zaqwsx12 Posted March 10, 2021 Posted March 10, 2021 # apt-get install linux-image-current-meson64 Reading package lists... Done Building dependency tree Reading state information... Done The following NEW packages will be installed: linux-image-current-meson64 0 upgraded, 1 newly installed, 0 to remove and 3 not upgraded. Need to get 0 B/42.5 MB of archives. After this operation, 214 MB of additional disk space will be used. Selecting previously unselected package linux-image-current-meson64. (Reading database ... 85331 files and directories currently installed.) Preparing to unpack .../linux-image-current-meson64_21.02.3_arm64.deb ... Unpacking linux-image-current-meson64 (21.02.3) ... Setting up linux-image-current-meson64 (21.02.3) ... * dkms: running auto installation service for kernel 5.10.21-meson64 [ OK ] update-initramfs: Generating /boot/initrd.img-5.10.21-meson64 update-initramfs: Converting to u-boot format dpkg: error processing package linux-image-current-meson64 (--configure): installed linux-image-current-meson64 package post-installation script subprocess returned error exit status 1 Errors were encountered while processing: linux-image-current-meson64 E: Sub-process /usr/bin/dpkg returned an error code (1)
guidol Posted March 10, 2021 Posted March 10, 2021 where did you get the .deb for the linux-image (5.10.21-meson64)? Why didnt you used armbian-config (System -> Other -> Switch to other Kernel) to change the kernel/image? When you did selfcompile the image via armbian-build-system....did you try to update the packages like u-boot, firmware and so on before the linux-image?
zaqwsx12 Posted March 11, 2021 Author Posted March 11, 2021 Thanks! Via apt-cache search ... apt-get install. If I will use System -> Other -> Switch to other Kernel is it possible to get kernel source also?
SteeMan Posted March 13, 2021 Posted March 13, 2021 You can't install armbian kernels on the balbes150 TV box builds. The file layouts are not compatible. TV boxes are not supported, there are not upgrade paths for the kernels. (Maybe someday, but not today). Also there are no builds that support the amlogic s9xx cpus after 2020-10-14 as the developer who was working on them dropped support for them at that time.
SteeMan Posted March 13, 2021 Posted March 13, 2021 Note that guidol's comments above are for supported armbian boards, the TV box builds do not work the same way as they are a fork of the core armbian.
