I've been using a M4V2 since its release mostly as a NAS (disks over UBS 3.0). I also have it booting from a Samsung NVMe with the official NVMe hat. My setup works flawlessly however I was thinking about ways to add more storage with reasonable performance/price so I thought, what if I managed to add a standard PCIe x1 port from the pins on the board and use standard hardware with it.
The idea was to add a cheap PCI switch + NVMe adapter (to boot from) and a PCI to SATA controller such as the following:
1) PCI Switch: https://www.ebay.com/itm/PCI-Express-1X-to-4X-PCI-E-4-Ports-Switch-Multiplier-Expansion-Riser-Card-New/293564888755
2) PCI > NVMe Adapter: https://www.ebay.com/itm/NVMe-PCIe-x4-x2-M-2-NGFF-SSD-to-PCIe-x1-converter-card-adapter-PCIe-x1-to-M-00e/143915406968
3) PCI > Sata: https://www.ebay.com/itm/PCI-Express-1x-To-4-Port-Sata-3-0-6G-Expansion-Controller-Card-Marvell-88SE9215/233219670613
Did anyone had success with a setup like this? It looks like there isn't any adapter for the board to add a standard PCI interface, however I could probably solder something. Software wise would it work? I believe the Marvell 88SE9215 is supported by Armbian from what I read on espressobin threads. Any tips?
Thank you!
So, after some research I decided to tune down a bit my project. I decided to ditch the NVMe as boot device because I believe a regular SATA SSD will be enough for my use case.
My goal was:
  • Boot from a SATA SSD;
  • Have around 10 SATA ports for 3.5" hard drives.
I ended up buying the following:
I chose this PCIe to SATA because I already had the NVMe adapter for my M4v2 and it uses the JMB585 chip is used by other SBC manufacturers in hats thus compatible with Armbian. This chip also features "Cascaded mode: support up to x75 SATA devices with JMB575" that allows me to pair it with the other board (based on JMB575) to have more SATA ports.
Here, my testing setup with both boards. Everything powered up by a standard ATX power supply.
Now I did run some benchmarks on the disks.
System/Kernel: Armbian 21.05.1 Buster with Linux 5.10.35-rockchip64
Hard Drives: Seagate Barracuda 7200rpm 1TB. ST31000524AS (hard drives from 06/2012)
https://www.seagate.com/docs/pdf/en-GB/datasheet/disc/barracuda-7200-12-ds1668-6-1101gb.pdf
Scenario: Amrbian installed to the SATA hard drive using the armbian-config helper tool. BTRFS filesystem used.
Benchmark Command: dd if=/dev/zero of=test bs=100MB count=100 conv=fdatasync
Notes: I enabled the PCIe x2 overlay.
- HDD Attached to the SATA to M2 Board (HDD > SATA to M2 > NanoPI M4v2)
10000000000 bytes (10 GB, 9.3 GiB) copied, 27.248 s, 367 MB/s
10000000000 bytes (10 GB, 9.3 GiB) copied, 24.6339 s, 406 MB/s
- HDD Attached to the SATA Expansion Board (HDD > SATA Expansion Board > SATA to M2 > NanoPI M4v2)
10000000000 bytes (10 GB, 9.3 GiB) copied, 25.1813 s, 397 MB/s
Conclusion: I run the test multiple times I was getting around 350-400MB/s regardless of having the disk connected to the SATA Expansion board or to the SATA to M2 board directly.
I run the same test by while booting from an eMMC card. The performance is the same if the the disks are mounted with:
mount -t btrfs -o defaults,noatime,commit=600,compress=lzo,x-gvfs-hide /dev/sda1 /mnt/HDD
Interestingly the performance of ext4 was very bad (tested both as boot device and simple mount):
10000000000 bytes (10 GB, 9.3 GiB) copied, 79.0775 s, 126 MB/s
So it seems I'm able to build a low power and high capacity NAS with this setup. Please note that I'm not after the best performance and parallel wiring to disks. I also seem to be able to write simultaneously to two disks without a performance drop and that's enough for my use case.
Does anyone has a similar setup?
Looks like a neat setup. I was not aware that M.2 to 5x SATA device existed.
But before you reinvent the wheel, have you considered that you basically made a Helios64 without the nice enclosure?
vor 15 Stunden schrieb TCB13:
Well - not similar from assembly, but similar in use case
I have Sata Tower from radxa. I have 4 ssd attached, but I didn't run any benchmarks. I love the small form factor, and its going to be useful after I ported driver from radxa.
Yes I did, however the limitation on the number of bays x price didn't make me very happy. My current setup with more SATA expansion boards can go up to 20 bays without cascading and 75 with cascading.
And.. I already had a M4v2 with a the NVMe adapter so... No more costs there.
Are you going to use it with the NanoPI?
vor 7 Stunden schrieb TCB13:
No - but look:  from what I read, your nanopi is a big size nanopi and is a rk3399 device.
I have a rockpi - normal size - and a rk3399 device too. So I think, both have more in common, than they differ.
I guess, we build the same image but may have different dtb and uboot.
Some pi software (like pigpio) does not work on my rockpi - and I guess, same is true for yours.
I try many os images, to find out, what the hardware supports, and what is software limitations.
For example - I build LE images on my own, but failed to build armbian. Images supported by radxa are pretty old. Twister is the most recent one, that seems to fulfill my needs. But my driver only works on LE. With armbian the button does not work and with twister the pwm does not work. So I have to start mixing my own flavour.
Indeed they've more in common than they differ.
