niccodemi Posted August 8, 2016 Posted August 8, 2016 Hi, I've been using Armbian with Banana Pi M2 for a while and I am very satisfied with performance. Recently I noticed that Teamviewer has been developed for ARM systems, officially only for Raspbian but it seems few people had success running it on Orange Pi too. I followed installation instructions and succeeded however once I connect to it I see only black screen. Did anyone else manage to get it working? Below is link to original thread: https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=144608
shahidali55 Posted August 8, 2016 Posted August 8, 2016 Install TeamViewer wget http://download.teamviewer.com/download/linux/version_11x/teamviewer-host_armhf.deb dpkg -i teamviewer-host_armhf.deb Install dependencies: apt install -f Get ID: cat /etc/teamviewer/global.conf | grep ClientID Finally, try logging in from another desktop using the TeamViewer desktop clientAdd a permanent password: teamviewer passwd my_password 1
niccodemi Posted August 10, 2016 Author Posted August 10, 2016 Thanks, after following your instructions I managed to log in from another computer. I can see armbian desktop but mouse and keyboard controls don't function.
shahidali55 Posted August 11, 2016 Posted August 11, 2016 Make sure to uncheck "send key combinations" from "Action" menu and try again
niccodemi Posted August 12, 2016 Author Posted August 12, 2016 I tried, it was unchecked. Another thing I noticed is that Teamviewer seems to connect to different desktop than ultravnc. And within Ultravnc desktop Teamviewer window pops up on boot but the content remains empty, only frame is visible (screenshot attached).
SHA_ndy Posted September 29, 2016 Posted September 29, 2016 Does not work on OrangePi PC jessie desktop. Installation works fine, but teamviewer doesn't start...global.conf seems weird to me...
HarfTarf Posted September 29, 2016 Posted September 29, 2016 Not sure if this will help, but I use x2go with great stability from all over the US, I like it better than teamviewer.If you need to tunnel through a firewall, then you can use ngrok or pagekite, or just open a port. Personally I use tinc to vpn into home rather than opening ports.
SHA_ndy Posted October 1, 2016 Posted October 1, 2016 I stumbled upon another solution for me: LogMeIn Hamachi. It creates a VPN connection and I can remotely access my OrangePi using IP. The hamachi client for armhf works very well, I used a tutorial from raspberry forums and found useful tips in a thread in orangepi.org forums. So I can remotely wake my PC at home with my OrangePi (wake on lan) and then use Teamviewer Android client with my PC (Teamviewer ist most useful for me).
carlos_rog Posted October 7, 2016 Posted October 7, 2016 I'd like install teamviewer, but can't too I installed tightvnc for while
John34 Posted December 9, 2018 Posted December 9, 2018 On 8/8/2016 at 3:55 PM, shahidali55 said: Install TeamViewer wget http://download.teamviewer.com/download/linux/version_11x/teamviewer-host_armhf.deb dpkg -i teamviewer-host_armhf.deb Install dependencies: apt install -f Get ID: cat /etc/teamviewer/global.conf | grep ClientID Finally, try logging in from another desktop using the TeamViewer desktop client Add a permanent password: teamviewer passwd my_password Expand Hello What i put in " ClientID " the ID from the armbian teamvieweer or the ID of my laptop xubuntu ( where i want to use to connect to my armbian ) ?
John34 Posted December 9, 2018 Posted December 9, 2018 I'm on Armbian ( debian 9 Stretch dev ) in Armbian ( Ubuntu Bionic 18.04.1 ) Teamviewer seems to doesn't work. On debian Teamviewer seems to works but i can't see my armbian under teamviewer where as all seems to be good, so i think i've missed something like your " ClientID ".
John34 Posted December 9, 2018 Posted December 9, 2018 ok i understood cat /etc/teamviewer/global.conf | grep ClientID = to see what is the clientID on Armbian (debian 9 for me) but i see already my ID because Teamviewer starts normally and it shows the ID to connect, but when i connect from my laptop to my armbian nothing happens...
John34 Posted December 9, 2018 Posted December 9, 2018 déc. 09 20:37:04 gon systemd[1]: Starting TeamViewer remote control daemon... déc. 09 20:37:04 gon systemd[1]: teamviewerd.service: PID file /var/run/teamviewerd.pid not readable (yet?) after start: No such file or directory déc. 09 20:37:04 gon systemd[1]: Started TeamViewer remote control daemon.
John34 Posted December 9, 2018 Posted December 9, 2018 Well teamviewer is active in Armbian but impossible to connect from another devices... ( teamviewer-host ) <- ( for armbian ) and i try to connect from ( teamviewer-amd64 ) <- ( my laptop xubuntu ) nothing happens just written " connecting " but the armbian desktop doesn't appears..... Ouiiiinnnnnnnnnnnnnnnn :'( :'( :'( i'm going to try another remote control...
Tido Posted December 9, 2018 Posted December 9, 2018 On 12/9/2018 at 7:58 PM, John34 said: i'm going to try another remote control.. Expand If you want to use something like TeamViewer try the searchbox (right hand corner) and search for: x2go
John34 Posted December 9, 2018 Posted December 9, 2018 ahhhh x2go ok i'm going to look now thanks a lot i'm on Banana Pi M3 i hope it will works
John34 Posted March 16, 2019 Posted March 16, 2019 Worked on the last Ubuntu Bionic but the wired is still broken where as on debian wired works perfectly, but x2go don't work actually on ARMBIAN 5.75 stable Debian GNU/Linux 9 (stretch) 4.19.20-sunxi i'm going to test again with teamviewer to see if it's work
Nelson R Posted August 29, 2019 Posted August 29, 2019 I use DWService, they uses a browser, installs via sh script....
Enric Posted January 9, 2021 Posted January 9, 2021 Hi Nelson. I've tried the DWService. The file and console access works good, but not the Screen one. Which Armbian version are were you using? I am really disappointed since no remote desktop over WAN has worked for me (although on LAN works perfect). I tried anydesk, teamviewer, RealVNC with no luck. A real bummer for my little projectes. Any ideas on how to solve that? Thanks!
NicoD Posted January 9, 2021 Posted January 9, 2021 @EnricI've never tried it, but I think it should work with x11vnc and an ssh tunnel. https://wiki.archlinux.org/index.php/X11vnc#SSH_Tunnel
