keitomi Posted February 1, 2021 Posted February 1, 2021 Hi~ After "sudo poweroff" , my OPI4 does not boot anymore.(p.s. when i use "sudo reboot" ,it works.) I had looked over some topics,but i still get how to fix uboot . Can someone help me?Thanks!!!!! p.s I try to use "armbian-config"/"install" to fix the problem,but there was no "boot from sd"
Werner Posted February 1, 2021 Posted February 1, 2021 Your issue report is invalid for one or multiple reasons (non-exhaustive enumeration): it has been stated at the wrong place it lacks fundamental requested data it could have been easily solved by a quick search and/or reading documentation Since you refused to use the bug reporting form carefully and follow the information there as you have been asked for we have no intention to further investigate. https://www.armbian.com/bugs
