Stroke_papy Posted December 17, 2020 Share Posted December 17, 2020 Hello I have a problem with my Xunlong Orange Pi PC Plus, if I put an SD card with Armbian_20.11.3_Orangepipcplus_buster_current_5.9.14 or focal (format with Etcher) it will boot with the MMC is not with the SD card i have an error Trying to boot from MMC1 ... MMC: mmc@1c0f000: 0, mmc@1c10000: 2, mmc@1c11000: 1 Loading Environment from FAT... *** Warning - bad CRC, using default environment ... mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr ... EHCI failed to shut down host controller. Loading Ramdisk to 4969c000, end 49fff9c3 ... OK Loading Device Tree to 4962b000, end 4969bfff ... OK Starting kernel ... and after nothing happens https://slexy.org/view/s2kxLKb95J if I do a boot without an sd card Trying to boot from MMC2 ... [ OK ] Listening on Journal Socket. Starting Load Kernel Modules... Starting Journal Service... Starting Remount Root and Kernel File Systems... Starting Nameserver information manager... Starting Create list of required st... nodes for the current kernel... Starting Set console keymap... Mounting Debug File System... Mounting POSIX Message Queue File System... [FAILED] Failed to start Load Kernel Modules. See 'systemctl status systemd-modules-load.service' for details. Mounting Configuration File System.. ... [ 10.775055] mmc1: cache flush error -110 [ 10.961936] sunxi-mmc 1c11000.mmc: data error, sending stop command [ 10.968312] sunxi-mmc 1c11000.mmc: send stop command failed [ 10.974505] mmcblk1: error -110 requesting status [ 10.974634] mmc1: cache flush error -110 [ OK ] Found device /dev/ttyS0. [ 11.135772] sunxi-mmc 1c11000.mmc: data error, and after nothing happens https://slexy.org/raw/s21mCSfWbI?token=1872091d8c19f94b154ea4a415782e86b296ee756c8d9a0715264a3ddac4d388&ts=1608196059 what to do Thank you very much 0 Quote Link to comment Share on other sites More sharing options...
TRS-80 Posted December 17, 2020 Share Posted December 17, 2020 6 hours ago, Stroke_papy said: *** Warning - bad CRC, using default environment I read recently (in some thread in Kobol Club as I recall, but could not find it with a quick look just now) that this error is not important (it's just a warning). If that's true, something else is the problem. To me, this is a bigger clue: 6 hours ago, Stroke_papy said: Starting kernel ... and after nothing happens So hardware seems to be fine, kernel is not starting for some reason. 6 hours ago, Stroke_papy said: [FAILED] Failed to start Load Kernel Modules. See 'systemctl status systemd-modules-load.service' for details. This is another clue. Did you look in there? 0 Quote Link to comment Share on other sites More sharing options...
Stroke_papy Posted December 18, 2020 Author Share Posted December 18, 2020 Hello I tried to let the 10 min boot run But nothing happens, the log U-Boot SPL 2020.10-armbian (Dec 12 2020 - 00:49:41 +0100) DRAM: 1024 MiB Trying to boot from MMC1 U-Boot 2020.10-armbian (Dec 12 2020 - 00:49:41 +0100) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi PC Plus DRAM: 1 GiB MMC: mmc @ 1c0f000: 0, mmc @ 1c10000: 2, mmc @ 1c11000: 1 Loading Environment from FAT ... *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: phy interface0 eth0: ethernet @ 1c30000 230 454 bytes read in 15 ms (14.7 MiB / s) starting USB ... Usb bus @ 1c1a000: USB EHCI 1.00 Usb bus @ 1c1a400: USB OHCI 1.0 Usb bus @ 1c1b000: USB EHCI 1.00 Usb bus @ 1c1b400: USB OHCI 1.0 Usb bus @ 1c1c000: USB EHCI 1.00 Usb bus @ 1c1c400: USB OHCI 1.0 Usb bus @ 1c1d000: USB EHCI 1.00 Usb bus @ 1c1d400: USB OHCI 1.0 scanning bus usb @ 1c1a000 for devices ... 1 USB Device (s) found scanning bus usb @ 1c1a400 for devices ... 1 USB Device (s) found scanning bus usb @ 1c1b000 for devices ... 1 USB Device (s) found scanning bus usb @ 1c1b400 for devices ... 1 USB Device (s) found scanning bus usb @ 1c1c000 for devices ... 1 USB Device (s) found scanning bus usb @ 1c1c400 for devices ... 1 USB Device (s) found scanning bus usb @ 1c1d000 for devices ... 1 USB Device (s) found scanning bus usb @ 1c1d400 for devices ... 1 USB Device (s) found scanning usb for storage devices ... 0 Storage Device (s) found Autoboot in 1 seconds, press <Space> to stop switch to partitions # 0, OK mmc0 is current device Scanning mmc 0: 1 ... Found U-Boot script /boot/boot.scr 3967 bytes read in 4 ms (967.8 KiB / s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 153 bytes read in 3 ms (49.8 KiB / s) 11434329 bytes read in 552 ms (19.8 MiB / s) 7808464 bytes read in 375 ms (19.9 MiB / s) Found mainline kernel configuration 32636 bytes read in 10 ms (3.1 MiB / s) 4185 bytes read in 8 ms (510.7 KiB / s) Applying kernel provided DT fixup script (sun8i-h3-fixup.scr) ## Executing script at 45000000 ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 11434265 Bytes = 10.9 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 EHCI failed to shut down host controller. Loading Ramdisk to 49518000, end 49fff919 ... OK Loading Device Tree to 494a7000, end 49517fff ... OK Starting kernel ... without the SD card I tried to I tried to go through the Kernel, I don't have the science for that !!!! Autoboot in 2 seconds, press <Space> to stop => => systemctl Unknown command 'systemctl' - try 'help' what to do Thank you very much 0 Quote Link to comment Share on other sites More sharing options...
TRS-80 Posted December 18, 2020 Share Posted December 18, 2020 2 hours ago, Stroke_papy said: I tried to let the 10 min boot run Yes, if you took no other steps, this is expected. I wasn't saying to let it run longer, I was suggesting that for some reason the kernel is not loading (seems like). 2 hours ago, Stroke_papy said: Autoboot in 2 seconds, press <Space> to stop => => systemctl Unknown command 'systemctl' - try 'help' This is U-Boot environment, not GNU/Linux shell. Type help (like it says) to see what you can do there. Basically, you should need to just tell the kernel to boot. Either manually, or fix the boot settings so that it works every time. You may find something helpful in Recovery section of docs. There are also some additional commands here.[0] [0] It's on my list to add the latter link to the former page at some point. 0 Quote Link to comment Share on other sites More sharing options...
Stroke_papy Posted December 19, 2020 Author Share Posted December 19, 2020 ouch without sd card I get this => mmc list mmc @ 1c0f000: 0 mmc @ 1c10000: 2 mmc @ 1c11000: 1 (eMMC) => mmc dev 1 switch to partitions # 0, OK mmc1 (part 0) is current device => ls mmc 1: 1 / System Volume Information / dtb / 3636584 System.map-pc-plus 230456 boot.bmp 3628 boot.cmd 3700 boot.scr 86 orangepiEnv.txt 5876450 uInitrd 7745856 zImage 7 queue (s), 2 dir (s) => mmc read 0 0x7fffffff 1 MMC read: dev # 1, block # 2147483647, count 1 ... MMC: block number 0x80000000 exceeds max (0xe90000) 0 read blocks: ERROR if i format the eMMC it is a good idea or not mmc erase 0 0x80000000 thank you so much 0 Quote Link to comment Share on other sites More sharing options...
Stroke_papy Posted December 21, 2020 Author Share Posted December 21, 2020 Hello I tried the tutorial https://docs.armbian.com/User-Guide_Recovery/ I tried that with the port Debug TTL UART => setenv bootargs init = / bin / bash root = / dev / mmcblk0p1 rootwait console = ttyS0,115200 => ext4load mmc 0 0x49000000 / boot / dtb / $ {fdtfile} ** Unrecognized filesystem type ** I tried that but it's not good too => mmc list mmc @ 1c0f000: 0 (SD) mmc @ 1c10000: 2 mmc @ 1c11000: 1 (eMMC) => mmc dev 0 switch to partitions # 0, OK mmc0 is current device => ls mmc 0 / 7745856 zImage 5876450 uInitrd 86 orangepiEnv.txt 230456 boot.bmp 3628 boot.cmd 3700 boot.scr 3636584 System.map-pc-plus dtb / System Volume Information / 7 queue (s), 2 dir (s) => ls mmc 0 / dtb / ./ ../ 30557 sun8i-h3-orangepi-pc-sapomat.dtb 28814 sun8i-h2-plus-orangepi-zero.dtb 28916 sun8i-h3-orangepi-2.dtb 30376 sun8i-h3-orangepi-lite.dtb 30046 sun8i-h3-orangepi-one.dtb 30628 sun8i-h3-orangepi-pc-plus.dtb 29462 sun8i-h3-orangepi-zero-plus2.dtb 30098 sun8i-h3-orangepi-pc.dtb 29751 sun8i-h3-orangepi-plus.dtb 31103 sun8i-h3-orangepi-plus2e.dtb 10 queue (s), 2 dir (s) => ext4load mmc 0 0x49000000 /boot/dtb/sun8i-h3-orangepi-pc-plus.dtb ** Unrecognized filesystem type ** I think I'm making a mess that isn't good but where ?? Thank you so much 0 Quote Link to comment Share on other sites More sharing options...
