test0x01 Posted December 13, 2020 Posted December 13, 2020 hi all, I am wondering if there's any reason that CEC is not built into legacy kernel for RK3399. In https://github.com/armbian/build/blob/master/config/kernel/linux-rk3399-legacy.config, module dw-hdmi-cec is not enabled. # CONFIG_DRM_DW_HDMI_CEC is not set If no special reason, I can make a PR for this. Thank you!
Igor Posted December 13, 2020 Posted December 13, 2020 5 hours ago, test0x01 said: If no special reason, I can make a PR for this. I don't recall but propose that you try at least booting the kernel with this change. Legacy kernels are full of surprises.
