SSD Unexpected_Power_Loss / POR_Recovery_Count on Reboot
I’m using the Helios64 with Armbian 20.11 Buster ( 5.9.10-rockchip64)
On every reboot the SMART counter for  “Unexpected_Power_Loss (174)” /  “POR_Recovery_Count (235)”  incresses by one. I’ve seen this unexpected behaviour on Samsung, WD and Crusical SSDs …
Rebooting the box with
sync && echo 1 > /sys/block/sdX/device/delete && reboot
turns the disk friendly off, but shouldn’t this be done in systemd/kernel?
Inspired by this topic https://forum.odroid.com/viewtopic.php?t=29069 I installed a shutdown script in /lib/systemd/system-shutdown:
#!/bin/bash
case "$1" in
    kexec)
       # Do not park disks when switching kernels.
       for disk in /sys/block/sd* ; do
         echo 1 > /sys/class/block/${disk##*/}/device/delete
       done
       sleep 1
esac
this works for my needs.
I don’t know if this problem is Helios64 specific, if not please move this topic to armbian common issues..
Good point indeed, we need to experiment to see to which extend it is really needed.
Experimenting with the following inspired from the odroid thread you shared
#!/bin/bash
# Wait mdadm arrays are in clean state
[ -x /sbin/mdadm ] && /sbin/mdadm --wait-clean --scan
# Choose hdparm param
systemctl list-jobs | egrep -q 'reboot.target.*start' && YVAL='Y' || YVAL='y'
# Park all SATA disks.
if [ -x /usr/sbin/hdparm ]; then
   for DEV in /sys/block/sd* ; do
      [ -e $DEV ] && /usr/sbin/hdparm -$YVAL /dev/${DEV##*/}
   done
   sleep 3
fi
   echo 1 > /sys/class/block/${DEV##*/}/device/delete
done
I've also noted the sudden power loss to drives and that it only happens during reboot, not regular shut down. When doing a regular shut down the drives seem to shut down one at a time, and when reboot:ing they lose power simultaneously.
Now, I'm wondering, what happens if the system is running from the drives and we're using a systemd script to stop them? Is there a chance that they will spin up again because another script is loaded or something similar? It may be a stupid question but I'm not very familiar with systemd. I imagine it should be the very last thing that's executed before the actual restart.
Edit: Side-question, is it actually necessary to power cycle the drives during reboot? Or could they be left running? Might that require changes to u-boot perhaps?
Maybe it is not necessary and rely on SATA soft reset. U-Boot definitely needs to be modified to differentiate reboot and power on.
