otlabs Posted January 29, 2021 Posted January 29, 2021 Armbianmonitor: http://ix.io/2NBN I am building kernel 5.10.4 sources on NanoPi Neo 2 with Armbian 20.11.10 Focal and get following error: nanopineo2:~:% cd /usr/src/linux-headers-5.10.4-sunxi64 nanopineo2:linux-headers-5.10.4-sunxi64:% sudo make headers_check nanopineo2:linux-headers-5.10.4-sunxi64:% sudo make scripts nanopineo2:linux-headers-5.10.4-sunxi64:% sudo make prepare scripts/Makefile.build:414: warning: overriding recipe for target 'modules.order' Makefile:1407: warning: ignoring old recipe for target 'modules.order' make[1]: *** No rule to make target 'arch/arm64/kernel/vdso/vdso.lds', needed by 'arch/arm64/kernel/vdso/vdso.so.dbg'. Stop. make: *** [arch/arm64/Makefile:182: vdso_prepare] Error 2 Do I miss something? Could someone confirm the error I see?
Igor Posted January 29, 2021 Posted January 29, 2021 7 hours ago, otlabs said: Do I miss something? Could someone confirm the error I see? https://armbian.atlassian.net/browse/AR-608 https://github.com/armbian/build/pull/2545
Scritch Posted March 23, 2021 Posted March 23, 2021 Hello Otlabs, Can you confirm that this problem is resolved for you? I run into the same compile issue, even with the latest armbian version and the mentioned fix available on the sys tem.
otlabs Posted March 28, 2021 Author Posted March 28, 2021 On 3/23/2021 at 2:21 PM, Scritch said: Hello Otlabs, Can you confirm that this problem is resolved for you? I run into the same compile issue, even with the latest armbian version and the mentioned fix available on the sys tem. Hi Scritch, Just tested on same setup you mention (Armbian 21.02.3, kernel 5.10.21). Need to confirm I do still have the issue on NanoPi Neo 2 board, it looks mostly the same: scripts/Makefile.build:414: warning: overriding recipe for target 'modules.order' Makefile:1403: warning: ignoring old recipe for target 'modules.order' make[1]: *** No rule to make target 'arch/arm64/kernel/vdso/vdso.lds', needed by 'arch/arm64/kernel/vdso/vdso.so.dbg'. Stop. make: *** [arch/arm64/Makefile:186: vdso_prepare] Error 2
Scritch Posted March 31, 2021 Posted March 31, 2021 The problem is still the same, also for nightly builds. I used the following package: https://beta.armbian.com/pool/main/l/linux-5.11.11-meson64/linux-headers-edge-meson64_21.05.0-trunk.68_arm64.deb scritch@odroidc2:/usr/src/linux-headers-5.11.11-meson64$ sudo make KERNELVERSION=5.11.11-meson64 -j3 modules_prepare scripts/Makefile.build:414: warning: overriding recipe for target 'modules.order' Makefile:1409: warning: ignoring old recipe for target 'modules.order' make[1]: *** No rule to make target 'arch/arm64/kernel/vdso/vdso.lds', needed by 'arch/arm64/kernel/vdso/vdso.so.dbg'. Stop. make: *** [arch/arm64/Makefile:191: vdso_prepare] Error 2
dmjang Posted December 22, 2021 Posted December 22, 2021 mic@radxa-zero:/usr/src/linux-headers-5.10.81-meson64$ sudo make UPD include/config/kernel.release UPD include/generated/utsrelease.h CC scripts/mod/empty.o HOSTCC scripts/mod/mk_elfconfig MKELF scripts/mod/elfconfig.h HOSTCC scripts/mod/modpost.o CC scripts/mod/devicetable-offsets.s HOSTCC scripts/mod/file2alias.o HOSTCC scripts/mod/sumversion.o HOSTLD scripts/mod/modpost scripts/Makefile.build:415: warning: overriding recipe for target 'modules.order' Makefile:1422: warning: ignoring old recipe for target 'modules.order' make[1]: *** No rule to make target 'arch/arm64/kernel/vdso/vdso.lds', needed by 'arch/arm64/kernel/vdso/vdso.so.dbg'. Stop. make: *** [arch/arm64/Makefile:186: vdso_prepare] Error 2
bulanov Posted January 27, 2022 Posted January 27, 2022 I have the same problem using rockchip64 kernel. Any suggestions?
