pi-hole and transmission-daemon not working After upgrade to 21.02.3 focal
From the logs and from the Armbian perspective, hardware wise, everything looks fine while applications such as Transmission or Pi-hole are not Armbian product. It can be a problem related to Armbian, but it can also be a problem of those applications or they were changing / breaking something. You will need to observe other (standard Linux) logs to get to the bottom of this.
Moving to general section since its not hardware related issue.
Have you pinned it down @Karol ?
I am suffering also a transmission not working at all.
Daemon is running and active yet the connection to the web interface is killed after several seconds of transmission running.
EDIT: Nevermind, I pinpointed the issue on the transmissions's blocklists. Due to upstream went under paywall, the hosted github file was returnint 404. Yes! transmission should not have fail in that case but it did. Other thing that is unrelated that I change the bind address from 0.0.0.0 to the actual one the armbian helios64 device has.
