wurmfood Posted April 9, 2021 Posted April 9, 2021 While I like having the helios-ups.timer in case of power failure, I don't like that my logs get three lines written to them every 20 seconds. Apr 09 07:43:26 helios64 systemd[1]: Starting Helios64 UPS Action... Apr 09 07:43:26 helios64 systemd[1]: helios64-ups.service: Succeeded. Apr 09 07:43:26 helios64 systemd[1]: Finished Helios64 UPS Action. Does anyone know if there is a way to keep the timer on but not fill the logs this way? Everything I've found about silencing systemd messages is about the output of the command, not the systemd activity itself.
SIGSEGV Posted April 9, 2021 Posted April 9, 2021 @wurmfood On my system the helios64-ups.timer is disabled by default. Is this a timer that has to be manually enabled ?? I thought that the Helios would check if it had the battery and activate this automagically. It might be better to have a daemon in the background that checked the battery value every 20 seconds and only printed out output when there was a change.
wurmfood Posted April 9, 2021 Author Posted April 9, 2021 @SIGSEGV It is disabled by default, but since I had some time the last few days I've been digging into things and came across this. There's a corresponding service, but all it does is check to see the state of the battery and then exit. If something else is monitoring the battery, I don't know what it is. The service could be rewritten as a script that has an loop that checks the state of the battery every 20 seconds and then sleeps.
clostro Posted April 10, 2021 Posted April 10, 2021 (edited) Can maybe disable the service and put the script it is running, /usr/bin/helios64-ups.sh to root cron for every minute. You could make it run every 20 seconds by adding a while loop that goes 3 turns and sleeps 20 seconds in each turn. However, I don't see where this script checks to see if mains power is active. What I see is a script that will continually shutdown the device if the battery voltage is low even when the mains returns. Is that function provided by the service timer, as in the timer stops when there is mains? If so absolutely do NOT cron helios64-ups.sh as it is. Because you won't be able to boot the device until the battery charges over 7 volts. #!/bin/bash #7.0V 916 Recommended threshold to force shutdown system TH=916 val=$(cat '/sys/bus/iio/devices/iio:device0/in_voltage2_raw') sca=$(cat '/sys/bus/iio/devices/iio:device0/in_voltage_scale') adc=$(echo "$val * $sca / 1" | bc) if [ "$adc" -le $TH ]; then /usr/sbin/poweroff fi There is a whole device with lots of data in there, is there any documentation on iio:device0? edit- apparently there is https://wiki.kobol.io/helios64/ups/#ups-status-under-linux Edited April 10, 2021 by clostro
wurmfood Posted April 10, 2021 Author Posted April 10, 2021 (edited) While something that sleeps for 20 seconds might be better, I've set up the following script in cron to go off every minute. <removed> My crontab looks like: <removed> I've tested this and it seems to work. The pipe to systemd-cat lets this log to the system journal at a set warn level. -- Edit: Removed extra stuff here to clean things up a little. This didn't work the way I wanted. Edited April 10, 2021 by wurmfood Didn't actually solve the problem.
wurmfood Posted April 10, 2021 Author Posted April 10, 2021 Sigh. Except that doesn't solve the problem. Now it's just cron filling up the log. New solution, using the sleep option. Modified helio64-ups.service: [Unit] Description=Helios64 UPS Action [Install] WantedBy=multi-user.target [Service] #Type=oneshot #ExecStart=/usr/bin/helios64-ups.sh Type=simple ExecStart=/usr/local/sbin/powermon.sh Modified powermon.sh: #!/bin/bash #7.0V 916 Recommended threshold to force shutdown system TH=916 # Values can be info, warning, emerg warnlevel="emerg" while [ : ] do main_power=$(cat '/sys/class/power_supply/gpio-charger/online') # Only use for testing: # main_power=0 if [ "$main_power" == 0 ]; then val=$(cat '/sys/bus/iio/devices/iio:device0/in_voltage2_raw') sca=$(cat '/sys/bus/iio/devices/iio:device0/in_voltage_scale') # The division is required to make the test later work. adc=$(echo "$val * $sca /1" | bc) echo "Main power lost. Current charge: $adc" | systemd-cat -p $warnlevel echo "Shutdown at $TH" | systemd-cat -p $warnlevel # Uncomment for testing # echo "Current values:" # echo -e "\tMain Power = $main_power" # echo -e "\tRaw Voltage = $val" # echo -e "\tVoltage Scale = $sca" # echo -e "\tVoltage = $adc" if [ "$adc" -le $TH ]; then echo "Critical power level reached. Powering off." | systemd-cat -p $warnlevel /usr/sbin/poweroff fi fi sleep 20 done 3
aprayoga Posted April 12, 2021 Posted April 12, 2021 On 4/10/2021 at 1:44 PM, clostro said: However, I don't see where this script checks to see if mains power is active. What I see is a script that will continually shutdown the device if the battery voltage is low even when the mains returns. Is that function provided by the service timer, as in the timer stops when there is mains? @SIGSEGV @clostro the service is triggered by udev rules. @wurmfood, I didn't realize the timer fill the the log every 20s. Initial idea was one time timer, poweroff after 10m of power loss event. Then it was improved to add polling of the battery level and poweroff when threshold reached. Your script look good, we are considering to adapt it to official release. Thank you 3
SIGSEGV Posted April 13, 2021 Posted April 13, 2021 @wurmfood The script looks goods. I like the check for main power before the battery level verification, it solves the use case @clostro mentioned. @aprayoga Looking forward to the new release
