I am using OV5640 in Nano PI duo 2
kernal:
Linux nanopiduo2 5.10.16-sunxi #21.02.2 SMP Sun Feb 14 21:12:17 CET 2021 armv7l armv7l armv7l GNU/Linux
I found that NanoPi Duo2 - FriendlyARM WiKi which is kernal 4.14 supports camera OV5640.
Do  Armbian Focal (mainline based kernel 5.10.y) have support?
if not Please say how to do it? I am new to this armbian kernal
Thanks in advance
Do we have support for OV5640 in NanoPIduo2?
root@nanopiduo2:~# media-ctl --print-topology
Media controller API version 5.10.16
Media device information
driver          cedrus
model           cedrus
serial
bus info        platform:cedrus
hw revision     0x0
driver version  5.10.16
Device topology
- entity 1: cedrus-source (1 pad, 1 link)
            type Node subtype V4L flags 0
            device node name /dev/video0
        pad0: Source
                -> "cedrus-proc":0 [ENABLED,IMMUTABLE]
- entity 3: cedrus-proc (2 pads, 2 links)
            type Node subtype Unknown flags 0
        pad0: Sink
                <- "cedrus-source":0 [ENABLED,IMMUTABLE]
        pad1: Source
                -> "cedrus-sink":0 [ENABLED,IMMUTABLE]
- entity 6: cedrus-sink (1 pad, 1 link)
        pad0: Sink
                <- "cedrus-proc":1 [ENABLED,IMMUTABLE]
Edited by srinath
quick check
You can follow this thread and add the ov5640 overlay, use the ov5640 params from FE dts node.
How can I enable OV5640 driver in order to have ov5640.ko driver to be loaded
Thanks and regards
Scizors
Make sure you have at least these kernel configs enabled:
CONFIG_I2C_GPIO=m
CONFIG_V4L_PLATFORM_DRIVERS=y
CONFIG_VIDEO_SUN6I_CSI=m
CONFIG_V4L_MEM2MEM_DRIVERS=y
CONFIG_VIDEO_MEM2MEM_DEINTERLACE=m
CONFIG_VIDEO_OV5640=m
Hi lex,
 Thank you for the kernal configs. I did that
After that what should I need to change in  sun8i-h3-nanopi-duo2.dts. AS I am using Nnao pi duo 2 with H3 chipset running under armhf(32bit) Armbian Focal (mainline based kernel 5.10.y)
Thanks in advance
