samba SMB Daemon. Feb 10 09:10:18 Server-Archivos dhclient[846]: bound to 10.200.0.174 -- renewal in 227 seconds. Feb 10 09:10:22 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:10:52 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:11:23 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:11:53 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:12:23 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:12:53 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:13:23 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:13:53 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:14:05 Server-Archivos dhclient[846]: DHCPREQUEST of 10.200.0.174 on enp0s25 to 10.200.0.1 port 67 Feb 10 09:14:05 Server-Archivos dhclient[846]: DHCPACK of 10.200.0.174 from 10.200.0.1 Feb 10 09:14:05 Server-Archivos systemd[1]: Reloading Samba SMB Daemon. Feb 10 09:14:05 Server-Archivos systemd[1]: Reloaded Samba SMB Daemon. Feb 10 09:14:05 Server-Archivos dhclient[846]: bound to 10.200.0.174 -- renewal in 278 seconds. Feb 10 09:14:23 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:14:53 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:15:01 Server-Archivos CRON[1850]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1) Feb 10 09:15:23 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:15:53 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:16:24 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:16:54 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:17:01 Server-Archivos CRON[1960]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Feb 10 09:17:01 Server-Archivos postfix/postsuper[1963]: fatal: scan_dir_push: open directory hold: No such file or directory Feb 10 09:17:24 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:17:54 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:18:24 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:18:44 Server-Archivos dhclient[846]: DHCPREQUEST of 10.200.0.174 on enp0s25 to 10.200.0.1 port 67 Feb 10 09:18:44 Server-Archivos dhclient[846]: DHCPACK of 10.200.0.174 from 10.200.0.1 Feb 10 09:18:44 Server-Archivos systemd[1]: Reloading Samba SMB Daemon. Feb 10 09:18:44 Server-Archivos systemd[1]: Reloaded Samba SMB Daemon. Feb 10 09:18:44 Server-Archivos dhclient[846]: bound to 10.200.0.174 -- renewal in 286 seconds. Feb 10 09:18:54 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:19:24 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:19:54 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:20:24 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:20:54 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:21:25 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:21:55 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:22:25 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:22:55 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:23:25 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:23:30 Server-Archivos dhclient[846]: DHCPREQUEST of 10.200.0.174 on enp0s25 to 10.200.0.1 port 67 Feb 10 09:23:30 Server-Archivos dhclient[846]: DHCPACK of 10.200.0.174 from 10.200.0.1 Feb 10 09:23:30 Server-Archivos systemd[1]: Reloading Samba SMB Daemon. Feb 10 09:23:30 Server-Archivos systemd[1]: Reloaded Samba SMB Daemon. Feb 10 09:23:30 Server-Archivos dhclient[846]: bound to 10.200.0.174 -- renewal in 262 seconds. Feb 10 09:23:55 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:24:25 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:24:50 Server-Archivos kernel: [ 2340.462817] md: kicking non-fresh sda from array! Feb 10 09:24:50 Server-Archivos kernel: [ 2340.482528] md/raid:md127: not clean -- starting background reconstruction Feb 10 09:24:50 Server-Archivos kernel: [ 2340.482559] md/raid:md127: device sdb operational as raid disk 1 Feb 10 09:24:50 Server-Archivos kernel: [ 2340.482561] md/raid:md127: device sdc operational as raid disk 2 Feb 10 09:24:50 Server-Archivos kernel: [ 2340.483245] md/raid:md127: cannot start dirty degraded array. Feb 10 09:24:50 Server-Archivos kernel: [ 2340.505492] md/raid:md127: failed to run raid set. Feb 10 09:24:50 Server-Archivos kernel: [ 2340.505493] md: pers->run() failed ... Feb 10 09:24:55 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:25:25 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:25:55 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:26:26 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:26:56 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:27:26 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:27:52 Server-Archivos dhclient[846]: DHCPREQUEST of 10.200.0.174 on enp0s25 to 10.200.0.1 port 67 Feb 10 09:27:52 Server-Archivos dhclient[846]: DHCPACK of 10.200.0.174 from 10.200.0.1 Feb 10 09:27:52 Server-Archivos systemd[1]: Reloading Samba SMB Daemon. Feb 10 09:27:52 Server-Archivos systemd[1]: Reloaded Samba SMB Daemon. Feb 10 09:27:52 Server-Archivos dhclient[846]: bound to 10.200.0.174 -- renewal in 288 seconds. Feb 10 09:27:56 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:28:26 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:28:56 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:29:26 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:29:56 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:30:01 Server-Archivos CRON[2147]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1) Feb 10 09:30:26 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:30:56 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:31:27 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:31:57 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:32:27 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:32:40 Server-Archivos dhclient[846]: DHCPREQUEST of 10.200.0.174 on enp0s25 to 10.200.0.1 port 67 Feb 10 09:32:40 Server-Archivos dhclient[846]: DHCPACK of 10.200.0.174 from 10.200.0.1 Feb 10 09:32:40 Server-Archivos systemd[1]: Reloading Samba SMB Daemon. Feb 10 09:32:40 Server-Archivos systemd[1]: Reloaded Samba SMB Daemon. Feb 10 09:32:40 Server-Archivos dhclient[846]: bound to 10.200.0.174 -- renewal in 239 seconds. Feb 10 09:32:57 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:33:27 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:33:57 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:34:27 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:34:57 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:35:27 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:35:57 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:36:28 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:36:39 Server-Archivos dhclient[846]: DHCPREQUEST of 10.200.0.174 on enp0s25 to 10.200.0.1 port 67 Feb 10 09:36:39 Server-Archivos dhclient[846]: DHCPACK of 10.200.0.174 from 10.200.0.1 Feb 10 09:36:39 Server-Archivos systemd[1]: Reloading Samba SMB Daemon. Feb 10 09:36:39 Server-Archivos systemd[1]: Reloaded Samba SMB Daemon. Feb 10 09:36:39 Server-Archivos dhclient[846]: bound to 10.200.0.174 -- renewal in 261 seconds. Feb 10 09:36:58 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:37:28 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:37:58 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:38:28 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:38:58 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:39:01 Server-Archivos CRON[2355]: (root) CMD ( [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi) Feb 10 09:39:02 Server-Archivos systemd[1]: Starting Clean php session files... Feb 10 09:39:02 Server-Archivos systemd[1]: Started Clean php session files. Feb 10 09:39:28 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:39:58 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:40:28 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:40:32 Server-Archivos systemd[1]: dev-disk-by\x2dlabel-Raid5.device: Job dev-disk-by\x2dlabel-Raid5.device/start timed out. Feb 10 09:40:32 Server-Archivos systemd[1]: Timed out waiting for device dev-disk-by\x2dlabel-Raid5.device. Feb 10 09:40:32 Server-Archivos systemd[1]: Dependency failed for /srv/dev-disk-by-label-Raid5. Feb 10 09:40:32 Server-Archivos systemd[1]: srv-dev\x2ddisk\x2dby\x2dlabel\x2dRaid5.mount: Job srv-dev\x2ddisk\x2dby\x2dlabel\x2dRaid5.mount/start failed with result 'dependency'. Feb 10 09:40:32 Server-Archivos systemd[1]: Dependency failed for File System Check on /dev/disk/by-label/Raid5. Feb 10 09:40:32 Server-Archivos systemd[1]: systemd-fsck@dev-disk-by\x2dlabel-Raid5.service: Job systemd-fsck@dev-disk-by\x2dlabel-Raid5.service/start failed with result 'dependency'. Feb 10 09:40:32 Server-Archivos systemd[1]: dev-disk-by\x2dlabel-Raid5.device: Job dev-disk-by\x2dlabel-Raid5.device/start failed with result 'timeout'. Feb 10 09:40:59 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:41:00 Server-Archivos dhclient[846]: DHCPREQUEST of 10.200.0.174 on enp0s25 to 10.200.0.1 port 67 Feb 10 09:41:00 Server-Archivos dhclient[846]: DHCPACK of 10.200.0.174 from 10.200.0.1 Feb 10 09:41:00 Server-Archivos systemd[1]: Reloading Samba SMB Daemon. Feb 10 09:41:00 Server-Archivos systemd[1]: Reloaded Samba SMB Daemon. Feb 10 09:41:00 Server-Archivos dhclient[846]: bound to 10.200.0.174 -- renewal in 259 seconds. Feb 10 09:41:20 Server-Archivos kernel: [ 3330.950567] md: md127 stopped. Feb 10 09:41:29 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:41:59 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:42:29 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:42:59 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:43:29 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:43:59 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:44:29 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:44:59 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:45:01 Server-Archivos CRON[2495]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1) Feb 10 09:45:20 Server-Archivos dhclient[846]: DHCPREQUEST of 10.200.0.174 on enp0s25 to 10.200.0.1 port 67 Feb 10 09:45:20 Server-Archivos dhclient[846]: DHCPACK of 10.200.0.174 from 10.200.0.1 Feb 10 09:45:20 Server-Archivos systemd[1]: Reloading Samba SMB Daemon. Feb 10 09:45:20 Server-Archivos systemd[1]: Reloaded Samba SMB Daemon. Feb 10 09:45:20 Server-Archivos dhclient[846]: bound to 10.200.0.174 -- renewal in 236 seconds. Feb 10 09:45:30 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:46:00 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:46:30 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:46:57 Server-Archivos kernel: [ 3667.423878] md: md0 stopped. Feb 10 09:46:57 Server-Archivos kernel: [ 3667.425907] md: md0 stopped. Feb 10 09:47:00 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:47:30 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:47:43 Server-Archivos rrdcached[1116]: flushing old values Feb 10 09:47:43 Server-Archivos rrdcached[1116]: rotating journals Feb 10 09:47:43 Server-Archivos rrdcached[1116]: started new journal /var/lib/rrdcached/journal/rrd.journal.1612961263.326240 Feb 10 09:48:00 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:48:30 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:49:00 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:49:16 Server-Archivos dhclient[846]: DHCPREQUEST of 10.200.0.174 on enp0s25 to 10.200.0.1 port 67 Feb 10 09:49:16 Server-Archivos dhclient[846]: DHCPACK of 10.200.0.174 from 10.200.0.1 Feb 10 09:49:16 Server-Archivos systemd[1]: Reloading Samba SMB Daemon. Feb 10 09:49:16 Server-Archivos systemd[1]: Reloaded Samba SMB Daemon. Feb 10 09:49:16 Server-Archivos dhclient[846]: bound to 10.200.0.174 -- renewal in 241 seconds. Feb 10 09:49:30 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:50:00 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:50:31 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:51:01 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:51:31 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:52:01 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:52:31 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:52:53 Server-Archivos cron-apt: CRON-APT RUN [/etc/cron-apt/config]: Wed Feb 10 08:52:33 -03 2021 Feb 10 09:52:53 Server-Archivos cron-apt: CRON-APT SLEEP: 3563, Wed Feb 10 09:51:56 -03 2021 Feb 10 09:52:53 Server-Archivos cron-apt: CRON-APT ACTION: 0-update Feb 10 09:52:53 Server-Archivos cron-apt: CRON-APT LINE: /usr/bin/apt-get -o Acquire::http::Dl-Limit=25 update -o quiet=2 Feb 10 09:52:54 Server-Archivos cron-apt: CRON-APT ACTION: 3-download Feb 10 09:52:54 Server-Archivos cron-apt: CRON-APT LINE: /usr/bin/apt-get -o Acquire::http::Dl-Limit=25 autoclean -y Feb 10 09:52:54 Server-Archivos cron-apt: Reading package lists... Feb 10 09:52:54 Server-Archivos cron-apt: Building dependency tree... Feb 10 09:52:54 Server-Archivos cron-apt: Reading state information... Feb 10 09:52:54 Server-Archivos cron-apt: CRON-APT LINE: /usr/bin/apt-get -o Acquire::http::Dl-Limit=25 dist-upgrade -d -y -o APT::Get::Show-Upgraded=true Feb 10 09:52:54 Server-Archivos cron-apt: Reading package lists... Feb 10 09:52:54 Server-Archivos cron-apt: Building dependency tree... Feb 10 09:52:54 Server-Archivos cron-apt: Reading state information... Feb 10 09:52:54 Server-Archivos cron-apt: Calculating upgrade... Feb 10 09:52:54 Server-Archivos cron-apt: The following NEW packages will be installed: Feb 10 09:52:54 Server-Archivos cron-apt: linux-image-4.19.0-0.bpo.9-amd64 Feb 10 09:52:54 Server-Archivos cron-apt: The following packages will be upgraded: Feb 10 09:52:54 Server-Archivos cron-apt: apt apt-transport-https apt-utils base-files bind9-host ca-certificates dbus Feb 10 09:52:54 Server-Archivos cron-apt: firmware-amd-graphics firmware-atheros firmware-bnx2 firmware-bnx2x Feb 10 09:52:54 Server-Archivos cron-apt: firmware-brcm80211 firmware-cavium firmware-intel-sound firmware-intelwimax Feb 10 09:52:54 Server-Archivos cron-apt: firmware-ipw2x00 firmware-ivtv firmware-iwlwifi firmware-libertas Feb 10 09:52:54 Server-Archivos cron-apt: firmware-linux firmware-linux-nonfree firmware-misc-nonfree firmware-myricom Feb 10 09:52:54 Server-Archivos cron-apt: firmware-netxen firmware-qlogic firmware-realtek firmware-samsung Feb 10 09:52:54 Server-Archivos cron-apt: firmware-siano firmware-ti-connectivity gdisk gettext-base grub-common Feb 10 09:52:54 Server-Archivos cron-apt: grub-efi-amd64 grub-efi-amd64-bin grub2-common intel-microcode Feb 10 09:52:54 Server-Archivos cron-apt: libapt-inst2.0 libapt-pkg5.0 libbind9-140 libcairo2 libcups2 libcurl3-gnutls Feb 10 09:52:54 Server-Archivos cron-apt: libdbi1 libdbus-1-3 libdns-export162 libdns162 libexpat1 libfreetype6 libgd3 Feb 10 09:52:54 Server-Archivos cron-apt: libglib2.0-0 libgnutls30 libgssapi-krb5-2 libicu57 libidn11 libisc-export160 Feb 10 09:52:54 Server-Archivos cron-apt: libisc160 libisccc140 libisccfg140 libjpeg62-turbo libk5crypto3 libkrb5-3 Feb 10 09:52:54 Server-Archivos cron-apt: libkrb5support0 libldap-2.4-2 libldap-common liblwres141 libmagic-mgc Feb 10 09:52:54 Server-Archivos cron-apt: libmagic1 libnghttp2-14 libnginx-mod-http-auth-pam libnginx-mod-http-dav-ext Feb 10 09:52:54 Server-Archivos cron-apt: libnginx-mod-http-echo libnginx-mod-http-geoip Feb 10 09:52:54 Server-Archivos cron-apt: libnginx-mod-http-image-filter libnginx-mod-http-subs-filter Feb 10 09:52:54 Server-Archivos cron-apt: libnginx-mod-http-upstream-fair libnginx-mod-http-xslt-filter Feb 10 09:52:54 Server-Archivos cron-apt: libnginx-mod-mail libnginx-mod-stream libonig4 libp11-kit0 libperl5.24 Feb 10 09:52:54 Server-Archivos cron-apt: libpython2.7 libpython2.7-minimal libpython2.7-stdlib libpython3.5-minimal Feb 10 09:52:54 Server-Archivos cron-apt: libpython3.5-stdlib libsasl2-2 libsasl2-modules libsasl2-modules-db Feb 10 09:52:54 Server-Archivos cron-apt: libsqlite3-0 libss2 libssl1.0.2 libssl1.1 libsystemd0 libtiff5 libudev1 Feb 10 09:52:54 Server-Archivos cron-apt: libwbclient0 libx11-6 libx11-data libxml2 libxslt1.1 linux-image-amd64 monit Feb 10 09:52:54 Server-Archivos cron-apt: nfs-common nfs-kernel-server nginx nginx-common nginx-full openmediavault Feb 10 09:52:54 Server-Archivos cron-apt: openssh-client openssh-server openssh-sftp-server openssl perl perl-base Feb 10 09:52:54 Server-Archivos cron-apt: perl-modules-5.24 php7.0-bcmath php7.0-cgi php7.0-cli php7.0-common Feb 10 09:52:54 Server-Archivos cron-apt: php7.0-fpm php7.0-json php7.0-mbstring php7.0-opcache php7.0-readline Feb 10 09:52:54 Server-Archivos cron-apt: php7.0-xml postfix postfix-sqlite proftpd-basic python-apt-common Feb 10 09:52:54 Server-Archivos cron-apt: python-samba python2.7 python2.7-minimal python3-apt python3-lxml python3.5 Feb 10 09:52:54 Server-Archivos cron-apt: python3.5-minimal samba samba-common samba-common-bin samba-libs Feb 10 09:52:54 Server-Archivos cron-apt: samba-vfs-modules sudo systemd systemd-sysv tzdata udev usbutils Feb 10 09:52:54 Server-Archivos cron-apt: wpasupplicant wsdd Feb 10 09:52:54 Server-Archivos cron-apt: 150 upgraded, 1 newly installed, 0 to remove and 0 not upgraded. Feb 10 09:52:54 Server-Archivos cron-apt: Need to get 0 B/173 MB of archives. Feb 10 09:52:54 Server-Archivos cron-apt: After this operation, 297 MB of additional disk space will be used. Feb 10 09:52:54 Server-Archivos cron-apt: Download complete and in download only mode Feb 10 09:52:55 Server-Archivos postfix/postsuper[3388]: fatal: scan_dir_push: open directory hold: No such file or directory Feb 10 09:52:56 Server-Archivos anacron[652]: Job `cron.daily' terminated (exit status: 1) (mailing output) Feb 10 09:52:56 Server-Archivos anacron[652]: Normal exit (1 job run) Feb 10 09:52:56 Server-Archivos systemd[1]: anacron.timer: Adding 4min 38.362909s random time. Feb 10 09:52:56 Server-Archivos systemd[1]: Started Run anacron jobs. Feb 10 09:52:56 Server-Archivos anacron[3416]: Anacron 2.3 started on 2021-02-10 Feb 10 09:52:56 Server-Archivos anacron[3416]: Normal exit (0 jobs run) Feb 10 09:52:56 Server-Archivos systemd[1]: anacron.timer: Adding 1min 47.384132s random time. Feb 10 09:53:01 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:53:17 Server-Archivos dhclient[846]: DHCPREQUEST of 10.200.0.174 on enp0s25 to 10.200.0.1 port 67 Feb 10 09:53:17 Server-Archivos dhclient[846]: DHCPACK of 10.200.0.174 from 10.200.0.1 Feb 10 09:53:17 Server-Archivos systemd[1]: Reloading Samba SMB Daemon. Feb 10 09:53:17 Server-Archivos systemd[1]: Reloaded Samba SMB Daemon. Feb 10 09:53:17 Server-Archivos dhclient[846]: bound to 10.200.0.174 -- renewal in 236 seconds. Feb 10 09:53:31 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:54:01 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:54:26 Server-Archivos systemd[1]: dev-disk-by\x2dlabel-Raid5.device: Job dev-disk-by\x2dlabel-Raid5.device/start timed out. Feb 10 09:54:26 Server-Archivos systemd[1]: Timed out waiting for device dev-disk-by\x2dlabel-Raid5.device. Feb 10 09:54:26 Server-Archivos systemd[1]: Dependency failed for /srv/dev-disk-by-label-Raid5. Feb 10 09:54:26 Server-Archivos systemd[1]: srv-dev\x2ddisk\x2dby\x2dlabel\x2dRaid5.mount: Job srv-dev\x2ddisk\x2dby\x2dlabel\x2dRaid5.mount/start failed with result 'dependency'. Feb 10 09:54:26 Server-Archivos systemd[1]: Dependency failed for File System Check on /dev/disk/by-label/Raid5. Feb 10 09:54:26 Server-Archivos systemd[1]: systemd-fsck@dev-disk-by\x2dlabel-Raid5.service: Job systemd-fsck@dev-disk-by\x2dlabel-Raid5.service/start failed with result 'dependency'. Feb 10 09:54:26 Server-Archivos systemd[1]: dev-disk-by\x2dlabel-Raid5.device: Job dev-disk-by\x2dlabel-Raid5.device/start failed with result 'timeout'. Feb 10 09:54:31 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:55:01 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:55:32 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:56:02 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:56:32 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:57:02 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:57:13 Server-Archivos dhclient[846]: DHCPREQUEST of 10.200.0.174 on enp0s25 to 10.200.0.1 port 67 Feb 10 09:57:13 Server-Archivos dhclient[846]: DHCPACK of 10.200.0.174 from 10.200.0.1 Feb 10 09:57:13 Server-Archivos systemd[1]: Reloading Samba SMB Daemon. Feb 10 09:57:13 Server-Archivos systemd[1]: Reloaded Samba SMB Daemon. Feb 10 09:57:13 Server-Archivos dhclient[846]: bound to 10.200.0.174 -- renewal in 231 seconds. Feb 10 09:57:32 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:58:02 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:58:32 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:59:02 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 09:59:32 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:00:01 Server-Archivos CRON[3549]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1) Feb 10 10:00:02 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:00:33 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:01:03 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:01:04 Server-Archivos dhclient[846]: DHCPREQUEST of 10.200.0.174 on enp0s25 to 10.200.0.1 port 67 Feb 10 10:01:04 Server-Archivos dhclient[846]: DHCPACK of 10.200.0.174 from 10.200.0.1 Feb 10 10:01:04 Server-Archivos systemd[1]: Reloading Samba SMB Daemon. Feb 10 10:01:04 Server-Archivos systemd[1]: Reloaded Samba SMB Daemon. Feb 10 10:01:04 Server-Archivos dhclient[846]: bound to 10.200.0.174 -- renewal in 245 seconds. Feb 10 10:01:33 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:01:52 Server-Archivos systemd[1]: Started Run anacron jobs. Feb 10 10:01:52 Server-Archivos anacron[3676]: Anacron 2.3 started on 2021-02-10 Feb 10 10:01:52 Server-Archivos anacron[3676]: Normal exit (0 jobs run) Feb 10 10:01:52 Server-Archivos systemd[1]: anacron.timer: Adding 4min 49.931943s random time. Feb 10 10:02:03 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:02:33 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:03:03 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:03:22 Server-Archivos systemd[1]: dev-disk-by\x2dlabel-Raid5.device: Job dev-disk-by\x2dlabel-Raid5.device/start timed out. Feb 10 10:03:22 Server-Archivos systemd[1]: Timed out waiting for device dev-disk-by\x2dlabel-Raid5.device. Feb 10 10:03:22 Server-Archivos systemd[1]: Dependency failed for /srv/dev-disk-by-label-Raid5. Feb 10 10:03:22 Server-Archivos systemd[1]: srv-dev\x2ddisk\x2dby\x2dlabel\x2dRaid5.mount: Job srv-dev\x2ddisk\x2dby\x2dlabel\x2dRaid5.mount/start failed with result 'dependency'. Feb 10 10:03:22 Server-Archivos systemd[1]: Dependency failed for File System Check on /dev/disk/by-label/Raid5. Feb 10 10:03:22 Server-Archivos systemd[1]: systemd-fsck@dev-disk-by\x2dlabel-Raid5.service: Job systemd-fsck@dev-disk-by\x2dlabel-Raid5.service/start failed with result 'dependency'. Feb 10 10:03:22 Server-Archivos systemd[1]: dev-disk-by\x2dlabel-Raid5.device: Job dev-disk-by\x2dlabel-Raid5.device/start failed with result 'timeout'. Feb 10 10:03:33 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:04:03 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:04:33 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:05:03 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:05:10 Server-Archivos dhclient[846]: DHCPREQUEST of 10.200.0.174 on enp0s25 to 10.200.0.1 port 67 Feb 10 10:05:10 Server-Archivos dhclient[846]: DHCPACK of 10.200.0.174 from 10.200.0.1 Feb 10 10:05:10 Server-Archivos systemd[1]: Reloading Samba SMB Daemon. Feb 10 10:05:10 Server-Archivos systemd[1]: Reloaded Samba SMB Daemon. Feb 10 10:05:10 Server-Archivos dhclient[846]: bound to 10.200.0.174 -- renewal in 276 seconds. Feb 10 10:05:34 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:06:04 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:06:34 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:07:04 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:07:34 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:08:04 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:08:34 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:09:01 Server-Archivos CRON[3760]: (root) CMD ( [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi) Feb 10 10:09:02 Server-Archivos systemd[1]: Starting Clean php session files... Feb 10 10:09:02 Server-Archivos systemd[1]: Started Clean php session files. Feb 10 10:09:04 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:09:34 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:09:46 Server-Archivos dhclient[846]: DHCPREQUEST of 10.200.0.174 on enp0s25 to 10.200.0.1 port 67 Feb 10 10:09:46 Server-Archivos dhclient[846]: DHCPACK of 10.200.0.174 from 10.200.0.1 Feb 10 10:09:46 Server-Archivos systemd[1]: Reloading Samba SMB Daemon. Feb 10 10:09:46 Server-Archivos systemd[1]: Reloaded Samba SMB Daemon. Feb 10 10:09:46 Server-Archivos dhclient[846]: bound to 10.200.0.174 -- renewal in 272 seconds. Feb 10 10:10:04 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:10:32 Server-Archivos systemd[1]: dev-disk-by\x2dlabel-Raid5.device: Job dev-disk-by\x2dlabel-Raid5.device/start timed out. Feb 10 10:10:32 Server-Archivos systemd[1]: Timed out waiting for device dev-disk-by\x2dlabel-Raid5.device. Feb 10 10:10:32 Server-Archivos systemd[1]: Dependency failed for /srv/dev-disk-by-label-Raid5. Feb 10 10:10:32 Server-Archivos systemd[1]: srv-dev\x2ddisk\x2dby\x2dlabel\x2dRaid5.mount: Job srv-dev\x2ddisk\x2dby\x2dlabel\x2dRaid5.mount/start failed with result 'dependency'. Feb 10 10:10:32 Server-Archivos systemd[1]: Dependency failed for File System Check on /dev/disk/by-label/Raid5. Feb 10 10:10:32 Server-Archivos systemd[1]: systemd-fsck@dev-disk-by\x2dlabel-Raid5.service: Job systemd-fsck@dev-disk-by\x2dlabel-Raid5.service/start failed with result 'dependency'. Feb 10 10:10:32 Server-Archivos systemd[1]: dev-disk-by\x2dlabel-Raid5.device: Job dev-disk-by\x2dlabel-Raid5.device/start failed with result 'timeout'. Feb 10 10:10:35 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:11:05 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:11:35 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:12:05 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:12:35 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:13:05 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:13:35 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:14:05 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:14:19 Server-Archivos dhclient[846]: DHCPREQUEST of 10.200.0.174 on enp0s25 to 10.200.0.1 port 67 Feb 10 10:14:19 Server-Archivos dhclient[846]: DHCPACK of 10.200.0.174 from 10.200.0.1 Feb 10 10:14:19 Server-Archivos systemd[1]: Reloading Samba SMB Daemon. Feb 10 10:14:19 Server-Archivos systemd[1]: Reloaded Samba SMB Daemon. Feb 10 10:14:19 Server-Archivos dhclient[846]: bound to 10.200.0.174 -- renewal in 245 seconds. Feb 10 10:14:35 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:15:01 Server-Archivos CRON[4075]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1) Feb 10 10:15:05 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:15:36 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:16:06 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:16:36 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:17:01 Server-Archivos CRON[4184]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Feb 10 10:17:01 Server-Archivos postfix/postsuper[4187]: fatal: scan_dir_push: open directory hold: No such file or directory Feb 10 10:17:06 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:17:36 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:18:06 Server-Archivos monit[1115]: 'mountpoint_srv_dev-disk-by-label-Raid5' status failed (1) -- /srv/dev-disk-by-label-Raid5 is not a mountpoint Feb 10 10:18:24 Server-Archivos dhclient[846]: DHCPREQUEST of 10.200.0.174 on enp0s25 to 10.200.0.1 port 67 Feb 10 10:18:24 Server-Archivos dhclient[846]: DHCPACK of 10.200.0.174 from 10.200.0.1 Feb 10 10:18:24 Server-Archivos systemd[1]: Reloading Samba SMB Daemon. Feb 10 10:18:24 Server-Archivos systemd[1]: Reloaded Samba SMB Daemon. Feb 10 10:18:24 Server-Archivos dhclient[846]: bound to 10.200.0.174 -- renewal in 284 seconds. Edited February 11, 2021 by aprayoga move long log to spoiler 1 Quote
gprovost Posted February 15, 2021 Posted February 15, 2021 @brunof You should first stop the array and then reassemble. mdadm --stop /dev/md0 then try to re assemble without --force option mdadm /dev/md0 --assemble /dev/sd[abcde] If if fails, please show the output. Next step, if previous one failed, it's to try assemble with --force option. Please take note that if --force is used you might end up with few file corrupted (whatever writing operation that happen in the difference of event count, in your case only /dev/sda is out of sync, so you shouldn't lose anything). mdadm /dev/md0 --assemble --force /dev/sd[abcde] Finally can you share the link output from command armbianmonitor -u 0 Quote
brunof Posted February 19, 2021 Posted February 19, 2021 Hello. Sorry for the delay. I ran those braking and raid commands again and it worked! I was able to get the files back. Thanks! The command armbianmonitor -u throws me as a message: -bash: armbianmonitor: command not found 0 Quote
dmfisch Posted January 26, 2023 Posted January 26, 2023 Hello gprovost and brunof, I have the same problem today, but at the end, I get: assembled from 2 drives - not enough to start the array (it is an helios 64 with 5 drives) here are the transcripts: Than You very much for this post and the forum!! Best regards, David lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT sda 8:0 0 12.8T 0 disk sdb 8:16 0 12.8T 0 disk sdc 8:32 0 12.8T 0 disk sdd 8:48 0 12.8T 0 disk sde 8:64 0 12.8T 0 disk mmcblk2 179:0 0 14.6G 0 disk └─mmcblk2p1 179:1 0 14.4G 0 part / mmcblk2boot0 179:32 0 4M 1 disk mmcblk2boot1 179:64 0 4M 1 disk cat /proc/mdstat cat/proc/mdstat -bash: cat/proc/mdstat: No such file or directory cat/etc/mdadm/mdadm.conf -bash: cat/etc/mdadm/mdadm.conf: No such file or directory cat/etc/fstab -bash: cat/etc/fstab: No such file or directory mdadm -D /dev/md0 mdadm: cannot open /dev/md0: No such file or directory cat /etc/fstab UUID=a7a41236-bd7e-4b26-a31d-e30f47633de7 / ext4 noatime,nodiratime,defaults,commit=60 0,errors=remount-ro 0 1 tmpfs /tmp tmpfs defaults,nosuid 0 0 # >>> [openmediavault] /dev/disk/by-uuid/9a6523a1-ad50-4f47-ad34-40969412fb14 /srv/dev-disk-by-uuid-9a6523a1-ad50-4f47-ad34 -40969412fb14 ext4 defaults,nofail,user_xattr,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,a cl 0 2 /dev/disk/by-uuid/7ab05eb1-2cfd-4e97-a58c-11dfa0c345b1 /srv/dev-disk-by-uuid-7ab05eb1-2cfd-4e97-a58c -11dfa0c345b1 ext4 defaults,nofail,user_xattr,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,a cl 0 2 /dev/disk/by-uuid/da21c77c-d9b0-438a-ae92-b3e5b69d43ea /srv/dev-disk-by-uuid-da21c77c-d9b0-438a-ae92 -b3e5b69d43ea ext4 defaults,nofail,user_xattr,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,a cl 0 2 /dev/disk/by-uuid/8a02774d-b5ae-48d8-acdf-21650a592e95 /srv/dev-disk-by-uuid-8a02774d-b5ae-48d8-acdf -21650a592e95 ext4 defaults,nofail,user_xattr,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,a cl 0 2 //192.168.178.32/share1 /srv/009c112d-24cc-4cd2-80a8-1a92225c0da7 cifs _netdev,iocharset=utf 8,vers=3.0,nofail,credentials=/root/.cifscredentials-c3c94089-2022-4974-afba-c886c545ac64 0 0 # <<< [openmediavault] cat /etc/mdadm/mdadm.conf # This file is auto-generated by openmediavault (https://www.openmediavault.org) # WARNING: Do not edit this file, your changes will get lost. # mdadm.conf # # Please refer to mdadm.conf(5) for information about this file. # # by default, scan all partitions (/proc/partitions) for MD superblocks. # alternatively, specify devices to scan, using wildcards if desired. # Note, if no DEVICE line is present, then "DEVICE partitions" is assumed. # To avoid the auto-assembly of RAID devices a pattern that CAN'T match is # used if no RAID devices are configured. DEVICE partitions # auto-create devices with Debian standard permissions CREATE owner=root group=disk mode=0660 auto=yes # automatically tag new arrays as belonging to the local system HOMEHOST <system> # instruct the monitoring daemon where to send mail alerts MAILADDR david@mayenfisch.com MAILFROM root # definitions of existing MD arrays ARRAY /dev/md/helios64:Meduraid metadata=1.2 name=helios64:Meduraid UUID=e8fadf3f:06489a06:20c58fb5:f3e10151 cat /proc/mdstat Personalities : [linear] [multipath] [raid0] [raid1] [raid6] [raid5] [raid4] [raid10] md127 : inactive sde[4](S) sdc[2](S) sdd[3](S) sdb[1](S) sda[0](S) 68361251840 blocks super 1.2 unused devices: <none> mdadm --stop /dev/md127 mdadm: stopped /dev/md127 root@helios64:~# mdadm /dev/md127 --assemble /dev/sd[abcde] #debut demmarage disques 12:29 censé syncher mdadm /dev/md127 --assemble /dev/sd[abcde] mdadm: /dev/md127 assembled from 2 drives - not enough to start the array. 0 Quote
Ryan Blankenship Posted February 6, 2025 Posted February 6, 2025 Having a simular issue to the one in this thread, however, slightly different, I believe. We experienced a power outage this morning. Luckily the OMV server is on battery backup, so I was able to shut the server down. Once power was restored, I restarted the server and the RAID drive is Missing. From what I can tell, during the reboot, a BIOS autorecovery setting applied GPT to 3 of my RAID drives, as seen in the blkid output below. Looking for options to recover this system. Thanks in advance for any assistance. lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS sda 8:0 0 10.9T 0 disk └─md0 9:0 0 0B 0 raid6 sdb 8:16 0 10.9T 0 disk └─md0 9:0 0 0B 0 raid6 sdc 8:32 0 10.9T 0 disk └─md0 9:0 0 0B 0 raid6 sdd 8:48 0 10.9T 0 disk └─md0 9:0 0 0B 0 raid6 sde 8:64 0 10.9T 0 disk └─md0 9:0 0 0B 0 raid6 sdf 8:80 0 10.9T 0 disk └─md0 9:0 0 0B 0 raid6 sdg 8:96 0 10.9T 0 disk └─md0 9:0 0 0B 0 raid6 sdh 8:112 0 10.9T 0 disk sdi 8:128 0 10.9T 0 disk └─md0 9:0 0 0B 0 raid6 sdj 8:144 0 10.9T 0 disk sdk 8:160 0 10.9T 0 disk nvme0n1 259:0 0 476.9G 0 disk ├─nvme0n1p1 259:1 0 512M 0 part /boot/efi ├─nvme0n1p2 259:2 0 475.5G 0 part /var/folder2ram/var/cache/samba │ /var/folder2ram/var/lib/monit │ /var/folder2ram/var/lib/rrdcached │ /var/folder2ram/var/spool │ /var/lib/containers/storage/overlay │ /var/folder2ram/var/lib/openmediavault/rrd │ /var/folder2ram/var/tmp │ /var/folder2ram/var/log │ / └─nvme0n1p3 259:3 0 976M 0 part [SWAP] blkid /dev/sdf: UUID="cbcc5712-da6b-1419-139a-de9757c7348b" UUID_SUB="bde193d0-b68d-c1d5-11ed-5f8275a4a220" LABEL="omvnas:0" TYPE="linux_raid_member" /dev/nvme0n1p3: UUID="2bb7348b-aa0a-42a1-af4b-f4ee684c78ba" TYPE="swap" PARTUUID="d804df87-8bf9-45bd-9cb5-da32f39fee2a" /dev/nvme0n1p1: UUID="4647-262F" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="8aa9ef68-1a9f-4d0e-a27b-afc72cc70946" /dev/nvme0n1p2: UUID="82bb97eb-6acc-4de0-8361-09b220ad4041" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="537d3034-7576-44ea-a8e8-ccce3d33c1b8" /dev/sdd: UUID="cbcc5712-da6b-1419-139a-de9757c7348b" UUID_SUB="3017eba0-37a3-83ff-202c-dd24668b7223" LABEL="omvnas:0" TYPE="linux_raid_member" /dev/sdb: UUID="cbcc5712-da6b-1419-139a-de9757c7348b" UUID_SUB="792c5ef1-7fb7-335c-6f63-b5a835548740" LABEL="omvnas:0" TYPE="linux_raid_member" /dev/sdi: UUID="cbcc5712-da6b-1419-139a-de9757c7348b" UUID_SUB="ee6cdfb3-c66c-013a-0918-1573a1f32bfd" LABEL="omvnas:0" TYPE="linux_raid_member" /dev/sdg: UUID="cbcc5712-da6b-1419-139a-de9757c7348b" UUID_SUB="711a8d42-424e-f6f6-9ff4-60cc2bee0cb9" LABEL="omvnas:0" TYPE="linux_raid_member" /dev/sde: UUID="cbcc5712-da6b-1419-139a-de9757c7348b" UUID_SUB="8955e286-76c7-a860-7421-928527ed2f2e" LABEL="omvnas:0" TYPE="linux_raid_member" /dev/sdc: UUID="cbcc5712-da6b-1419-139a-de9757c7348b" UUID_SUB="04f481c7-5f9f-d02b-a759-61d0b880c975" LABEL="omvnas:0" TYPE="linux_raid_member" /dev/sda: UUID="cbcc5712-da6b-1419-139a-de9757c7348b" UUID_SUB="8440a728-ed6c-82a2-bbcf-2b533cc73f22" LABEL="omvnas:0" TYPE="linux_raid_member" /dev/sdk: PTUUID="5066a101-8bc4-412b-8c31-9989f6114efe" PTTYPE="gpt" /dev/sdj: PTUUID="0543fe2c-2926-4428-a9bb-4d8478340340" PTTYPE="gpt" /dev/sdh: PTUUID="bed11372-978a-482f-8eff-9d94f18c9b61" PTTYPE="gpt" mdadm --detail /dev/md0 /dev/md0: Version : 1.2 Creation Time : Sun Sep 3 15:35:48 2023 Raid Level : raid6 Used Dev Size : 18446744073709551615 Raid Devices : 11 Total Devices : 8 Persistence : Superblock is persistent Update Time : Thu Feb 6 05:21:31 2025 State : active, FAILED, Not Started Active Devices : 8 Working Devices : 8 Failed Devices : 0 Spare Devices : 0 Layout : left-symmetric Chunk Size : 512K Consistency Policy : unknown Name : omvnas:0 (local to host omvnas) UUID : cbcc5712:da6b1419:139ade97:57c7348b Events : 260594 Number Major Minor RaidDevice State - 0 0 0 removed - 0 0 1 removed - 0 0 2 removed - 0 0 3 removed - 0 0 4 removed - 0 0 5 removed - 0 0 6 removed - 0 0 7 removed - 0 0 8 removed - 0 0 9 removed - 0 0 10 removed - 8 64 2 sync /dev/sde - 8 32 0 sync /dev/sdc - 8 0 1 sync /dev/sda - 8 80 9 sync /dev/sdf - 8 48 4 sync /dev/sdd - 8 16 3 sync /dev/sdb - 8 128 5 sync /dev/sdi - 8 96 7 sync /dev/sdg cat /etc/mdadm/mdadm.conf # This file is auto-generated by openmediavault (https://www.openmediavault.org) # WARNING: Do not edit this file, your changes will get lost. # mdadm.conf # # Please refer to mdadm.conf(5) for information about this file. # # by default, scan all partitions (/proc/partitions) for MD superblocks. # alternatively, specify devices to scan, using wildcards if desired. # Note, if no DEVICE line is present, then "DEVICE partitions" is assumed. # To avoid the auto-assembly of RAID devices a pattern that CAN'T match is # used if no RAID devices are configured. DEVICE partitions # auto-create devices with Debian standard permissions CREATE owner=root group=disk mode=0660 auto=yes # automatically tag new arrays as belonging to the local system HOMEHOST <system> # definitions of existing MD arrays ARRAY /dev/md0 metadata=1.2 name=omvnas:0 UUID=cbcc5712:da6b1419:139ade97:57c7348b cat /proc/mdstat Personalities : [linear] [multipath] [raid0] [raid1] [raid6] [raid5] [raid4] [raid10] md0 : inactive sdi[5](S) sde[2](S) sdg[6](S) sdf[7](S) sdd[4](S) sda[1](S) sdc[0](S) sdb[3](S) 93750140928 blocks super 1.2 unused devices: <none> mdadm --examine /dev/sd[a-k] /dev/sda: Magic : a92b4efc Version : 1.2 Feature Map : 0x1 Array UUID : cbcc5712:da6b1419:139ade97:57c7348b Name : omvnas:0 (local to host omvnas) Creation Time : Sun Sep 3 15:35:48 2023 Raid Level : raid6 Raid Devices : 11 Avail Dev Size : 23437535232 sectors (10.91 TiB 12.00 TB) Array Size : 105468811776 KiB (98.23 TiB 108.00 TB) Used Dev Size : 23437513728 sectors (10.91 TiB 12.00 TB) Data Offset : 235520 sectors Super Offset : 8 sectors Unused Space : before=235440 sectors, after=21504 sectors State : clean Device UUID : 8440a728:ed6c82a2:bbcf2b53:3cc73f22 Internal Bitmap : 8 sectors from superblock Update Time : Thu Feb 6 05:21:31 2025 Bad Block Log : 512 entries available at offset 56 sectors Checksum : aa6cf6bd - correct Events : 260594 Layout : left-symmetric Chunk Size : 512K Device Role : Active device 1 Array State : AAAAAAAAAAA ('A' == active, '.' == missing, 'R' == replacing) /dev/sdb: Magic : a92b4efc Version : 1.2 Feature Map : 0x1 Array UUID : cbcc5712:da6b1419:139ade97:57c7348b Name : omvnas:0 (local to host omvnas) Creation Time : Sun Sep 3 15:35:48 2023 Raid Level : raid6 Raid Devices : 11 Avail Dev Size : 23437535232 sectors (10.91 TiB 12.00 TB) Array Size : 105468811776 KiB (98.23 TiB 108.00 TB) Used Dev Size : 23437513728 sectors (10.91 TiB 12.00 TB) Data Offset : 235520 sectors Super Offset : 8 sectors Unused Space : before=235440 sectors, after=21504 sectors State : clean Device UUID : 792c5ef1:7fb7335c:6f63b5a8:35548740 Internal Bitmap : 8 sectors from superblock Update Time : Thu Feb 6 05:21:31 2025 Bad Block Log : 512 entries available at offset 56 sectors Checksum : a0a64df4 - correct Events : 260594 Layout : left-symmetric Chunk Size : 512K Device Role : Active device 3 Array State : AAAAAAAAAAA ('A' == active, '.' == missing, 'R' == replacing) /dev/sdc: Magic : a92b4efc Version : 1.2 Feature Map : 0x1 Array UUID : cbcc5712:da6b1419:139ade97:57c7348b Name : omvnas:0 (local to host omvnas) Creation Time : Sun Sep 3 15:35:48 2023 Raid Level : raid6 Raid Devices : 11 Avail Dev Size : 23437535232 sectors (10.91 TiB 12.00 TB) Array Size : 105468811776 KiB (98.23 TiB 108.00 TB) Used Dev Size : 23437513728 sectors (10.91 TiB 12.00 TB) Data Offset : 235520 sectors Super Offset : 8 sectors Unused Space : before=235440 sectors, after=21504 sectors State : clean Device UUID : 04f481c7:5f9fd02b:a75961d0:b880c975 Internal Bitmap : 8 sectors from superblock Update Time : Thu Feb 6 05:21:31 2025 Bad Block Log : 512 entries available at offset 56 sectors Checksum : a3552017 - correct Events : 260594 Layout : left-symmetric Chunk Size : 512K Device Role : Active device 0 Array State : AAAAAAAAAAA ('A' == active, '.' == missing, 'R' == replacing) /dev/sdd: Magic : a92b4efc Version : 1.2 Feature Map : 0x1 Array UUID : cbcc5712:da6b1419:139ade97:57c7348b Name : omvnas:0 (local to host omvnas) Creation Time : Sun Sep 3 15:35:48 2023 Raid Level : raid6 Raid Devices : 11 Avail Dev Size : 23437535232 sectors (10.91 TiB 12.00 TB) Array Size : 105468811776 KiB (98.23 TiB 108.00 TB) Used Dev Size : 23437513728 sectors (10.91 TiB 12.00 TB) Data Offset : 235520 sectors Super Offset : 8 sectors Unused Space : before=235440 sectors, after=21504 sectors State : clean Device UUID : 3017eba0:37a383ff:202cdd24:668b7223 Internal Bitmap : 8 sectors from superblock Update Time : Thu Feb 6 05:21:31 2025 Bad Block Log : 512 entries available at offset 56 sectors Checksum : 52962446 - correct Events : 260594 Layout : left-symmetric Chunk Size : 512K Device Role : Active device 4 Array State : AAAAAAAAAAA ('A' == active, '.' == missing, 'R' == replacing) /dev/sde: Magic : a92b4efc Version : 1.2 Feature Map : 0x1 Array UUID : cbcc5712:da6b1419:139ade97:57c7348b Name : omvnas:0 (local to host omvnas) Creation Time : Sun Sep 3 15:35:48 2023 Raid Level : raid6 Raid Devices : 11 Avail Dev Size : 23437535232 sectors (10.91 TiB 12.00 TB) Array Size : 105468811776 KiB (98.23 TiB 108.00 TB) Used Dev Size : 23437513728 sectors (10.91 TiB 12.00 TB) Data Offset : 235520 sectors Super Offset : 8 sectors Unused Space : before=235440 sectors, after=21504 sectors State : clean Device UUID : 8955e286:76c7a860:74219285:27ed2f2e Internal Bitmap : 8 sectors from superblock Update Time : Thu Feb 6 05:21:31 2025 Bad Block Log : 512 entries available at offset 56 sectors Checksum : 524ddf1 - correct Events : 260594 Layout : left-symmetric Chunk Size : 512K Device Role : Active device 2 Array State : AAAAAAAAAAA ('A' == active, '.' == missing, 'R' == replacing) /dev/sdf: Magic : a92b4efc Version : 1.2 Feature Map : 0x1 Array UUID : cbcc5712:da6b1419:139ade97:57c7348b Name : omvnas:0 (local to host omvnas) Creation Time : Sun Sep 3 15:35:48 2023 Raid Level : raid6 Raid Devices : 11 Avail Dev Size : 23437535232 sectors (10.91 TiB 12.00 TB) Array Size : 105468811776 KiB (98.23 TiB 108.00 TB) Used Dev Size : 23437513728 sectors (10.91 TiB 12.00 TB) Data Offset : 235520 sectors Super Offset : 8 sectors Unused Space : before=235440 sectors, after=21504 sectors State : clean Device UUID : bde193d0:b68dc1d5:11ed5f82:75a4a220 Internal Bitmap : 8 sectors from superblock Update Time : Thu Feb 6 05:21:31 2025 Bad Block Log : 512 entries available at offset 56 sectors Checksum : b32fb355 - correct Events : 260594 Layout : left-symmetric Chunk Size : 512K Device Role : Active device 9 Array State : AAAAAAAAAAA ('A' == active, '.' == missing, 'R' == replacing) /dev/sdg: Magic : a92b4efc Version : 1.2 Feature Map : 0x1 Array UUID : cbcc5712:da6b1419:139ade97:57c7348b Name : omvnas:0 (local to host omvnas) Creation Time : Sun Sep 3 15:35:48 2023 Raid Level : raid6 Raid Devices : 11 Avail Dev Size : 23437535232 sectors (10.91 TiB 12.00 TB) Array Size : 105468811776 KiB (98.23 TiB 108.00 TB) Used Dev Size : 23437513728 sectors (10.91 TiB 12.00 TB) Data Offset : 235520 sectors Super Offset : 8 sectors Unused Space : before=235440 sectors, after=21504 sectors State : clean Device UUID : 711a8d42:424ef6f6:9ff460cc:2bee0cb9 Internal Bitmap : 8 sectors from superblock Update Time : Thu Feb 6 05:21:31 2025 Bad Block Log : 512 entries available at offset 56 sectors Checksum : 28c8fdd9 - correct Events : 260594 Layout : left-symmetric Chunk Size : 512K Device Role : Active device 7 Array State : AAAAAAAAAAA ('A' == active, '.' == missing, 'R' == replacing) /dev/sdh: MBR Magic : aa55 Partition[0] : 4294967295 sectors at 1 (type ee) /dev/sdi: Magic : a92b4efc Version : 1.2 Feature Map : 0x1 Array UUID : cbcc5712:da6b1419:139ade97:57c7348b Name : omvnas:0 (local to host omvnas) Creation Time : Sun Sep 3 15:35:48 2023 Raid Level : raid6 Raid Devices : 11 Avail Dev Size : 23437535232 sectors (10.91 TiB 12.00 TB) Array Size : 105468811776 KiB (98.23 TiB 108.00 TB) Used Dev Size : 23437513728 sectors (10.91 TiB 12.00 TB) Data Offset : 235520 sectors Super Offset : 8 sectors Unused Space : before=235440 sectors, after=21504 sectors State : clean Device UUID : ee6cdfb3:c66c013a:09181573:a1f32bfd Internal Bitmap : 8 sectors from superblock Update Time : Thu Feb 6 05:21:31 2025 Bad Block Log : 512 entries available at offset 56 sectors Checksum : c7f997b8 - correct Events : 260594 Layout : left-symmetric Chunk Size : 512K Device Role : Active device 5 Array State : AAAAAAAAAAA ('A' == active, '.' == missing, 'R' == replacing) /dev/sdj: MBR Magic : aa55 Partition[0] : 4294967295 sectors at 1 (type ee) /dev/sdk: MBR Magic : aa55 Partition[0] : 4294967295 sectors at 1 (type ee) 0 Quote
