My NAS do very little overnight so my NAS4 shuts down in the evening and shortly afterwards a physical time switch cuts the power - reinstating power in the morning at which time the NAS4 automatically reboots.
I want to do the same with the NAS64 - but even though I've read this (https://wiki.kobol.io/helios64/auto_poweron/) I'm not sure how to go about it.
I can't understand if it only works if the UPS has died, or if I have to run a script before shutdown or both.
Could you please clarify?
Thx ... Nick
OK Thanks ebin-dev
For others who are as dumb as me you need to edit  "/lib/systemd/system-shutdown/disable_auto_poweron"
and change line ...
"echo 0 > /sys/class/gpio/gpio153/value"
to
"echo 1 > /sys/class/gpio/gpio153/value"
and it works!!!
Hi gprovost,
Yes I happened to find RTC in the doc yesterday!
I'm still using auto power on in case of power failure.
But, as you kindly suggest, I'm now using RTC - 2 tasks in OpenMediaVault5 job scheduling...
1/  sudo rtcwake -m disable                                                           (each reboot to reset any outstanding wake timers)
2/  sudo rtcwake -m off --date '+ 6 hour 15 minutes 0 seconds'    (each morning at 01:00 to shutdown and set wake timer for 07:15)
It worked fine this morning!
