Janek Posted January 11, 2021 Share Posted January 11, 2021 Hello Guys, I would like to have question maybe unwise but it's hard to find information about it. I would like to prevent somehow my Helios64 or it's power supply to minimize risk of fire. Do you have any propositions to minimize that risk? Thank you for your help in advance 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted January 11, 2021 Share Posted January 11, 2021 You cannot. Happens very rarely but sometimes electronics in general can end up in magic smoke or even worse. Best you can do is to look ahead and think about what would happen IF. Are flammable objects close by? Does the device lie on a wooden table? Are other devices close by that radiate heat and cause the concerned devices to heat up additionally? How is your local public power supply? Do voltage spikes occur often? If so think about installing devices in the building connection that prevents such spikes from hitting your stuff. Kind a lightning conductor but way more sensitive against voltage above rated. Quote but it's hard to find information about it. Try to look for more general information about fire hazard prevention. Maybe ask your local firefighter station. 1 Quote Link to comment Share on other sites More sharing options...
gprovost Posted January 12, 2021 Share Posted January 12, 2021 You can also check all the certification and conformity document for the PSU we provide with Helios64 : https://wiki.kobol.io/helios64/docs/#psu We have designed Helios64 with safety and protection in mind... no shortcut. 1 Quote Link to comment Share on other sites More sharing options...
Atticka Posted January 15, 2021 Share Posted January 15, 2021 In general any electronic device should be plugged in to a proper electrical outlet with a circuit breaker. The circuit breaker is critical in cutting the current in case of a short, therefore preventing a fire. 1 Quote Link to comment Share on other sites More sharing options...
