Guest Posted December 27, 2020 Share Posted December 27, 2020 Armbianmonitor: http://ix.io/2K1p Hi, I've got since several days an issue with armbian-truncate-logs. I received mail alerts from cron as this one, error: error running shared postrotate script for '/var/log.hdd/mysql/mysql.log /var/log.hdd/mysql/mysql-slow.log +/var/log.hdd/mysql/mariadb-slow.log /var/log.hdd/mysql/error.log ' error: error running shared postrotate script for '/var/log.hdd/nginx/*.log ' How to debug that? Laurent 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted December 27, 2020 Share Posted December 27, 2020 Check the definition of the postrotate command. Start your research here: /etc/logrotate.d/ 0 Quote Link to comment Share on other sites More sharing options...
Guest Posted December 28, 2020 Share Posted December 28, 2020 In /etc/logrotate.d/mysql-server I've got a mysql-server script: /var/log.hdd/mysql/mysql.log /var/log.hdd/mysql/mysql-slow.log /var/log.hdd/mysql/mariadb-slow.log /var/log.hdd/mysql/error.log { daily rotate 7 missingok create 640 mysql adm compress sharedscripts postrotate test -x /usr/bin/mysqladmin || exit 0 if [ -f `my_print_defaults --mysqld | grep -m 1 -oP "pid-file=\K.+$"` ]; then # If this fails, check debian.conf! mysqladmin --defaults-file=/etc/mysql/debian.cnf --local flush-error-log \ flush-engine-log flush-general-log flush-slow-log fi endscript } I don't know where to start... Thank you for help. 0 Quote Link to comment Share on other sites More sharing options...
Solution Guest Posted January 1, 2021 Solution Share Posted January 1, 2021 Solved by updating /usr/lib/armbian/armbian-ramlog file and creating /etc/systemd/system/logrotate.service file according to https://github.com/armbian/build/issues/1582. 0 Quote Link to comment Share on other sites More sharing options...
