Brightness of HDD status LEDs is cycling from 0% to 100% back to 0% continuously
Not sure if anyone has seen the same as I have been seen on my box; the HDD status LEDs are cycling in brightness, from 0% to 100% and back to 0% continuously. It's a smooth transition, no flashy circus.
I might have triggered this myself, but no idea how? Is this is a new feature? I tried to make some video of it, but it is quite difficult to see.
Groetjes,
Only the USB HDD (sdc) is configured to have spindown after some minutes, the others were not explicitly configured to enter either standby/sleep mode. Note that all of the HDD status LEDs show are cycling, not just a few.
hdparm shows the following strange values:
Device: Used as: Interface: Media: hdparm -C says:
sdb rootfs USB USB stick drive state is:  standby
sdg swap SATA SSD drive state is:  active/idle
sda data0 SATA HDD drive state is:  active/idle
sdd data1 SATA HDD drive state is:  active/idle
sde data2 SATA HDD drive state is:  active/idle
sdf data3 SATA HDD drive state is:  active/idle
sdc parity0 USB HDD drive state is:  active/idle
I've never heard that a USB media stick can be put in standby mode? Even more strange is that '/' is running off of this USB device.
See below for more details.
  Reveal hidden contents
Groetjes,
  On 11/30/2020 at 7:19 AM, gprovost said:
Are all the HDD status LED (blue) doing this dimming in and out simultaneously ?
Expand
Hi @gprovost, replies have crossed.
Yes, all the HDD status LEDs are cycling simultaneously. For the HDD with activity, it's still blinking with activity. I cannot make out if the actitivy LED itself is also cycling, my eyes are a bit too old for that.
Groetjes,
Sorry a bit confused. Can you confirm again clearly your statement.
Expand
Only the HDD activity LED are impacted by the dimming cycling ? Or the System Activity LED is also impacted ?
It's only the "HDD x Activity LEDs" that are cycling. The other LEDs are not showing this cycling.
The cycling speed appears to increase with CPU frequency, just like how the "System Activity LED" (heartbeat trigger) frequency will increase when CPU frequency increases.
I made a video of the effect, but have some trouble uploading it (>20MiB). here: https://streamable.com/v8wa36,
Note I do not have any trouble with this effect, just wondering if this is by design and how I can customize it :-)
Groetjes,
Edited by djurny
Thanks for the video.
It's the SATA controller which is doing that dimming thingy
Effectively when I configure link_power_management_policy to med_power_with_dipm I will see the LED dimming cycle happen.
By default link power policy is max_performance
root@helios64:/sys/class# egrep . /sys/class/scsi_host/host*/link_power_management_policy
/sys/class/scsi_host/host0/link_power_management_policy:max_performance
/sys/class/scsi_host/host1/link_power_management_policy:max_performance
/sys/class/scsi_host/host2/link_power_management_policy:max_performance
/sys/class/scsi_host/host3/link_power_management_policy:max_performance
/sys/class/scsi_host/host4/link_power_management_policy:max_performance
Did you set med_power_with_dipm yourself. If not I wonder what program did that for you.
For now i don't see the point to use a different link_power_management_policy than max_performance. But that deserves some investigation.
Hi @gprovost,
Looks like I had 'tlp' installed, presumably during some messing about with getting things like powertop installed. Thanks for the trigger: Removed tlp and LEDs are back to normal!
Groetjes,
