jstefanop Posted December 11, 2020 Posted December 11, 2020 What is the current pcie link speed set for stable Armbian 5.9.x release? I know stock kernels from orange pi have it set to Gen 1 speed. Need to test some Gen 2 hardware and see if it works. 0 Quote
piter75 Posted December 11, 2020 Posted December 11, 2020 22 minutes ago, jstefanop said: What is the current pcie link speed set for stable Armbian 5.9.x release? We have Gen1 by default as it's the only one that's officially supported by Rockchip with RK3399: https://github.com/armbian/build/blob/master/patch/kernel/rockchip64-current/add-board-orangepi-4.patch#L839 You can however try switching it to Gen2 with pcie-gen2 overlay (overlays=pcie-gen2 in /boot/armbianEnv.txt) and see how it goes: https://github.com/armbian/build/blob/master/patch/kernel/rockchip64-current/general-rockchip-overlays.patch#L70 0 Quote
ScottP Posted December 13, 2020 Posted December 13, 2020 I have a NanoPC T4 (RK3399) with Friendly ARM ubuntu distro NOT Armbian as yet - I plan to migrate hence why I am reading these forums If this provides a data point? scott@hass:~$ sudo lspci -vv | grep -E 'PCI bridge|LnkCap' 00:00.0 PCI bridge: Fuzhou Rockchip Electronics Co., Ltd Device 0100 (prog-if 00 [Normal decode]) LnkCap: Port #0, Speed 5GT/s, Width x4, ASPM L1, Exit Latency L0s <256ns, L1 <8us LnkCap: Port #0, Speed 8GT/s, Width x4, ASPM L1, Exit Latency L0s unlimited, L1 <64us scott@hass:~$ sudo hdparm -t /dev/nvme0n1p2 /dev/nvme0n1p2: Timing buffered disk reads: 1784 MB in 3.00 seconds = 594.26 MB/sec 1 Quote
jstefanop Posted January 4, 2021 Author Posted January 4, 2021 On 12/11/2020 at 2:26 PM, piter75 said: We have Gen1 by default as it's the only one that's officially supported by Rockchip with RK3399: https://github.com/armbian/build/blob/master/patch/kernel/rockchip64-current/add-board-orangepi-4.patch#L839 You can however try switching it to Gen2 with pcie-gen2 overlay (overlays=pcie-gen2 in /boot/armbianEnv.txt) and see how it goes: https://github.com/armbian/build/blob/master/patch/kernel/rockchip64-current/general-rockchip-overlays.patch#L70 Ok we just finished our 2x M.2 breakout board (uses both lanes exposed by the PCIE port on the orange pi 4). Is there a similar setting for link width? Its currently picking up a x4 Gen 3 M.2 drive with both link speed downgraded to gen 1 (as expected), and width downgraded to 1x. Should be 2x. 0 Quote
VyacheslavS Posted January 5, 2021 Posted January 5, 2021 14 часов назад, jstefanop сказал: Ok we just finished our 2x M.2 breakout board (uses both lanes exposed by the PCIE port on the orange pi 4). Which adapter do you use to connect the M2 for PCIE port on the orange pi 4? I can't find. 0 Quote
jstefanop Posted January 8, 2021 Author Posted January 8, 2021 On 1/5/2021 at 7:30 AM, VyacheslavS said: Which adapter do you use to connect the M2 for PCIE port on the orange pi 4? I can't find. Its a custom board we have made. 0 Quote
thc013 Posted February 23, 2021 Posted February 23, 2021 On 1/5/2021 at 1:30 PM, VyacheslavS said: Which adapter do you use to connect the M2 for PCIE port on the orange pi 4? I can't find. they are back in stock now from what i see , i just ordered one last week https://www.aliexpress.com/item/4000575054675.html?spm=2114.12010612.8148356.1.30b67fddNzcI4W 1 Quote
VyacheslavS Posted March 2, 2021 Posted March 2, 2021 23.02.2021 в 17:51, thc013 сказал: they are back in stock now from what i see , i just ordered one last week I bought this one a year ago, along with the board. This is a miniPCIe. Me also need an adapter to connect an NVMe SSD with an M2 key. I can't find one. 0 Quote
thc013 Posted March 3, 2021 Posted March 3, 2021 Yeah it is a m2 slot and just 2 lanes and there are nvme ssd with a m2 key they are called m2 ssd they copied the m2 slot of the rk3399 board to a pcie/m2 slot with a flex cable so more as 2x pcie is not gonna happen i get today that pcie board , just in time i fixed yesterday the typc boot option in uboot the pinebook and the helios gave the solution rk3399 is not that good in bringing up all rails in 1 time and they do it in the board c file instead with the dts file 0 Quote
jstefanop Posted March 5, 2021 Author Posted March 5, 2021 They only expose one PCIE lane on that adapter, and it won't work with M.2 directly or run at Gen2. Might release our custom board, 2x lanes, Gen2 running stable ~1TB/s bandwidth. 0 Quote
disablewong Posted April 7, 2021 Posted April 7, 2021 hello jstefanop! Have you released your custom board at last>? I want to use the orangepi with my NvME SSD and 10Gbps network card but it seems not detect neither of them..... with the mini-pcie to PCI-E converter and PCIE hub it could not boot at all..... Did you built your own kernel to get it working? 0 Quote
jstefanop Posted April 30, 2021 Author Posted April 30, 2021 On 4/7/2021 at 4:41 AM, disablewong said: hello jstefanop! Have you released your custom board at last>? I want to use the orangepi with my NvME SSD and 10Gbps network card but it seems not detect neither of them..... with the mini-pcie to PCI-E converter and PCIE hub it could not boot at all..... Did you built your own kernel to get it working? stock kernel works, issue is with orange pi 4 has badly designed FPC connector for PCIE lanes. They didn't group the diff pairs so transmission over FPC cable sucks. We had to make a flex ribbon board to correct this and route as diff pairs so Gen 2 2x works great. Might make some extra and release the board if there is enough interest. 3 Quote
disablewong Posted May 25, 2021 Posted May 25, 2021 On 5/1/2021 at 12:39 AM, jstefanop said: stock kernel works, issue is with orange pi 4 has badly designed FPC connector for PCIE lanes. They didn't group the diff pairs so transmission over FPC cable sucks. We had to make a flex ribbon board to correct this and route as diff pairs so Gen 2 2x works great. Might make some extra and release the board if there is enough interest. I would be happy to buy one or two of this if it's available. I think it would be a good choice for building NAS with the power of RK3399. Is your board go with M.2 adaptor and could be converted to PCI-E x1 slot? Which image you've tested with? the stock kernel from orangepi? or the image from armbian? 0 Quote
joaofl Posted December 2, 2021 Posted December 2, 2021 On 4/30/2021 at 6:39 PM, jstefanop said: stock kernel works, issue is with orange pi 4 has badly designed FPC connector for PCIE lanes. They didn't group the diff pairs so transmission over FPC cable sucks. We had to make a flex ribbon board to correct this and route as diff pairs so Gen 2 2x works great. Might make some extra and release the board if there is enough interest. Nice job! Have you released the design files, or any means to buy your adapter? Do you have any tips on booting from the external SSD? 0 Quote
slmq Posted November 23, 2022 Posted November 23, 2022 Hello jstefanop, good job. I would be interested in buying one of those adapters. Is there any other way to contact you? Regards SLMQ 0 Quote
