Hi All,
My helios64 died the other day - well failing to boot. It had been solid for quite some time, then I might have made the mistake of updating it....
This is from putty on booting:
DDR Version 1.24 20191016
In
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 416MHz 0,1
Channel 0: LPDDR4,416MHz
Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB
Channel 1: LPDDR4,416MHz
256B stride
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0, cs 0, advanced training done
channel 1, cs 0, advanced training done
change freq to 856MHz 1,0
ch 0 ddrconfig = 0x101, ddrsize = 0x40
ch 1 ddrconfig = 0x101, ddrsize = 0x40
pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD
ddr_set_rate to 328MHZ
ddr_set_rate to 666MHZ
ddr_set_rate to 928MHZ
ddr_set_rate to 416MHZ, ctl_index 0
ddr_set_rate to 856MHZ, ctl_index 1
support 416 856 328 666 928 MHz, current 856MHz
OUT
Boot1: 2019-03-14, version: 1.19
CPUId = 0x0
ChipType = 0x10, 254
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 67777
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT 0x3380ec0 signature is wrong
recovery gpt...
recovery gpt fail!
LoadTrust Addr:0x4000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xdd6b0
RunBL31 0x40000
NOTICE:  BL31: v1.3(debug):42583b6
NOTICE:  BL31: Built : 07:55:13, Oct 15 2019
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    plat_rockchip_pmu_init(1190): pd status 3e
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2020.07-armbian (Nov 27 2020 - 21:56:51 +0100)
SoC: Rockchip rk3399
Reset cause: POR
DRAM:  3.9 GiB
PMIC:  RK808
SF: Detected w25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
MMC:   mmc@fe320000: 1, sdhci@fe330000: 0
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Model: Helios64
Revision: 1.2 - 4GB non ECC
Net:   eth0: ethernet@fe300000
scanning bus for devices...
Hit any key to stop autoboot:  0
Card did not respond to voltage select!
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
3185 bytes read in 19 ms (163.1 KiB/s)
## Executing script at 00500000
Boot script loaded from mmc 0
166 bytes read in 13 ms (11.7 KiB/s)
15756730 bytes read in 1512 ms (9.9 MiB/s)
81913 bytes read in 41 ms (1.9 MiB/s)
2698 bytes read in 34 ms (77.1 KiB/s)
Applying kernel provided DT fixup script (rockchip-fixup.scr)
## Executing script at 09000000
Bad Linux ARM64 Image magic!
SCRIPT FAILED: continuing...
starting USB...
Bus usb@fe380000: USB EHCI 1.00
Bus dwc3: usb maximum-speed not found
Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
scanning bus usb@fe380000 for devices... 1 USB Device(s) found
scanning bus dwc3 for devices... cannot reset port 4!?
4 USB Device(s) found
Device 0: unknown device
Speed: 1000, full duplex
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
DHCP client bound to address 192.168.1.232 (1026 ms)
*** ERROR: `serverip' not set
Cannot autoload with TFTPGET
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/01-64-62-66-d0-04-8c
Retrieving file: pxelinux.cfg/C0A801E8
Retrieving file: pxelinux.cfg/default-arm-rk3399-helios64
Config file not found
BOOTP broadcast 1
DHCP client bound to address 192.168.1.232 (23 ms)
BOOTP broadcast 1
DHCP client bound to address 192.168.1.232 (18 ms)
Any chance of recovery or start again? Any help would be much appreciated.
Cheers
Scott
It looks like you have been booting from the eMMC, right?
recovery gpt...
recovery gpt fail!
I think you're going to need to boot off an SD card and try to fix the GPT. This may help you with doing that.
Thanks for your help - I played around with that for a while, but ended up just reinstalling. It was pretty annoying actually, but fast.
How does something like this go wrong in a system that is just sitting there?? Anyhow back on deck.
@scottf007, it could be filesystem corruption or something wrong during update and kernel symlink was not updated to correct file. If you have access to Linux PC, you can use recovery button to enter UMS mode and do fsck or fixed the symlink.
@wurmfood, it is not a problem. Rockchip loader expect the storage to be partitioned and formatted in certain way but it also can load using raw offset. Armbian does not use GPT, so the loader will print such errors.
i have been struggling with a very similar issue for the past few days. I did an update roughly a week ago and did not reboot afterwards. The Helios64 continued running for some time, until some days later my files stopped being available. Then i checked what is going on and came to very similar startup logs:
In
channel 0
CS = 0
MR0=0x18
MR4=0x2
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
256B stride
channel 0
CS = 0
MR0=0x18
MR4=0x2
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
OUT
CPUId = 0x0
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 67804
SecureMode = 0
recovery gpt...
recovery gpt fail!
No find bl30.bin
No find bl32.bin
RunBL31 0x40000
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE init        ialization. SMC`s destined for OPTEE will return SMC_UNK
INFO:    SPSR = 0x3c9
U-Boot 2020.07-armbian (Dec 15 2020 - 08:45:45 +0100)
Reset cause: POR
DRAM:  3.9 GiB
PMIC:  RK808
In:    serial
Out:   serial
Err:   serial
Model: Helios64
Scanning mmc 0:1...
3185 bytes read in 18 ms (171.9 KiB/s)
195 bytes read in 15 ms (12.7 KiB/s)
15760333 bytes read in 1516 ms (9.9 MiB/s)
81913 bytes read in 44 ms (1.8 MiB/s)
2698 bytes read in 36 ms (72.3 KiB/s)
starting USB...
USB XHCI 1.10
ethernet@fe300000 Waiting for PHY auto negotiation to complete......... TIMEOUT !
Could not initialize PHY ethernet@fe300000
Retrieving file: pxelinux.cfg/01-64-62-66-d0-06-ec
Retrieving file: pxelinux.cfg/00000000
I used UMS mode to examine the situation, but nothing seemed to be wrong. I did fsck /dev/sdb1 -f and looks fine. When i did fsck /dev/sdb it told me that the device had bad magic number in super-block  and that it found a dos partition table in /dev/sdb i tried the same fsck on /dev/sdb but with the superblocks that i found via mke2fs -n /dev/sdb and it did not show anything else.
i am running out of ideas now unfortunately.... and i would really appreciate the support, if you have any... i am trying to avoid starting from scratch...
So,
after struggling for quite some time i finally was able to get things back to normal without losing data (at least i think so).
The problem was apparently a broken kernel upgrade to version 5.10.43 . There were broken symlinks and not only.
In the end what solved it was the following:
I first put the latest stable armbian on an sd card and booted with it. then i actually upgraded that image to the latest kernel and copied all version related files from /boot of the sd card to the /boot of the mmc. I also copied the 5.10.45 modules from /lib/module from the sd card to the mmc.
Fixed all symlinks in /boot and then the device finally booted. After that it was all about reinstalling kernel headers, cleaning up wrong zfs versions and packages and rebooting frequently enough in between :)
Hope that i didnt break too much and that this helps someone.
Well an identical error happened again............
I am getting really frustrated with this machine - I am not touching it and it just stops working. I have had a helios4 stable for 2-3 years (or however long we have had them) and never had a hiccup.
This machine randomly reboots, the software / hardware does not seem stable. Am I doing something wrong?
You shoud contact the Kobol team. I wonder what they are doing these days ...
