jhofman Posted January 22, 2021 Posted January 22, 2021 Armbianmonitor: http://ix.io/2MUh Hello, I try to communicate via SPI, if i try receive data over SPI on MISO pin I got message without last bit so I should receive 0x23 and i got 0x22. SPI is set on MODE 3. It has same behaviour on PI PC and PC2. If i try on RPi it works fine. Do you have anybody some advice ? Regards Jan
Werner Posted January 22, 2021 Posted January 22, 2021 Information for you and somebody who might be able to help you. The system packages are outdated. ii armbian-config 20.05.2 all Armbian configuration utility ii armbian-firmware 20.05.2 all Linux firmware ii armbian-focal-desktop 20.11.1 all Armbian desktop for Ubuntu focal ii hostapd 3:2.9-102~armbian20.05.2+1 armhf IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator ii htop 2.2.0-3~armbian19.11.9+1 armhf interactive processes viewer ii linux-base 4.5ubuntu3 all Linux image base package ii linux-dtb-current-sunxi 20.05.2 armhf Linux DTB, version 5.4.43-sunxi ii linux-focal-root-current-orangepipc 20.05.2 armhf Armbian tweaks for focal on orangepipc (current branch) ii linux-image-current-sunxi 20.05.2 armhf Linux kernel, version 5.4.43-sunxi ii linux-libc-dev:armhf 5.4.0-33.37 armhf Linux Kernel Headers for development ii linux-u-boot-orangepipc-current 20.05.2 armhf Uboot loader 2020.04
jhofman Posted January 23, 2021 Author Posted January 23, 2021 I ofc try it on the newest armbian, no change. I check on logical analyzator and on osciloscope, edges and values were right. Is it possible, that SPI decode bad on mode 3? I am using spi dev on ioctl, decrease the speed doesnt help. Regards Jan
