Odroid C2 does not boot from orange 64GB eMMC module
Armbianmonitor:
I recently bought a 64 GB eMMC module (chip on orange board) from Ordoid/Hardkernel but u-boot does not recognize the eMMC.
What I did:
  • installed the official Armbian_20.11.10_Odroidc2_focal_current_5.9.14.img.xz with Etcher on SD card
  • booted successfully from SD card, eMMC is accessible from within Armbian/Ubuntu
  • executed nand-sata-install to transfer the system to eMMC, which completed without error messages
  • shutdown the system, removed SDcard and restarted it
The serial console displayed the following:
U-Boot 2020.10-armbian (Jan 05 2021 - 01:40:47 +0100) odroid-c2
Model: Hardkernel ODROID-C2
SoC:   Amlogic Meson GXBB (S905) Revision 1f:c (0:1)
DRAM:  2 GiB
MMC:   mmc@72000: 0, mmc@74000: 1
In:    serial
Out:   serial
Err:   serial
Net:   eth0: ethernet@c9410000
Card did not respond to voltage select!
MMC Device 2 not found
no mmc device at slot 2
starting USB...
Bus usb@c9100000: USB DWC2
scanning bus usb@c9100000 for devices... 2 USB Device(s) found
and then tried to boot via network.
I then flashed the eMMC with the official Odroid image ubuntu-20.04-3.16-minimal-odroid-c2-20200617.img.xz and the system booted up successfully, so the eMMC module is working fine.
Next step was to try the nightly build (Armbian_21.02.0-trunk.80_Odroidc2_focal_current_5.10.10_gnome_desktop.img.xz, with Etcher flashed on SD, then nand-sata-install) and again the eMMC as not visible in u-boot so the system did not come up.
Therefore I set up an Armbian build environment and first tried to use this promising patch for u-boot https://gitlab.denx.de/u-boot/custodians/u-boot-amlogic/-/commit/5ccd5d2cc98224108ae9fb09593a862c9caa5e80 but it seemed not to be suficient.
I then replaced the provided u-boot v2020.10 with the new v2021.01 version and after replacing the kernel and uboot packages with the self compiled ones the eMMC was recognised by u-boot and the system boots from the orange 64GB eMMC module.
U-Boot 2021.01-armbian (Feb 01 2021 - 11:57:23 +0100) odroid-c2
DRAM:  2 GiB
In:    serial
Out:   serial
Err:   serial
Card did not respond to voltage select! : -110
switch to partitions #0, OK
mmc1(part 0) is current device
Scanning mmc 1:1...
7136 bytes read in 1 ms (6.8 MiB/s)
## Executing script at 08000000
161 bytes read in 1 ms (157.2 KiB/s)
15703885 bytes read in 342 ms (43.8 MiB/s)
25461248 bytes read in 556 ms (43.7 MiB/s)
38868 bytes read in 2 ms (18.5 MiB/s)
232 bytes read in 1 ms (226.6 KiB/s)
Applying kernel provided DT fixup script (meson-fixup.scr)
The "Card did not respond to voltage select" message is from the missing SD card
Therefore I kindly ask to upgrade the u-boot of Odroid C2 to version 2021.01 in the next release.
