trying to start my Banana Pi Pro Board with the latest Armbian buster image (Armbian_21.02.1_Bananapipro_buster_current_5.10.12.img.xz) without success.
There is initial output on the screen until there is the message "Starting kernel ...", the after a few seconds the monitor loses its signal and nothing seems to happen any more
see: https://c.1und1.de/@520257322610590089/1IBkHiwHQX6jYxLPdlkTZQ
Reading through the forum I guessed it could have to do with an issue of automatic discovery of the correct DTB, so I edited the armbianEnv.txt file and added the following line to it:
fdtfile=sun7i-a20-bananapro.dtb
But still the same behavior.
I then tested another image from the archive (Armbian_20.08.1_Bananapipro_bionic_current_5.8.5.img.xz). The board comes up fine.
SD Card ist brand new SanDisk 32GB Class 10 A1
What should I be looking at next ?
Thx. in advance
Your issue report is invalid for one or multiple reasons (non-exhaustive enumeration):
  • it has been stated at the wrong place
  • it lacks fundamental requested data
  • it could have been easily solved by a quick search and/or reading documentation
Since you refused to use the bug reporting form carefully and follow the information there as you have been asked for we have no intention to further investigate.
https://www.armbian.com/bugs
