Video in VLC and Youtube Jerky
Go to solution Solved by jarbear,
Hello, I would like to have some help with the video in Armbian. I have migrated to it and I want to make it the best possible.
I hope there is some things I can do to make it run smoother.  It is ok with small screen but not with full screen.
I have a Tinkerboard S.
All the info you need is here.
  • Solution
It's working finally.  I guess update or a fresh install did it.
This new installed asked me to update my firmware on the board. I said yes.
I ran    sudo armbian-config   Then installed the desktop. That is where it asked to update the firmware.
Thanks for your help.
Also the below stopped my VLC crashing.
       Tool>pref>video>output>XVideoOutput  worked with 1080p
