nand-sata-install "This tool must run from SD-card!"
I built and successfully installed Armbian with Cryptroot SSH unlock. Now I wanted to have everything on SATA SSD, but when I run nand-sata-install I get the following message:
How could I have everything on my SATA SSD?
I assume nand-sata-install tool is not compatible with cryptroot. It is to mention that cryptroot is a community contribution and did not come from Armbian itself.
So probably some tinkering with the script will be necessary.
I contacted the author of this nice blog post:
https://maxammann.org/posts/2020/01/armbian-encrypt-root/
They suggested to remove from "case" to "esac" here:
https://github.com/armbian/build/blob/master/packages/bsp/common/usr/sbin/nand-sata-install#L616
I did it and run the edited nand-sata-install.
That looked like it was going to work ok, as it let me run the script without any problem. I chose to use EMMC and SATA SSD. It started to show the progressing bar, and it finished as it everything was fine. However, it did not work. It did not move things to EMMC or SATA.
Any suggestion would be very much welcome...
Choosing to have the boot partition on the microSD card and the root partition on the USB/SATA drive does work ok.
