andrewufrank Posted August 6, 2015 Posted August 6, 2015 i have just downloaded the new version (dated 5-8) for jessie 4.1.4 for the cubietruck. it runs till it gets the greetings screen but then hangs and says: time timed out waiting for device dev-ttyS).device. depend dependency failed for serial getty on ttySO. -- i had a hdmi monitor, but then connectted a vga monitor (both show the initial informations) - the same result. what did i wrong? andrew ps. thank you for adding the upgrade using ppa!
Igor Posted August 6, 2015 Posted August 6, 2015 Cut the power (not reset or power button) and try again. This problems sometimes shows up .. suggested solution is implemented but I guess it's not bullet proof. Thanks! P.S. Moving thread
andrewufrank Posted August 6, 2015 Author Posted August 6, 2015 sorry if this is a duplication. i just started a new topic regarding the new version (dated 5-8). and cannot find it to add information: i installed jessie_4_1 and jessie 4_0 both with 4.1.2 and 4.1.4 and it hangs with the (known) error: time timed out missing for device dev-ttyS0.device dependency failed foer serial getty on ttSO. i have two cubietrucks: on one (the newer one) 4.1 it installs, on the older one it does not. probably a difference in hardware (the old cubietruck ran a wheezy 3.4.75 kernel, from you) and i wanted to upgrade. fortunately the jessie_3.4.108 download does not show this problem and installs. i hope this additional information helps to pin down the problem and perhaps you find a solution! thank you! andrew
Igor Posted August 6, 2015 Posted August 6, 2015 I have one of the first Cubietrucks and it works but sometimes I also get this error but only on Jessie.
edil10 Posted August 6, 2015 Posted August 6, 2015 I getting the same with wheezy. It shows ## Executing script at 43100000 0 bytes read in 290 ms (o Bytes/s) 26583 bytes read in 518 ms (49.8 KiB/s) ** ext4fs_devread read error - block Kernel image @ 0x46000000 [ 0x000000 - 0x519668 ] ## Flattened Device Tree blog at 49000000 Booting using the fdt blog at 0x49000000 Ising Device Tree in place at 49000000, end 490097d6 Starting kernel ...
andrewufrank Posted August 6, 2015 Author Posted August 6, 2015 i have exactly the same ** ex4fs_devread read eror blocl i have solved he issue with jessie 3.4.108 can i use the upgrade with the ppa from there to 4.xx ? thanks for the help! andrew
Igor Posted August 6, 2015 Posted August 6, 2015 @edil10 This looks like some file system / bad (written) SD card error? Does it boot. How long have you waited? No output (to serial) is normal by default with mainline kernel. @andrewufrank can i use the upgrade with the ppa from there to 4.xx ? Not yet. Manual only ... check FAQ.
