Geekati Posted May 7, 2021 Posted May 7, 2021 Hello In advance I appreciate the support you can give me. I have 2 4gb / 32gb version computers, which I would like to give to some relatives who need it. Seeing on the net I saw that the version I needed for this equipment is: armbian-h6-tvbox-5.7-rc6.7z, which never started in the tv box, I want to assume that it could change some type of component, possibly it is a new revision, however if I start with the version: aw h6 tv buster current 5.1.27 xfce desktop, I think it is the last one, The main problem is that it does not turn off well, it begins to close all processes but in the end it always stays full on the shutdown logo, but if it can be restarted, the only way to turn it off is to disconnect it from the power, either The wifi works and it only recognizes 2gb of ram from the 4gb. The truth is I don't have much knowledge, but if you help me I can do it, if you help me I can compensate you, I would really appreciate your help.
SteeMan Posted May 8, 2021 Posted May 8, 2021 @Geekati Please first read: https://forum.armbian.com/topic/16976-status-of-armbian-on-tv-boxes-please-read-first Then read the following thread which should be relevant for your needs: https://forum.armbian.com/topic/16859-allwinner-h6/
