ebalcsk Posted February 10, 2021 Posted February 10, 2021 Hello, I try to communicate on UART3 (pin 11/13) just TTL, but cannot see any data on the lines. After first attempt i added overlays=uart3 to /boot/armbianEnv.txt and rebooted the system. oot@orangepioneplus:~# cat /boot/armbianEnv.txt verbosity=1 bootlogo=false console=both disp_mode=1920x1080p60 overlay_prefix=sun50i-h6 rootdev=UUID=d7bd3629-b17f-4c85-9031-909157a0ce7e rootfstype=ext4 overlays=uart3 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u Then i also executed update-initramfs -u and rebooted the board. None of these are helped I wonder what i am doing wrong? I see the following in the logs: root@orangepioneplus:~# dmesg | egrep --color 'serial|ttyS' [ 1.944312] printk: console [ttyS0] disabled [ 1.944394] 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 31, base_baud = 1500000) is a 16550A [ 1.944599] printk: console [ttyS0] enabled [ 1.945269] sun50i-h6-pinctrl 300b000.pinctrl: pin-119 (5000c00.serial) status -517 [ 1.945284] dw-apb-uart 5000c00.serial: Error applying setting, reverse things back [ 1.971491] sun50i-h6-pinctrl 300b000.pinctrl: pin-119 (5000c00.serial) status -517 [ 1.971505] dw-apb-uart 5000c00.serial: Error applying setting, reverse things back [ 1.973846] sun50i-h6-pinctrl 300b000.pinctrl: pin-119 (5000c00.serial) status -517 [ 1.973860] dw-apb-uart 5000c00.serial: Error applying setting, reverse things back [ 1.975764] sun50i-h6-pinctrl 300b000.pinctrl: pin-119 (5000c00.serial) status -517 [ 1.975778] dw-apb-uart 5000c00.serial: Error applying setting, reverse things back [ 2.376127] sun50i-h6-pinctrl 300b000.pinctrl: pin-119 (5000c00.serial) status -517 [ 2.376141] dw-apb-uart 5000c00.serial: Error applying setting, reverse things back [ 2.401927] 5000c00.serial: ttyS3 at MMIO 0x5000c00 (irq = 32, base_baud = 1500000) is a 16550A [ 5.035583] systemd[1]: Created slice system-serial\x2dgetty.slice. I think it is looks okey. Also i can connect to UART0. During testing i used the same setting on minicom as UART0 +-----------------------------------------------------------------------+ | A - Serial Device : /dev/ttyS3 | | B - Lockfile Location : /var/lock | | C - Callin Program : | | D - Callout Program : | | E - Bps/Par/Bits : 9600 8N1 | | F - Hardware Flow Control : No | | G - Software Flow Control : No | | | | Change which setting? | +-----------------------------------------------------------------------+ Also just done a same test with a USB-serial adapter which is worked so i can rule out at least problem with my testing mythology. Thank you!
martinayotte Posted February 10, 2021 Posted February 10, 2021 On 2/10/2021 at 8:58 PM, ebalcsk said: I try to communicate on UART3 Expand Can you check DT if pinctrl-0 is present in UART3 node ? You can verify using this : ll /proc/device-tree/soc/serial@5000c00 (In my old 5.9 build, I see that they are missing and only UART0 has its pinctl-0 handle.) If missing, you can decompile DTB into DTS, edit DTS to add "pinctrl-0 = <phandle>;" where phandle can be found in "uart3-pins" node ...
ebalcsk Posted February 10, 2021 Author Posted February 10, 2021 it looks like exist: root@orangepioneplus:~# ll /proc/device-tree/soc/serial@5000c00 total 0 -r--r--r-- 1 root root 8 Feb 10 21:50 clocks -r--r--r-- 1 root root 17 Feb 10 21:50 compatible -r--r--r-- 1 root root 12 Feb 10 21:50 interrupts -r--r--r-- 1 root root 7 Feb 10 21:50 name -r--r--r-- 1 root root 4 Feb 10 21:50 phandle -r--r--r-- 1 root root 4 Feb 10 21:50 pinctrl-0 -r--r--r-- 1 root root 8 Feb 10 21:50 pinctrl-names -r--r--r-- 1 root root 8 Feb 10 21:50 reg -r--r--r-- 1 root root 4 Feb 10 21:50 reg-io-width -r--r--r-- 1 root root 4 Feb 10 21:50 reg-shift -r--r--r-- 1 root root 8 Feb 10 21:50 resets -r--r--r-- 1 root root 5 Feb 10 21:50 status root@orangepioneplus:~#
martinayotte Posted February 10, 2021 Posted February 10, 2021 On 2/10/2021 at 9:55 PM, ebalcsk said: it looks like exist: Expand which kernel version ? (because it seems that it still missing in 5.10 of @megous branch)
ebalcsk Posted February 10, 2021 Author Posted February 10, 2021 root@orangepioneplus:~# uname -r 5.10.12-sunxi64
martinayotte Posted February 10, 2021 Posted February 10, 2021 On 2/10/2021 at 10:01 PM, ebalcsk said: 5.10.12-sunxi64 Expand Could you check DTS directly by decompiling DTB ? dtc -@ -I dtb -O dts -o /root/sun50i-h6-orangepi-one-plus.dts-5.10.12 /boot/dtb/allwinner/sun50i-h6-orangepi-one-plus.dtb
ebalcsk Posted February 11, 2021 Author Posted February 11, 2021 root@orangepioneplus:~# dtc -@ -I dtb -O dts -o /root/sun50i-h6-orangepi-one-plus.dts-5.10.12 /boot/dtb/allwinner/sun50i-h6-orangepi-one-plus.dtb /root/sun50i-h6-orangepi-one-plus.dts-5.10.12: Warning (unit_address_vs_reg): /cpu-opp-table/opp@480000000: node has a unit name, but no reg property /root/sun50i-h6-orangepi-one-plus.dts-5.10.12: Warning (unit_address_vs_reg): /cpu-opp-table/opp@720000000: node has a unit name, but no reg property /root/sun50i-h6-orangepi-one-plus.dts-5.10.12: Warning (unit_address_vs_reg): /cpu-opp-table/opp@816000000: node has a unit name, but no reg property /root/sun50i-h6-orangepi-one-plus.dts-5.10.12: Warning (unit_address_vs_reg): /cpu-opp-table/opp@888000000: node has a unit name, but no reg property /root/sun50i-h6-orangepi-one-plus.dts-5.10.12: Warning (unit_address_vs_reg): /cpu-opp-table/opp@1080000000: node has a unit name, but no reg property /root/sun50i-h6-orangepi-one-plus.dts-5.10.12: Warning (unit_address_vs_reg): /cpu-opp-table/opp@1320000000: node has a unit name, but no reg property /root/sun50i-h6-orangepi-one-plus.dts-5.10.12: Warning (unit_address_vs_reg): /cpu-opp-table/opp@1488000000: node has a unit name, but no reg property /root/sun50i-h6-orangepi-one-plus.dts-5.10.12: Warning (unit_address_vs_reg): /cpu-opp-table/opp@1608000000: node has a unit name, but no reg property /root/sun50i-h6-orangepi-one-plus.dts-5.10.12: Warning (unit_address_vs_reg): /cpu-opp-table/opp@1704000000: node has a unit name, but no reg property /root/sun50i-h6-orangepi-one-plus.dts-5.10.12: Warning (unit_address_vs_reg): /cpu-opp-table/opp@1800000000: node has a unit name, but no reg property /root/sun50i-h6-orangepi-one-plus.dts-5.10.12: Warning (graph_child_address): /soc/tcon-top@6510000/ports/port@0: graph node has single child node 'endpoint@0', #address-cells/#size-cells are not necessary /root/sun50i-h6-orangepi-one-plus.dts-5.10.12: Warning (graph_child_address): /soc/tcon-top@6510000/ports/port@4: graph node has single child node 'endpoint@0', #address-cells/#size-cells are not necessary root@orangepioneplus:~# sun50i-h6-orangepi-one-plus.dts-5.10.12Fetching info...
ebalcsk Posted February 11, 2021 Author Posted February 11, 2021 Hello Sorry it was my fault The IO PIN layout 180' was rotated. Used a wrong PIN. Thank you for your help
martinayotte Posted February 11, 2021 Posted February 11, 2021 On 2/11/2021 at 10:35 AM, ebalcsk said: Sorry it was my fault Expand Do you mean that UART3 is working fine ?
