OK, so while documenting the Armbian patch process I needed something actual to patch. I added gpio-line-names to the device tree, so now all lines are defined. Once I finish the documentation I'll PR this patch. No more guessing what physical pin is! At some point it might make sense to put in jumper and physical pin #.
gpioinfo
gpiochip0 - 8 lines:
	line   0:     "GPY7.0"       unused   input  active-high
	line   1:     "GPY7.1"       unused   input  active-high
	line   2:     "GPY7.2"       unused   input  active-high
	line   3:     "GPY7.3"       unused   input  active-high
	line   4:     "GPY7.4"       unused   input  active-high
	line   5:     "GPY7.5"       unused   input  active-high
	line   6:     "GPY7.6"       unused   input  active-high
	line   7:     "GPY7.7"       unused   input  active-high
gpiochip1 - 8 lines:
	line   0:     "GPX0.0"       unused   input  active-high
	line   1:     "GPX0.1"       unused   input  active-high
	line   2:     "GPX0.2"       unused   input  active-high
	line   3:     "GPX0.3"  "power key"   input   active-low [used]
	line   4:     "GPX0.4"  "interrupt"   input  active-high [used]
	line   5:     "GPX0.5"       unused   input  active-high
	line   6:     "GPX0.6"       unused   input  active-high
	line   7:     "GPX0.7"       unused   input  active-high
gpiochip10 - 8 lines:
	line   0:     "GPD1.0"      "reset"  output   active-low [used]
	line   1:     "GPD1.1"       unused   input  active-high
	line   2:     "GPD1.2"       unused   input  active-high
	line   3:     "GPD1.3"       unused   input  active-high
	line   4:     "GPD1.4"       unused   input  active-high
	line   5:     "GPD1.5"       unused   input  active-high
	line   6:     "GPD1.6"       unused   input  active-high
	line   7:     "GPD1.7"       unused   input  active-high
gpiochip11 - 6 lines:
	line   0:     "GPY0.0"       unused   input  active-high
	line   1:     "GPY0.1"       unused   input  active-high
	line   2:     "GPY0.2"       unused   input  active-high
	line   3:     "GPY0.3"       unused   input  active-high
	line   4:     "GPY0.4"       unused   input  active-high
	line   5:     "GPY0.5"       unused   input  active-high
gpiochip12 - 4 lines:
	line   0:     "GPY1.0"       unused   input  active-high
	line   1:     "GPY1.1"       unused   input  active-high
	line   2:     "GPY1.2"       unused   input  active-high
	line   3:     "GPY1.3"       unused   input  active-high
gpiochip13 - 6 lines:
	line   0:     "GPY2.0"       unused   input  active-high
	line   1:     "GPY2.1"       unused   input  active-high
	line   2:     "GPY2.2"       unused   input  active-high
	line   3:     "GPY2.3"       unused   input  active-high
	line   4:     "GPY2.4"       unused   input  active-high
	line   5:     "GPY2.5"       unused   input  active-high
gpiochip14 - 8 lines:
	line   0:     "GPY3.0"       unused   input  active-high
	line   1:     "GPY3.1"       unused   input  active-high
	line   2:     "GPY3.2"       unused   input  active-high
	line   3:     "GPY3.3"       unused   input  active-high
	line   4:     "GPY3.4"       unused   input  active-high
	line   5:     "GPY3.5"       unused   input  active-high
	line   6:     "GPY3.6"       unused   input  active-high
	line   7:     "GPY3.7"       unused   input  active-high
gpiochip15 - 8 lines:
	line   0:     "GPY4.0"       unused   input  active-high
	line   1:     "GPY4.1"       unused   input  active-high
	line   2:     "GPY4.2"       unused   input  active-high
	line   3:     "GPY4.3"       unused   input  active-high
	line   4:     "GPY4.4"       unused   input  active-high
	line   5:     "GPY4.5"       unused   input  active-high
	line   6:     "GPY4.6"       unused   input  active-high
	line   7:     "GPY4.7"       unused   input  active-high
gpiochip16 - 8 lines:
	line   0:     "GPY5.0"       unused   input  active-high
	line   1:     "GPY5.1"       unused   input  active-high
	line   2:     "GPY5.2"       unused   input  active-high
	line   3:     "GPY5.3"       unused   input  active-high
	line   4:     "GPY5.4"       unused   input  active-high
	line   5:     "GPY5.5"       unused   input  active-high
	line   6:     "GPY5.6"       unused   input  active-high
	line   7:     "GPY5.7"       unused   input  active-high
gpiochip17 - 8 lines:
	line   0:     "GPY6.0"       unused   input  active-high
	line   1:     "GPY6.1"       unused   input  active-high
	line   2:     "GPY6.2"       unused   input  active-high
	line   3:     "GPY6.3"       unused   input  active-high
	line   4:     "GPY6.4"       unused   input  active-high
	line   5:     "GPY6.5"       unused   input  active-high
	line   6:     "GPY6.6"       unused   input  active-high
	line   7:     "GPY6.7"       unused   input  active-high
gpiochip18 - 8 lines:
	line   0:     "GPE0.0"       unused   input  active-high
	line   1:     "GPE0.1"       unused   input  active-high
	line   2:     "GPE0.2"       unused   input  active-high
	line   3:     "GPE0.3"       unused   input  active-high
	line   4:     "GPE0.4"       unused   input  active-high
	line   5:     "GPE0.5"       unused   input  active-high
	line   6:     "GPE0.6"       unused   input  active-high
	line   7:     "GPE0.7"       unused   input  active-high
gpiochip19 - 2 lines:
	line   0:     "GPE1.0"       unused   input  active-high
	line   1:     "GPE1.1"       unused   input  active-high
gpiochip2 - 8 lines:
	line   0:     "GPX1.0"       unused   input  active-high
	line   1:     "GPX1.1"       unused   input  active-high
	line   2:     "GPX1.2"       unused   input  active-high
	line   3:     "GPX1.3"       unused   input  active-high
	line   4:     "GPX1.4"       unused   input  active-high
	line   5:     "GPX1.5"       unused   input  active-high
	line   6:     "GPX1.6"       unused   input  active-high
	line   7:     "GPX1.7"       unused   input  active-high
gpiochip20 - 6 lines:
	line   0:     "GPF0.0"       unused   input  active-high
	line   1:     "GPF0.1"       unused   input  active-high
	line   2:     "GPF0.2"       unused   input  active-high
	line   3:     "GPF0.3"       unused   input  active-high
	line   4:     "GPF0.4"       unused   input  active-high
	line   5:     "GPF0.5"       unused   input  active-high
gpiochip21 - 8 lines:
	line   0:     "GPF1.0"       unused   input  active-high
	line   1:     "GPF1.1"       unused   input  active-high
	line   2:     "GPF1.2"       unused   input  active-high
	line   3:     "GPF1.3"       unused   input  active-high
	line   4:     "GPF1.4"       unused   input  active-high
	line   5:     "GPF1.5"       unused   input  active-high
	line   6:     "GPF1.6"       unused   input  active-high
	line   7:     "GPF1.7"       unused   input  active-high
gpiochip22 - 8 lines:
	line   0:     "GPG0.0"       unused   input  active-high
	line   1:     "GPG0.1"       unused   input  active-high
	line   2:     "GPG0.2"       unused   input  active-high
	line   3:     "GPG0.3"       unused   input  active-high
	line   4:     "GPG0.4"       unused   input  active-high
	line   5:     "GPG0.5"       unused   input  active-high
	line   6:     "GPG0.6"       unused   input  active-high
	line   7:     "GPG0.7"       unused   input  active-high
gpiochip23 - 8 lines:
	line   0:     "GPG1.0"       unused   input  active-high
	line   1:     "GPG1.1"       unused   input  active-high
	line   2:     "GPG1.2"       unused   input  active-high
	line   3:     "GPG1.3"       unused   input  active-high
	line   4:     "GPG1.4"       unused   input  active-high
	line   5:     "GPG1.5"       unused   input  active-high
	line   6:     "GPG1.6"       unused   input  active-high
	line   7:     "GPG1.7"       unused   input  active-high
gpiochip24 - 2 lines:
	line   0:     "GPG2.0"       unused   input  active-high
	line   1:     "GPG2.1"       unused   input  active-high
gpiochip25 - 4 lines:
	line   0:     "GPJ4.0"       unused   input  active-high
	line   1:     "GPJ4.1"       unused   input  active-high
	line   2:     "GPJ4.2"       unused   input  active-high
	line   3:     "GPJ4.3"       unused   input  active-high
gpiochip26 - 8 lines:
	line   0:     "GPA0.0"       unused   input  active-high
	line   1:     "GPA0.1"       unused   input  active-high
	line   2:     "GPA0.2"       unused   input  active-high
	line   3:     "GPA0.3"       unused   input  active-high
	line   4:     "GPA0.4"       unused   input  active-high
	line   5:     "GPA0.5"       unused   input  active-high
	line   6:     "GPA0.6"       unused   input  active-high
	line   7:     "GPA0.7"       unused   input  active-high
gpiochip27 - 6 lines:
	line   0:     "GPA1.0"       unused   input  active-high
	line   1:     "GPA1.1"       unused   input  active-high
	line   2:     "GPA1.2"       unused   input  active-high
	line   3:     "GPA1.3"       unused   input  active-high
	line   4:     "GPA1.4"       unused   input  active-high
	line   5:     "GPA1.5"       unused   input  active-high
gpiochip28 - 8 lines:
	line   0:     "GPA2.0"       unused   input  active-high
	line   1:     "GPA2.1"       unused   input  active-high
	line   2:     "GPA2.2"       unused   input  active-high
	line   3:     "GPA2.3"       unused   input  active-high
	line   4:     "GPA2.4"       unused   input  active-high
	line   5:     "GPA2.5"       unused   input  active-high
	line   6:     "GPA2.6"       unused   input  active-high
	line   7:     "GPA2.7"       unused   input  active-high
gpiochip29 - 5 lines:
	line   0:     "GPB0.0"       unused   input  active-high
	line   1:     "GPB0.1"       unused   input  active-high
	line   2:     "GPB0.2"       unused   input  active-high
	line   3:     "GPB0.3"       unused   input  active-high
	line   4:     "GPB0.4"       unused   input  active-high
gpiochip3 - 8 lines:
	line   0:     "GPX2.0"       unused   input  active-high
	line   1:     "GPX2.1"       unused   input  active-high
	line   2:     "GPX2.2"       unused   input  active-high
	line   3:     "GPX2.3"       unused   input  active-high
	line   4:     "GPX2.4"       unused   input  active-high
	line   5:     "GPX2.5"       unused   input  active-high
	line   6:     "GPX2.6"       unused   input  active-high
	line   7:     "GPX2.7"       unused   input  active-high
gpiochip30 - 5 lines:
	line   0:     "GPB1.0"       unused   input  active-high
	line   1:     "GPB1.1"       unused   input  active-high
	line   2:     "GPB1.2"       unused   input  active-high
	line   3:     "GPB1.3"       unused   input  active-high
	line   4:     "GPB1.4"       unused   input  active-high
gpiochip31 - 4 lines:
	line   0:     "GPB2.0"       unused   input  active-high
	line   1:     "GPB2.1"       unused   input  active-high
	line   2:     "GPB2.2"       unused   input  active-high
	line   3:     "GPB2.3"       unused   input  active-high
gpiochip32 - 8 lines:
	line   0:     "GPB3.0"       unused   input  active-high
	line   1:     "GPB3.1"       unused   input  active-high
	line   2:     "GPB3.2"       unused   input  active-high
	line   3:     "GPB3.3"       unused   input  active-high
	line   4:     "GPB3.4"       unused   input  active-high
	line   5:     "GPB3.5"       unused   input  active-high
	line   6:     "GPB3.6"       unused   input  active-high
	line   7:     "GPB3.7"       unused   input  active-high
gpiochip33 - 2 lines:
	line   0:     "GPB4.0"       unused   input  active-high
	line   1:     "GPB4.1"       unused   input  active-high
gpiochip34 - 8 lines:
	line   0:     "GPH0.0"       unused   input  active-high
	line   1:     "GPH0.1"       unused   input  active-high
	line   2:     "GPH0.2"       unused   input  active-high
	line   3:     "GPH0.3"       unused   input  active-high
	line   4:     "GPH0.4"       unused   input  active-high
	line   5:     "GPH0.5"       unused   input  active-high
	line   6:     "GPH0.6"       unused   input  active-high
	line   7:     "GPH0.7"       unused   input  active-high
gpiochip35 - 7 lines:
	line   0:      "GPZ.0"       unused   input  active-high
	line   1:      "GPZ.1"       unused   input  active-high
	line   2:      "GPZ.2"       unused   input  active-high
	line   3:      "GPZ.3"       unused   input  active-high
	line   4:      "GPZ.4"       unused   input  active-high
	line   5:      "GPZ.5"       unused   input  active-high
	line   6:      "GPZ.6"       unused   input  active-high
gpiochip4 - 8 lines:
	line   0:     "GPX3.0"       unused   input  active-high
	line   1:     "GPX3.1"       unused   input  active-high
	line   2:     "GPX3.2"       unused   input  active-high
	line   3:     "GPX3.2"       unused   input  active-high
	line   4:     "GPX3.4"       unused   input  active-high
	line   5:     "GPX3.5"       unused   input  active-high
	line   6:     "GPX3.6"       unused   input  active-high
	line   7:     "GPX3.7"        "hpd"   input  active-high [used]
gpiochip5 - 8 lines:
	line   0:     "GPC0.0"       unused   input  active-high
	line   1:     "GPC0.1"       unused   input  active-high
	line   2:     "GPC0.2"       unused   input  active-high
	line   3:     "GPC0.3"       unused   input  active-high
	line   4:     "GPC0.4"       unused   input  active-high
	line   5:     "GPC0.5"       unused   input  active-high
	line   6:     "GPC0.6"       unused   input  active-high
	line   7:     "GPC0.7"       unused   input  active-high
gpiochip6 - 8 lines:
	line   0:     "GPC1.0"       unused   input  active-high
	line   1:     "GPC1.1"       unused   input  active-high
	line   2:     "GPC1.2"       unused   input  active-high
	line   3:     "GPC1.3"       unused   input  active-high
	line   4:     "GPC1.4"       unused   input  active-high
	line   5:     "GPC1.5"       unused   input  active-high
	line   6:     "GPC1.6"       unused   input  active-high
	line   7:     "GPC1.7"       unused   input  active-high
gpiochip7 - 7 lines:
	line   0:     "GPC2.0"       unused   input  active-high
	line   1:     "GPC2.1"       unused   input  active-high
	line   2:     "GPC2.2"       unused   input  active-high
	line   3:     "GPC2.3"       unused   input  active-high
	line   4:     "GPC2.4"       unused   input  active-high
	line   5:     "GPC2.5"       unused   input  active-high
	line   6:     "GPC2.6"       unused   input  active-high
gpiochip8 - 4 lines:
	line   0:     "GPC3.0"       unused   input  active-high
	line   1:     "GPC3.1"       unused   input  active-high
	line   2:     "GPC3.2"       unused   input  active-high
	line   3:     "GPC3.3"       unused   input  active-high
gpiochip9 - 2 lines:
	line   0:     "GPC4.0"       unused   input  active-high
	line   1:     "GPC4.1"       unused   input  active-high
Edited by TRS-80
put long output inside spoiler
Cool, man!
Please forgive me if this out of place, as I really have no idea about any of this stuff.  However as a casual observer, those mappings look quite random and I could not discern any sort of order.  But maybe that's because they map to some underlying hardware or something else I am not understanding?  In which case, feel free to disregard this feedback.
In either case, thanks for your contribution!  :thumbup:  :beer:
So if you look at the device tree you'll see pin controllers like GPA0, GPA1, etc. I'm not sure how the kernel gpio device enumerates them, but basically a chip is a pin controller and lines are the pins. The main thing is soon you'll be able to look at a pin map and know exactly which physical pin it is.
Also gpioinfo seems to sort by chip string instead of int, thus 2, 21, 22, etc. are all 2s :(
