hi,
i have only one fan that spin, i have set the systemctl stop fancontrol and checked the pwm1 the value is 255, and only one who spin
i can turn off the only fan spinning with value 0, but i can't control the seconds fan at all,
i have verified the connectique on the board and everything is fine, when i opened it and checked without disk , and i saw that both fan was spinning, so i thought it was fine, when i closed the board and disk's are on, i again have the same issue, i can control only 1 fan, it's always the same one.
any idea how to fix this issue? is it a software related?
There is apparently no way to mark solution in this "Club" sub-forum, however thank you for reporting it back anyway.
Edited by TRS-80
