Nabeel Posted April 21, 2021 Posted April 21, 2021 Hi All, Can anyone help in setting up HifiBerry Digi + with Opi PC Plus with i2s0.The HIfi Berry is based on wm8804 codec and it acts as a master while i2s on Opi acts as a slave I havent any examples of using i2s in slave mode on H3 boards so just need some help. Kernel is 5.10.19 built with Armbian Build system. This is the driver I am using https://github.com/raspberrypi/linux/blob/rpi-5.10.y/sound/soc/bcm/rpi-wm8804-soundcard.c on my PC PLUS This is my dts: /dts-v1/; /plugin/; / { compatible = "allwinner,sun8i-h3"; fragment@0 { target = <&i2c0>; __overlay__ { status = "okay"; wm8804: wm8804@3b { #sound-dai-cells = <0>; compatible = "wlf,wm8804"; reg = <0x3b>; status = "okay"; }; }; }; fragment@1 { target = <&i2s0>; __overlay__ { status = "okay"; pinctrl-0 = <&i2s0_pins>; sound-dai = <&wm8804>; pinctrl-names = "default"; }; }; fragment@2 { target-path = "/"; __overlay__ { sound_i2s { compatible = "hifiberry,hifiberry-digi"; i2s-controller = <&i2s0>; hifiberry,format = "i2s"; hifiberry,bitclock-master = <&sndcodec>; hifiberry,frame-master = <&sndcodec>; #hifiberry,mclk-fs = <256>; #hifiberry,frame-inversion; status = "okay"; hifiberry,cpu { sound-dai = <&i2s0>; dai-tdm-slot-num = <0x2>; dai-tdm-slot-width = <0x20>; }; sndcodec: hifiberry,codec { sound-dai = <&wm8804>; system-clock-frequency = <11289600>; }; Many Thanks for your help.
Werner Posted April 21, 2021 Posted April 21, 2021 Your issue report is not a valid bug report per the Armbian bug reporting instructions (https://www.armbian.com/bugs). With limited resources the Armbian project is only able to spend time on issues where all the requested information has been provided and for only the boards/images/software that are supported. Your report is invalid for one or more of the following reasons (non-exhaustive list): it is for an unsupported board or image (CSC/EOS/WIP/edge) it is for software that is not supported (such as userspace modules installed on top of the core operating system) it has been logged in the wrong forum (for example requests for help that are not actual bug reports) it lacks requested data (armbianmonitor output) it could have been easily solved by a quick search and/or reading documentation Please review what you have submitted and the bug logging instructions (https://www.armbian.com/bugs) and either add the required information or open a new topic in the correct forum (such as Common issues / peer to peer technical support or General chit chat)
