NanoPi M4v2 - Monitor turns off (no signal text) at startup booting after Starting kernel ... text
I have an FriendlyElec M4v2 board without eMMC card. (so i only use SD card)
I tried this image: Armbian_21.02.1_Nanopim4v2_focal_current_5.10.12_desktop.img
I Wrote to SD with Balena Etcher.
After the new installation I turning on my board, I see my two attached .jpg file contents on the screen and after my screen flashes and
immediately turns off my monitor (with no signal text on the screen) and if then I can only see Armbian again if I turn my monitor off and after on.
So the Armbian is booting in the background, just need an HDMI channel refresh with a monitor physical off and after on.
Then I installed all updates ('apt update' after 'apt upgrade') but it didn't help anything,,,
,,, in fact, it got worse because the system became unstable.
The OS screen did not return to the monitor four times.
I tried 6 times turns off the monitor and turn back on.
I tried with Buster image,,, same problem.
I tried the FriendElec images (FriendlyDesktop and Android10), all work well (so no hardware problem), only the two Armbian images do not (Focal and Buster).
Please write me how I can solve it so that after I turn on my board the next image should be on the Armbian login screen without monitor turn off-on.
I made a short video, maybe it can help: ' Before updates, Newly installed system, second power on.avi '
https://www.dropbox.com/s/8m72sm1a2t5guk5/Before updates%2C Newly installed system%2C second power on.avi?dl=1
Before%20updates,%20Newly%20installed%20After%20ALL%20updates,%20Newly%20install
Edited by greglly
Known issue with hdmi enabled in u-boot and rk3399.
NanoPi M4V2 is long known to be unstable in current and dev branches - you can search the forum.
Fortunately there is hope ;-) Try the image referred in the following message and report your results.
It contains both stability fix and the "lying around patch" to disable hdmi in u-boot.
Dear piter75
I’m not a beginner, but I’m not even at a completely advanced level.
I don’t see crystal clear with the help links you sent above.
Please write here more simply in a few steps how to solve my problem.
I’ll do everything, just the links above are too complicated because you don’t know exactly where to find the file to repair.
Thank you very much for your work and help !
