Hello
I put an image of Armbian on a micro-disk and was able to start with, and was able to start an HC1 with it.
Now I put the disk in an HC2 it does start also fine. But I could not find the IP address on the network.
Not with nmap and not with the utility on the provider modem.
What could be wrong?
Freerk Jongsma
Try different ethernet cables. Or your network interface may be broken. Or many other things.
The best option would be to use a UART to USB adapter, log into the machine and see what is happening.
