[Invalid] - Can't delete a wrong ttyUSB device
Go to solution Solved by wollik,
  • Solution
Armbianmonitor:
Hi Linux Admins,
I have a wrong device in the /dev direcrory and can't delete it.
Here is what I get when I do a: ls -la /dev/ttyUSB*
pi@armbian_test: ls -la /dev/ttyUSB*
crw-rw---- 1 root dialout 188, 0 Feb 15 20:47 /dev/ttyUSB0
-rw-r--r-- 1 root root         1 Feb 15 20:48 /dev/ttyUSB1
You see that the device ttyUSB1 is not character device and has no major device number assigned.
Also the device belongs not to the dialout group.
The causing USB_2_Serial Stick is disconnected and the device entry is still there.
Trying to remove this devis is also not working.
pi@armbian_test: sudo rm /dev/ttyUSB1
pi@armbian_test:
Pleas can somone help me to fix this wrong device ?
Regards
wollik
Your issue report is invalid for one or multiple reasons (non-exhaustive enumeration):
  • it has been stated at the wrong place
  • it lacks fundamental requested data
  • it could have been easily solved by a quick search and/or reading documentation
  • unsupported userspace/image/SBC
Since you refused to use the bug reporting form carefully and follow the information there as you have been asked for we have no intention to further investigate.
Please add missing information if applicable.
https://www.armbian.com/bugs
Hi Werner,
I don't know what is missing so I put some additional informations.
I'm using a A20 SBC so I put it here, please can you move it to the right forum section ?
I don't think this is a bug, I just want help how I can get rid of this wrong device.
Regards
wollik
Hi All,
this was caused by a hardware problem during the detection of the second USB-device.
The system tried to create the node, but becaus of the hw failure it created a regular file. If someone tried to delete this file, the system recreated this wrong regular file again, what can be seen on the new I-Nodenumber. This situation persists even after a reboot without the failing USB-Stick!
Here is my solution how I fixed this:
I rebooted without any USB-device, and then reconnected each USB-2-Serial stick again each after the other.
Regards
wollik
