xkcd Posted January 22, 2021 Posted January 22, 2021 Hi I'm trying to get the SPI ports to work in a RockPi 4B board. I've done the following: Installed the Armbian_20.11.6_Rockpi-4b_focal_legacy_4.4.213.img.xz image Edited armbianEnv.txt overlays=spi-spidev param_spidev_spi_bus=0 There is a entry at: /sys/class/spidev/spidev0.0, but nothing at /dev/spidev/ Next, I built libmraa, which fails to run any examples with SPI, as it can initialize any SPI devices. What am I missing, Hope you can help me
martinayotte Posted January 22, 2021 Posted January 22, 2021 On 1/22/2021 at 11:56 AM, xkcd said: but nothing at /dev/spidev/ Expand It won't appear as subfolder, but as direct node /dev/spidev0.0 ... Also, check with "dmesg | grep spi" ...
xkcd Posted January 25, 2021 Author Posted January 25, 2021 (edited) On 1/22/2021 at 4:06 PM, martinayotte said: It won't appear as subfolder, but as direct node /dev/spidev0.0 ... Also, check with "dmesg | grep spi" ... Expand Hi, thanks for the swift answer, wasn't expecting that. There are no nodes named /dev/spidev0.0 (or similar). I get the following from dmesg|grep spi (slightly cropped) [...] rockchip-spi ff1c0000.spi: no high_speed pinctrl state [...] ffffffc0f7f737f8: buggy DT: spidev listed directly in DT [...] WARNING: at drivers/spi/spidev.c:722 /skipping some lines/ [...] rockchip-pinctrl pinctrl: pin gpio3-7 already requested by ff1c0000.spi; cannot claim for fe30000.ethernet I should say that the device is only connected to wifi and not ethernet. Hope you can push in the right direction. Edited January 25, 2021 by xkcd Add info on /dev/spidev0.0
piter75 Posted January 25, 2021 Posted January 25, 2021 On 1/22/2021 at 11:56 AM, xkcd said: param_spidev_spi_bus=0 Expand Are you sure you are actually using SPI 0? It's not routed out to GPIO pins and its pins are indeed used by ethernet interface. Shouldn't you set bus 2 or 1 according to which GPIO pins you decided to use?
xkcd Posted January 26, 2021 Author Posted January 26, 2021 On 1/25/2021 at 9:02 AM, piter75 said: Are you sure you are actually using SPI 0? It's not routed out to GPIO pins and its pins are indeed used by ethernet interface. Shouldn't you set bus 2 or 1 according to which GPIO pins you decided to use? Expand I'm not sure of anything. That's is why I asked here. I can't understand what I'm doing wrong or are supposed to do. I tried to use SPI bus 1 as suggested here: but that leads to a kernel panic when I reboot (how does one get out of these, without writing a new image).
denni_isl Posted January 27, 2021 Posted January 27, 2021 Pin 19, 21, 23, 24 are laid out directly to the pins of SPI device on board. spi bus 1 (Function1), although I have never tried this.
xkcd Posted January 29, 2021 Author Posted January 29, 2021 Thanks for the reply. I'm not even at a state where can get one single SPI device to work. Either nothing shows up under /dev or kernel panic. Is there some other image that is better to use?
