Kimberly White Posted March 30, 2021 Posted March 30, 2021 Hello, My mic works on my laptop, but I tried to do the computer, but the mic is not working. I tried a troubleshooter, allowing audio to be recorded. I have tried to reinstall the drivers, but nothing seems to be working. Even after doing a lot of research, the solution was not found. Then after going to the settings, after looking at the setting of the microphone, it came to know that the microphone needs permission to run in the device which was disabled. At the same point, after I have given permission in the settings, the microphone was not working due to not giving it, then the https://mictests.net is checking the mic from the site and see if the mic is working properly.
Igor Posted March 30, 2021 Posted March 30, 2021 16 minutes ago, Kimberly White said: Thanks in Advance. I am not sure anyone knows what you are asking.
