jarbear Posted April 1, 2021 Posted April 1, 2021 Hello, I would like to have some help with the video in Armbian. I have migrated to it and I want to make it the best possible. I hope there is some things I can do to make it run smoother. It is ok with small screen but not with full screen. I have a Tinkerboard S.
Werner Posted April 1, 2021 Posted April 1, 2021 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed.
NicoD Posted April 1, 2021 Posted April 1, 2021 On 4/1/2021 at 3:51 AM, jarbear said: I hope there is some things I can do to make it run smoother. Expand All the info you need is here.
Solution jarbear Posted April 2, 2021 Author Solution Posted April 2, 2021 It's working finally. I guess update or a fresh install did it. This new installed asked me to update my firmware on the board. I said yes. I ran sudo armbian-config Then installed the desktop. That is where it asked to update the firmware. Thanks for your help. Also the below stopped my VLC crashing. Tool>pref>video>output>XVideoOutput worked with 1080p
